path: root/drivers/hid/hid-roccat-common.h
2013-10-30HID: roccat: generalize some common codeStefan Achatz
Reduced some duplicate code by moving it to hid-roccat-common. Signed-off-by: Stefan Achatz <erazor_de@users.sourceforge.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-06-28HID: roccat: rename roccat_common functions to roccat_common2Stefan Achatz
Did this to illustrate my understanding of the firmware generations: Valo and Kone were 1st generation Arvo was externaly developed and lies in the middle All others until now are considered 2nd generation Signed-off-by: Stefan Achatz <erazor_de@users.sourceforge.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-06-28HID: roccat: move functionality to roccat-commonStefan Achatz
Reduced code duplication by moving functions from individual drivers to roccat-common module. Signed-off-by: Stefan Achatz <erazor_de@users.sourceforge.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-06-13HID: roccat: correction and cleanup of HID feature reportsStefan Achatz
Removed analog feature report enums and modified code in roccat_common to reflect this. Non standard conform Kone got its own copy of the old code. That helps extracting more generalizations for newer devices. Signed-off-by: Stefan Achatz <erazor_de@users.sourceforge.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-02-03HID: roccat: Introduce module hid-roccat-commonStefan Achatz
Module hid-roccat-common contains functions used by roccat device driver modules to reduce code duplication. At the moment it contains just two wrapper methods for usb_control_msg that ensure that the buffer used for transfer is dma capable which wasn't the case before. The kconfig option is not visible to the user but will be selected by the device specific drivers. Signed-off-by: Stefan Achatz <erazor_de@users.sourceforge.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
