commit 717adfdaf14704fd3ec7fa2c04520c0723247eac upstream.
If our length is greater than the size of the buffer, we
overflow the buffer
Cc: stable@vger.kernel.org
Signed-off-by: Daniel Rosenberg <drosen@google.com>
Reviewed-by: Benjamin Tissoires <benjamin.tissoires@redhat.com>
The code in hid_debug_event() causes horrible code generation. First,
we do a strlen() call for every byte we copy (we're doing a store to
global memory, so gcc has no way of proving that strlen(buf) doesn't
change). Second, since both i, list->tail and HID_DEBUG_BUFSIZE have
signed type, the modulo computation has to take into account the
possibility that list->tail+i is negative, so it's not just a simple
and.
Fix the former by simply not doing strlen() at all (we have to load
buf[i] anyway, so testing it is almost free) and the latter by
changing i to unsigned. This cuts 29% (69 bytes) of the size of the
function.
Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk>
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
Pull input subsystem updates from Dmitry Torokhov:
"You will get the following new drivers:
- Qualcomm PM8941 power key drver
- ChipOne icn8318 touchscreen controller driver
- Broadcom iProc touchscreen and keypad drivers
- Semtech SX8654 I2C touchscreen controller driver
ALPS driver now supports newer SS4 devices; Elantech got a fix that
should make it work on some ASUS laptops; and a slew of other
enhancements and random fixes"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (51 commits)
Input: alps - non interleaved V2 dualpoint has separate stick button bits
Input: alps - fix touchpad buttons getting stuck when used with trackpoint
Input: atkbd - document "no new force-release quirks" policy
Input: ALPS - make alps_get_pkt_id_ss4_v2() and others static
Input: ALPS - V7 devices can report 5-finger taps
Input: ALPS - add support for SS4 touchpad devices
Input: ALPS - refactor alps_set_abs_params_mt()
Input: elantech - fix absolute mode setting on some ASUS laptops
Input: atmel_mxt_ts - split out touchpad initialisation logic
Input: atmel_mxt_ts - implement support for T100 touch object
Input: cros_ec_keyb - fix clearing keyboard state on wakeup
Input: gscps2 - drop pci_ids dependency
Input: synaptics - allocate 3 slots to keep stability in image sensors
Input: Revert "Revert "synaptics - use dmax in input_mt_assign_slots""
Input: MT - make slot assignment work for overcovered solutions
mfd: tc3589x: enforce device-tree only mode
Input: tc3589x - localize platform data
Input: tsc2007 - Convert msecs to jiffies only once
Input: edt-ft5x06 - remove EV_SYN event report
Input: edt-ft5x06 - allow to setting the maximum axes value through the DT
'for-4.1/huion-uclogic-merge', 'for-4.1/i2c-hid', 'for-4.1/kconfig-drop-expert-dependency', 'for-4.1/logitech', 'for-4.1/multitouch', 'for-4.1/rmi', 'for-4.1/sony', 'for-4.1/upstream' and 'for-4.1/wacom' into for-linus
In the unlikely case of hdev vanishing while hid_debug_events_read() was
sleeping, we can't really break out of the case switch as with other cases,
as on the way out we'll try to remove ourselves from the hdev waitqueue.
Fix this by taking a shortcut exit path and avoiding cleanup that doesn't
make sense in case hdev doesn't exist any more anyway.
Reported-by: Jiri Slaby <jslaby@suse.cz>
According to [1], Windows Precision Touchpad devices must supply
a button type usage in the device capabilities feature report. A
value of 0 indicates that the device contains a depressible
button (i.e. it's a click-pad) whereas a value of 1 indicates
a non-depressible button. Add support for this usage and set
INPUT_PROP_BUTTONPAD on the touchpad input device whenever a
depressible button is present.
[1] https://msdn.microsoft.com/en-us/library/windows/hardware/dn467314(v=vs.85).aspx
Signed-off-by: Seth Forshee <seth.forshee@canonical.com>
Signed-off-by: Stefan Brüns <stefan.bruens@rwth-aachen.de>
Acked-by: Jiri Kosina <jkosina@suse.cz>
Add keyboard input assist controls usages from approved
hid usage table request HUTTR42:
http://www.usb.org/developers/hidpage/HUTRR42c.pdf
Signed-off-by: Olivier Gay <ogay@logitech.com>
Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
On Feb 17, 2014, two new usages are approved to HID usage Table 18 -
Digitizer Page:
5A Secondary Barrel Switch MC 16.4
5B Transducer Serial Number SV 16.3.1
This patch adds relevant definitions to hid/input. It also removes
outdated comments in hid.h.
Signed-off-by: Ping Cheng <pingc@wacom.com>
Add in debugfs report descriptor labels for HID Sensor Usages.
Signed-off-by: Reyad Attiyat <reyad.attiyat@gmail.com>
Add some missing hid usages from consumer page, add
some display brightness control usages from approved hid usage
table request HUTTR41:
http://www.usb.org/developers/hidpage/HUTRR41.pdf
and add voice command usage from approved request HUTTR45:
http://www.usb.org/developers/hidpage/Voice_Command_Usage.pdf
[jkosina@suse.cz: removed KEY_BRIGHTNESS_TOGGLE / KEY_DISPLAYTOGGLE
conflict from hid-debug.c]
Signed-off-by: Mathieu Meisser <mmeisser@logitech.com>
Add labels for BTN_DPAD_UP, BTN_DPAD_DOWN, BTN_DPAD_LEFT, BTN_DPAD_RIGHT and
BTN_TOOL_QUADTAP.
[jkosina@suse.cz: make changelog more verbose]
Signed-off-by: Antonio Ospite <ospite@studenti.unina.it>
Commit 2353f2bea ("HID: protect hid_debug_list") introduced mutex
locking around debug_list access to prevent SMP races when debugfs
nodes are being operated upon by multiple userspace processess.
mutex is not a proper synchronization primitive though, as the hid-debug
callbacks are being called from atomic contexts.
We also have to be careful about disabling IRQs when taking the lock
to prevent deadlock against IRQ handlers.
Benjamin reports this has also been reported in RH bugzilla as bug #958935.
[ INFO: suspicious RCU usage. ]
3.9.0+ #94 Not tainted
include/linux/rcupdate.h:476 Illegal context switch in RCU read-side critical section!
rcu_scheduler_active = 1, debug_locks = 0
4 locks held by Xorg/5502:
#0: (&evdev->mutex){+.+...}, at: [<ffffffff81512c3d>] evdev_write+0x6d/0x160
#1: (&(&dev->event_lock)->rlock#2){-.-...}, at: [<ffffffff8150dd9b>] input_inject_event+0x5b/0x230
#2: (rcu_read_lock){.+.+..}, at: [<ffffffff8150dd82>] input_inject_event+0x42/0x230
#3: (&(&usbhid->lock)->rlock){-.....}, at: [<ffffffff81565289>] usb_hidinput_input_event+0x89/0x120
stack backtrace:
CPU: 0 PID: 5502 Comm: Xorg Not tainted 3.9.0+ #94
Hardware name: Dell Inc. OptiPlex 390/0M5DCD, BIOS A09 07/24/2012
0000000000000001 ffff8800689c7c38 ffffffff816f249f ffff8800689c7c68
ffffffff810acb1d 0000000000000000 ffffffff81a03ac7 000000000000019d
0000000000000000 ffff8800689c7c90 ffffffff8107cda7 0000000000000000
Call Trace:
[<ffffffff816f249f>] dump_stack+0x19/0x1b
[<ffffffff810acb1d>] lockdep_rcu_suspicious+0xfd/0x130
[<ffffffff8107cda7>] __might_sleep+0xc7/0x230
[<ffffffff816f7770>] mutex_lock_nested+0x40/0x3a0
[<ffffffff81312ac4>] ? vsnprintf+0x354/0x640
[<ffffffff81553cc4>] hid_debug_event+0x34/0x100
[<ffffffff81554197>] hid_dump_input+0x67/0xa0
[<ffffffff81556430>] hid_set_field+0x50/0x120
[<ffffffff8156529a>] usb_hidinput_input_event+0x9a/0x120
[<ffffffff8150d89e>] input_handle_event+0x8e/0x530
[<ffffffff8150df10>] input_inject_event+0x1d0/0x230
[<ffffffff8150dd82>] ? input_inject_event+0x42/0x230
[<ffffffff81512cae>] evdev_write+0xde/0x160
[<ffffffff81185038>] vfs_write+0xc8/0x1f0
[<ffffffff81185535>] SyS_write+0x55/0xa0
[<ffffffff81704482>] system_call_fastpath+0x16/0x1b
BUG: sleeping function called from invalid context at kernel/mutex.c:413
in_atomic(): 1, irqs_disabled(): 1, pid: 5502, name: Xorg
INFO: lockdep is turned off.
irq event stamp: 1098574
hardirqs last enabled at (1098573): [<ffffffff816fb53f>] _raw_spin_unlock_irqrestore+0x3f/0x70
hardirqs last disabled at (1098574): [<ffffffff816faaf5>] _raw_spin_lock_irqsave+0x25/0xa0
softirqs last enabled at (1098306): [<ffffffff8104971f>] __do_softirq+0x18f/0x3c0
softirqs last disabled at (1097867): [<ffffffff81049ad5>] irq_exit+0xa5/0xb0
ffffffff81a03ac7 ffff8800689c7c68 ffffffff816f249f ffff8800689c7c90
ffffffff8107ce60 0000000000000000 ffff8800689c7fd8 ffff88006a62c800
ffff8800689c7d10 ffffffff816f7770 ffff8800689c7d00 ffffffff81312ac4
Call Trace:
[<ffffffff8107ce60>] __might_sleep+0x180/0x230
Reported-by: majianpeng <majianpeng@gmail.com>
Reported-by: Benjamin Tissoires <benjamin.tissoires@gmail.com>
Reviewed-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Accesses to hid_device->hid_debug_list are not serialized properly, which
could result in SMP concurrency issues when HID debugfs events are accessesed
Serialize all the list operations by a mutex.
Spotted by Al Viro.
No semantic changes, but hid_dump_report should be in hid-debug.c, not
in hid-core.c
Signed-off-by: Benjamin Tissoires <benjamin.tissoires@redhat.com>
Since commit a7197c2e, the raw report descriptor is available also for
unclaimed devices. This patchs make it show in the rdesc debugfs node.
Signed-off-by: Henrik Rydberg <rydberg@euromail.se>
'upstream-fixes', 'wacom' and 'wiimote' into for-linus
The USB HID Usage Tables spec defines page 6 for Generic Device Controls, the
most useful of which (to me) is Battery Strength.
Signed-off-by: Jeremy Fitzhardinge <jeremy@goop.org>
With module.h being implicitly everywhere via device.h, the absence
of explicitly including something for EXPORT_SYMBOL went unnoticed.
Since we are heading to fix things up and clean module.h from the
device.h file, we need to explicitly include these files now.
Signed-off-by: jeffbrown@android.com
Reviewed-by: Benjamin Tissoires <benjamin.tissoires@logitech.com>
Neaten current uses of dev_<level> by adding and using
hid specific hid_<level> macros.
Convert existing uses of dev_<level> uses to hid_<level>.
Convert hid-pidff printk uses to hid_<level>.
Remove err_hid and use hid_err instead.
Add missing newlines to logging messages where necessary.
Coalesce format strings.
Add and use pr_fmt(fmt) KBUILD_MODNAME ": " fmt
Other miscellaneous changes:
Add const struct hid_device * argument to hid-core functions
extract() and implement() so hid_<level> can be used by them.
Fix bad indentation in hid-core hid_input_field function
that calls extract() function above.
All file_operations should get a .llseek operation so we can make
nonseekable_open the default for future file operations without a
.llseek pointer.
The three cases that we can automatically detect are no_llseek, seq_lseek
and default_llseek. For cases where we can we can automatically prove that
the file offset is always ignored, we use noop_llseek, which maintains
the current behavior of not returning an error from a seek.
New drivers should normally not use noop_llseek but instead use no_llseek
and call nonseekable_open at open time. Existing drivers can be converted
to do the same when the maintainer knows for certain that no user code
relies on calling seek on the device file.
The generated code is often incorrectly indented and right now contains
comments that clarify for each added line why a specific variant was
chosen. In the version that gets submitted upstream, the comments will
be gone and I will manually fix the indentation, because there does not
seem to be a way to do that using coccinelle.
Some amount of new code is currently sitting in linux-next that should get
the same modifications, which I will do at the end of the merge window.
Many thanks to Julia Lawall for helping me learn to write a semantic
patch that does all this.
===== begin semantic patch =====
// This adds an llseek= method to all file operations,
// as a preparation for making no_llseek the default.
// The rules are
// - use no_llseek explicitly if we do nonseekable_open
// - use seq_lseek for sequential files
// - use default_llseek if we know we access f_pos
// - use noop_llseek if we know we don't access f_pos,
// but we still want to allow users to call lseek
@ open1 exists @
identifier nested_open;
nested_open(...)
nonseekable_open(...)
@ open exists@
identifier open_f;
identifier i, f;
identifier open1.nested_open;
int open_f(struct inode *i, struct file *f)
nested_open(...)
@ read disable optional_qualifier exists @
identifier read_f;
identifier f, p, s, off;
type ssize_t, size_t, loff_t;
expression E;
identifier func;
ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ read_no_fpos disable optional_qualifier exists @
identifier read_f;
... when != off
@ write @
identifier write_f;
expression E;
identifier func;
ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ write_no_fpos @
identifier write_f;
... when != off
@ fops0 @
identifier fops;
struct file_operations fops = {
@ has_llseek depends on fops0 @
identifier fops0.fops;
identifier llseek_f;
.llseek = llseek_f,
@ has_read depends on fops0 @
identifier read_f;
.read = read_f,
@ has_write depends on fops0 @
identifier write_f;
.write = write_f,
@ has_open depends on fops0 @
identifier open_f;
.open = open_f,
// use no_llseek if we call nonseekable_open
@ nonseekable1 depends on !has_llseek && has_open @
identifier nso ~= "nonseekable_open";
... .open = nso, ...
+.llseek = no_llseek, /* nonseekable */
@ nonseekable2 depends on !has_llseek @
identifier open.open_f;
... .open = open_f, ...
+.llseek = no_llseek, /* open uses nonseekable */
// use seq_lseek for sequential files
@ seq depends on !has_llseek @
identifier sr ~= "seq_read";
... .read = sr, ...
+.llseek = seq_lseek, /* we have seq_read */
// use default_llseek if there is a readdir
@ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier readdir_e;
// any other fop is used that changes pos
... .readdir = readdir_e, ...
+.llseek = default_llseek, /* readdir is present */
// use default_llseek if at least one of read/write touches f_pos
@ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read.read_f;
// read fops use offset
... .read = read_f, ...
+.llseek = default_llseek, /* read accesses f_pos */
@ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier write.write_f;
// write fops use offset
... .write = write_f, ...
+ .llseek = default_llseek, /* write accesses f_pos */
// Use noop_llseek if neither read nor write accesses f_pos
@ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read_no_fpos.read_f;
identifier write_no_fpos.write_f;
.write = write_f,
.read = read_f,
+.llseek = noop_llseek, /* read and write both use no f_pos */
@ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* write uses no f_pos */
@ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* read uses no f_pos */
@ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* no read or write fn */
===== End semantic patch =====
Cc: Julia Lawall <julia@diku.dk>
Some devices poke the hid core in a way that causes hid_debug_event to
be called, while never calling hid_dump_input. Without this wakeup
addition, tasks reading for hid events through debugfs may never see any
events. It may be that a well written driver doesn't cause this, but
then what's the point of debugfs?
Signed-off-by: Chase Douglas <chase.douglas@canonical.com>
The path around the loop ends with the lock held, so the call to mutex_lock
is moved before the beginning of the loop.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
// <smpl>
@locked@
expression E1;
position p;
read_lock(E1@p,...);
@r exists@
expression x <= locked.E1;
expression locked.E1;
expression E2;
identifier lock;
position locked.p,p1,p2;
*lock@p1 (E1@p,...);
... when != E1
when != \(x = E2\|&x\)
*lock@p2 (E1,...);
// </smpl>
Signed-off-by: Daniel Mack <daniel@caiaq.de>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
When dumping /sys/kernel/debug/hid/$device/events '\0' characters show up
(invisible if cat to console but shown by less or while looking at a dump
file). These are due to hid_debug_event() adding strlen()+1 bytes to the ring
buffer (e.g. including the trailing '\0'). Any roll-over causes a '\0' as well
as hid_debug_event() handles the ring buffers with HID_DEBUG_BUFSIZE-1 size
while hid_debug_events_read() handles it with full HID_DEBUG_BUFSIZE size.
Signed-off-by: Bruno Prémont <bonbons@linux-vserver.org>
hid-debug.c: make local symbols static
The symbols hid_resolv_event and hid_dump_input_mapping
are only used locally in this file. Make them static to prevent
the following sparse warnings:
warning: symbol 'hid_resolv_event' was not declared. Should it be static?
warning: symbol 'hid_dump_input_mapping' was not declared. Should it be static?
Error handling code following a kzalloc should free the allocated data.
The semantic match that finds the problem is as follows:
(http://www.emn.fr/x-info/coccinelle/)
// <smpl>
@r exists@
local idexpression x;
statement S;
expression E;
identifier f,f1,l;
position p1,p2;
expression *ptr != NULL;
x@p1 = \(kmalloc\|kzalloc\|kcalloc\)(...);
if (x == NULL) S
<... when != x
when != if (...) { <+...x...+> }
x->f1 = E
(x->f1 == NULL || ...)
f(...,x->f1,...)
return \(0\|<+...x...+>\|ptr\);
return@p2 ...;
@script:python@
p1 << r.p1;
p2 << r.p2;
print "* file: %s kmalloc %s return %s" % (p1[0].file,p1[0].line,p2[0].line)
// </smpl>
Cc: Jiri Kosina <jkosina@suse.cz>
This is a followup patch to the one implemeting rdesc representation in debugfs
rather than being dependent on compile-time CONFIG_HID_DEBUG setting.
The API of the appropriate formatting functions is slightly modified -- if
they are passed seq_file pointer, the one-shot output for 'rdesc' file mode
is used, and therefore the message is formatted into the corresponding seq_file
immediately.
Otherwise the called function allocated a new buffer, formats the text into the
buffer and returns the pointer to it, so that it can be queued into the ring-buffer
of the processess blocked waiting on input on 'events' file in debugfs.
'debug' parameter to the 'hid' module is now used solely for the prupose of inetrnal
driver state debugging (parser, transport, etc).
It is a little bit inconvenient for people who have some non-standard
HID hardware (usually violating the HID specification) to have to
recompile kernel with CONFIG_HID_DEBUG to be able to see kernel's perspective
of the HID report descriptor and observe the parsed events. Plus the messages
are then mixed up inconveniently with the rest of the dmesg stuff.
This patch implements /sys/kernel/debug/hid/<device>/rdesc file, which
represents the kernel's view of report descriptor (both the raw report
descriptor data and parsed contents).
With all the device-specific debug data being available through debugfs, there
is no need for keeping CONFIG_HID_DEBUG, as the 'debug' parameter to the
hid module will now only output only driver-specific debugging options, which has
absolutely minimal memory footprint, just a few error messages and one global
flag (hid_debug).
We use the current set of output formatting functions. The ones that need to be
used both for one-shot rdesc seq_file and also for continuous flow of data
(individual reports, as being sent by the device) distinguish according to the
passed seq_file parameter, and if it is NULL, it still output to kernel ringbuffer,
otherwise the corresponding seq_file is used for output.
The format of the output is preserved.
Added constants to hid.h for all digitizer usages (including the new multitouch
ones that are not yet in the official USB spec but are being pushed by Microsft
as described in their paper "Digitizer Drivers for Windows Touch and Pen-Based
Computers"). Updated hid-debug.c to support the new MT input constants such as
ABS_MT_POSITION_X.
Signed-off-by: Stephane Chatty <chatty@enac.fr>
This patch removes CVS keywords that weren't updated for a long time
from comments.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Currently using debug=1 with hid module prints out all sent and received
reports to the kernel log, while in many cases we only want to see the
report descriptors and hid-input mappings that are printed when a device
is probed.
Add new level debug=2, and only dump the report traffic with that level.
Signed-off-by: Anssi Hannula <anssi.hannula@gmail.com>
HUT 1.12 defines Logoff usage 0x19c in Consumer page. There are
keyboards out there emitting this usage code (for example Microsoft
Wireless Laser Keyboard 6000). Add this key so that HID code could
map usages to it.
Signed-off-by: Khelben Blackstaff <eye.of.the.8eholder@gmail.com>
- added KERN_DEBUG to output lines
- fixed preffered -> preferred typo
- added const to char *'s
Also, exported symbol hid_resolv_event is unused by the current
kernel tree and perhaps should be removed.
This keyboard emits a few usages that are not handled properly by
hid-input.
The usages from MSVENDOR page are colliding with Chicony Tactical
Pad device, so we have to distinguish in runtime. Ugly ...
Also, the buttons 1-5 have to be handled in a non-standard way,
as they are emitted by the keyboard in a bitfield-like fashion, but
the field is not presented as bit-field by the keyboard. The keys can't
be pressed simultaneously, so the handling we have is correct.
This patch also extends hid_keyboard[] with KPLeftParenthesis and
KPRightParenthesis as defined by Keyboard page in HUT 1.12. The
corresponding usages are also emitted by this keyboard.
There have been many reports recently about broken HID devices, the
diagnosis of which required users to recompile their kernels in order
to be able to provide debugging output needed for coding a quirk for
a particular device.
This patch makes CONFIG_HID_DEBUG default y if !EMBEDDED and makes it
possible to control debugging output produced by HID code by supplying
'debug=1' module parameter.
Every file should include the headers containing the prototypes for
it's global functions.
CONFIG_INPUT_DEBUG is non-existent option, so remove anything depending
on it.
Also, as we have new CONFIG_HID_DEBUG, this should be used on places
where ifdef DEBUG was used before.
Suggested by Adrian Bunk.
hid-debug.h contains a lot of code, and should not therefore
be a header.
This patch moves the code to generic hid layer as .c source, and
introduces CONFIG_HID_DEBUG to conditionally compile it, instead
of playing with #define DEBUG and including hid-debug.h.
