commit d9d4b1e46d9543a82c23f6df03f4ad697dab361b upstream.
The syzbot fuzzer found a slab-out-of-bounds write bug in the hid-gaff
driver. The problem is caused by the driver's assumption that the
device must have an input report. While this will be true for all
normal HID input devices, a suitably malicious device can violate the
assumption.
The same assumption is present in over a dozen other HID drivers.
This patch fixes them by checking that the list of hid_inputs for the
hid_device is nonempty before allowing it to be used.
Reported-and-tested-by: syzbot+403741a091bf41d4ae79@syzkaller.appspotmail.com
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
CC: <stable@vger.kernel.org>
Signed-off-by: Benjamin Tissoires <benjamin.tissoires@redhat.com>
[ Upstream commit 1f87b0cd32b3456d7efdfb017fcf74d0bfe3ec29 ]
According to hidpp20_batterylevel_get_battery_info my Logitech K270
keyboard reports only 2 battery levels. This matches with what I've seen
after testing with batteries at varying level of fullness, it always
reports either 5% or 30%.
Windows reports "battery good" for the 30% level. I've captured an USB
trace of Windows reading the battery and it is getting the same info
as the Linux hidpp code gets.
Now that Linux handles these devices as hidpp devices, it reports the
battery as being low as it treats anything under 31% as low, this leads
to the user constantly getting a "Keyboard battery is low" warning from
GNOME3, which is very annoying.
This commit fixes this by changing the low threshold to anything under
30%, which I assume is what Windows does.
[ Upstream commit 096377525cdb8251e4656085efc988bdf733fb4c ]
According to the logitech_hidpp_2.0_specification_draft_2012-06-04.pdf doc:
https://lekensteyn.nl/files/logitech/logitech_hidpp_2.0_specification_draft_2012-06-04.pdf
We should use a register-access-protocol request using the short input /
output report ids. This is necessary because 27MHz HID++ receivers have
a max-packetsize on their HIP++ endpoint of 8, so they cannot support
long reports. Using a feature-access-protocol request (which is always
long or very-long) with these will cause a timeout error, followed by
the hidpp driver treating the device as not being HID++ capable.
This commit fixes this by switching to using a rap request to get the
protocol version.
Besides being tested with a (046d:c517) 27MHz receiver with various
27MHz keyboards and mice, this has also been tested to not cause
regressions on a non-unifying dual-HID++ nano receiver (046d:c534) with
k270 and m185 HID++-2.0 devices connected and on a unifying/dj receiver
(046d:c52b) with a HID++-2.0 Logitech Rechargeable Touchpad T650.
[ Upstream commit 6c44b15e1c9076d925d5236ddadf1318b0a25ce2 ]
create_singlethread_workqueue may fail and return NULL. The fix checks if it is
NULL to avoid NULL pointer dereference. Also, the fix moves the call of
create_singlethread_workqueue earlier to avoid resource-release issues.
Signed-off-by: Kangjie Lu <kjlu@umn.edu>
attribute_group are not supposed to change at runtime. All functions
working with attribute_group provided by <linux/sysfs.h> work with
const attribute_group. So mark the non-const structs as const.
Signed-off-by: Arvind Yadav <arvind.yadav.cs@gmail.com>
Check return value from call to devm_kmemdup() in order to prevent a NULL
Signed-off-by: Gustavo A. R. Silva <garsilva@embeddedor.com>
Reviewed-by: Benjamin Tissoires <benjamin.tissoires@redhat.com>
This way, upower can add a simple udev rule to decide whether or not
it should use the internal unifying support or just the generic kernel
one.
Tested-by: Bastien Nocera <hadess@hadess.net>
Also enable battery reporting for HID++ 1.0 devices through 2 registers:
0x07: battery status -> reports only 4 levels (critical, low, good, full)
0x0D: battery mileage -> reports true pourcentage
The Solar Keyboard uses a different feature to report the battery level.
CAPACITY LEVEL allows to forward rough information on the battery mileage.
HID++ 2.0 devices will either report percentage or levels, so better
forwarding this information to the user space.
The M325 supports only 2 levels: 'Full' and 'Critical'. With mileage,
it will report either 90% or 5%, which might confuse users. With this
change the battery will either report "Full" or "Critical".
The power_supply term for the percentage is capacity. Capacity level
can be given when non accurate mileage is provided by the device, so
better stick to the terms used in power_supply.
When ONLINE isn't set, upower should ignore the battery capacity,
so there is no need to overload it with some random values.
When a device reconnects, there is a high chance its power supply has
been changed (for a battery replacement for instance). Just forward
the battery state here.
Or the device just answers a valid feature '0'.
The creation of the power_supply should not be in a HID++ 2.0 specific
function.
Better forwarding the device name, manufacturer and serial to upower.
Note that serial is still empty, it will be filled in a later patch
in this series.
Battery events are reported through HID++, so we need to be sure
the report ID is the HID++ one.
Without this, we might receive keyboard events that looks just like
battery events with wrong data and which will confuse user space.
Looks like all users don't care about a disconnect.
Simplify the various variant_connect() and put the connect state check
at the beginning.
For delayed input devices, make sure we go through all other connect
values (protocol, battery) before bailing out.
hidpp->name can't be null.
Only HID++ 2.0 and above device supports the query.
Unifying devices are different from others because they can probed
while not connected. So we need to talk to the receiver to get some
extra information like the device name and the serial.
Instead of having conditionals while attempting to read the device name
from HID++ 2.0, have a special init path for them.
Store the retrieved serial in hdev->uniq.
Do not pollute the quirks bits field which is public API
with elements that are queried from the device.
Move the 2 battery capabilities into the new field.
Unless they are connected through unifying, they don't support it,
so remove one error in the logs.
Simple check to add, huge improvement :)
Without a scope defined, UPower assumes that the battery provides
power to the computer it's connected to, like a laptop battery or a UPS.
Tested-by: Peter Hutterer <peter.hutterer@who-t.net>
Signed-off-by: Bastien Nocera <hadess@hadess.net>
Now that we can create battery power_supply sources, it's better to enable
the connect_event callback unconditionally.
Signed-off-by: Peter Hutterer <peter.hutterer@who-t.net>
If the 0x1000 Unified Battery Level Status feature exists, expose the battery
level.
The main drawback is that while a device is plugged in its battery level is 0.
To avoid exposing that as 0% charge we make up a number based on the charging
status.
hidpp_ff_init() and hidpp_ff_deinit() are not used outside of
hid-logitech-hidpp.c, so let's make them static.
This patch implements force feedback support for the Logitech
G920 Driving Force Racing Wheel. It is a generic implementation
of feature 0x8123 of the Logitech HID++ protocol and should be
usable for any future devices that implement this feature.
This patch should be applied after the basic G920 support patch
by Simon Wood:
http://www.spinics.net/lists/linux-input/msg42174.html
The driving supports everything that is supported by the G920
firmware:
FF_CONSTANT
FF_PERIODIC
FF_SINE
FF_SQUARE
FF_SAW_UP
FF_SAW_DOWN
FF_TRIANGLE
FF_SPRING
FF_DAMPER
FF_AUTOCENTER
FF_GAIN
and for version 2 firmware also:
FF_FRICTION
FF_INERTIA
FF_RAMP
Both envelopes and replay values are supported as well, but some
problems may occur when using firmware release 1. There is also a
small residual clockwise damper in the wheel when using the first
firmware release. All problems are fixed in the soon te be released
firmware version 2.
The default spring is disabled by permanently placing a spring
force in the wheel. This spring is also used as the autocenter
spring.
Note: The wheel _DOES_NOT_ auto switch to Logitech/HID mode (it is stuck
in XBox since the xpad changes where not included). Michal has an
alternative approach documented here (and the changes should be submitted
upstream to usb_modeswitch project):
Create a file named "046d:c261" in "/etc/usb_modeswitch.d" with the
following content:
DefaultVendor=046d
DefaultProduct=c261
MessageEndpoint=01
ResponseEndpoint=01
TargetClass=0x03
MessageContent="0f00010142"
Then run "usb_modeswitch -c /etc/modeswitch.d/046d:c291" as root and
watch the magic happen:)
[jkosina@suse.cz: added information about mode switching from Simon]
[jkosina@suse.cz: fixed a few stylistic issues pointed out by Simon]
[jkosina@suse.cz: fix merge conflict due to to_hid_device() changes]
Signed-off-by: Edwin Velds <e.velds@gmail.com>
Tested-by: Elias Vanderstuyft <elias.vds@gmail.com>
Tested-by: Simon Wood <simon@mungewell.org>
to_hid_device() macro is defined in both hid-lg4ff.c and
hid-logitech-hidpp.c. So I move it to include/linux/hid.h.
Signed-off-by: Geliang Tang <geliangtang@163.com>
Ensure that the G920 is not given the default deadzones.
Signed-off-by: Simon Wood <simon@mungewell.org>
The G920 can adjust the amount of 'turn' it permits, this patch adds
a sysfs file 'range' to control this.
This patch adds basic support for the Logitech G920 wheel when in HID
mode. This wheel 'speaks' the HID++ protocol, and therefor is driven
with hid-logitech-hidpp.
At this stage the driver only shows that it can communicate with the
wheel by outputting the name discovered over HID++.
The normal HID functions work to give input functionality using
joystick/event interface.
Note: in 'hidpp_probe()' we have to start the hardware to get packets
flowing, the same might apply in future for other devices which don't
use the unifying protocol.
Patch add support for the 'very long' HID++ packets, which are
64 bytes in length.
'for-4.4/dragonrise', 'for-4.4/i2c-hid', 'for-4.4/logitech', 'for-4.4/microsoft', 'for-4.4/multitouch', 'for-4.4/roccat-sysfs-deprecation', 'for-4.4/upstream' and 'for-4.4/wacom' into for-linus
When configuring input device via input_configured callback we may
encounter errors (for example input_mt_init_slots() may fail). Instead
of continuing with half-initialized input device let's allow driver
indicate failures.
Signed-off-by: Jaikumar Ganesh <jaikumarg@android.com>
Signed-off-by: Arve Hjønnevåg <arve@android.com>
Reviewed-by: David Herrmann <dh.herrmann@gmail.com>
Acked-by: Nikolai Kondrashov <Nikolai.Kondrashov@redhat.com>
Acked-by: Andrew Duggan <aduggan@synaptics.com>
The Logitech K400 keyboard has an embedded touchpad which is seen as a
mouse from the OS point of view. There is a hardware shortcut to disable
tap-to-click but the setting is not remembered accross reset, annoying
some users.
We can toggle this feature from the host by using the feature 0x6010:
Touchpad FW items
Reported-by: BALATON Zoltan <balaton@eik.bme.hu>
Tested-by: BALATON Zoltan <balaton@eik.bme.hu>
HIDPP_QUIRK_DELAYED_INIT means two things currently:
- we want to delay the initialization process
- we do not want hid to create an input device based on the report
descriptor.
This should actually be 2 different quirks so we can have special connect
events while still having HID creating the input for us.
'for-4.2/logitech' into for-linus
drivers/hid/hid-logitech-hidpp.c
The Logitech M560 is a wireless mouse designed for windows 8 which uses
the unifying receiver.
Compared to a standard one, some buttons (the middle one and the
two ones placed on the side) are bound to a key combination
instead of a generating classic "mouse" button events.
The device shows up as a mouse and keyboard combination: when the middle
button is pressed it sends a key (as keyboard) combination, the same
happens for the two side button. The left/right/wheel work as expected
from a mouse. To complicate things further, the middle button sends
different keys combinations between odd and even presses.
In the "even" press it also sends a left click. But the worst thing
is that no event is generated when the middle button is released.
It is possible to re-configure the mouse sending a command (see function
m560_send_config_command()). After this command the mouse sends some
useful data when the buttons are pressed and/or released.
[jkosina@suse.cz: fix build breakage due to leftover from previous
patch version]
Signed-off-by: Goffredo Baroncelli <kreijack@inwind.it>
This reverts commit 3a61e97563d78a2ca10752902449570d8433ce76.
The Logitech TK820 seems to be affected by a firmware bug which
delays the sending of the keys (pressed, or released, which triggers
a key-repeat) while holding fingers on the touch sensor.
This behavior can be observed while using the mouse emulation mode
if the user moves the finger while typing (highly improbable though).
Holding the finger still while in the mouse emulation mode does
not trigger the key repeat problem.
So better keep things in their previous state to not have to
explain users that the new key-repeat bug they see is a "feature".
Furthermore, I noticed that I disabled the media keys whith
this patch. Sorry, my bad.
I think it is best to revert the patch, in all the current
versions it has been shipped.
Cc: <stable@vger.kernel.org> # v3.19 and above
Return a negative error code on failure.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
// <smpl>
identifier ret; expression e1,e2;
if (\(ret < 0\|ret != 0\))
{ ... return ret; }
ret = 0
... when != ret = e1
when != &ret
*if(...)
... when != ret = e2
when forall
return ret;
// </smpl>
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
The Logitech T650 used to report 3 fingers swipes to the up as a press on the
Super key. When we switched the touchpad to the raw mode, we also disable such
firmware gesture and some users may rely on it.
Unfortunately, 3 finger swipes are still not supported in most of the Linux
environments, which means that we disabled a feature of the touchpad.
Allow users to revert the raw reporting mode and keep going with the firmware
gestures by providing a new module parameter.
'for-3.20/betop', 'for-3.20/lenovo', 'for-3.20/logitech', 'for-3.20/rmi', 'for-3.20/upstream' and 'for-3.20/wacom' into for-linus
If a disconnect occurs while getting the actual name of the device
(which can take several HID transactions), the name of the device will
be the hid name, provided by the Unifying Receiver.
This means that in some cases, the user space will see a different
name that what it usually sees when there is no disconnect.
We should store the name of the device in the struct hidpp. That way,
if a disconnect occurs while we are accessing the name,
hidpp_connect_event() can fail, and the input node is not created.
The input node will be created only if we have a connection which
lasts long enough to retrieve all the requested information:
name, protocol, and specific configuration.
Reviewed-by: Peter Wu <peter@lekensteyn.nl>
Tested-by: Peter Wu <peter@lekensteyn.nl>
Current names are reported as "K750", "M705", and it can be misleading
for the users when they look at their input device list.
Prefixing the names with "Logitech " makes things better.
Add a return to avoid a fall-through. Introduced in commit
57ac86cf52e903d9e3e0f12b34c814cce6b65550 ("HID: logitech-hidpp: add
support of the first Logitech Wireless Touchpad").
Signed-off-by: Peter Wu <peter@lekensteyn.nl>
Devices speaking HID++ 2.0 report a different error code (0xff). Detect
these errors too to avoid 5 second delays when the device reports an
error. Caught by... well, a bug in the QEMU emulation of this receiver.
Renamed fap to rap for HID++ 1.0 errors because it is more logical,
it has no functional difference.
If wtp_connect() fails, that means most of the time that the device has
been disconnected. Subsequent attempts to contact the device will fail
too, so it's simpler to bail out earlier.
Previously wtp_raw_event would be called through
hidpp_raw_hidpp_event (for the touchpad report) and hidpp_raw_event
(for the mouse report).
This patch removes one calling surface, making a clearer distinction
between "generic HID++ processing" (matching internal reports) and
device-specific event processing.
Suggested-by: Benjamin Tissoires <benjamin.tissoires@redhat.com>
