commit 3d61510f4ecacfe47c75c0eb51c0659dfa77fb1b upstream.
This patch (as1365) enables remote wakeup by default for USB keyboard
devices. Keyboards in general are supposed to be wakeup devices, but
the correct place to enable it depends on the device's bus; no single
approach will work for all keyboard devices. In particular, this
covers only USB keyboards (and then only those supporting the boot
protocol).
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Use strlcat() to append a string to the previously created first part.
Signed-off-by: Márton Németh <nm127@freemail.hu>
Acked-by: Jiri Kosina <jkosina@suse.cz>
USB should not be having it's own printk macros, so remove warn() and
use the system-wide standard of dev_warn() wherever possible. In the
few places that will not work out, use a basic printk().
USB should not be having it's own printk macros, so remove info() and
use the system-wide standard of dev_info() wherever possible.
This patch completely removes the dependency of usbkbd and usbmouse drivers
on usbhid code.
usbkbd/usbmouse drivers are not needed in the vast majority of cases anyway,
and they shouldn't be loaded in standard configurations at all. They are supposed
to be as trivial as possible, and searching for HID_QUIRK_IGNORE can even be
bad in some cases.
When usbmouse/kbd is set to build, USB_HID is never defined due to
the USB_HID!=y Kconfig rule. Test CONFIG_USB_HID_MODULE in both
drivers instead.
Signed-off-by: Jiri Slaby <jirislaby@gmail.com>
mark it as const because it is read only
Signed-off-by: Ming Lei <tom.leiming@gmail.com>
This patch removes CVS keywords that weren't updated for a long time
from comments.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
We can use the blacklist only if usbhid code is compiled.
Reported-by: jurriaan <thunder7@xs4all.nl>
Cc: Pascal Terjan <pterjan@mandriva.com>
This fixes wacom tablets not working if usbmouse is loaded.
Signed-off-by: Pascal Terjan <pterjan@mandriva.com>
get rid of input BIT* duplicate defines
use newly global defined macros for input layer. Also remove includes of
input.h from non-input sources only for BIT macro definiton. Define the
macro temporarily in local manner, all those local definitons will be
removed further in this patchset (to not break bisecting).
BIT macro will be globally defined (1<<x)
Cc: <dtor@mail.ru>
Cc: <lenb@kernel.org>
Acked-by: Marcel Holtmann <marcel@holtmann.org>
Cc: <perex@suse.cz>
Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org>
Cc: <vernux@us.ibm.com>
Cc: <malattia@linux.it>
There have been many reports recently about broken HID devices, the
diagnosis of which required users to recompile their kernels in order
to be able to provide debugging output needed for coding a quirk for
a particular device.
This patch makes CONFIG_HID_DEBUG default y if !EMBEDDED and makes it
possible to control debugging output produced by HID code by supplying
'debug=1' module parameter.
In preparation for struct class_device -> struct device input
core conversion switch to using input_dev->dev.parent when
specifying device position in sysfs tree.
usb_buffer_free() now handles NULLs so remove unneeded checks
form callers.
Handle errors when registering input devices in usbkbd/usbmouse.
Separate usbhid code into dedicated drivers/hid/usbhid directory as
discussed previously with Greg, so that it eases maintaineance process.
