commit d9d4b1e46d9543a82c23f6df03f4ad697dab361b upstream.
The syzbot fuzzer found a slab-out-of-bounds write bug in the hid-gaff
driver. The problem is caused by the driver's assumption that the
device must have an input report. While this will be true for all
normal HID input devices, a suitably malicious device can violate the
assumption.
The same assumption is present in over a dozen other HID drivers.
This patch fixes them by checking that the list of hid_inputs for the
hid_device is nonempty before allowing it to be used.
Reported-and-tested-by: syzbot+403741a091bf41d4ae79@syzkaller.appspotmail.com
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
CC: <stable@vger.kernel.org>
Signed-off-by: Benjamin Tissoires <benjamin.tissoires@redhat.com>
This allows the hid drivers to be independent from the transport layer.
The patch was constructed by replacing all occurences of
usbhid_submit_report() by its hid_hw_request() counterpart.
Then, drivers not requiring USB_HID anymore have their USB_HID
dependency cleaned in the Kconfig file.
Finally, few drivers still depends on USB_HID. Many of them
are requiring the io wait callback. They are found in the next patch.
Signed-off-by: Benjamin Tissoires <benjamin.tissoires@gmail.com>
Reviewed-by: Mika Westerberg <mika.westerberg@linux.intel.com>
For the sensor-hub part:
Tested-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Use the new module_hid_driver macro in all HID drivers that have
a simple register/unregister init/exit.
This also converts the hid drivers that test for a failure of
hid_register_driver() and report the failure. Using module_hid_driver
in those drivers removes the failure message.
A pending cleanup will mean that module.h won't be implicitly
everywhere anymore. Make sure the modular drivers in clocksource
are actually calling out for <module.h> explicitly in advance.
Neaten current uses of dev_<level> by adding and using
hid specific hid_<level> macros.
Convert existing uses of dev_<level> uses to hid_<level>.
Convert hid-pidff printk uses to hid_<level>.
Remove err_hid and use hid_err instead.
Add missing newlines to logging messages where necessary.
Coalesce format strings.
Add and use pr_fmt(fmt) KBUILD_MODNAME ": " fmt
Other miscellaneous changes:
Add const struct hid_device * argument to hid-core functions
extract() and implement() so hid_<level> can be used by them.
Fix bad indentation in hid-core hid_input_field function
that calls extract() function above.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Currently, the hid-*ff force feedback drivers, which claim the blacklisted
device on a HID bus, are only compiled in if the user selects force feedback
support.
However we want the device to be supported even when the kernel is configured
without force feedback.
This patch fixes the drivers in a way that they get compiled even if force
feedback is turned off; all the force feedback support code is compiled out in
such case, and the driver works as a usual driver on HID bus, claiming and
initializing the device, making it operational without FF effects.
Reported-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi>
This removal was scheduled and there is no problem with later
distros to adapt for the new bus, thanks to aliases.
module-init-tools map files are deprecated nowadays, so that
the patch which introduced hid ones into the m-i-t won't be
accepted and hence there is no reason for leaving compat stuff in.
Signed-off-by: Jiri Slaby <jirislaby@gmail.com>
Cc: Jiri Kosina <jkosina@suse.cz>
I have implemented Force Feedback driver for another "GreeAsia" based device
(0e8f:0012 "GreenAsia Inc. USB Joystick"). The functionality was tested with
MANTA Warior MM816 and SpeedLink Strike2 SL-6635 and fftest software -
everything seems to work right.
Signed-off-by: Lukasz Lubojanski <lukasz@lubojanski.info>
