We may eventually end up with per-connector backlights, especially with
ddcci devices. Make sure that the parent node for the backlight device is
the connector rather than the PCI device.
Cc: Richard Purdie <rpurdie@rpsys.net>
Cc: Chris Wilson <chris@chris-wilson.co.uk>
Cc: David Airlie <airlied@linux.ie>
Cc: Alex Deucher <alexdeucher@gmail.com>
Acked-by: Ben Skeggs <bskeggs@redhat.com>
Cc: Zhang Rui <rui.zhang@intel.com>
Cc: Len Brown <lenb@kernel.org>
Cc: Jesse Barnes <jbarnes@virtuousgeek.org>
Tested-by: Sedat Dilek <sedat.dilek@googlemail.com>
Allows e.g. power management daemons to control the backlight level. Inspired
by the corresponding code in radeonfb.
[mjg@redhat.com: updated to add backlight type and make the connector the parent device]
Signed-off-by: Michel Dänzer <michel@daenzer.net>
Acked-by: Alex Deucher <alexdeucher@gmail.com>
Cc: Ben Skeggs <bskeggs@redhat.com>
There may be multiple ways of controlling the backlight on a given
machine. Allow drivers to expose the type of interface they are
providing, making it possible for userspace to make appropriate policy
decisions.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (47 commits)
doc: CONFIG_UNEVICTABLE_LRU doesn't exist anymore
Update cpuset info & webiste for cgroups
dcdbas: force SMI to happen when expected
arch/arm/Kconfig: remove one to many l's in the word.
asm-generic/user.h: Fix spelling in comment
drm: fix printk typo 'sracth'
Remove one to many n's in a word
Documentation/filesystems/romfs.txt: fixing link to genromfs
drivers:scsi Change printk typo initate -> initiate
serial, pch uart: Remove duplicate inclusion of linux/pci.h header
fs/eventpoll.c: fix spelling
mm: Fix out-of-date comments which refers non-existent functions
drm: Fix printk typo 'failled'
coh901318.c: Change initate to initiate.
mbox-db5500.c Change initate to initiate.
edac: correct i82975x error-info reported
edac: correct i82975x mci initialisation
edac: correct commented info
fs: update comments to point correct document
target: remove duplicate include of target/target_core_device.h from drivers/target/target_core_hba.c
Trivial conflict in fs/eventpoll.c (spelling vs addition)
This was using old gem refcounting methods, fix it to be the same
as the normal create ioctl.
Simplify the way the return value is set a number of times (mostly on
error).
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
Merge list_del() + list_add_tail() to list_move_tail().
Signed-off-by: Nicolas Kaiser <nikai@nikai.net>
This commit changed an internal radeon structure, that meant a new driver
in -next had to be fixed up, merge in the commit and fix up the driver.
Also fixes a trivial nouveau merge.
drivers/gpu/drm/nouveau/nouveau_mem.c
Usually EDID retrieval is fine. However, sometimes, especially when the
machine is loaded, it fails, but succeeds after a few retries.
Based on a patch by Michael Buesch.
Reported-by: Michael Buesch <mb@bu3sch.de>
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
Reviewed-by: Alex Deucher <alexdeucher@gmail.com>
Typo in the aspect scale setup.
Signed-off-by: Alex Deucher <alexdeucher@gmail.com>
Cc: stable@kernel.org
As detect will use hw registers and may modify structures, it needs to be
serialised by use of the dev->mode_config.mutex. Make it so.
Otherwise, we may cause random crashes as the sysfs file is queried
whilst a concurrent hotplug poll is being run. For example:
[ 1189.189626] BUG: unable to handle kernel NULL pointer dereference at 00000100
[ 1189.189821] IP: [<e0c22019>] intel_tv_detect_type+0xa2/0x203 [i915]
[ 1189.190020] *pde = 00000000
[ 1189.190104] Oops: 0000 [#1] SMP
[ 1189.190209] last sysfs file: /sys/devices/pci0000:00/0000:00:02.0/drm/card0/card0-SVIDEO-1/status
[ 1189.190412] Modules linked in: mperf cpufreq_conservative cpufreq_userspace cpufreq_powersave cpufreq_stats decnet uinput fuse loop joydev snd_hd a_codec_realtek snd_hda_intel snd_hda_codec snd_hwdep snd_pcm_oss snd_mixer_oss snd_pcm i915 snd_seq_midi snd_rawmidi snd_seq_midi_event snd_seq drm_kms_helper snd_timer uvcvideo d rm snd_seq_device eeepc_laptop tpm_tis usbhid videodev i2c_algo_bit v4l1_compat snd sparse_keymap i2c_core hid serio_raw tpm psmouse evdev tpm_bios rfkill shpchp ac processor rng_c ore battery video power_supply soundcore pci_hotplug button output snd_page_alloc usb_storage uas ext3 jbd mbcache sd_mod crc_t10dif ata_generic ahci libahci ata_piix libata uhci_h cd ehci_hcd scsi_mod usbcore thermal atl2 thermal_sys nls_base [last unloaded: scsi_wait_scan]
[ 1189.192007]
[ 1189.192007] Pid: 1464, comm: upowerd Not tainted 2.6.37-2-686 #1 ASUSTeK Computer INC. 701/701
[ 1189.192007] EIP: 0060:[<e0c22019>] EFLAGS: 00010246 CPU: 0
[ 1189.192007] EIP is at intel_tv_detect_type+0xa2/0x203 [i915]
[ 1189.192007] EAX: 00000000 EBX: dca74000 ECX: e0f68004 EDX: 00068004
[ 1189.192007] ESI: dd110c00 EDI: 400c0c37 EBP: dca7429c ESP: de365e2c
[ 1189.192007] DS: 007b ES: 007b FS: 00d8 GS: 00e0 SS: 0068
[ 1189.192007] Process upowerd (pid: 1464, ti=de364000 task=dcc8acb0 task.ti=de364000)
[ 1189.192007] Stack: Mar 15 03:43:23 hostname kernel: [ 1189.192007] e0c2cda4 70000000 400c0c30 00000000 dd111000 de365e54 de365f24 dd110c00
[ 1189.192007] e0c22203 01000000 00000003 00000000 00000000 00000000 00000000 4353544e
[ 1189.192007] 30383420 00000069 00000000 00000000 00000000 00000000 00000000 00000000
[ 1189.192007] Call Trace: Mar 15 03:43:23 hostname kernel: [ 1189.192007] [<e0c22203>] ? intel_tv_detect+0x89/0x12d [i915]
[ 1189.192007] [<e0a9dcef>] ? status_show+0x0/0x2f [drm]
[ 1189.192007] [<e0a9dd03>] ? status_show+0x14/0x2f [drm]
[Digression: what is upowerd doing reading those power hungry files?]
Reported-by: Paul Menzel <paulepanter@users.sourceforge.net>
drm-core-next
* 'nouveau/drm-nouveau-next' of ../drm-nouveau-next:
drm/nouveau: fix __nouveau_fence_wait performance
drm/nv40: attempt to reserve just enough vram for all 32 channels
drm/nv50: check for vm traps on every gr irq
drm/nv50: decode vm faults some more
drm/nouveau: add nouveau_enum_find() util function
drm/nouveau: properly handle pushbuffer check failures
drm/nvc0: remove vm hack forcing large/small pages to not share a PDE
Commit 21e86c1c8a844bf978f8fc431a59c9f5a578812d ("drm/nouveau: remove
cpu_writers lock") turned on lazy waits. Unfortunately
__nouveau_fence_wait was not optimized for this case and on HZ=100
kernel wasted up to 10 ms per call.
Depending on application, it led to 10-30% FPS regression.
Fix it.
Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com>
Signed-off-by: Francisco Jerez <currojerez@riseup.net>
This also makes the fact we're giving 512MiB of GART space to all PCIE
boards explicit, although the vast majority (if not all) of them will
now have a ramin_rsvd_vram larger than 2MiB anyway.
Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
When "buffer in list" check does not pass, don't free validation lists - they were
not initialized yet.
Fixes this oops:
[drm] nouveau 0000:02:00.0: push 105 buffer not in list
BUG: unable to handle kernel NULL pointer dereference at 000000000000057c
IP: [<ffffffff81236aa4>] do_raw_spin_lock+0x14/0x13c
PGD 1ac6cb067 PUD 1aaa52067 PMD 0
CPU 0
Modules linked in: nouveau ttm drm_kms_helper snd_hda_codec_realtek snd_hda_intel snd_hda_codec
Pid: 6265, comm: OilRush_x86 Not tainted 2.6.38-rc6-nv+ #632 System manufacturer System Product Name/P6T SE
RIP: 0010:[<ffffffff81236aa4>] [<ffffffff81236aa4>] do_raw_spin_lock+0x14/0x13c
Process OilRush_x86 (pid: 6265, threadinfo ffff8801a6aee000, task ffff8801a26c0000)
0000000000000000 ffff8801ac74c618 0000000000000000 0000000000000578
0000000000000000 ffff8801ac74c618 0000000000000000 ffff8801bd9d0000
[<ffffffff81417f78>] _raw_spin_lock+0x1e/0x22
[<ffffffffa00a2746>] nouveau_bo_fence+0x2e/0x60 [nouveau]
[<ffffffffa00a540b>] validate_fini_list+0x35/0xeb [nouveau]
[<ffffffffa00a54d3>] validate_fini+0x12/0x31 [nouveau]
[<ffffffffa00a6386>] nouveau_gem_ioctl_pushbuf+0xe94/0xf6b [nouveau]
[<ffffffff8141ac56>] ? sub_preempt_count+0x9e/0xb2
[<ffffffff81417e94>] ? _raw_spin_unlock_irqrestore+0x30/0x4d
[<ffffffff8105dea2>] ? __wake_up+0x3f/0x48
[<ffffffff812aebb4>] drm_ioctl+0x289/0x361
[<ffffffffa00a54f2>] ? nouveau_gem_ioctl_pushbuf+0x0/0xf6b [nouveau]
[<ffffffffa010caa2>] nouveau_compat_ioctl+0x16/0x1c [nouveau]
[<ffffffff81142c0d>] compat_sys_ioctl+0x1c8/0x12d7
[<ffffffff814179ca>] ? trace_hardirqs_off_thunk+0x3a/0x6c
[<ffffffff81058099>] sysenter_dispatch+0x7/0x30
[<ffffffff8141798e>] ? trace_hardirqs_on_thunk+0x3a/0x3c
RIP [<ffffffff81236aa4>] do_raw_spin_lock+0x14/0x13c
RSP <ffff8801a6aefb88>
---[ end trace 0014d5d93e6147e1 ]---
Additionally, don't call validate_fini twice in case of validation failure.
Signed-off-by: Maarten Maathuis <madman2003@gmail.com>
Appears to be fixed with commit:
"drm/nv50-nvc0: make sure vma is definitely unmapped when destroying bo"
At least on my HP 2540p this is wrong at bootup, fine
at any other time once a lid event has occured. This is due to
_REG vs _INI ordering in the ACPI tables.
* 'intel/drm-intel-next' of ../drm-next: (755 commits)
drm/i915: Only wait on a pending flip if we intend to write to the buffer
drm/i915/dp: Sanity check eDP existence
drm/i915: Rebind the buffer if its alignment constraints changes with tiling
drm/i915: Disable GPU semaphores by default
drm/i915: Do not overflow the MMADDR write FIFO
Revert "drm/i915: fix corruptions on i8xx due to relaxed fencing"
drm/i915: Don't save/restore hardware status page address register
drm/i915: don't store the reg value for HWS_PGA
drm/i915: fix memory corruption with GM965 and >4GB RAM
Linux 2.6.38-rc7
Revert "TPM: Long default timeout fix"
drm/i915: Re-enable GPU semaphores for SandyBridge mobile
drm/i915: Replace vblank PM QoS with "Interrupt-Based AGPBUSY#"
Revert "drm/i915: Use PM QoS to prevent C-State starvation of gen3 GPU"
drm/i915: Allow relocation deltas outside of target bo
drm/i915: Silence an innocuous compiler warning for an unused variable
fs/block_dev.c: fix new kernel-doc warning
ACPI: Fix build for CONFIG_NET unset
mm: <asm-generic/pgtable.h> must include <linux/mm_types.h>
x86: Use u32 instead of long to set reset vector back to 0
drivers/gpu/drm/i915/i915_gem.c
So we used to use lpfn directly to restrict VRAM when we couldn't
access the unmappable area, however this was removed in
93225b0d7bc030f4a93165347a65893685822d70 as it also restricted
the gtt placements. However it was only later noticed that this
broke on some hw.
This removes the active_vram_size, and just explicitly sets it
when it changes, TTM/drm_mm will always use the real_vram_size,
and the active vram size will change the TTM size used for lpfn
setting.
We should re-work the fpfn/lpfn to per-placement at some point
I suspect, but that is too late for this kernel.
Hopefully this addresses:
https://bugs.freedesktop.org/show_bug.cgi?id=35254
v2: fix reported useful VRAM size to userspace to be correct.
We've been getting reports of complete system lockups with rv3xx hw on
AGP and PCIE when running gnome-shell or kwin with compositing.
It appears the hw really doesn't like setting these registers while
stuff is running, this moves the setting of the registers into the modeset
since they aren't required to be changed anywhere else.
fixes: https://bugs.freedesktop.org/show_bug.cgi?id=35183
Reported-and-tested-by: Álmos <aaalmosss@gmail.com
Looks like these got passed over with both being merged at the same
time but not quite meeting in the middle.
should fix: https://bugs.freedesktop.org/show_bug.cgi?id=34137
along with Michael's phoronix article.
Reported-by: Chi-Thanh Christopher Nguyen
Article-written-by: Michael Larabel @ phoronix
This reverts commit 951f3512dba5bd44cda3e5ee22b4b522e4bb09fb
drm/i915: Do not handle backlight combination mode specially
since this commit introduced other regressions due to untouched LBPC
register, e.g. the backlight dimmed after resume.
In addition to the revert, this patch includes a fix for the original
issue (weird backlight levels) by removing the wrong bit shift for
computing the current backlight level.
Also, including typo fixes (lpbc -> lbpc).
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=34524
Acked-by: Indan Zupancic <indan@nul.nu>
Reviewed-by: Keith Packard <keithp@keithp.com>
Reviewed-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Cc: <stable@kernel.org>
Index i was already used in thhe first loop
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
* ickle/drm-intel-fixes:
The per-vm mutex doesn't prevent this completely, a flush coming from the
BAR VM could potentially happen at the same time as one for the channel
VM. Not to mention that if/when we get per-client/channel VM, this will
happen far more frequently.
TTM assumes an error condition from man->func->get_node() means that
something went horribly wrong, and causes it to bail.
The driver is supposed to return 0, and leave mm_node == NULL to
signal that it couldn't allocate any memory.
Apply the trivial conflicting regression fixes, but keep GPU semaphores
enabled.
drivers/gpu/drm/i915/i915_drv.h
drivers/gpu/drm/i915/i915_gem_execbuffer.c
... as if we are only reading from it, we can do that concurrently with
the queue flip.
Some hardware claims to have both an LVDS panel and an eDP output.
Whilst this may be true in a rare case, more often it is just broken
hardware. If we see an eDP device we know that it must be connected and
so we can confirm its existence with a simple probe.
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=34165
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=24822
Early gen3 and gen2 chipset do not have the relaxed per-surface tiling
constraints of the later chipsets, so we need to check that the GTT
alignment is correct for the new tiling. If it is not, we need to
rebind.
Reported-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Andi Kleen narrowed his GPU hangs on his Sugar Bay (SNB desktop) rev 09
down to the use of GPU semaphores, and we already know that they appear
broken up to Huron River (mobile) rev 08. (I'm optimistic that disabling
GPU semaphores is simply hiding another bug by the latency and
side-effects of the additional device interaction it introduces...)
However, use of semaphores is a massive performance improvement... Only
as long as the system remains stable. Enable at your peril.
Reported-by: Andi Kleen <andi-fd@firstfloor.org>
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=33921
Whilst the GT is powered down (rc6), writes to MMADDR are placed in a
FIFO by the System Agent. This is a limited resource, only 64 entries, of
which 20 are reserved for Display and PCH writes, and so we must take
care not to queue up too many writes. To avoid this, there is counter
which we can poll to ensure there are sufficient free entries in the
fifo.
"Issuing a write to a full FIFO is not supported; at worst it could
result in corruption or a system hang."
Reported-and-Tested-by: Matt Turner <mattst88@gmail.com>
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=34056
This reverts commit c2e0eb167070a6e9dcb49c84c13c79a30d672431.
As it turns out, userspace already depends upon being able to enable
tiling on existing bo which it promises to be large enough for its
purposes i.e. it will not access beyond the end of the last full-tile
row.
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=35016
Reported-and-tested-by: Kamal Mostafa <kamal@canonical.com>
This allows libkms to make an easier decision.
We're coming to see a need to have a set of generic capability checks in
the core DRM, in addition to the driver-specific ioctls that already
exist.
This patch defines an ioctl to do as such, but does not yet define any
capabilities.
[airlied: drop the driver callback for now.]
The nv30/nv40 3d driver is about to start using DMA_FENCE from the 3D
object which, it turns out, doesn't like its DMA object to not be
aligned to a 4KiB boundary.
hdmi 1.3 raises the max clock from 165 Mhz to 340 Mhz.
These should be handled by the clear_state setup, but set them
directly as well just to be sure.
Added to existing evergreen CS checker.
For the CS checker.
Cayman is different enough from evergreen to warrant it's own functions.
Cayman asics have 3 ring buffers:
ring 0 supports both gfx and compute
rings 1 and 2 are compute only
At the moment we only support ring 0.
