path: root/drivers/hid/usbhid
2009-07-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: HID: Move dereferences below a NULL test HID: hiddev, fix lock imbalance
2009-07-12headers: smp_lock.h reduxAlexey Dobriyan
* Remove smp_lock.h from files which don't need it (including some headers!) * Add smp_lock.h to files which do need it * Make smp_lock.h include conditional in hardirq.h It's needed only for one kernel_locked() usage which is under CONFIG_PREEMPT This will make hardirq.h inclusion cheaper for every PREEMPT=n config (which includes allmodconfig/allyesconfig, BTW) Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-22HID: hiddev, fix lock imbalanceJiri Slaby
Add omitted BKL to one switch/case. Cc: Stable <stable@kernel.org> Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-06-15Driver Core: usb: add nodename support for usb drivers.Kay Sievers
This adds support for USB drivers to report their requested nodename to userspace. It also updates a number of USB drivers to provide the needed subdirectory and device name to be used for them. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Jan Blunck <jblunck@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-04HID: no more reinitializtion is needed in post_resetJiri Kosina
No more reinitialization is needed in the post reset hook, remove the FIXME comment. While at it, clean up whitespaces in the immediate surrounding. Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-05-11HID: add NOGET quirk for devices from CH ProductsAlan Stern
This patch (as1240) adds the NOGET quirk for three devices from CH Products: the Pro pedals, the Combatstick joystick, and the Flight-Sim yoke. Without these quirks, the devices haven't worked for many kernel releases. Sometimes replugging them after boot-up would get them to work and sometimes they wouldn't work at all. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Reported-by: Sean Hildebrand <silverwraithii@gmail.com> Reported-by: Sid Boyce <sboyce@blueyonder.co.uk> Tested-by: Sean Hildebrand <silverwraithii@gmail.com> Tested-by: Sid Boyce <sboyce@blueyonder.co.uk> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-05-11HID: fix dropped device-specific quirksZoltan Karcagi
Device-specific quirks are set up correctly in their respective vendor-specific driver, then get overwritten in usbhid_parse(). This is only issue for device-specific NOGET quirks being set by driver for a few devices out there. Signed-off-by: Zoltan Karcagi <zkr@freemail.hu> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-04-29HID: fix possible deadlock in usbhid_close()Oliver Neukum
This patch switches usbhid_close() from flush_scheduled_work() to canceling the outstanding work. This fixes a possible deadlock due to work taking the mutex usbhid_close() holds. Lockdep reported the problem. Signed-off-by: Oliver Neukum <oliver@neukum.org> -- Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-03-30Merge branch 'autosuspend' into for-nextJiri Kosina
Conflicts: drivers/hid/hid-core.c
2009-03-30HID: fix race between usb_register_dev() and hiddev_open()Oliver Neukum
upon further thought this code is still racy. retval = usb_register_dev(usbhid->intf, &hiddev_class); here you open a window during which open can happen if (retval) { err_hid("Not able to get a minor for this device."); hid->hiddev = NULL; kfree(hiddev); return -1; } else { hid->minor = usbhid->intf->minor; hiddev_table[usbhid->intf->minor - HIDDEV_MINOR_BASE] = hiddev; and will fail because hiddev_table hasn't been updated The obvious fix of using a mutex to guard hiddev_table doesn't work because usb_open() and usb_register_dev() take minor_rwsem and we'd have an AB-BA deadlock. We need a lock usb_open() also takes in the right order and that leaves only one option, BKL. I don't like it but I see no alternative. Once the usb_open() implements something better than lock_kernel(), we could also do so. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-03-30HID: bring back possibility to specify vid/pid ignore on module loadJiri Kosina
When hid quirks were converted to specialized driver, the HID_QUIRK_IGNORE has been moved completely, as the hid_ignore_list[] has been moved into the generic code. However userspace already got used to the possibility that modprobing usbhid with 'quirks=vid:pid:0x4' makes the device ignored by usbhid driver. So keep this quirk flag in place for backwards compatibility. Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-03-26Merge branch 'bkl-removal' of git://git.lwn.net/linux-2.6Linus Torvalds
* 'bkl-removal' of git://git.lwn.net/linux-2.6: Rationalize fasync return values Move FASYNC bit handling to f_op->fasync() Use f_lock to protect f_flags Rename struct file->f_ep_lock
2009-03-25HID: autosuspend -- fix lockup of hid on resetOliver Neukum
This fixes a use of flush_scheduled_work() in USB HID's reset logic that can deadlock. Tested-by: Valdis Kletniks <Valdis.Kletnieks@vt.edu> Signed-off-by: Oliver Neukum <oliver@neukum.name> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-03-25HID: hid_reset_resume() needs to be defined only when CONFIG_PM is setJiri Kosina
There is no point of having hid_reset_resume() when CONFIG_PM is not set, and even the corresponding .reset_resume pointer in hid_driver struct is properly ifdefed. Move the definition into the ifdef CONFIG_PM part of the source to avoid drivers/hid/usbhid/hid-core.c:1337: warning: 'hid_reset_resume' defined but not used Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-03-25HID: fix USB HID devices after STD with autosuspendOliver Neukum
This patch fixes a bug caused by reset_resume not changing the internal status flags for a device that is resumed via reset_resume. To do so the reset handlers, which correctly assume that a device is awake, can no longer do all the work of reset_resume handling. Signed-off-by: Oliver Neukum <oneukum@suse.de> Tested-by: Laurent Riffard <laurent.riffard@free.fr> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-03-25HID: do not try to compile PM code with CONFIG_PM unsetJiri Kosina
Fixes this build breakage in case when CONFIG_PM is not set drivers/hid/usbhid/hid-core.c: In function 'hid_suspend': drivers/hid/usbhid/hid-core.c:1220: error: 'struct usb_device' has no member named 'auto_pm' drivers/hid/usbhid/hid-core.c:1245: error: 'struct usb_device' has no member named 'auto_pm' drivers/hid/usbhid/hid-core.c:1258: error: 'struct usb_device' has no member named 'auto_pm' by throwing both the hid_suspend() and hid_resume() away completely in such case, as they won't be used anyway. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-03-25HID: autosuspend support for USB HIDOliver Neukum
This uses the USB busy mechanism for aggessive autosuspend of USB HID devices. It autosuspends all opened devices supporting remote wakeup after a timeout unless - output is being done to the device - a key is being held down (remote wakeup isn't triggered upon key release) - LED(s) are lit - hiddev is opened As in the current driver closed devices will be autosuspended even if they don't support remote wakeup. The patch is quite large because output to devices is done in hard interrupt context meaning a lot a queuing and locking had to be touched. The LED stuff has been solved by means of a simple counter. Additions to the generic HID code could be avoided. In addition it now covers hidraw. It contains an embryonic version of an API to let the generic HID code tell the lower levels which capabilities with respect to power management are needed. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-03-16Rationalize fasync return valuesJonathan Corbet
Most fasync implementations do something like: return fasync_helper(...); But fasync_helper() will return a positive value at times - a feature used in at least one place. Thus, a number of other drivers do: err = fasync_helper(...); if (err < 0) return err; return 0; In the interests of consistency and more concise code, it makes sense to map positive return values onto zero where ->fasync() is called. Cc: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2009-03-10HID: fix waitqueue usage in hiddevJohannes Weiner
DECLARE_WAITQUEUE doesn't initialize the wait descriptor's task_list to 'empty' but to zero. prepare_to_wait() will not enqueue the descriptor to the waitqueue and finish_wait() will do list_del_init() on a list head that contains NULL pointers, which oopses. This was introduced by 079034073 "HID: hiddev cleanup -- handle all error conditions properly". The prior code used an unconditional add_to_waitqueue() which didn't care about the wait descriptor's list head and enqueued the thing unconditionally. The new code uses prepare_to_wait() which DOES check the prior list state, so use DEFINE_WAIT instead. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Oliver Neukum <oliver@neukum.name> Cc: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-03-10HID: fix incorrect free in hiddevJohannes Weiner
If hiddev_open() fails, it wrongly frees the shared hiddev structure kept in hiddev_table instead of the hiddev_list structure allocated for the opened file descriptor. Existing references to this structure will then accessed free memory. This was introduced by 079034073 "HID: hiddev cleanup -- handle all error conditions properly". Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Oliver Neukum <oliver@neukum.name> Cc: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-01-29HID: fix reversed logic in disconnect testing of hiddevOliver Neukum
The logic for testing for disconnection is reversed in an ioctl leading to false reports of disconnection. Signed-off-by: Oliver Neukum <oneukum@suse.de> Tested-by: Folkert van Heusden <folkert@vanheusden.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-01-07Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (123 commits) wimax/i2400m: add CREDITS and MAINTAINERS entries wimax: export linux/wimax.h and linux/wimax/i2400m.h with headers_install i2400m: Makefile and Kconfig i2400m/SDIO: TX and RX path backends i2400m/SDIO: firmware upload backend i2400m/SDIO: probe/disconnect, dev init/shutdown and reset backends i2400m/SDIO: header for the SDIO subdriver i2400m/USB: TX and RX path backends i2400m/USB: firmware upload backend i2400m/USB: probe/disconnect, dev init/shutdown and reset backends i2400m/USB: header for the USB bus driver i2400m: debugfs controls i2400m: various functions for device management i2400m: RX and TX data/control paths i2400m: firmware loading and bootrom initialization i2400m: linkage to the networking stack i2400m: Generic probe/disconnect, reset and message passing i2400m: host/device procotol and core driver definitions i2400m: documentation and instructions for usage wimax: Makefile, Kconfig and docbook linkage for the stack ...
2009-01-07HID: fix hid->hiddev initialization in hiddev_connect()Jiri Kosina
Commit 079034073fa ("HID: hiddev cleanup -- handle all error conditions properly") by mistake removed proper initialization of hid->hiddev pointer in hiddev_connect() in case usb_register_dev() succeeds for the hiddev node. Put it properly back in place. Reported-and-tested-by: Gabriel C <nix.or.die@googlemail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-07USB: change interface to usb_lock_device_for_reset()Alan Stern
This patch (as1161) changes the interface to usb_lock_device_for_reset(). The existing interface is apparently not very clear, judging from the fact that several of its callers don't use it correctly. The new interface always returns 0 for success and it always requires the caller to unlock the device afterward. The new routine will not return immediately if it is called while the driver's probe method is running. Instead it will wait until the probe is over and the device has been unlocked. This shouldn't cause any problems; I don't know of any cases where drivers call usb_lock_device_for_reset() during probe. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Cc: Pete Zaitcev <zaitcev@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-04Merge branch 'upstream-fixes' into for-nextJiri Kosina
Conflicts: drivers/hid/hid-ids.h
2009-01-04HID: add proper support for pensketch 12x9 tabletMatt Helsley
The Genius PenSketch 12x9 tablet has a puck (labeled a "Tablet Mouse") in addition to a pen. Without registering a quirk the tablet appears to be a single input device that reports the wrong axis information in /proc/bus/input/devices, and sends incorrect events (e.g. ABS_Z instead of ABS_Y). This information confuses the X evdev driver and makes the device impossible to use. The quirk fixes events and splits the device into multiple input event devices so that at least the puck is useful. Signed-off-by: Matt Helsley <matt.helsley@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-01-04HID: make boot protocol drivers depend on EMBEDDEDParag Warudkar
The usbmouse and usbkbd modules are not supposed to be used with regular USB mice and keyboards. Make them depend on EMBEDDED to prevent them from being built and loaded on non-EMBEDDED configs. Signed-off-by: Parag Warudkar <parag.lkml@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-01-04HID: hiddev cleanup -- handle all error conditions properlyOliver Neukum
This is a cleanup of hiddev and fixes the following issues: - thread safety by locking in read & ioctl, introducing a per device mutex - race between ioctl and disconnect, introducing a flag and locking in form of a per low level device mutex - race between open and other methods, making sure only successfully opened devices are put on the list, changing order of events - range checking both upper and lower limits of the minor range - make sure further calls to open fail for unplugged devices even if the device still has opened files - error checking for low level open - possible loss of wakeup events, using standard waiting macros - race in initialisation by moving registration after full initialisation Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-01-04HID: use GFP_KERNEL in hid_alloc_buffersJiri Slaby
We might sleep, so no problem to use GFP_KERNEL. While at it bring the function to coding style. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-01-04HID: usbhid, use usb_endpoint_xfer_intJiri Slaby
Use usb_endpoint_xfer_int() instead of direct use of constants. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-01-04HID: move usbhid flags to usbhid.hJiri Slaby
Move usbhid specific flags from global hid.h into local usbhid.h. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-01-04HID: automatically call usbhid_set_leds in usbhid driverAlan Stern
This patch (as1146c) makes usbhid automatically call usbhid_set_leds() for any device that supports the keyboard boot protocol. In theory this should be perfectly safe. BIOSes send the LED output report as part of their normal device initialization, so any keyboard device supporting the boot protocol has to be able to handle it. As a side effect, the hid-dell and hid-bright drivers are no longer needed, and the Logitech keyboard driver can be removed from hid-lg. CC: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-01-04HID: non-input reports can also be numberedJiri Kosina
When computing the maximal buffer size needed, we must take into account that not only input reports can be numbered. Pointed out in bugzilla #10467 Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2008-11-23HID: remove setup mutex, fix possible deadlockJiri Slaby
It causes recursive locking warning and is unneeded after introduction of STARTED flag. * Resume vs. stop is effectively solved by DISCONNECT flag. * No problem in suspend vs. start -- urb is submitted even after open which is possible after connect which is called after start. * Resume vs. start solved by STARTED flag. * Suspend vs. stop -- no problem in killing urb and timer twice. Reported-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2008-11-14HID: don't grab devices with no inputJiri Slaby
Some devices have no input interrupt endpoint. These won't be handled by usbhid, but currently they are not refused and reside on hid bus. Perform this checking earlier so that we refuse to control such a device early enough (and not pass it to the hid bus at all). Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2008-11-13HID: fix start/stop cycle in usbhid driverJiri Slaby
`stop' left out usbhid->urb* pointers and so the next `start' thought it needs to allocate nothing and used the memory pointers previously pointed to. This led to memory corruption and device malfunction. Also don't forget to clear disconnect flag on start which was left set by the previous `stop'. This fixes echo DEVICE > /sys/bus/hid/drivers/DRIVER/unbind echo DEVICE > /sys/bus/hid/drivers/DRIVER/bind failures. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2008-11-01saner FASYNC handling on file closeAl Viro
As it is, all instances of ->release() for files that have ->fasync() need to remember to evict file from fasync lists; forgetting that creates a hole and we actually have a bunch that *does* forget. So let's keep our lives simple - let __fput() check FASYNC in file->f_flags and call ->fasync() there if it's been set. And lose that crap in ->release() instances - leaving it there is still valid, but we don't have to bother anymore. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-27HID: sync on deleted io_retry timer in usbhid driverJiri Slaby
When suspending, make sure that the timer is not running any more. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2008-10-27HID: fix oops during suspend of unbound HID devicesJiri Slaby
Usbhid structure is allocated on start invoked only from probe of some driver. When there is no driver, the structure is null and causes null-dereference oopses. Fix it by allocating the structure on probe and disconnect of the device itself. Also make sure we won't race between start and resume or stop and suspend respectively. References: http://bugzilla.kernel.org/show_bug.cgi?id=11827 Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Johannes Berg <johannes@sipsolutions.net> Cc: Andreas Schwab <schwab@suse.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2008-10-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: HID: Add support for Sony Vaio VGX-TP1E HID: fix lock imbalance in hiddev HID: fix lock imbalance in hidraw HID: fix hidbus/appletouch device binding regression HID: add hid_type to general hid struct HID: quirk for OLED devices present in ASUS G50/G70/G71 HID: Remove "default m" for Thrustmaster and Zeroplus HID: fix hidraw_exit section mismatch HID: add support for another Gyration remote control Revert "HID: Invert HWHEEL mappings for some Logitech mice"
2008-10-23HID: fix lock imbalance in hiddevJiri Slaby
Don't forget to unlock_kernel() in hiddev_ioctl_usage(). Added in 7961df16819085b8a357720d89d0239036e6af2a (HID: Switch hiddev to unlocked_ioctl). Corresponing sparse warning: drivers/hid/usbhid/hiddev.c:515:10: warning: context imbalance in 'hiddev_ioctl_usage': wrong count at exit drivers/hid/usbhid/hiddev.c:515:10: context 'kernel_lock': wanted 0, got 1 Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2008-10-22HID: add hid_type to general hid structJiri Slaby
Add type to the hid structure to distinguish to which device type (now only mouse) we are talking to. Needed for per device type ignore list support. Note: this patch leaves the type as unknown for bluetooth devices, there is not support for this in the hidp code. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2008-10-17USB: remove warn macro from HID coreGreg Kroah-Hartman
There were two stragglers that got missed in the last merge of the HID tree that forgot to change the warn() calls to dev_warn(). This patch fixes them up. Acked-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-14HID: remove warn() macro from usb hid driversFrom: Greg Kroah-Hartman
USB should not be having it's own printk macros, so remove warn() and use the system-wide standard of dev_warn() wherever possible. In the few places that will not work out, use a basic printk(). Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2008-10-14HID: remove info() macro from usb HID driversGreg Kroah-Hartman
USB should not be having it's own printk macros, so remove info() and use the system-wide standard of dev_info() wherever possible. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2008-10-14HID: fix a lockup regression when using force feedback on a PID deviceAnssi Hannula
Commit 8006479c9b75fb6594a7b746af3d7f1fbb68f18f introduced a spinlock in input_dev->event_lock, which is locked when handling input events. However, the hid-pidff driver sleeps when handling events as it waits for reports being sent to the device before changing the report contents again. This causes a system lockup when trying to use force feedback with a PID device, a regression introduced in 2.6.24 and 2.6.23.15. Fix it by extracting the raw report data from struct hid_report immediately when hid_submit_report() is called, therefore allowing drivers to change the contents of struct hid_report immediately without affecting the already-queued transfer. In hid-pidff, re-add the removed usbhid_wait_io() to pidff_erase_effect() instead, to prevent a full report queue from causing the submission to fail, thus not freeing up device memory. pidff_erase_effect() is not called while dev->event_lock is held. Signed-off-by: Anssi Hannula <anssi.hannula@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2008-10-14HID: remove hid-ffJiri Slaby
hid-ff.c now calls only pidff (generic driver), the special ones are now in separate drivers. Invoke pidff on all non-special directly. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2008-10-14HID: move zeroplus FF processingJiri Slaby
2008-10-14HID: move thrustmaster FF processingJiri Slaby
2008-10-14HID: move pantherlord FF processingJiri Slaby
Move the force feedback processing into a separate module. [jkosina@suse.cz: fix Kconfig texts a little bit] Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
