path: root/drivers/hid/hid-debug.c
2009-09-13Merge branches 'upstream', 'upstream-fixes' and 'debugfs' into for-linusJiri Kosina
2009-08-08HID: fix memory leak on error patch in debug codeJulia Lawall
Error handling code following a kzalloc should free the allocated data. The semantic match that finds the problem is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @r exists@ local idexpression x; statement S; expression E; identifier f,f1,l; position p1,p2; expression *ptr != NULL; @@ x@p1 = \(kmalloc\|kzalloc\|kcalloc\)(...); ... if (x == NULL) S <... when != x when != if (...) { <+...x...+> } ( x->f1 = E | (x->f1 == NULL || ...) | f(...,x->f1,...) ) ...> ( return \(0\|<+...x...+>\|ptr\); | return@p2 ...; ) @script:python@ p1 << r.p1; p2 << r.p2; @@ print "* file: %s kmalloc %s return %s" % (p1[0].file,p1[0].line,p2[0].line) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Cc: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-06-12HID: use debugfs for events/reports dumpingJiri Kosina
This is a followup patch to the one implemeting rdesc representation in debugfs rather than being dependent on compile-time CONFIG_HID_DEBUG setting. The API of the appropriate formatting functions is slightly modified -- if they are passed seq_file pointer, the one-shot output for 'rdesc' file mode is used, and therefore the message is formatted into the corresponding seq_file immediately. Otherwise the called function allocated a new buffer, formats the text into the buffer and returns the pointer to it, so that it can be queued into the ring-buffer of the processess blocked waiting on input on 'events' file in debugfs. 'debug' parameter to the 'hid' module is now used solely for the prupose of inetrnal driver state debugging (parser, transport, etc). Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-06-12HID: use debugfs for report dumping descriptorJiri Kosina
It is a little bit inconvenient for people who have some non-standard HID hardware (usually violating the HID specification) to have to recompile kernel with CONFIG_HID_DEBUG to be able to see kernel's perspective of the HID report descriptor and observe the parsed events. Plus the messages are then mixed up inconveniently with the rest of the dmesg stuff. This patch implements /sys/kernel/debug/hid/<device>/rdesc file, which represents the kernel's view of report descriptor (both the raw report descriptor data and parsed contents). With all the device-specific debug data being available through debugfs, there is no need for keeping CONFIG_HID_DEBUG, as the 'debug' parameter to the hid module will now only output only driver-specific debugging options, which has absolutely minimal memory footprint, just a few error messages and one global flag (hid_debug). We use the current set of output formatting functions. The ones that need to be used both for one-shot rdesc seq_file and also for continuous flow of data (individual reports, as being sent by the device) distinguish according to the passed seq_file parameter, and if it is NULL, it still output to kernel ringbuffer, otherwise the corresponding seq_file is used for output. The format of the output is preserved. Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-05-20HID: add new multitouch and digitizer contantsStephane Chatty
Added constants to hid.h for all digitizer usages (including the new multitouch ones that are not yet in the official USB spec but are being pushed by Microsft as described in their paper "Digitizer Drivers for Windows Touch and Pen-Based Computers"). Updated hid-debug.c to support the new MT input constants such as ABS_MT_POSITION_X. Signed-off-by: Stephane Chatty <chatty@enac.fr> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2008-05-20HID: remove CVS keywordsAdrian Bunk
This patch removes CVS keywords that weren't updated for a long time from comments. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2008-04-22HID: only dump report traffic with debug level 2Anssi Hannula
Currently using debug=1 with hid module prints out all sent and received reports to the kernel log, while in many cases we only want to see the report descriptors and hid-input mappings that are printed when a device is probed. Add new level debug=2, and only dump the report traffic with that level. Signed-off-by: Anssi Hannula <anssi.hannula@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2007-10-14Input: add KEY_LOGOFFKhelben Blackstaff
HUT 1.12 defines Logoff usage 0x19c in Consumer page. There are keyboards out there emitting this usage code (for example Microsoft Wireless Laser Keyboard 6000). Add this key so that HID code could map usages to it. Signed-off-by: Khelben Blackstaff <eye.of.the.8eholder@gmail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2007-10-14HID: trivial fixes in hid-debugJoe Perches
- added KERN_DEBUG to output lines - fixed preffered -> preferred typo - added const to char *'s Also, exported symbol hid_resolv_event is unused by the current kernel tree and perhaps should be removed. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2007-10-14HID: add support for Microsoft Natural Ergonomic Keyboard 4000Jiri Kosina
This keyboard emits a few usages that are not handled properly by hid-input. The usages from MSVENDOR page are colliding with Chicony Tactical Pad device, so we have to distinguish in runtime. Ugly ... Also, the buttons 1-5 have to be handled in a non-standard way, as they are emitted by the keyboard in a bitfield-like fashion, but the field is not presented as bit-field by the keyboard. The keys can't be pressed simultaneously, so the handling we have is correct. This patch also extends hid_keyboard[] with KPLeftParenthesis and KPRightParenthesis as defined by Keyboard page in HUT 1.12. The corresponding usages are also emitted by this keyboard. Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2007-07-09HID: make debugging output runtime-configurableJiri Kosina
There have been many reports recently about broken HID devices, the diagnosis of which required users to recompile their kernels in order to be able to provide debugging output needed for coding a quirk for a particular device. This patch makes CONFIG_HID_DEBUG default y if !EMBEDDED and makes it possible to control debugging output produced by HID code by supplying 'debug=1' module parameter. Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2007-03-01HID: hid-debug.c should #include <linux/hid-debug.h>Adrian Bunk
Every file should include the headers containing the prototypes for it's global functions. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2007-02-05HID: move away from DEBUG defines in favor of CONFIG_HID_DEBUGJiri Kosina
CONFIG_INPUT_DEBUG is non-existent option, so remove anything depending on it. Also, as we have new CONFIG_HID_DEBUG, this should be used on places where ifdef DEBUG was used before. Suggested by Adrian Bunk. Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2007-02-05HID: hid debug from hid-debug.h to hid layerJiri Kosina
hid-debug.h contains a lot of code, and should not therefore be a header. This patch moves the code to generic hid layer as .c source, and introduces CONFIG_HID_DEBUG to conditionally compile it, instead of playing with #define DEBUG and including hid-debug.h. Signed-off-by: Jiri Kosina <jkosina@suse.cz>
