path: root/drivers/hid/usbhid/usbmouse.c
2008-07-23HID: remove quirk lookup from usbkbd/usbmouseJiri Kosina
This patch completely removes the dependency of usbkbd and usbmouse drivers on usbhid code. usbkbd/usbmouse drivers are not needed in the vast majority of cases anyway, and they shouldn't be loaded in standard configurations at all. They are supposed to be as trivial as possible, and searching for HID_QUIRK_IGNORE can even be bad in some cases. Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2008-07-23HID: fix quirk handling in usbmouse/kbdJiri Slaby
When usbmouse/kbd is set to build, USB_HID is never defined due to the USB_HID!=y Kconfig rule. Test CONFIG_USB_HID_MODULE in both drivers instead. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2008-05-20HID: remove CVS keywordsAdrian Bunk
This patch removes CVS keywords that weren't updated for a long time from comments. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2008-01-28HID: fix compilation of hidbp drivers without usbhidJiri Kosina
We can use the blacklist only if usbhid code is compiled. Reported-by: jurriaan <thunder7@xs4all.nl> Cc: Pascal Terjan <pterjan@mandriva.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2008-01-28HID: Use hid blacklist in usbmouse/usbkbdPascal Terjan
This fixes wacom tablets not working if usbmouse is loaded. Signed-off-by: Pascal Terjan <pterjan@mandriva.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2007-10-19get rid of input BIT* duplicate definesJiri Slaby
get rid of input BIT* duplicate defines use newly global defined macros for input layer. Also remove includes of input.h from non-input sources only for BIT macro definiton. Define the macro temporarily in local manner, all those local definitons will be removed further in this patchset (to not break bisecting). BIT macro will be globally defined (1<<x) Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: <dtor@mail.ru> Acked-by: Jiri Kosina <jkosina@suse.cz> Cc: <lenb@kernel.org> Acked-by: Marcel Holtmann <marcel@holtmann.org> Cc: <perex@suse.cz> Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: <vernux@us.ibm.com> Cc: <malattia@linux.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09HID: switch to using input_dev->dev.parentDmitry Torokhov
In preparation for struct class_device -> struct device input core conversion switch to using input_dev->dev.parent when specifying device position in sysfs tree. Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2007-04-11USB HID: usbkbd/usbmouse - handle errors when registering devicesDmitry Torokhov
Handle errors when registering input devices in usbkbd/usbmouse. Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2007-04-11USB HID: move usbhid code from drivers/usb/input to drivers/hid/usbhidJiri Kosina
Separate usbhid code into dedicated drivers/hid/usbhid directory as discussed previously with Greg, so that it eases maintaineance process. Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
