path: root/drivers/hid/hid-debug.c
2010-12-10HID: Add and use hid_<level>: dev_<level> equivalentsJoe Perches
Neaten current uses of dev_<level> by adding and using hid specific hid_<level> macros. Convert existing uses of dev_<level> uses to hid_<level>. Convert hid-pidff printk uses to hid_<level>. Remove err_hid and use hid_err instead. Add missing newlines to logging messages where necessary. Coalesce format strings. Add and use pr_fmt(fmt) KBUILD_MODNAME ": " fmt Other miscellaneous changes: Add const struct hid_device * argument to hid-core functions extract() and implement() so hid_<level> can be used by them. Fix bad indentation in hid-core hid_input_field function that calls extract() function above. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-10-23Merge branches 'upstream' and 'upstream-fixes' into for-linusJiri Kosina
All file_operations should get a .llseek operation so we can make nonseekable_open the default for future file operations without a .llseek pointer. The three cases that we can automatically detect are no_llseek, seq_lseek and default_llseek. For cases where we can we can automatically prove that the file offset is always ignored, we use noop_llseek, which maintains the current behavior of not returning an error from a seek. New drivers should normally not use noop_llseek but instead use no_llseek and call nonseekable_open at open time. Existing drivers can be converted to do the same when the maintainer knows for certain that no user code relies on calling seek on the device file. The generated code is often incorrectly indented and right now contains comments that clarify for each added line why a specific variant was chosen. In the version that gets submitted upstream, the comments will be gone and I will manually fix the indentation, because there does not seem to be a way to do that using coccinelle. Some amount of new code is currently sitting in linux-next that should get the same modifications, which I will do at the end of the merge window. Many thanks to Julia Lawall for helping me learn to write a semantic patch that does all this. ===== begin semantic patch ===== // This adds an llseek= method to all file operations, // as a preparation for making no_llseek the default. // // The rules are // - use no_llseek explicitly if we do nonseekable_open // - use seq_lseek for sequential files // - use default_llseek if we know we access f_pos // - use noop_llseek if we know we don't access f_pos, // but we still want to allow users to call lseek // @ open1 exists @ identifier nested_open; @@ nested_open(...) { <+... nonseekable_open(...) ...+> } @ open exists@ identifier open_f; identifier i, f; identifier open1.nested_open; @@ int open_f(struct inode *i, struct file *f) { <+... ( nonseekable_open(...) | nested_open(...) ) ...+> } @ read disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ read_no_fpos disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { ... when != off } @ write @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ write_no_fpos @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { ... when != off } @ fops0 @ identifier fops; @@ struct file_operations fops = { ... }; @ has_llseek depends on fops0 @ identifier fops0.fops; identifier llseek_f; @@ struct file_operations fops = { ... .llseek = llseek_f, ... }; @ has_read depends on fops0 @ identifier fops0.fops; identifier read_f; @@ struct file_operations fops = { ... .read = read_f, ... }; @ has_write depends on fops0 @ identifier fops0.fops; identifier write_f; @@ struct file_operations fops = { ... .write = write_f, ... }; @ has_open depends on fops0 @ identifier fops0.fops; identifier open_f; @@ struct file_operations fops = { ... .open = open_f, ... }; // use no_llseek if we call nonseekable_open //////////////////////////////////////////// @ nonseekable1 depends on !has_llseek && has_open @ identifier fops0.fops; identifier nso ~= "nonseekable_open"; @@ struct file_operations fops = { ... .open = nso, ... +.llseek = no_llseek, /* nonseekable */ }; @ nonseekable2 depends on !has_llseek @ identifier fops0.fops; identifier open.open_f; @@ struct file_operations fops = { ... .open = open_f, ... +.llseek = no_llseek, /* open uses nonseekable */ }; // use seq_lseek for sequential files ///////////////////////////////////// @ seq depends on !has_llseek @ identifier fops0.fops; identifier sr ~= "seq_read"; @@ struct file_operations fops = { ... .read = sr, ... +.llseek = seq_lseek, /* we have seq_read */ }; // use default_llseek if there is a readdir /////////////////////////////////////////// @ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier readdir_e; @@ // any other fop is used that changes pos struct file_operations fops = { ... .readdir = readdir_e, ... +.llseek = default_llseek, /* readdir is present */ }; // use default_llseek if at least one of read/write touches f_pos ///////////////////////////////////////////////////////////////// @ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read.read_f; @@ // read fops use offset struct file_operations fops = { ... .read = read_f, ... +.llseek = default_llseek, /* read accesses f_pos */ }; @ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, ... + .llseek = default_llseek, /* write accesses f_pos */ }; // Use noop_llseek if neither read nor write accesses f_pos /////////////////////////////////////////////////////////// @ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; identifier write_no_fpos.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, .read = read_f, ... +.llseek = noop_llseek, /* read and write both use no f_pos */ }; @ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write_no_fpos.write_f; @@ struct file_operations fops = { ... .write = write_f, ... +.llseek = noop_llseek, /* write uses no f_pos */ }; @ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; @@ struct file_operations fops = { ... .read = read_f, ... +.llseek = noop_llseek, /* read uses no f_pos */ }; @ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; @@ struct file_operations fops = { ... +.llseek = noop_llseek, /* no read or write fn */ }; ===== End semantic patch ===== Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Julia Lawall <julia@diku.dk> Cc: Christoph Hellwig <hch@infradead.org>
2010-09-08HID: debugfs: wake up reading tasks upon eventChase Douglas
Some devices poke the hid core in a way that causes hid_debug_event to be called, while never calling hid_dump_input. Without this wakeup addition, tasks reading for hid events through debugfs may never see any events. It may be that a well written driver doesn't cause this, but then what's the point of debugfs? Signed-off-by: Chase Douglas <chase.douglas@canonical.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-06-21HID: eliminate a double lock in debug codeJulia Lawall
The path around the loop ends with the lock held, so the call to mutex_lock is moved before the beginning of the loop. A simplified version of the semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @locked@ expression E1; position p; @@ read_lock(E1@p,...); @r exists@ expression x <= locked.E1; expression locked.E1; expression E2; identifier lock; position locked.p,p1,p2; @@ *lock@p1 (E1@p,...); ... when != E1 when != \(x = E2\|&x\) *lock@p2 (E1,...); // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-05-20Input: use ABS_CNT rather than (ABS_MAX + 1)Daniel Mack
Signed-off-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-16HID: avoid '\0' in hid debugfs events fileBruno Prémont
When dumping /sys/kernel/debug/hid/$device/events '\0' characters show up (invisible if cat to console but shown by less or while looking at a dump file). These are due to hid_debug_event() adding strlen()+1 bytes to the ring buffer (e.g. including the trailing '\0'). Any roll-over causes a '\0' as well as hid_debug_event() handles the ring buffers with HID_DEBUG_BUFSIZE-1 size while hid_debug_events_read() handles it with full HID_DEBUG_BUFSIZE size. Signed-off-by: Bruno Prémont <bonbons@linux-vserver.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-01-15HID: hid-debug.c: make local symbols staticH Hartley Sweeten
hid-debug.c: make local symbols static The symbols hid_resolv_event and hid_dump_input_mapping are only used locally in this file. Make them static to prevent the following sparse warnings: warning: symbol 'hid_resolv_event' was not declared. Should it be static? warning: symbol 'hid_dump_input_mapping' was not declared. Should it be static? Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-09-13Merge branches 'upstream', 'upstream-fixes' and 'debugfs' into for-linusJiri Kosina
2009-08-08HID: fix memory leak on error patch in debug codeJulia Lawall
Error handling code following a kzalloc should free the allocated data. The semantic match that finds the problem is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @r exists@ local idexpression x; statement S; expression E; identifier f,f1,l; position p1,p2; expression *ptr != NULL; @@ x@p1 = \(kmalloc\|kzalloc\|kcalloc\)(...); ... if (x == NULL) S <... when != x when != if (...) { <+...x...+> } ( x->f1 = E | (x->f1 == NULL || ...) | f(...,x->f1,...) ) ...> ( return \(0\|<+...x...+>\|ptr\); | return@p2 ...; ) @script:python@ p1 << r.p1; p2 << r.p2; @@ print "* file: %s kmalloc %s return %s" % (p1[0].file,p1[0].line,p2[0].line) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Cc: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-06-12HID: use debugfs for events/reports dumpingJiri Kosina
This is a followup patch to the one implemeting rdesc representation in debugfs rather than being dependent on compile-time CONFIG_HID_DEBUG setting. The API of the appropriate formatting functions is slightly modified -- if they are passed seq_file pointer, the one-shot output for 'rdesc' file mode is used, and therefore the message is formatted into the corresponding seq_file immediately. Otherwise the called function allocated a new buffer, formats the text into the buffer and returns the pointer to it, so that it can be queued into the ring-buffer of the processess blocked waiting on input on 'events' file in debugfs. 'debug' parameter to the 'hid' module is now used solely for the prupose of inetrnal driver state debugging (parser, transport, etc). Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-06-12HID: use debugfs for report dumping descriptorJiri Kosina
It is a little bit inconvenient for people who have some non-standard HID hardware (usually violating the HID specification) to have to recompile kernel with CONFIG_HID_DEBUG to be able to see kernel's perspective of the HID report descriptor and observe the parsed events. Plus the messages are then mixed up inconveniently with the rest of the dmesg stuff. This patch implements /sys/kernel/debug/hid/<device>/rdesc file, which represents the kernel's view of report descriptor (both the raw report descriptor data and parsed contents). With all the device-specific debug data being available through debugfs, there is no need for keeping CONFIG_HID_DEBUG, as the 'debug' parameter to the hid module will now only output only driver-specific debugging options, which has absolutely minimal memory footprint, just a few error messages and one global flag (hid_debug). We use the current set of output formatting functions. The ones that need to be used both for one-shot rdesc seq_file and also for continuous flow of data (individual reports, as being sent by the device) distinguish according to the passed seq_file parameter, and if it is NULL, it still output to kernel ringbuffer, otherwise the corresponding seq_file is used for output. The format of the output is preserved. Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-05-20HID: add new multitouch and digitizer contantsStephane Chatty
Added constants to hid.h for all digitizer usages (including the new multitouch ones that are not yet in the official USB spec but are being pushed by Microsft as described in their paper "Digitizer Drivers for Windows Touch and Pen-Based Computers"). Updated hid-debug.c to support the new MT input constants such as ABS_MT_POSITION_X. Signed-off-by: Stephane Chatty <chatty@enac.fr> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2008-05-20HID: remove CVS keywordsAdrian Bunk
This patch removes CVS keywords that weren't updated for a long time from comments. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2008-04-22HID: only dump report traffic with debug level 2Anssi Hannula
Currently using debug=1 with hid module prints out all sent and received reports to the kernel log, while in many cases we only want to see the report descriptors and hid-input mappings that are printed when a device is probed. Add new level debug=2, and only dump the report traffic with that level. Signed-off-by: Anssi Hannula <anssi.hannula@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2007-10-14Input: add KEY_LOGOFFKhelben Blackstaff
HUT 1.12 defines Logoff usage 0x19c in Consumer page. There are keyboards out there emitting this usage code (for example Microsoft Wireless Laser Keyboard 6000). Add this key so that HID code could map usages to it. Signed-off-by: Khelben Blackstaff <eye.of.the.8eholder@gmail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2007-10-14HID: trivial fixes in hid-debugJoe Perches
- added KERN_DEBUG to output lines - fixed preffered -> preferred typo - added const to char *'s Also, exported symbol hid_resolv_event is unused by the current kernel tree and perhaps should be removed. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2007-10-14HID: add support for Microsoft Natural Ergonomic Keyboard 4000Jiri Kosina
This keyboard emits a few usages that are not handled properly by hid-input. The usages from MSVENDOR page are colliding with Chicony Tactical Pad device, so we have to distinguish in runtime. Ugly ... Also, the buttons 1-5 have to be handled in a non-standard way, as they are emitted by the keyboard in a bitfield-like fashion, but the field is not presented as bit-field by the keyboard. The keys can't be pressed simultaneously, so the handling we have is correct. This patch also extends hid_keyboard[] with KPLeftParenthesis and KPRightParenthesis as defined by Keyboard page in HUT 1.12. The corresponding usages are also emitted by this keyboard. Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2007-07-09HID: make debugging output runtime-configurableJiri Kosina
There have been many reports recently about broken HID devices, the diagnosis of which required users to recompile their kernels in order to be able to provide debugging output needed for coding a quirk for a particular device. This patch makes CONFIG_HID_DEBUG default y if !EMBEDDED and makes it possible to control debugging output produced by HID code by supplying 'debug=1' module parameter. Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2007-03-01HID: hid-debug.c should #include <linux/hid-debug.h>Adrian Bunk
Every file should include the headers containing the prototypes for it's global functions. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2007-02-05HID: move away from DEBUG defines in favor of CONFIG_HID_DEBUGJiri Kosina
CONFIG_INPUT_DEBUG is non-existent option, so remove anything depending on it. Also, as we have new CONFIG_HID_DEBUG, this should be used on places where ifdef DEBUG was used before. Suggested by Adrian Bunk. Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2007-02-05HID: hid debug from hid-debug.h to hid layerJiri Kosina
hid-debug.h contains a lot of code, and should not therefore be a header. This patch moves the code to generic hid layer as .c source, and introduces CONFIG_HID_DEBUG to conditionally compile it, instead of playing with #define DEBUG and including hid-debug.h. Signed-off-by: Jiri Kosina <jkosina@suse.cz>
