path: root/drivers/hid/hid-roccat-kone.h
2011-06-13HID: roccat: correction and cleanup of HID feature reportsStefan Achatz
Removed analog feature report enums and modified code in roccat_common to reflect this. Non standard conform Kone got its own copy of the old code. That helps extracting more generalizations for newer devices. Signed-off-by: Stefan Achatz <erazor_de@users.sourceforge.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-01-08HID: roccat: don't use #pragma packJiri Kosina
Replace #pragma pack ocurences with __atribute__((__packed__)); Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-01-08HID: roccat: declare meaning of pack pragma usage in driver headersStefan Achatz
Using pack pragma to prevent padding bytes in binary data structures used for hardware communication. Explanation of these pragmas was requested. Signed-off-by: Stefan Achatz <erazor_de@users.sourceforge.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-06-21HID: roccat: remove obsolete kone_abi_version sysfs attributeStefan Achatz
The newest version of the accompanying userland tools cuts backward compatibility and uses libudev to find its devices superseding the quirky kone_abi_version sysfs attribute. Therefore it should be removed. Signed-off-by: Stefan Achatz <erazor_de@users.sourceforge.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-05-31HID: roccat: change kone_driver_version to kone_abi_versionStefan Achatz
Renamed the sysfs attribute kone_driver_version to kone_abi_version and simplified returned data to integer. Signed-off-by: Stefan Achatz <erazor_de@users.sourceforge.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-05-25HID: roccat: propagate special events of roccat hardware to userspaceStefan Achatz
Module roccat is a char device used to report special events of roccat hardware to userland. These events include requests for on-screen-display of profile or dpi settings or requests for execution of macro sequences that are not stored in device. The information in these events depends on hid device implementation and contains data that is not available in a single hid event or else hidraw could have been used. It is inspired by hidraw, but uses only one circular buffer for all readers. The device is as generic as possible so that the functionality is usable by all (kone and upcomming) roccat device drivers. Signed-off-by: Stefan Achatz <erazor_de@users.sourceforge.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-05-19HID: roccat: cleanup preprocessor macrosStefan Achatz
Removed useless preprocessor macros and renamed remaining one to be more qualified. Signed-off-by: Stefan Achatz <erazor_de@users.sourceforge.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-05-19HID: roccat: fix special button supportStefan Achatz
Added new data and changed workaround for abnormal button behaviour according to new gained knowledge about Roccat Kone device. Signed-off-by: Stefan Achatz <erazor_de@users.sourceforge.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-03-22HID: add driver for Roccat Kone gaming mouseStefan Achatz
This Patch adds support for Kone gaming mouse from Roccat. It provides access to profiles, settings, firmware, weight, actual settings etc. through sysfs attributes. Event handling of this mouse differs from standard hid behaviour in that tilt button press is reported in each move event which results in strange behaviour if not handled by the driver. This is a heavily reworked version of the previously introduced driver. The changes include most of the previously raised concerns, memory leak and other fixes, code cleanups, adoption of additional achieved knowlege about the hardware and is (IMHO) a much better version than before even when I exchanged reduced USB-IO with a bigger memory consumption. I refused to implement one mentioned point: Removing the 'just-because-we-can' attributes. Motivation: Reading the clipped in weight: I'm no gamer and can't determine the usefulness of this feature but if the manufacturer implements such a feature it might make sense to someone and I would unwillingly limit the functionality besides its such a small feature. Reading the actual profile and dpi settings: Here I can testify that one can get lost of the actual settings when switching back and forth. The manufacturers windows driver has the ability for on-screen-display of the values and there is a mouse in the market that has an lcd on the underside of it to show these values. So I think this feature makes sense not only for me and shouldn't be removed. Signed-off-by: Stefan Achatz <erazor_de@users.sourceforge.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
