commit 6d4472d7bec39917b54e4e80245784ea5d60ce49 upstream.
Undo what we did for opening before releasing the memory slice.
Reported-by: syzbot <syzbot+62a1e04fd3ec2abf099e@syzkaller.appspotmail.com>
Cc: Andrey Konovalov <andreyknvl@google.com>
Signed-off-by: Hillf Danton <hdanton@sina.com>
commit 9c09b214f30e3c11f9b0b03f89442df03643794d upstream.
syzbot found the following crash on:
HEAD commit: e96407b4 usb-fuzzer: main usb gadget fuzzer driver
git tree: https://github.com/google/kasan.git usb-fuzzer
console output: https://syzkaller.appspot.com/x/log.txt?x=147ac20c600000
kernel config: https://syzkaller.appspot.com/x/.config?x=792eb47789f57810
dashboard link: https://syzkaller.appspot.com/bug?extid=62a1e04fd3ec2abf099e
compiler: gcc (GCC) 9.0.0 20181231 (experimental)
BUG: KASAN: use-after-free in __lock_acquire+0x302a/0x3b50
kernel/locking/lockdep.c:3753
Read of size 8 at addr ffff8881cf591a08 by task syz-executor.1/26260
CPU: 1 PID: 26260 Comm: syz-executor.1 Not tainted 5.3.0-rc2+ #24
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS
Google 01/01/2011
Call Trace:
__dump_stack lib/dump_stack.c:77 [inline]
dump_stack+0xca/0x13e lib/dump_stack.c:113
print_address_description+0x6a/0x32c mm/kasan/report.c:351
__kasan_report.cold+0x1a/0x33 mm/kasan/report.c:482
kasan_report+0xe/0x12 mm/kasan/common.c:612
__lock_acquire+0x302a/0x3b50 kernel/locking/lockdep.c:3753
lock_acquire+0x127/0x320 kernel/locking/lockdep.c:4412
__raw_spin_lock_irqsave include/linux/spinlock_api_smp.h:110 [inline]
_raw_spin_lock_irqsave+0x32/0x50 kernel/locking/spinlock.c:159
hiddev_release+0x82/0x520 drivers/hid/usbhid/hiddev.c:221
__fput+0x2d7/0x840 fs/file_table.c:280
task_work_run+0x13f/0x1c0 kernel/task_work.c:113
exit_task_work include/linux/task_work.h:22 [inline]
do_exit+0x8ef/0x2c50 kernel/exit.c:878
do_group_exit+0x125/0x340 kernel/exit.c:982
get_signal+0x466/0x23d0 kernel/signal.c:2728
do_signal+0x88/0x14e0 arch/x86/kernel/signal.c:815
exit_to_usermode_loop+0x1a2/0x200 arch/x86/entry/common.c:159
prepare_exit_to_usermode arch/x86/entry/common.c:194 [inline]
syscall_return_slowpath arch/x86/entry/common.c:274 [inline]
do_syscall_64+0x45f/0x580 arch/x86/entry/common.c:299
entry_SYSCALL_64_after_hwframe+0x49/0xbe
RIP: 0033:0x459829
Code: fd b7 fb ff c3 66 2e 0f 1f 84 00 00 00 00 00 66 90 48 89 f8 48 89 f7
48 89 d6 48 89 ca 4d 89 c2 4d 89 c8 4c 8b 4c 24 08 0f 05 <48> 3d 01 f0 ff
ff 0f 83 cb b7 fb ff c3 66 2e 0f 1f 84 00 00 00 00
RSP: 002b:00007f75b2a6ccf8 EFLAGS: 00000246 ORIG_RAX: 00000000000000ca
RAX: fffffffffffffe00 RBX: 000000000075c078 RCX: 0000000000459829
RDX: 0000000000000000 RSI: 0000000000000080 RDI: 000000000075c078
RBP: 000000000075c070 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000246 R12: 000000000075c07c
R13: 00007ffcdfe1023f R14: 00007f75b2a6d9c0 R15: 000000000075c07c
Allocated by task 104:
save_stack+0x1b/0x80 mm/kasan/common.c:69
set_track mm/kasan/common.c:77 [inline]
__kasan_kmalloc mm/kasan/common.c:487 [inline]
__kasan_kmalloc.constprop.0+0xbf/0xd0 mm/kasan/common.c:460
kmalloc include/linux/slab.h:552 [inline]
kzalloc include/linux/slab.h:748 [inline]
hiddev_connect+0x242/0x5b0 drivers/hid/usbhid/hiddev.c:900
hid_connect+0x239/0xbb0 drivers/hid/hid-core.c:1882
hid_hw_start drivers/hid/hid-core.c:1981 [inline]
hid_hw_start+0xa2/0x130 drivers/hid/hid-core.c:1972
appleir_probe+0x13e/0x1a0 drivers/hid/hid-appleir.c:308
hid_device_probe+0x2be/0x3f0 drivers/hid/hid-core.c:2209
really_probe+0x281/0x650 drivers/base/dd.c:548
driver_probe_device+0x101/0x1b0 drivers/base/dd.c:709
__device_attach_driver+0x1c2/0x220 drivers/base/dd.c:816
bus_for_each_drv+0x15c/0x1e0 drivers/base/bus.c:454
__device_attach+0x217/0x360 drivers/base/dd.c:882
bus_probe_device+0x1e4/0x290 drivers/base/bus.c:514
device_add+0xae6/0x16f0 drivers/base/core.c:2114
hid_add_device+0x33c/0x990 drivers/hid/hid-core.c:2365
usbhid_probe+0xa81/0xfa0 drivers/hid/usbhid/hid-core.c:1386
usb_probe_interface+0x305/0x7a0 drivers/usb/core/driver.c:361
usb_set_configuration+0xdf6/0x1670 drivers/usb/core/message.c:2023
generic_probe+0x9d/0xd5 drivers/usb/core/generic.c:210
usb_probe_device+0x99/0x100 drivers/usb/core/driver.c:266
usb_new_device.cold+0x6a4/0xe79 drivers/usb/core/hub.c:2536
hub_port_connect drivers/usb/core/hub.c:5098 [inline]
hub_port_connect_change drivers/usb/core/hub.c:5213 [inline]
port_event drivers/usb/core/hub.c:5359 [inline]
hub_event+0x1b5c/0x3640 drivers/usb/core/hub.c:5441
process_one_work+0x92b/0x1530 kernel/workqueue.c:2269
worker_thread+0x96/0xe20 kernel/workqueue.c:2415
kthread+0x318/0x420 kernel/kthread.c:255
ret_from_fork+0x24/0x30 arch/x86/entry/entry_64.S:352
Freed by task 104:
__kasan_slab_free+0x130/0x180 mm/kasan/common.c:449
slab_free_hook mm/slub.c:1423 [inline]
slab_free_freelist_hook mm/slub.c:1470 [inline]
slab_free mm/slub.c:3012 [inline]
kfree+0xe4/0x2f0 mm/slub.c:3953
hiddev_connect.cold+0x45/0x5c drivers/hid/usbhid/hiddev.c:914
The buggy address belongs to the object at ffff8881cf591900
which belongs to the cache kmalloc-512 of size 512
The buggy address is located 264 bytes inside of
512-byte region [ffff8881cf591900, ffff8881cf591b00)
The buggy address belongs to the page:
page:ffffea00073d6400 refcount:1 mapcount:0 mapping:ffff8881da002500
index:0x0 compound_mapcount: 0
flags: 0x200000000010200(slab|head)
raw: 0200000000010200 0000000000000000 0000000100000001 ffff8881da002500
raw: 0000000000000000 00000000000c000c 00000001ffffffff 0000000000000000
page dumped because: kasan: bad access detected
Memory state around the buggy address:
ffff8881cf591900: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
ffff8881cf591980: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
> ffff8881cf591a00: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
ffff8881cf591a80: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
ffff8881cf591b00: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
In order to avoid opening a disconnected device, we need to check exist
again after acquiring the existance lock, and bail out if necessary.
commit 49869d2ea9eecc105a10724c1abf035151a3c4e2 upstream.
The PixArt OEM mice are known for disconnecting every minute in
runlevel 1 or 3 if they are not always polled. So add quirk
ALWAYS_POLL for this one as well.
Jonathan Teh (@jonathan-teh) reported and tested the quirk.
Reference: https://github.com/sriemer/fix-linux-mouse/issues/15
Signed-off-by: Sebastian Parschauer <s.parschauer@gmx.de>
CC: stable@vger.kernel.org
commit f11274396a538b31bc010f782e05c2ce3f804c13 upstream.
uref->usage_index can be indirectly controlled by userspace, hence leading
to a potential exploitation of the Spectre variant 1 vulnerability.
This field is used as an array index by the hiddev_ioctl_usage() function,
when 'cmd' is either HIDIOCGCOLLECTIONINDEX, HIDIOCGUSAGES or
HIDIOCSUSAGES.
For cmd == HIDIOCGCOLLECTIONINDEX case, uref->usage_index is compared to
field->maxusage and then used as an index to dereference field->usage
array. The same thing happens to the cmd == HIDIOC{G,S}USAGES cases, where
uref->usage_index is checked against an array maximum value and then it is
used as an index in an array.
This is a summary of the HIDIOCGCOLLECTIONINDEX case, which matches the
traditional Spectre V1 first load:
copy_from_user(uref, user_arg, sizeof(*uref))
if (uref->usage_index >= field->maxusage)
goto inval;
i = field->usage[uref->usage_index].collection_index;
return i;
This patch fixes this by sanitizing field uref->usage_index before using it
to index field->usage (HIDIOCGCOLLECTIONINDEX) or field->value in
HIDIOC{G,S}USAGES arrays, thus, avoiding speculation in the first load.
Cc: <stable@vger.kernel.org>
Signed-off-by: Breno Leitao <leitao@debian.org>
v2: Contemplate cmd == HIDIOC{G,S}USAGES case
commit 01cffe9ded15c0d664e0beb33c594e00c0d57bba upstream.
This mouse keep disconnecting in runleve 3 like below, add it needs the
quirk to mute the anoying messages.
[ 111.230555] usb 2-2: USB disconnect, device number 6
[ 112.718156] usb 2-2: new low-speed USB device number 7 using xhci_hcd
[ 112.941594] usb 2-2: New USB device found, idVendor=03f0, idProduct=094a
[ 112.984866] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 113.027731] usb 2-2: Product: HP USB Optical Mouse
[ 113.069977] usb 2-2: Manufacturer: PixArt
[ 113.113500] input: PixArt HP USB Optical Mouse as /devices/pci0000:00/0000:00:14.0/usb2/2-2/2-2:1.0/0003:03F0:094A.0002/input/input14
[ 113.156787] hid-generic 0003:03F0:094A.0002: input: USB HID v1.11 Mouse [PixArt HP USB Optical Mouse] on usb-0000:00:14.0-2/input0
[ 173.262642] usb 2-2: USB disconnect, device number 7
[ 174.750244] usb 2-2: new low-speed USB device number 8 using xhci_hcd
[ 174.935740] usb 2-2: New USB device found, idVendor=03f0, idProduct=094a
[ 174.990435] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 175.014984] usb 2-2: Product: HP USB Optical Mouse
[ 175.037886] usb 2-2: Manufacturer: PixArt
[ 175.061794] input: PixArt HP USB Optical Mouse as /devices/pci0000:00/0000:00:14.0/usb2/2-2/2-2:1.0/0003:03F0:094A.0003/input/input15
[ 175.084946] hid-generic 0003:03F0:094A.0003: input: USB HID v1.11 Mouse [PixArt HP USB Optical Mouse] on usb-0000:00:14.0-2/input0
Signed-off-by: Dave Young <dyoung@redhat.com>
Cc: stable@vger.kernel.org
Reviewed-by: Benjamin Tissoires <benjamin.tissoires@redhat.com>
Signed-off-by: Sudip Mukherjee <sudipm.mukherjee@gmail.com>
commit 4f65245f2d178b9cba48350620d76faa4a098841 upstream.
uref->field_index, uref->usage_index, finfo.field_index and cinfo.index can be
indirectly controlled by user-space, hence leading to a potential exploitation
This issue was detected with the help of Smatch:
drivers/hid/usbhid/hiddev.c:473 hiddev_ioctl_usage() warn: potential spectre issue 'report->field' (local cap)
drivers/hid/usbhid/hiddev.c:477 hiddev_ioctl_usage() warn: potential spectre issue 'field->usage' (local cap)
drivers/hid/usbhid/hiddev.c:757 hiddev_ioctl() warn: potential spectre issue 'report->field' (local cap)
drivers/hid/usbhid/hiddev.c:801 hiddev_ioctl() warn: potential spectre issue 'hid->collection' (local cap)
Fix this by sanitizing such structure fields before using them to index
report->field, field->usage and hid->collection
Notice that given that speculation windows are large, the policy is
to kill the speculation on the first load and not worry if it can be
completed with a dependent load/store [1].
[1] https://marc.info/?l=linux-kernel&m=152449131114778&w=2
Signed-off-by: Gustavo A. R. Silva <gustavo@embeddedor.com>
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
The hid descriptor identifies the length and type of subordinate
descriptors for a device. If the received hid descriptor is smaller than
the size of the struct hid_descriptor, it is possible to cause
out-of-bounds.
In addition, if bNumDescriptors of the hid descriptor have an incorrect
value, this can also cause out-of-bounds while approaching hdesc->desc[n].
So check the size of hid descriptor and bNumDescriptors.
BUG: KASAN: slab-out-of-bounds in usbhid_parse+0x9b1/0xa20
Read of size 1 at addr ffff88006c5f8edf by task kworker/1:2/1261
CPU: 1 PID: 1261 Comm: kworker/1:2 Not tainted
4.14.0-rc1-42251-gebb2c2437d80 #169
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011
Workqueue: usb_hub_wq hub_event
Call Trace:
__dump_stack lib/dump_stack.c:16
dump_stack+0x292/0x395 lib/dump_stack.c:52
print_address_description+0x78/0x280 mm/kasan/report.c:252
kasan_report_error mm/kasan/report.c:351
kasan_report+0x22f/0x340 mm/kasan/report.c:409
__asan_report_load1_noabort+0x19/0x20 mm/kasan/report.c:427
usbhid_parse+0x9b1/0xa20 drivers/hid/usbhid/hid-core.c:1004
hid_add_device+0x16b/0xb30 drivers/hid/hid-core.c:2944
usbhid_probe+0xc28/0x1100 drivers/hid/usbhid/hid-core.c:1369
usb_probe_interface+0x35d/0x8e0 drivers/usb/core/driver.c:361
really_probe drivers/base/dd.c:413
driver_probe_device+0x610/0xa00 drivers/base/dd.c:557
__device_attach_driver+0x230/0x290 drivers/base/dd.c:653
bus_for_each_drv+0x161/0x210 drivers/base/bus.c:463
__device_attach+0x26e/0x3d0 drivers/base/dd.c:710
device_initial_probe+0x1f/0x30 drivers/base/dd.c:757
bus_probe_device+0x1eb/0x290 drivers/base/bus.c:523
device_add+0xd0b/0x1660 drivers/base/core.c:1835
usb_set_configuration+0x104e/0x1870 drivers/usb/core/message.c:1932
generic_probe+0x73/0xe0 drivers/usb/core/generic.c:174
usb_probe_device+0xaf/0xe0 drivers/usb/core/driver.c:266
usb_new_device+0x7b8/0x1020 drivers/usb/core/hub.c:2457
hub_port_connect drivers/usb/core/hub.c:4903
hub_port_connect_change drivers/usb/core/hub.c:5009
port_event drivers/usb/core/hub.c:5115
hub_event+0x194d/0x3740 drivers/usb/core/hub.c:5195
process_one_work+0xc7f/0x1db0 kernel/workqueue.c:2119
worker_thread+0x221/0x1850 kernel/workqueue.c:2253
kthread+0x3a1/0x470 kernel/kthread.c:231
ret_from_fork+0x2a/0x40 arch/x86/entry/entry_64.S:431
Reported-by: Andrey Konovalov <andreyknvl@google.com>
Signed-off-by: Jaejoong Kim <climbbb.kim@gmail.com>
Tested-by: Andrey Konovalov <andreyknvl@google.com>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
The Ideacom 6680 touchscreen is found in the Dell Latitude 2100. It
has two USB descriptors, the first of which has two input reports. The
HID_QUIRK_MULTI_INPUT quirk is needed to keep the correct maximum
value for ABS_X/ABS_Y (8191 instead of 65535).
Signed-off-by: Nicholas Bishop <nbishop@neverware.com>
- name generation improvement for Wacom devices from Jason Gerecke
- Kconfig dependency fix for Wacom driver from Arnd Bergmann
- usb_device_id and snd_rawmidi_ops constifications from Julia Lawall
and Arvind Yadav
usb_device_id are not supposed to change at runtime. All functions
working with usb_device_id provided by <linux/usb.h> work with
const usb_device_id. So mark the non-const structs as const.
Fix checkpatch.pl error:
ERROR: space prohibited before open square bracket '['.
Signed-off-by: Arvind Yadav <arvind.yadav.cs@gmail.com>
Without a quirk or the X Window System, this device disconnects every
60 seconds. This patch also renames the define associated with the
Logitech 0xc007 product ID, which appeared to have a conflicting typo.
Cc: Oliver Neukum <oliver@neukum.org>
Signed-off-by: Kyle Roarty <kroarty@xes-inc.com>
Signed-off-by: Aaron Sierra <asierra@xes-inc.com>
Although HID itself is transport-agnostic, occasionally a driver may
want to interact with the low-level transport that a device is connected
through. To do this, we need to know what kind of bus is in use. The
first guess may be to look at the 'bus' field of the 'struct hid_device',
but this field may be emulated in some cases (e.g. uhid).
More ideally, we can check which ll_driver a device is using. This
function introduces a 'hid_is_using_ll_driver' function and makes the
'struct hid_ll_driver' of the four most common transports accessible
through hid.h.
Signed-off-by: Jason Gerecke <jason.gerecke@wacom.com>
Acked-By: Benjamin Tissoires <benjamin.tissoires@redhat.com>
Even though the IO for devices with "always poll" quirk is already running,
we still need to set HID_OPENED bit in usbhid->iofl so the interrupt
handler does not ignore the data coming from the device.
Reported-by: Olof Johansson <olof@lixom.net>
Tested-by: Olof Johansson <olof@lixom.net>
Fixes: e399396a6b0 ("HID: usbhid: remove custom locking from usbhid_open...")
Acked-by: Benjamin Tissoires <benjamin.tissoires@redhat.com>
'for-4.13/transport-open-close-consolidation', 'for-4.13/upstream' and 'for-4.13/wacom' into for-linus
Now that HID core enforces serialization of transport driver open/close
calls we can remove custom locking from usbhid driver.
Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com>
Instead of checking hid->open (that we plan on having HID core manage) in
hid_start_in(), let's allocate a couple of new flags: HID_IN_POLLING and
HID_OPENED, and use them to decide whether we should be submitting URBs or
not.
Instead of calling into usbhid code directly, let's use the standard
accessors for the transport HID drivers, and stop clobbering their error
codes with -EIO.
This also allows us to remove usbhid_get/put_power(), leaving only
usbhid_power().
accessors for the transport HID drivers, and stop clobbering their errors
with -EIO.
This also allows us make usbhid_open and close static.
This mouse is also known under other IDs. It needs the quirk
ALWAYS_POLL or will disconnect in runlevel 1 or 3.
Signed-off-by: Sebastian Parschauer <sparschauer@suse.de>
'for-4.12/cp2112', 'for-4.12/hid-core-null-state-handling', 'for-4.12/hiddev', 'for-4.12/i2c-hid', 'for-4.12/innomedia', 'for-4.12/logitech-hidpp-battery-power-supply', 'for-4.12/multitouch', 'for-4.12/nti', 'for-4.12/upstream' and 'for-4.12/wacom' into for-linus
Like other switches, the Aten CS-1758 KVM switch needs a quirk to avoid
spewing errors:
[12599018.071059] usb 5-2: input irq status -75 received
[12599018.079053] usb 5-2: input irq status -75 received
Signed-off-by: Vasilis Liaskovitis <vliaskovitis@suse.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid
Pull HID fixes from Jiri Kosina:
- regression fixes for Wacom devices, from Aaron Armstrong Skomra and
Ping Cheng
- memory leak in hid-sony driver from Roderick Colenbrander
- new device IDs support from Oscar Campos and Daniel Drake
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid:
HID: wacom: generic: Wacom mouse is only provided for opaque tablets
HID: corsair: Add driver Scimitar Pro RGB gaming mouse 1b1c:1b3e support to hid-corsair
HID: corsair: support for K65-K70 Rapidfire and Scimitar Pro RGB
HID: wacom: don't manually release resources for the EKR
HID: wacom: Correct Intuos Pro 2 resolution
HID: sony: Fix input device leak when connecting a DS4 twice using USB/BT
HID: chicony: Add support for another ASUS Zen AiO keyboard
We need to store the minor number each drivers. In case of hidraw, the
minor number is stored stores in struct hidraw. But hiddev's minor is
located in struct hid_device.
The hid-core driver announces a kernel message which driver is loaded when
HID device connected, but hiddev's minor number is always zero. To proper
display hiddev's minor number, we need to store the minor number asked from
usb core and do some refactoring work (move from hiddev.c to hiddev.h) to
access hiddev in hid-core.
[jkosina@suse.cz: rebase on top of newer codebase]
It looks like a bunch of devices do not like to be polled
for their reports at init time. When you look into the details,
it seems that for those that are requiring the quirk
HID_QUIRK_NO_INIT_REPORTS, the driver fails to retrieve part
of the features/inputs while others (more generic) work.
IMO, it should be acceptable to remove the need for the quirk
in the general case. On the small amount of cases where
we actually need to read the current values, the driver
in charge (hid-mt or wacom) already retrieves the features
manually.
There are 2 cases where we might need to retrieve the reports at
init:
1. hiddev devices with specific use-space tool
2. a device that would require the driver to fetch a specific
feature/input at plug
For case 2, I have seen this a few time on hid-multitouch. It
is solved in hid-multitouch directly by fetching the feature.
I hope it won't be too common and this can be solved on a per-case
basis (crossing fingers).
For case 1, we moved the implementation of HID_QUIRK_NO_INIT_REPORTS
in hiddev. When somebody starts calling ioctls that needs an initial
update, the hiddev device will fetch the initial state of the reports
to mimic the current behavior. This adds a small amount of time during
the first HIDIOCGUSAGE(S), but it should be acceptable in
most cases. To keep the currently known broken devices, we have to
keep around HID_QUIRK_NO_INIT_REPORTS, but the scope will only be
for hiddev.
Note that I don't think hidraw would be affected and I checked that
the FF drivers that need to interact with the report fields are all
using output reports, which are not initialized by
usbhid_init_reports().
NO_INIT_INPUT_REPORTS is then replaced by HID_QUIRK_NO_INIT_REPORTS:
there is no point keeping it for just one device.
Signed-off-by: Benjamin Tissoires <benjamin.tissoires@redhat.com>
Add quirks for several corsair gaming devices to avoid long delays on
report initialization
Supported devices:
- Corsair K65RGB Rapidfire Gaming Keyboard
- Corsair K70RGB Rapidfire Gaming Keyboard
- Corsair Scimitar Pro RGB Gaming Mouse
Signed-off-by: Oscar Campos <oscar.campos@member.fsf.org>
Use a more common logging style and remove the unnecessary
OOM messages as there is default dump_stack when OOM.
Miscellanea:
o Hoist an assignment in an if
o Realign arguments
o Realign a deeply indented if descendent above a printk
For mouse devices we can currently change the polling interval
via usbhid.mousepoll. Implement the same thing for joysticks, so
users can reduce input latency this way.
This has been tested with a Logitech RumblePad 2 with jspoll=2,
resulting in a polling rate of 500Hz (verified with evhz).
Signed-off-by: Tobias Jakobi <tjakobi@math.uni-bielefeld.de>
The (1292:4745) Innomedia INNEX GENESIS/ATARI adapter needs
HID_QUIRK_MULTI_INPUT to split the device up into two controllers
instead of inputs from both being merged into one.
Signed-off-by: Tomasz Kramkowski <tk@the-tk.com>
<linux/sched.h> into <linux/sched/signal.h>
Fix up affected files that include this signal functionality via sched.h.
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
'for-4.11/mayflash', 'for-4.11/microsoft', 'for-4.11/rmi', 'for-4.11/upstream' and 'for-4.11/wacom' into for-linus
Quirking the following AMI USB device with ALWAYS_POLL fixes an AMI
virtual keyboard and mouse from not responding and timing out when
it is attached to a ppc64el Power 8 system and when we have some
rapid open/closes on the mouse device.
usb 1-3: new high-speed USB device number 2 using xhci_hcd
usb 1-3: New USB device found, idVendor=046b, idProduct=ff01
usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
usb 1-3: Product: Virtual Hub
usb 1-3: Manufacturer: American Megatrends Inc.
usb 1-3: SerialNumber: serial
usb 1-3.3: new high-speed USB device number 3 using xhci_hcd
usb 1-3.3: New USB device found, idVendor=046b, idProduct=ff31
usb 1-3.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
usb 1-3.3: Product: Virtual HardDisk Device
usb 1-3.3: Manufacturer: American Megatrends Inc.
usb 1-3.4: new low-speed USB device number 4 using xhci_hcd
usb 1-3.4: New USB device found, idVendor=046b, idProduct=ff10
usb 1-3.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
usb 1-3.4: Product: Virtual Keyboard and Mouse
usb 1-3.4: Manufacturer: American Megatrends Inc.
With the quirk I have not been able to trigger the issue with
half an hour of saturation soak testing.
Removes trailing whitespace in hid-core.c and usbhid/hid-quirks.c
Signed-off-by: Dennis Chen <barracks510@gmail.com>
Nearly identical to the previous set of patches related to Microsoft
Surface Keyboards.
Removes Surface Pro 3 generation TypeCover support from hid-microsoft
so proper multitouch data can be reported from the touchpad.
The Mayflash GameCube adapter has received a firmware update which, among other
things, changes the device's PID. It also fixes enumeration, therefore the
updated firmware no longer requires HID_QUIRK_MULTI_INPUT.
Signed-off-by: Marcel Hasler <mahasler@gmail.com>
multitouch data
Nearly identical to the patch "multitouch: enable the Surface 4 Type Cover Pro
(JP) to report multitouch data"
We can now remove the support of the Surface 4 Type Cover Pro (not JP versions)
from hid-microsoft so it can properly report multi touch from the touchpad.
Signed-off-by: Daniel Keller <daniel.keller@gcd.de>
Local "#define DRIVER_LICENSE" obfuscates which license is used
in MODULE_LICENSE(). "fgrep -R MODULE_LICENSE" is more informative
when the string is hard coded in MODULE_LICENSE.
Signed-off-by: Grant Grundler <grundler@google.com>
The DolphinBar by Mayflash (identified as Dragonrise) needs
HID_QUIRK_MULTI_INPUT to split it up into four input devices. Without this
quirk the adapter is falsely recognized as a tablet. See also bug 115841
(https://bugzilla.kernel.org/show_bug.cgi?id=115841).
The Futaba TOSD-5711BB VFD crashes when the initial HID report is requested,
register the display in hid-ids and tell hid-quirks to not do the init.
Signed-off-by: Alex Wood <thetewood@gmail.com>
multitouch data
Since commit 8fe89ef076fa1 ("HID: multitouch: enable the Surface 3 Type
Cover to report multitouch data"), the TypeCover can be properly handled
by hid-multitouch and don't require any special quirk in the kernel.
Remove the support of the Surface 4 Type Cover Pro (JP) from
hid-microsoft so it can properly report multitouch from the touchpad.
Signed-off-by: Yuta Kobayashi <alu.ula@outlook.com>
'for-4.10/i2c-hid-nopower', 'for-4.10/intel-ish', 'for-4.10/mayflash', 'for-4.10/microsoft-surface-3', 'for-4.10/multitouch', 'for-4.10/sony', 'for-4.10/udraw-ps3', 'for-4.10/upstream' and 'for-4.10/wacom/generic' into for-linus
Function hid_post_reset() should return negative error codes on failures.
However, in its implementation, it incorrectly returns 1. This patch fixes the
bug, returning proper error codes on failures.
Signed-off-by: Pan Bian <bianpan2016@163.com>
There is no reasons to filter out keyboard and consumer control collections
in hid-multitouch.
With the previous hid-input fix, there is now a full support of the Type
Cover and we can remove all specific bits from hid-core and hid-microsoft.
hid-multitouch will automatically set HID_QUIRK_NO_INIT_REPORTS so we can
also remove it from the list of ushbid quirks.
Adding support for not JP versions of the Microsoft Surface 4 Type Cover Pro
[jkosina@suse.cz: The identical patch has been sent by Jeff Farthing, so I am
including his signoff as well]
Signed-off-by: Jeff Farthing <jeff@jfarthing.com>
All known gamepad adapters by Mayflash (identified as Dragonrise) need
HID_QUIRK_MULTI_INPUT to split them up into four input devices. Without this
quirk those adapters are falsely recognized as tablets. Fixes bug 115841
Like many similar devices it needs a quirk to work.
Issuing the request gets the device into an irrecoverable state.
Signed-off-by: Oliver Neukum <oneukum@suse.com>
The Akai MIDImix (09e8:0031) is a MIDI fader controller that speaks
regular MIDI and works well with Linux. However, initialization gets
delayed due to reports timeout:
[3643645.631124] hid-generic 0003:09E8:0031.0020: timeout initializing reports
[3643645.632416] hid-generic 0003:09E8:0031.0020: hiddev0: USB HID v1.11 Device [AKAI MIDI Mix] on usb-0000:00:14.0-2/input0
Adding "usbhid.quirks=0x09e8:0x0031:0x20000000" on the kernel
command line makes the issues go away.
Signed-off-by: Steinar H. Gunderson <sgunderson@bigfoot.com>
