path: root/drivers/hv/hyperv_vmbus.h
2012-02-09drivers: hv: Increase the number of VCPUs supported in the guestK. Y. Srinivasan
The current code arbirarily limited the number of CPUs the guest could have. Change that so that we can support the maximum number of CPUs the guest can support. While we use NR_CPUS to size the per-cpu state all we are allocating based on NR_CPUS are the pointers to per-cpu state that will be allocatted in the context of the initializing CPU. This patch triggers a checkpatch warning for the usage of NR_CPU and since all we are allocating a couple of pointers per CPU, it should be ok. Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: Haiyang Zhang <haiyangz@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2011-12-12Drivers: hv: Make the vmbus driver unloadableK. Y. Srinivasan
It turns out that the vmbus driver can be made unloadable. Make it unloadable. Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: Haiyang Zhang <haiyangz@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-11Staging: hv: remove last user of DPRINT() macroGreg Kroah-Hartman
This also removed the unused function hv_dump_ring_info(). Cc: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-10Staging: hv: move hyperv code out of staging directoryGreg Kroah-Hartman
After many years wandering the desert, it is finally time for the Microsoft HyperV code to move out of the staging directory. Or at least the core hyperv bus code, and the utility driver, the rest still have some review to get through by the various subsystem maintainers. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: K. Y. Srinivasan <kys@microsoft.com>
