git://people.freedesktop.org/~danvet/drm-intel into drm-fixes
Daniel writes:
"Just a few smaller things:
- Fix up a pipe vs. plane confusion from a refactoring, fixes a regression
from 3.1 (Anhua Xu).
- Fix ivb sprite pixel formats (Vijay).
- Fixup ppgtt pde placement for machines where the Bios artifically limits
the availbale gtt space in the name of ... product differentiation
(Chris). This fixes an oops.
- Yet another no_lvds quirk entry."
* 'drm-intel-fixes' of git://people.freedesktop.org/~danvet/drm-intel:
i915: Quirk no_lvds on Gigabyte GA-D525TUD ITX motherboard
drm/i915: Use the correct size of the GTT for placing the per-process entries
drm/i915: fix color order for BGR formats on IVB
drm/i915: fix wrong order of parameters in port checking functions
git://anongit.freedesktop.org/git/nouveau/linux-2.6 into drm-fixes
Ben says its just a single fix to avoid the wrong pcopy units being used.
* 'drm-nouveau-fixes' of git://anongit.freedesktop.org/git/nouveau/linux-2.6:
drm/nvc0/copy: check PUNITS to determine which copy engines are disabled
On some Fermi chipsets (NVCE particularly) PCOPY1 doesn't exist. And if
what I've seen on Kepler is true of Fermi too, chipsets of the same type
can have different PCOPY units available.
This should fix a v3.5 regression reported by a number of people effecting
suspend/resume on NVC8/NVCE chipsets.
Cc: stable@vger.kernel.org [3.5]
Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
This board is incorrectly detected as having an LVDS connector,
resulting in the VGA output (the only available output on the board)
showing the console only in the top-left 1024x768 pixels, and an extra
LVDS connector appearing in X.
It's a desktop Mini-ITX board using an Atom D525 CPU with an NM10
chipset.
I've had this board for about a year, but this is the first time I
noticed the issue because I've been running it headless for most of its
life.
Signed-off-by: Calvin Walton <calvin.walton@kepstin.ca>
The current layout is to place the per-process tables at the end of the
GTT. However, this is currently using a hardcoded maximum size for the GTT
and not taking in account limitations imposed by the BIOS. Use the value
for the total number of entries allocated in the table as provided by
the configuration registers.
Reported-by: Matthew Garrett <mjg@redhat.com>
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
Cc: Daniel Vetter <daniel.vetter@ffwll.ch>
Cc: Ben Widawsky <ben@bwidawsk.net>
Cc: Matthew Garret <mjg@redhat.com>
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Signed-off-by: Jakob Bornecrantz <jakob@vmware.com>
This is already fixed for ILK and SNB in the below commit but somehow
IVB is missed.
commit ab2f9df10dd955f1fc0a8650e377588c98f1c029
Author: Jesse Barnes <jbarnes@virtuousgeek.org>
Date: Mon Feb 27 12:40:10 2012 -0800
drm/i915: fix color order for BGR formats on SNB
Had the wrong bits and field definitions.
Signed-off-by: Vijay Purushothaman <vijay.a.purushothaman@intel.com>
Reviewed-by: Antti Koskipää <antti.koskipaa@linux.intel.com>
Wrong order of parameters passed-in when calling hdmi/adpa
/lvds_pipe_enabled(), 2nd and 3rd parameters are reversed.
This bug was indroduced by
commit 1519b9956eb4b4180fa3f47c73341463cdcfaa37
Author: Keith Packard <keithp@keithp.com>
Date: Sat Aug 6 10:35:34 2011 -0700
drm/i915: Fix PCH port pipe select in CPT disable paths
The reachable tag for this commit is v3.1-rc1-3-g1519b99
Signed-off-by: Anhua Xu <anhua.xu@intel.com>
Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk>
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=44876
Tested-by: Daniel Schroeder <sec@dschroeder.info>
Pull drm fixes from Dave Airlie:
"Intel: edid fixes, power consumption fix, s/r fix, haswell fix
Radeon: BIOS loading fixes for UEFI and Thunderbolt machines, better
MSAA validation, lockup timeout fixes, modesetting fixes
One udl dpms fix, one vmwgfx fix, a couple of trivial core changes.
There is an export added to ACPI as part of the radeon bios fixes.
I've also included the fbcon flashing cursor vs deinit race fix, that
seems the simplest place to start"
Trivial conflict in drivers/video/console/fbcon.c due to me having
already applied the fbcon flashing cursor vs deinit race fix, and Dave
had added a comment in there too.
* 'drm-fixes' of git://people.freedesktop.org/~airlied/linux: (22 commits)
fbcon: fix race condition between console lock and cursor timer (v1.1)
drm: Add missing static storage class specifiers in drm_proc.c file
drm/udl: dpms off the crtc when disabled.
drm: Remove two unused fields from struct drm_display_mode
drm: stop vmgfx driver explosion
drm/radeon/ss: use num_crtc rather than hardcoded 6
Revert "drm/radeon: fix bo creation retry path"
drm/i915: use hsw rps tuning values everywhere on gen6+
drm/radeon: split ATRM support out from the ATPX handler (v3)
drm/radeon: convert radeon vfct code to use acpi_get_table_with_size
ACPI: export symbol acpi_get_table_with_size
drm/radeon: implement ACPI VFCT vbios fetch (v3)
drm/radeon/kms: extend the Fujitsu D3003-S2 board connector quirk to cover later silicon stepping
drm/radeon: fix checking of MSAA renderbuffers on r600-r700
drm/radeon: allow CMASK and FMASK in the CS checker on r600-r700
drm/radeon: init lockup timeout on ring init
drm/radeon: avoid turning off spread spectrum for used pll
drm/i915: fall back to bit-banging if GMBUS fails in CRT EDID reads
drm/i915: extract connector update from intel_ddc_get_modes() for reuse
drm/i915: fix hsw uncached pte
Fixes the following sparse warning:
drivers/gpu/drm/drm_proc.c:92:5:
warning: symbol 'drm_proc_create_files' was not declared. Should it be static?
drivers/gpu/drm/drm_proc.c:175:5:
warning: symbol 'drm_proc_remove_files' was not declared. Should it be static?
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
This turns off the crtc when its been disabled,
fixes it not turning off properly the whole time.
Reviewed-by: Alex Deucher <alexander.deucher@amd.com>
Signed-off-by: Damien Lespiau <damien.lespiau@intel.com>
Reviewed-by: Jani Nikula <jani.nikula@intel.com>
If you do a page flip with no flags set then event is NULL. If event is
NULL then the vmw_gfx driver likes to go digging into NULL and extracts
NULL->base.file_priv.
On a modern kernel with NULL mapping protection it's just another oops,
without it there are some "intriguing" possibilities.
What it should do is an open question but that for the driver owners to
sort out.
Signed-off-by: Alan Cox <alan@linux.intel.com>
Reviewed-by: Jakob Bornecrantz <jakob@vmware.com>
Daniel writes:
" Nothing too major:
- A few fixes around the edid handling from Jani, also fixing a regression
in 3.5 due to us using gmbus by default.
- Fixup hsw uncached pte flags.
- Fix suspend/resume crash when using hw contexts, from Ben.
- Try to tune gpu turbo a bit better, seems to help with some oddball
power regressions."
drm/i915/contexts: fix list corruption
drm/i915: fix EDID memory leak in SDVO
When checking if a pll is in use.
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
This reverts commit d1c7871ddb1f588b8eb35affd9ee1a3d5e11cd0c.
ttm_bo_init() destroys the BO on failure. So this patch makes
the retry path work with freed memory. This ends up causing
kernel panics when this path is hit.
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull more USB patches from Greg Kroah-Hartman:
"Here are 10 more USB patches for 3.6-rc3. They all fix reported
problems (build problems for one of them, and easily repeatable oopses
for the others.)
Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>"
* tag 'usb-3.6-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb:
gpu/mfd/usb: Fix USB randconfig problems
USB: CDC ACM: Fix NULL pointer dereference
USB: emi62: remove __devinit* from the struct usb_device_id table
USB: winbond: remove __devinit* from the struct usb_device_id table
USB: vt6656: remove __devinit* from the struct usb_device_id table
USB: rtl8187: remove __devinit* from the struct usb_device_id table
USB: p54usb: remove __devinit* from the struct usb_device_id table
USB: spca506: remove __devinit* from the struct usb_device_id table
USB: jl2005bcd: remove __devinit* from the struct usb_device_id table
USB: smsusb: remove __devinit* from the struct usb_device_id table
Fix config warning:
warning: ( ... && DRM_USB) selects USB which has unmet direct dependencies
(USB_SUPPORT && USB_ARCH_HAS_HCD)
and build error:
ERROR: "usb_speed_string" [drivers/usb/core/usbcore.ko] undefined!
by adding the missing dependency on USB_ARCH_HAS_HCD to DRM_UDL and DRM_USB.
This exposes:
drivers/video/Kconfig:36:error: recursive dependency detected!
drivers/video/Kconfig:36: symbol FB is selected by DRM_KMS_HELPER
drivers/gpu/drm/Kconfig:28: symbol DRM_KMS_HELPER is selected by DRM_UDL
drivers/gpu/drm/udl/Kconfig:1: symbol DRM_UDL depends on USB_ARCH_HAS_HCD
drivers/usb/Kconfig:78: symbol USB_ARCH_HAS_HCD depends on USB_ARCH_HAS_OHCI
drivers/usb/Kconfig:16: symbol USB_ARCH_HAS_OHCI depends on I2C
drivers/i2c/Kconfig:5: symbol I2C is selected by FB_DDC
drivers/video/Kconfig:86: symbol FB_DDC is selected by FB_CYBER2000_DDC
drivers/video/Kconfig:385: symbol FB_CYBER2000_DDC depends on FB_CYBER2000
drivers/video/Kconfig:373: symbol FB_CYBER2000 depends on FB
which is due to drivers/usb/Kconfig:
config USB_ARCH_HAS_OHCI
default y if ARCH_PNX4008 && I2C
Fix by dropping I2C from the above dependency; logic is that this is not a
platform dependency but a configuration dependency: the _architecture_ still
supports USB even is I2C is not selected.
This exposes:
drivers/usb/Kconfig:17: symbol USB_ARCH_HAS_OHCI depends on MFD_TC6393XB
drivers/mfd/Kconfig:396: symbol MFD_TC6393XB depends on GPIOLIB
drivers/gpio/Kconfig:35: symbol GPIOLIB is selected by FB_VIA
drivers/video/Kconfig:1560: symbol FB_VIA depends on FB
which can be fixed by having MFD_TC6393XB select GPIOLIB instead of depending on
it.
James Bottomley reported [1] a massive power regression, due to the
enabling of semaphores by default in 3.5. A workaround for him is to
again disable semaphores. And indeed, his system has a very hard time
to enter rc6 with semaphores enabled.
Ben Widawsky run around with a kill-a-watt a lot and noticed:
- There are indeed a few rare systems that seem to have a hard time
entering rc6 when desktop-idle.
- One machine, The Indestructible Toshiba regressed in this behaviour
between 3.5 and 3.6 in a merge commit! So rc6 behaviour with the
current setting seems to be highly timing dependent and not robust
at all.
- The behaviour James reported wrt semaphores seems to be a freak
timing thing that only happens on his specific machine, confirming
that enabling semaphores shouldn't reduce rc6 residency.
Now furthermore the Google ChromeOS guys reported [2] a while ago that
at least on some machines a simply a blinking cursor can keep the gpu
turbo at the highest frequency. This is because the current rps limits
used on snb/ivb are highly asymmetric.
On the theory that gpu turbo and rc6 tuning values are related, we've
tried whether the much saner looking (since much less asymmetric) rps
tuning values used for hsw would also help entering rc6 more robustly.
And it seems to mostly work, and we don't really have the resources to
through-roughly tune things in any better way: The values from the
ChromeOS ppl seem to fare a bit worse for James' machine, so I guess
we better stick with something vpg (the gpu hw/windows group)
provided, hoping that they've done their jobs.
Reference[1]: http://lists.freedesktop.org/archives/dri-devel/2012-July/025675.html
Reference[2]: http://lists.freedesktop.org/archives/intel-gfx/2012-July/018692.html
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=53393
Tested-by: Ben Widawsky <ben@bwidawsk.net>
There are systems that use ATRM, but not ATPX.
Fixes:
https://bugs.freedesktop.org/show_bug.cgi?id=41265
V2: fix #ifdefs as per Greg's comments
V3: fix it harder
Allows us to verify the table size.
This is required for pure UEFI systems. The vbios is stored
in ACPI rather than at the legacy vga location.
Fixes:
https://bugs.freedesktop.org/show_bug.cgi?id=26891
V3: fix it harder
Reviewed-by: Jerome Glisse <jglisse@redhat.com>
There is a more recent APU stepping with a new PCI ID
shipping in the same board by Fujitsu which needs the
same quirk to correctly mark the back plane connectors.
Signed-off-by: Tvrtko Ursulin <tvrtko.ursulin@onelan.co.uk>
The MSAA checking was mostly unimplemented on r600-r700. The userspace
submits GPU commands and the kernel driver computes how much memory
the GPU will access and checks if it's all within buffer bounds the
userspace allocated. This patch fixes the computations of the size of
MSAA surfaces in memory.
Signed-off-by: Marek Olšák <maraeo@gmail.com>
MSAA is impossible without them.
Reset the lockup timeout on ring (re-)initialisation.
Otherwise we get error messages like this on gpu resets:
[ 1559.949177] radeon 0000:01:00.0: GPU lockup CP stall for more than 1482270msec
Signed-off-by: Christian König <deathsimple@vodafone.de>
cc: stable@vger.kernel.org
Reviewed-by: Michel Dänzer <michel.daenzer@amd.com>
If spread spectrum is enabled and in use for a given pll we
should not turn it off as it will lead to turning off display
for crtc that use the pll (this behavior was observed on chelsea
edp).
Signed-off-by: Jerome Glisse <jglisse@redhat.com>
This callback is a no-op in nouveau, and the upcoming apple-gmux
switcheroo support won't require it either. Rather than forcing drivers
to stub it out, just make it optional and remove the callback from
nouveau.
Signed-off-by: Seth Forshee <seth.forshee@canonical.com>
GMBUS was enabled over bit-banging as the default in commits:
commit c3dfefa0a6d235bd465309e12f4c56ea16e71111
Author: Daniel Vetter <daniel.vetter@ffwll.ch>
Date: Tue Feb 14 22:37:25 2012 +0100
drm/i915: reenable gmbus on gen3+ again
and
commit 0fb3f969c8683505fb7323c06bf8a999a5a45a15
Date: Fri Mar 2 19:38:30 2012 +0100
drm/i915: enable gmbus on gen2
Unfortunately, GMBUS seems to fail on some CRT displays. Add a bit-banging
fallback to CRT EDID reads.
LKML-Reference: <201207251020.47637.maciej.rutecki@gmail.com>
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=45881
Signed-off-by: Jani Nikula <jani.nikula@intel.com>
Tested-by: Alex Ferrando <alferpal@gmail.com>
Cc: stable@vger.kernel.org (for 3.4+3.5)
Refactor the connector update part of intel_ddc_get_modes() into a separate
intel_connector_update_modes() function for reuse. No functional changes.
They've changed it ... for no apparent reason. Meh.
V2: remove unused 'is_hsw' field.
Signed-off-by: Paulo Zanoni <paulo.r.zanoni@intel.com>
After reset we unconditionally reinitialize lists. If the context switch
hasn't yet completed before the suspend, the default context object will
end up on lists that are going to go away when we resume.
The patch forces the context switch to be synchronous before suspend
assuring that the active/inactive tracking is correct at the time of
resume.
References: https://bugs.freedesktop.org/show_bug.cgi?id=52429
Tested-by: Guang A Yang <guang.a.yang@intel.com>
Signed-off-by: Ben Widawsky <ben@bwidawsk.net>
The EDID returned by drm_get_edid() was never freed.
git://git.freedesktop.org/git/nouveau/linux-2.6 into drm-fixes
* 'drm-nouveau-fixes' of git://git.freedesktop.org/git/nouveau/linux-2.6:
drm/nv86/fifo: suspend fix
drm/nouveau: disable copy engine on NVAF
nouveau: fixup scanout enable in nvc0_pm
drm/nouveau/aux: mask off higher bits of auxch index in i2c table entry
drm/nvd0/disp: mask off high 16 bit of negative cursor x-coordinate
drm/nve0/fifo: add support for the flip completion swmthd
Daniel Vetter writes:
"A few important fixers:
- fix various lvds backlight issues, regressed in 3.6 (Takashi Iwai)
- make the retina mbp work (ignore bogus edp bpc value in vbt)
- fix a gmbus regression introduced in (iirc) 3.4 (Jani Nikula)
- fix an edp panel power sequence regression, fixes the new macbook air
- apply the tlb invalidate w/a
Otherwise we still have another gmbus regression (patches are awaiting
tested-bys) and there's something odd going with some rare systems not
entering rc6 often enough (and hence blowing through too much power). It
seems to be a timing-related issue and can be mitigated by frobbing the
magic tuning parameters. We're still working on that one. Also, we still
have some fallout from the hw context support, but you can only hit that
with mesa master."
drm/i915: Apply post-sync write for pipe control invalidates
drm/i915: reorder edp disabling to fix ivb MacBook Air
drm/i915: ensure i2c adapter is all set before adding it
drm/i915: ignore eDP bpc settings from vbt
drm/i915: Fix blank panel at reopening lid
When invalidating the TLBs it is documentated as requiring a post-sync
write. Failure to do so seems to result in a GPU hang.
Exposure to this hang on IVB seems to be a result of removing the extra
stalls required for SNB pipecontrol workarounds:
commit 6c6cf5aa9c583478b19e23149feaa92d01fb8c2d
Author: Chris Wilson <chris@chris-wilson.co.uk>
Date: Fri Jul 20 18:02:28 2012 +0100
drm/i915: Only apply the SNB pipe control w/a to gen6
Note: Manually switch the pipe_control cmd to 4 dwords to avoid a
(silent) functional conflict with -next. This way will get a loud (but
conflict with next (since the scratch_addr has been deleted there).
Reported-and-tested-by: yex.tian@intel.com
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=53322
Acked-by: Ben Widawsky <ben@bwidawsk.net>
[danvet: added note about merge conflict with -next.]
eDP is tons of fun. It turns out that at least the new MacBook Air 5,1
model absolutely doesn't like the new force vdd dance we've introduced
in
commit 6cb49835da0426f69a2931bc2a0a8156344b0e41
Date: Sun May 20 17:14:50 2012 +0200
drm/i915: enable vdd when switching off the eDP panel
But that patch also tried to fix some neat edp sequence issue with the
force_vdd timings. Closer inspection reveals that we've raised
force_vdd only to do the aux channel communication dp_sink_dpms. If we
move the edp_panel_off below that, we don't need any force_vdd for the
disable sequence, which makes the Air happy.
Unfortunately the reporter of the original bug that the above commit
fixed is travelling, so we can't test whether this regresses things.
But my theory is that since we don't check for any power-off ->
force_vdd-on delays in edp_panel_vdd_on, this was the actual
root-cause of this failure. With that force_vdd dance completely
eliminated, I'm hopeful the original bug stays fixed, too.
For reference the old bug, which hopefully doesn't get broken by this:
https://bugzilla.kernel.org/show_bug.cgi?id=43163
In any case, regression fixers win over plain bugfixes, so this needs
to go in asap.
v2: The crucial pieces seems to be to clear the force_vdd flag
uncoditionally, too, in edp_panel_off. Looks like this is left behind
by the firmware somehow.
v3: The Apple firmware seems to switch off the panel on it's own, hence
we still need to keep force_vdd on, but properly clear it when switching
the panel off.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=45671
Tested-by: Roberto Romer <sildurin@gmail.com>
Tested-by: Daniel Wagner <wagi@monom.org>
Tested-by: Keith Packard <keithp@keithp.com>
Cc: Keith Packard <keithp@keithp.com>
This fix is a backport from the reworked nouveau driver. It masks off the
engines we're not expecting to use before attempting a channel kickoff.
Signed-off-by: Maxim Levitsky <maximlevitsky@gmail.com>
The copy engine exhibits random memory corruption in at least one case, the
GeForce 320M (nv50, 0xaf) in the MacBookAir3,1.
This patch omits creating the engine for the specific chipset, falling back
to M2MF, which kills the symptoms.
Signed-off-by: Henrik Rydberg <rydberg@euromail.se>
Fixes screen being black after changing performance level.
Signed-off-by: Maarten Lankhorst <maarten.lankhorst@canonical.com>
Cc: stable@vger.kernel.org [3.5+]
At least partially fixes DP output detection on W530. Not sure if more
issues remain, or if my adaptor is just behaving weirdly (it does that
sometimes).
In any case, this patch is necessary.
Signed-off-by: Christoph Bumiller <e0425955@student.tuwien.ac.at>
i2c_add_adapter() may do i2c transfers on the bus to detect supported
devices. Therefore the adapter needs to be all set before adding it. This
was not the case for the bit-banging fallback, resulting in an oops if the
device detection GMBUS transfers timed out. Fix the issue by calling
i2c_add_adapter() only after intel_gpio_setup().
LKML-Reference: <5021F00B.7000503@ionic.de>
Tested-by: Mihai Moldovan <ionic@ionic.de>
Signed-off-by: Dmitrii Cherkasov <DCherkasov@luxsoft.com>
Returns a snapshot of the GPU clock counter. Needed
for certain OpenGL extensions.
v2: agd5f
- address Jerome's comments
- add function documentation
Most of the checking seems to be in place already. As you can see,
log2(number of samples) resides in LAST_LEVEL.
This is required for MSAA support (namely for depth-stencil resolve and
blitting between MSAA resources).
Virtual address need to be fenced to know when we can safely remove it.
This patch also properly clear the pagetable. Previously it was
serouisly broken.
Kernel 3.5/3.4 need a similar patch but adapted for difference in mutex locking.
v2: For to update pagetable when unbinding bo (don't bailout if
bo_va->valid is true).
v3: Add kernel 3.5/3.4 comment.
v4: Fix compilation warnings.
Better safe than sorry.
No functional change, but re-order the cases so they
evaluate properly due to the way the DCE macros work.
Noticed by kallisti5 on IRC.
