Bug 1348440
Change-Id: If25c49f027dc2a69642f7ed4733e965962b2a5a2
Signed-off-by: Deepak Nibade <dnibade@nvidia.com>
commit e85843bec6c2ea7c10ec61238396891cc2b753a9 upstream.
BugLink: https://bugzilla.kernel.org/show_bug.cgi?id=47941
BugLink: https://bugs.launchpad.net/bugs/1163720
BugLink: https://bugs.launchpad.net/bugs/1162026
Some machines suffer from non-functional backlight controls if
BLM_PCH_PWM_ENABLE is set, so provide a quirk to avoid doing so.
Apply this quirk to Dell XPS 13 models.
[ kamal: backport to 3.4 ]
Tested-by: Eric Griffith <EGriffith92@gmail.com>
Tested-by: Kent Baxley <kent.baxley@canonical.com>
Signed-off-by: Kamal Mostafa <kamal@canonical.com>
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
commit 42a21826dc54583cdb79cc8477732e911ac9c376 upstream.
The ProcessAuxChannel table on some rv635 boards assumes
the divmul members are initialized to 0 otherwise we get
an invalid fb offset since it has a bad mask set when
setting the fb base. While here initialize all the
atom interpretor elements to 0.
Fixes:
https://bugzilla.kernel.org/show_bug.cgi?id=60639
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
commit 03ed8cf9b28d886c64c7e705c7bb1a365fd8fb95 upstream.
Hopefully avoid more quirks in the future due to bogus
vbios dac data.
commit cef1d00cd56f600121ad121875655ad410a001b8 upstream.
Noticed that my old Radeon 7500 hung after printing
drm: GPU not posted. posting now...
when it wasn't selected as the primary card the BIOS. Some digging
revealed that it was hanging in combios_parse_mmio_table() while
parsing the ASIC INIT 3 table. Looking at the BIOS ROM for the card,
it becomes obvious that there is no ASIC INIT 3 table in the BIOS.
The code is just processing random garbage. No surprise it hangs!
Why do I say that there is no ASIC INIT 3 table is the BIOS? This
table is found through the MISC INFO table. The MISC INFO table can
be found at offset 0x5e in the COMBIOS header. But the header is
smaller than that. The COMBIOS header starts at offset 0x126. The
standard PCI Data Structure (the bit that starts with 'PCIR') lives at
offset 0x180. That means that the COMBIOS header can not be larger
than 0x5a bytes and therefore cannot contain a MISC INFO table.
I looked at a dozen or so BIOS images, some my own, some downloaded from:
<http://www.techpowerup.com/vgabios/index.php?manufacturer=ATI&page=1>
It is fairly obvious that the size of the COMBIOS header can be found
at offset 0x6 of the header. Not sure if it is a 16-bit number or
just an 8-bit number, but that doesn't really matter since the tables
seems to be always smaller than 256 bytes.
So I think combios_get_table_offset() should check if the requested
table is present. This can be done by checking the offset against the
size of the header. See the diff below. The diff is against the WIP
OpenBSD codebase that roughly corresponds to Linux 3.8.13 at this
point. But I don't think this bit of the code changed much since
then.
For what it is worth:
Signed-off-by: Mark Kettenis <kettenis@openbsd.org>
commit 34be8c9af7b8728465963740fc11136ae90dfc36 upstream.
The atom interpreter expects data in LE format, so
swap the message buffer as apprioriate.
v2: properly handle non-dw aligned byte counts.
v3: properly handle remainder
Cc: Dong He <hedonghust@gmail.com>
commit c3456fb3e4712d0448592af3c5d644c9472cd3c1 upstream.
In
commit 53d3b4d7778daf15900867336c85d3f8dd70600c
Author: Egbert Eich <eich@suse.de>
Date: Tue Jun 4 17:13:21 2013 +0200
drm/i915/sdvo: Use &intel_sdvo->ddc instead of intel_sdvo->i2c for DDC
Egbert Eich fixed a long-standing bug where we simply used a
non-working i2c controller to read the EDID for SDVO-LVDS panels.
Unfortunately some machines seem to not be able to cope with the mode
provided in the EDID. Specifically they seem to not be able to cope
with a 4x pixel mutliplier instead of a 2x one, which seems to have
been worked around by slightly changing the panels native mode in the
VBT so that the dotclock is just barely above 50MHz.
Since it took forever to notice the breakage it's fairly safe to
assume that at least for SDVO-LVDS panels the VBT contains fairly sane
data. So just switch around the order and use VBT modes first.
v2: Also add EDID modes just in case, and spell Egbert correctly.
v3: Elaborate a bit more about what's going on on Chris' machine.
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=65524
Reported-and-tested-by: Chris Wilson <chris@chris-wilson.co.uk>
Cc: Egbert Eich <eich@suse.de>
commit 22e7c385a80d771aaf3a15ae7ccea3b0686bbe10 upstream.
The framebuffer needs to be unpinned in the crtc->disable callback
because of previous pinning in psb_intel_pipe_set_base(). This will fix
a memory leak where the framebuffer was released but not unpinned
properly. This patch only affects Cedarview.
Bugzilla: https://bugzilla.redhat.com/show_bug.cgi?id=889511
Bugzilla: https://bugzilla.novell.com/show_bug.cgi?id=812113
Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Signed-off-by: Patrik Jakobsson <patrik.r.jakobsson@gmail.com>
commit 820de86a90089ee607d7864538c98a23b503c846 upstream.
properly. This patch only affects Poulsbo.
commit cbbd379aa43890f36da934f5af619d2fb8ec3d87 upstream.
By having a higher max resolution we can now set up a virtual
framebuffer that spans several monitors. 4096 should be ok since we're
gen 3 or higher and should be enough for most dual head setups.
Bugzilla:
https://bugs.launchpad.net/ubuntu/+source/xserver-xorg-video-modesetting/+bug/1169147
commit 45a211d75137b1ac869a8a758a6667f15827a115 upstream.
Last year, a patch was made for the "HP t5740e Thin Client" (see
http://lists.freedesktop.org/archives/dri-devel/2012-May/023245.html).
This device reports an lvds panel, but does not really have one.
The predecessor of this device is the "hp t5740", which also does not have
an lvds panel. This patch will add the same quirk for this device.
Signed-off-by: Ben Mesman <ben@bnc.nl>
commit 53d3b4d7778daf15900867336c85d3f8dd70600c upstream.
In intel_sdvo_get_lvds_modes() the wrong i2c adapter record is used
for DDC. Thus the code will always have to rely on a LVDS panel
mode supplied by VBT.
In most cases this succeeds, so this didn't get detected for quite
a while.
This regression seems to have been introduced in
commit f899fc64cda8569d0529452aafc0da31c042df2e
Author: Chris Wilson <chris@chris-wilson.co.uk>
Date: Tue Jul 20 15:44:45 2010 -0700
drm/i915: use GMBUS to manage i2c links
Signed-off-by: Egbert Eich <eich@suse.de>
Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk>
[danvet: Add note about which commit likely introduced this issue.]
commit b7ea85a4fed37835eec78a7be3039c8dc22b8178 upstream.
When GPU acceleration is disabled, drm_vblank_cleanup() will free the
vblank-related data, such as vblank_refcount, vblank_inmodeset, etc.
But we found that drm_vblank_post_modeset() may be called after the
cleanup, which use vblank_refcount and vblank_inmodeset. And this will
cause a kernel panic.
Fix this by return immediately if dev->num_crtcs is zero. This is the
same thing that drm_vblank_pre_modeset() does.
Call trace of a drm_vblank_post_modeset() after drm_vblank_cleanup():
[ 62.628906] [<ffffffff804868d0>] drm_vblank_post_modeset+0x34/0xb4
[ 62.628906] [<ffffffff804c7008>] atombios_crtc_dpms+0xb4/0x174
[ 62.628906] [<ffffffff804c70e0>] atombios_crtc_commit+0x18/0x38
[ 62.628906] [<ffffffff8047f038>] drm_crtc_helper_set_mode+0x304/0x3cc
[ 62.628906] [<ffffffff8047f92c>] drm_crtc_helper_set_config+0x6d8/0x988
[ 62.628906] [<ffffffff8047dd40>] drm_fb_helper_set_par+0x94/0x104
[ 62.628906] [<ffffffff80439d14>] fbcon_init+0x424/0x57c
[ 62.628906] [<ffffffff8046a638>] visual_init+0xb8/0x118
[ 62.628906] [<ffffffff8046b9f8>] take_over_console+0x238/0x384
[ 62.628906] [<ffffffff80436df8>] fbcon_takeover+0x7c/0xdc
[ 62.628906] [<ffffffff8024fa20>] notifier_call_chain+0x44/0x94
[ 62.628906] [<ffffffff8024fcbc>] __blocking_notifier_call_chain+0x48/0x68
[ 62.628906] [<ffffffff8042d990>] register_framebuffer+0x228/0x260
[ 62.628906] [<ffffffff8047e010>] drm_fb_helper_single_fb_probe+0x260/0x314
[ 62.628906] [<ffffffff8047e2c4>] drm_fb_helper_initial_config+0x200/0x234
[ 62.628906] [<ffffffff804e5560>] radeon_fbdev_init+0xd4/0xf4
[ 62.628906] [<ffffffff804e0e08>] radeon_modeset_init+0x9bc/0xa18
[ 62.628906] [<ffffffff804bfc14>] radeon_driver_load_kms+0xdc/0x12c
[ 62.628906] [<ffffffff8048b548>] drm_get_pci_dev+0x148/0x238
[ 62.628906] [<ffffffff80423564>] local_pci_probe+0x5c/0xd0
[ 62.628906] [<ffffffff80241ac4>] work_for_cpu_fn+0x1c/0x30
[ 62.628906] [<ffffffff802427c8>] process_one_work+0x274/0x3bc
[ 62.628906] [<ffffffff80242934>] process_scheduled_works+0x24/0x44
[ 62.628906] [<ffffffff8024515c>] worker_thread+0x31c/0x3f4
[ 62.628906] [<ffffffff802497a8>] kthread+0x88/0x90
[ 62.628906] [<ffffffff80206794>] kernel_thread_helper+0x10/0x18
Signed-off-by: Huacai Chen <chenhc@lemote.com>
Signed-off-by: Binbin Zhou <zhoubb@lemote.com>
Reviewed-by: Michel Dänzer <michel.daenzer@amd.com>
Acked-by: Paul Menzel <paulepanter@users.sourceforge.net>
Signed-off-by: Dave Airlie <airlied@gmail.com>
commit 1cbcca302a318499f20a512847c5d6a510c08c35 upstream.
It's not supported yet. Fixes display issues when
users force it on.
commit e49f3959a96dc279860af7e86e6dbcfda50580a5 upstream.
The current radeon driver initialization routines, when using KMS, are written
so that the IRQ installation routine is called before initializing the WB buffer
and the CP rings. With some ASICs, though, the IRQ routine tries to access the
GFX_INDEX ring causing a call to RREG32 with the value of -1 in
radeon_fence_read. This, in turn causes the system to completely hang with some
cards, requiring a hard reset.
A call stack that can cause such a hang looks like this (using rv515 ASIC for the
example here):
* rv515_init (rv515.c)
* radeon_irq_kms_init (radeon_irq_kms.c)
* drm_irq_install (drm_irq.c)
* radeon_driver_irq_preinstall_kms (radeon_irq_kms.c)
* rs600_irq_process (rs600.c)
* radeon_fence_process - due to SW interrupt (radeon_fence.c)
* radeon_fence_read (radeon_fence.c)
* hang due to RREG32(-1)
The patch moves the IRQ installation to the card startup routine, after the ring
has been initialized, but before the IRQ has been set. This fixes the issue, but
requires a check to see if the IRQ is already installed, as is the case in the
system resume codepath.
I have tested the patch on three machines using the rv515, the rv770 and the
evergreen ASIC. They worked without issues.
This seems to be a known issue and has been reported on several bug tracking
sites by various distributions (see links below). Most of reports recommend
booting the system with KMS disabled and then enabling KMS by reloading the
radeon module. For some reason, this was indeed a usable workaround, however,
UMS is now deprecated and disabled by default.
Bug reports:
https://bugzilla.redhat.com/show_bug.cgi?id=845745
https://bugs.launchpad.net/ubuntu/+source/linux/+bug/561789
https://bbs.archlinux.org/viewtopic.php?id=156964
Signed-off-by: Adis Hamzić <adis@hamzadis.com>
commit 09fb8bd1a63b0f9f15e655c4fe8d047e5d2bf67a upstream.
Newer asics have variable numbers of crtcs. Use that
rather than the asic family to determine which crtcs
to check. This avoids checking non-existent crtcs or
missing crtcs on certain asics.
commit fc986034540102cd090237bf3f70262e1ae80d9c upstream.
Add ULL prefix to avoid overflow.
Signed-off-by: Niels Ole Salscheider <niels_ole@salscheider-online.de>
commit fefaedcfb82d2e57c2320acf60604ab03b750cc0 upstream.
The "boxes" parameter points into userspace memory. It should be verified
like any other operation against user memory.
commit 3a359f0b21ab218c1bf7a6a1b638b6fd143d0b99 upstream.
In
commit 9e8944ab564f2e3dde90a518cd32048c58918608
Date: Thu Nov 15 11:32:17 2012 +0000
drm: Introduce an iterator over holes in the drm_mm range manager
helpers and iterators for hole handling have been introduced with some
debug BUG_ONs sprinkled over. Unfortunately this broke the mm dumper
which unconditionally tried to compute the size of the very first
hole.
While at it unify the code a bit with the hole dumping in the loop.
v2: Extract a hole dump helper.
Reported-by: Christopher Harvey <charvey@matrox.com>
Cc: Christopher Harvey <charvey@matrox.com>
Cc: Dave Airlie <airlied@redhat.com>
Cc: Chris Wilson <chris@chris-wilson.co.uk>
Acked-by: Dave Airlie <airlied@redhat.com>
commit 441e76ca83ac604eaf0f046def96d8e3a27eea28 upstream.
The code was mis-handling variable sized arrays.
Reported-by: Sylvain BERTRAND <sylware@legeek.net>
commit 62d1f92e06aef9665d71ca7e986b3047ecf0b3c7 upstream.
commit f8e6bfc2ce162855fa4f9822a45659f4b542c960 upstream.
If we have a empty power table, bail early and allocate
the default power state.
Should fix:
https://bugs.freedesktop.org/show_bug.cgi?id=63865
commit beb71fc61c2cad64e347f164991b8ef476529e64 upstream.
Reviwed-by: Michel Dänzer <michel.daenzer@amd.com>
commit 2e97be73e5f74a317232740ae82eb8f95326a660 upstream.
Avoids potential interrupt storms when the display is disabled.
May fix:
https://bugzilla.kernel.org/show_bug.cgi?id=56041
commit abf1457bbbe4c62066bd03c6d31837dea28644dc upstream.
Just disabling the mem requests should be enough, but
that doesn't seem to work correctly on efi systems.
May fix:
https://bugs.freedesktop.org/show_bug.cgi?id=57567
https://bugs.freedesktop.org/show_bug.cgi?id=43655
https://bugzilla.kernel.org/show_bug.cgi?id=56441
v2: blank displays first, then disable.
commit 968c01664ccbe0e46c19a1af662c4c266a904203 upstream.
Need to wait for the new addresses to take affect before
re-enabling the MC.
commit 7c1c7c18fc752b2a1d07597286467ef186312463 upstream.
A new tiling config register for the display blocks was
added on DCE6.
May fix:
https://bugs.freedesktop.org/show_bug.cgi?id=62889
https://bugs.freedesktop.org/show_bug.cgi?id=57919
commit bf05d9985111f85ed6922c134567b96eb789283b upstream.
It doesn't work reliably. Just report back the currently
selected engine clock.
Partially fixes:
https://bugs.freedesktop.org/show_bug.cgi?id=62493
commit e4bfff54ed3f5de88f5358504c78c2cb037813aa upstream.
As discussed in this thread
http://lists.freedesktop.org/archives/dri-devel/2013-April/037411.html
GMBUS based DVO transmitter detection seems to be unreliable which could
result in an unusable DVO port.
The attached patch fixes this by falling back to bit banging mode for
the time DVO transmitter detection is in progress.
Signed-off-by: David Müller <d.mueller@elsoft.ch>
Tested-by: David Müller <d.mueller@elsoft.ch>
commit 9e9dd0e889c76c786e8f2e164c825c3c06dea30c upstream.
The "Mobile Sandy Bridge CPUs" in the Fujitsu Esprimo Q900
mini desktop PCs are probably misleading the LVDS detection
code in intel_lvds_supported. Nothing is connected to the
LVDS ports in these systems.
Signed-off-by: Christian Lamparter <chunkeey@googlemail.com>
commit 054430e773c9a1e26f38e30156eff02dedfffc17 upstream.
Okay so Alan's patch handled the case where there was no registered fbcon,
however the other path entered in set_con2fb_map pit.
In there we called fbcon_takeover, but we also took the console lock in a couple
of places. So push the console lock out to the callers of set_con2fb_map,
this means fbmem and switcheroo needed to take the lock around the fb notifier
entry points that lead to this.
This should fix the efifb regression seen by Maarten.
Tested-by: Maarten Lankhorst <maarten.lankhorst@canonical.com>
Tested-by: Lu Hua <huax.lu@intel.com>
commit 1baee58638fc58248625255f5c5fcdb987f11b1f upstream.
Don't oops seems proper.
commit 9a0f938bde74bf9e50bd75c8de9e38c1787398cd upstream.
The current layout is to place the per-process tables at the end of the
GTT. However, this is currently using a hardcoded maximum size for the GTT
and not taking in account limitations imposed by the BIOS. Use the value
for the total number of entries allocated in the table as provided by
the configuration registers.
Reported-by: Matthew Garrett <mjg@redhat.com>
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
Cc: Daniel Vetter <daniel.vetter@ffwll.ch>
Cc: Ben Widawsky <ben@bwidawsk.net>
Cc: Matthew Garret <mjg@redhat.com>
Cc: Jonathan Nieder <jrnieder@gmail.com>
commit 4a35f83b2b7c6aae3fc0d1c4554fdc99dc33ad07 upstream.
Restore crtc->fb to the old framebuffer if queue_flip fails.
While at it, kill the pointless intel_fb temp variable.
v2: Update crtc->fb before queue_flip and restore it back
after a failure.
Backported for 3.4-stable. Adjusted context only.
Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com>
Reported-and-Tested-by: Mika Kuoppala <mika.kuoppala@intel.com>
Signed-off-by: Lingzhu Xiang <lxiang@redhat.com>
Reviewed-by: CAI Qian <caiqian@redhat.com>
commit d627b62ff8d4d36761adbcd90ff143d79c94ab22 upstream.
This is rather a hack to fix brightness hotkeys on a Clevo laptop. CADL is not
used anywhere in the driver code at the moment, but it could be used in BIOS as
is the case with the Clevo laptop.
The Clevo B7130 requires the CADL field to contain at least the ID of
the LCD device. If this field is empty, the ACPI methods that are called
on pressing brightness / display switching hotkeys will not trigger a
notification. As a result, it appears as no hotkey has been pressed.
Reference: https://bugs.freedesktop.org/show_bug.cgi?id=45452
Tested-by: Peter Wu <lekensteyn@gmail.com>
Signed-off-by: Peter Wu <lekensteyn@gmail.com>
Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Cc: Ben Hutchings <ben@decadent.org.uk>
commit fa8d387dc3f62062a6b4afbbb2a3438094fd8584 upstream.
Fixes a segfault on asics without a blit callback.
Fixes:
https://bugs.freedesktop.org/show_bug.cgi?id=62239
commit e4d170633fde379f39a90f8a5e7eb619b5d1144d upstream.
Richland APUs are a new version of the Trinity APUs
with performance and power management improvements.
Reviewed-by: Jerome Glisse <jglisse@redhat.com>
commit c19b3b0f6eed552952845e4ad908dba2113d67b4 upstream.
When KMS has parsed an EDID "detailed timing", it leaves the frame rate
zeroed. Consecutive (debug-) output of that mode thus yields 0 for
vsync. This simple fix also speeds up future invocations of
drm_mode_vrefresh().
While it is debatable whether this qualifies as a -stable fix I'd apply
it for consistency's sake; drm_helper_probe_single_connector_modes()
does the same thing already for all probed modes.
Signed-off-by: Torsten Duwe <duwe@lst.de>
commit 16dad1d743d31a104a849c8944e6b9eb479f6cd7 upstream.
EDID spreads some values across multiple bytes; bit-fiddling is needed
to retrieve these. The current code to parse "detailed timings" has a
cut&paste error that results in a vsync offset of at most 15 lines
instead of 63.
See
http://en.wikipedia.org/wiki/EDID
and in the "EDID Detailed Timing Descriptor" see bytes 10+11 show why
that needs to be a left shift.
commit 3118a4f652c7b12c752f3222af0447008f9b2368 upstream.
It is possible to wrap the counter used to allocate the buffer for
relocation copies. This could lead to heap writing overflows.
CVE-2013-0913
v3: collapse test, improve comment
v2: move check into validate_exec_list
Reported-by: Pinkie Pie
commit 2563a4524febe8f4a98e717e02436d1aaf672aa2 upstream.
Masks kernel address info-leak in object dumps with the %pK suffix,
so they cannot be used to target kernel memory corruption attacks if
the kptr_restrict sysctl is set.
commit 0920a48719f1ceefc909387a64f97563848c7854 upstream.
This increases GEN6_RC6p_THRESHOLD from 100000 to 150000. For some
reason this avoids the gen6_gt_check_fifodbg.isra warnings and
associated GPU lockups, which makes my ivy bridge machine stable.
Signed-off-by: Stéphane Marchesin <marcheu@chromium.org>
commit e79e0fe380847493266fba557217e2773c61bd1b upstream.
Subsequent threads returning EBUSY from vm_insert_pfn() was not handled
correctly. As a result concurrent access from new threads to
mmapped data caused SIGBUS.
Note that this fixes i-g-t/tests/gem_threaded_tiled_access.
Signed-off-by: Dmitry Rogozhkin <dmitry.v.rogozhkin@intel.com>
commit e8fc41377f5037ff7a661ea06adc05f1daec1548 upstream.
vbios values are wrong leading to colors that are
too bright. Use the default values instead.
Bug 1243631
Change-Id: I915826047b2e20f0ad0a7d75df295c6cbf6e5b0a
commit 4f7dfb6788dd022446847fbbfbe45e13bedb5be2 upstream.
The Intel PRM says the M1 and M2 divisors must be in the range of 10-20 and 5-9.
Since we do all calculations based on them being register values (which are
subtracted by 2) we need to specify them accordingly.
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=56359
commit 24a1f16de97c4cf0029d9acd04be06db32208726 upstream.
If encoder is switched off by BIOS, but the panel fitter is left on,
we never try to turn off the panel fitter and leave it still attached
to the pipe - which can cause blurry output elsewhere.
Based on work by Chris Wilson <chris@chris-wilson.co.uk>
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=58867
Signed-off-by: Mika Kuoppala <mika.kuoppala@intel.com>
Tested-by: Andreas Sturmlechner <andreas.sturmlechner@gmail.com>
[danvet: Remove the redundant HAS_PCH_SPLIT check and add a tiny
comment.]
commit 9f23de52b64f7fb801fd76f3dd8651a0dc89187b upstream.
While looking at plymouth on udl I noticed that plymouth was trying
to use its fb plugin not its drm one, it was trying to drmOpen a driver called
usb not udl, noticed that we actually had out driver pointing at the wrong
device.
commit d84f031bd230fdf9c3b7734940c859bf28b90219 upstream.
Support for real RGB332 is a rarity, most hardware only really support
C8. So use C8 instead of RGB332 when determining the format based on
depth/bpp.
This fixes 8bpp fbcon on i915, since i915 will only accept C8 and not
RGB332.
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=59572
Acked-by: Dave Airlie <airlied@gmail.com>
Tested-by: mlsemon35@gmail.com
commit c51a6bc5f6d328926a9a4a1247c5030faf190a80 upstream.
Set depth/bits_per_pixel to 8 for C8 format.
