path: root/drivers/hv
2014-06-12Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: 1) Seccomp BPF filters can now be JIT'd, from Alexei Starovoitov. 2) Multiqueue support in xen-netback and xen-netfront, from Andrew J Benniston. 3) Allow tweaking of aggregation settings in cdc_ncm driver, from Bjørn Mork. 4) BPF now has a "random" opcode, from Chema Gonzalez. 5) Add more BPF documentation and improve test framework, from Daniel Borkmann. 6) Support TCP fastopen over ipv6, from Daniel Lee. 7) Add software TSO helper functions and use them to support software TSO in mvneta and mv643xx_eth drivers. From Ezequiel Garcia. 8) Support software TSO in fec driver too, from Nimrod Andy. 9) Add Broadcom SYSTEMPORT driver, from Florian Fainelli. 10) Handle broadcasts more gracefully over macvlan when there are large numbers of interfaces configured, from Herbert Xu. 11) Allow more control over fwmark used for non-socket based responses, from Lorenzo Colitti. 12) Do TCP congestion window limiting based upon measurements, from Neal Cardwell. 13) Support busy polling in SCTP, from Neal Horman. 14) Allow RSS key to be configured via ethtool, from Venkata Duvvuru. 15) Bridge promisc mode handling improvements from Vlad Yasevich. 16) Don't use inetpeer entries to implement ID generation any more, it performs poorly, from Eric Dumazet. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1522 commits) rtnetlink: fix userspace API breakage for iproute2 < v3.9.0 tcp: fixing TLP's FIN recovery net: fec: Add software TSO support net: fec: Add Scatter/gather support net: fec: Increase buffer descriptor entry number net: fec: Factorize feature setting net: fec: Enable IP header hardware checksum net: fec: Factorize the .xmit transmit function bridge: fix compile error when compiling without IPv6 support bridge: fix smatch warning / potential null pointer dereference via-rhine: fix full-duplex with autoneg disable bnx2x: Enlarge the dorq threshold for VFs bnx2x: Check for UNDI in uncommon branch bnx2x: Fix 1G-baseT link bnx2x: Fix link for KR with swapped polarity lane sctp: Fix sk_ack_backlog wrap-around problem net/core: Add VF link state control policy net/fsl: xgmac_mdio is dependent on OF_MDIO net/fsl: Make xgmac_mdio read error message useful net_sched: drr: warn when qdisc is not work conserving ...
2014-06-03hyper-v: make uuid_le conststephen hemminger
The uuid structure could be managed as a const in several places. Signed-off-by: Stephen Hemminger <stephen@networkplumber.org> Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-28hv: use correct order when freeing monitor_pagesRadim Krčmář
We try to free two pages when only one has been allocated. Cleanup path is unlikely, so I haven't found any trace that would fit, but I hope that free_pages_prepare() does catch it. Cc: stable@vger.kernel.org Signed-off-by: Radim Krčmář <rkrcmar@redhat.com> Reviewed-by: Amos Kong <akong@redhat.com> Acked-by: Jason Wang <jasowang@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-05-03Drivers: hv: balloon: Ensure pressure reports are posted regularlyK. Y. Srinivasan
The current code posts periodic memory pressure status from a dedicated thread. Under some conditions, especially when we are releasing a lot of memory into the guest, we may not send timely pressure reports back to the host. Fix this issue by reporting pressure in all contexts that can be active in this driver. Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Cc: stable@vger.kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-05-03hv: Remove unnecessary comparison of unsigned against 0Tobias Klauser
pfncount is of type u32 and thus can never be smaller than 0. Found by the coverity scanner, CID 143213. Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-05-03Drivers: hv: vmbus: Implement per-CPU mapping of relid to channelK. Y. Srinivasan
Currently the mapping of the relID to channel is done under the protection of a single spin lock. Starting with ws2012, each channel is bound to a specific VCPU in the guest. Use this binding to eliminate the spin lock by setting up per-cpu state for mapping relId to the channel. Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Reviewed-by: Haiyang Zhang <haiyangz@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-05-03Drivers: hv: Eliminate the channel spinlock in the callback pathK. Y. Srinivasan
By ensuring that we set the callback handler to NULL in the channel close path on the same CPU that the channel is bound to, we can eliminate this lock acquisition and release in a performance critical path. Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Reviewed-by: Haiyang Zhang <haiyangz@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-04-16Drivers: hv: vmbus: Negotiate version 3.0 when running on ws2012r2 hostsK. Y. Srinivasan
Only ws2012r2 hosts support the ability to reconnect to the host on VMBUS. This functionality is needed by kexec in Linux. To use this functionality we need to negotiate version 3.0 of the VMBUS protocol. Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Cc: <stable@vger.kernel.org> [3.9+] Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-04-01Merge tag 'char-misc-3.15-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc Pull char/misc driver patches from Greg KH: "Here's the big char/misc driver updates for 3.15-rc1. Lots of various things here, including the new mcb driver subsystem. All of these have been in linux-next for a while" * tag 'char-misc-3.15-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (118 commits) extcon: Move OF helper function to extcon core and change function name extcon: of: Remove unnecessary function call by using the name of device_node extcon: gpio: Use SIMPLE_DEV_PM_OPS macro extcon: palmas: Use SIMPLE_DEV_PM_OPS macro mei: don't use deprecated DEFINE_PCI_DEVICE_TABLE macro mei: amthif: fix checkpatch error mei: client.h fix checkpatch errors mei: use cl_dbg where appropriate mei: fix Unnecessary space after function pointer name mei: report consistently copy_from/to_user failures mei: drop pr_fmt macros mei: make me hw headers private to me hw. mei: fix memory leak of pending write cb objects mei: me: do not reset when less than expected data is received drivers: mcb: Fix build error discovered by 0-day bot cs5535-mfgpt: Simplify dependencies spmi: pm: drop bus-level PM suspend/resume routines spmi: pmic_arb: make selectable on ARCH_QCOM Drivers: hv: vmbus: Increase the limit on the number of pfns we can handle pch_phub: Report error writing MAC back to user ...
2014-03-05x86: hyperv: Fixup the (brain) damage caused by the irq cleanupThomas Gleixner
Compiling last minute changes without setting the proper config options is not really clever. Reported-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2014-03-04x86: Hyperv: Cleanup the irq messThomas Gleixner
The vmbus/hyperv interrupt handling is another complete trainwreck and probably the worst of all currently in tree. If CONFIG_HYPERV=y then the interrupt delivery to the vmbus happens via the direct HYPERVISOR_CALLBACK_VECTOR. So far so good, but: The driver requests first a normal device interrupt. The only reason to do so is to increment the interrupt stats of that device interrupt. For no reason it also installs a private flow handler. We have proper accounting mechanisms for direct vectors, but of course it's too much effort to add that 5 lines of code. Aside of that the alloc_intr_gate() is not protected against reallocation which makes module reload impossible. Solution to the problem is simple to rip out the whole mess and implement it correctly. First of all move all that code to arch/x86/kernel/cpu/mshyperv.c and merily install the HYPERVISOR_CALLBACK_VECTOR with proper reallocation protection and use the proper direct vector accounting mechanism. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: K. Y. Srinivasan <kys@microsoft.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: linuxdrivers <devel@linuxdriverproject.org> Cc: x86 <x86@kernel.org> Link: http://lkml.kernel.org/r/20140223212739.028307673@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2014-02-24vmbus: use resource for hyperv mmio regionGerd Hoffmann
Use a resource for the hyperv mmio region instead of start/size variables. Register the region properly so it shows up in /proc/iomem. Signed-off-by: Gerd Hoffmann <kraxel@redhat.com> Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-24vmbus: add missing breaksGerd Hoffmann
Signed-off-by: Gerd Hoffmann <kraxel@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-18Drivers: hv: fcopy_open() can be staticFengguang Wu
CC: "K. Y. Srinivasan" <kys@microsoft.com> CC: "Greg Kroah-Hartman" <gregkh@linuxfoundation.org> Signed-off-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-18Drivers: hv: Implement the file copy serviceK. Y. Srinivasan
Implement the file copy service for Linux guests on Hyper-V. This permits the host to copy a file (over VMBUS) into the guest. This facility is part of "guest integration services" supported on the Windows platform. Here is a link that provides additional details on this functionality: http://technet.microsoft.com/en-us/library/dn464282.aspx In V1 version of the patch I have addressed comments from Olaf Hering <olaf@aepfle.de> and Dan Carpenter <dan.carpenter@oracle.com> In V2 version of this patch I did some minor cleanup (making some globals static). In V4 version of the patch I have addressed all of Olaf's most recent set of comments/concerns. In V5 version of the patch I had addressed Greg's most recent comments. I would like to thank Greg for suggesting that I use misc device; it has significantly simplified the code. In V6 version of the patch I have cleaned up error message based on Olaf's comments. I have also rebased the patch based on the current tip. In this version of the patch, I have addressed the latest comments from Greg. Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-18Merge 3.14-rc3 into char-misc-nextGreg Kroah-Hartman
We need the fixes here for future mei and other patches. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-15Drivers: hv: Ballon: Make pressure posting thread sleep interruptiblyK. Y. Srinivasan
The non-interruptible sleep of the memory pressure posting thread results in higher reported load average. Make this sleep interruptible. Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-07connector: add portid to unicast in addition to broadcastingDavid Fries
This allows replying only to the requestor portid while still supporting broadcasting. Pass 0 to portid for the previous behavior. Signed-off-by: David Fries <David@Fries.net> Acked-by: Evgeniy Polyakov <zbr@ioremap.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-07Drivers: hv: vmbus: Cleanup the packet send pathK. Y. Srinivasan
The current channel code is using scatterlist abstraction to pass data to the ringbuffer API on the send path. This causes unnecessary translations between virtual and physical addresses. Fix this. Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-07Drivers: hv: vmbus: Extract the mmio information from DSDTK. Y. Srinivasan
On Gen2 firmware, Hyper-V does not emulate the PCI bus. However, the MMIO information is packaged up in DSDT. Extract this information and export it for use by the synthetic framebuffer driver. This is the only driver that needs this currently. In this version of the patch mmio, I have updated the hyperv header file (linux/hyperv.h) with mmio definitions. Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-07Drivers: hv: vmbus: Don't timeout during the initial connection with hostK. Y. Srinivasan
When the guest attempts to connect with the host when there may already be a connection with the host (as would be the case during the kdump/kexec path), it is difficult to guarantee timely response from the host. Starting with WS2012 R2, the host supports this ability to re-connect with the host (explicitly to support kexec). Prior to responding to the guest, the host needs to ensure that device states based on the previous connection to the host have been properly torn down. This may introduce unbounded delays. To deal with this issue, don't do a timed wait during the initial connect with the host. Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Cc: <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-07Drivers: hv: vmbus: Specify the target CPU that should receive notificationK. Y. Srinivasan
During the initial VMBUS connect phase, starting with WS2012 R2, we should specify the VPCU in the guest that should receive the notification. Fix this issue. This fix is required to properly connect to the host in the kexeced kernel. Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Cc: <stable@vger.kernel.org> [3.9+] Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-27hyperv: Add support for physically discontinuous receive bufferHaiyang Zhang
This will allow us to use bigger receive buffer, and prevent allocation failure due to fragmented memory. Signed-off-by: Haiyang Zhang <haiyangz@microsoft.com> Reviewed-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-24Merge tag 'pm+acpi-3.14-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull ACPI and power management updates from Rafael Wysocki: "As far as the number of commits goes, the top spot belongs to ACPI this time with cpufreq in the second position and a handful of PM core, PNP and cpuidle updates. They are fixes and cleanups mostly, as usual, with a couple of new features in the mix. The most visible change is probably that we will create struct acpi_device objects (visible in sysfs) for all devices represented in the ACPI tables regardless of their status and there will be a new sysfs attribute under those objects allowing user space to check that status via _STA. Consequently, ACPI device eject or generally hot-removal will not delete those objects, unless the table containing the corresponding namespace nodes is unloaded, which is extremely rare. Also ACPI container hotplug will be handled quite a bit differently and cpufreq will support CPU boost ("turbo") generically and not only in the acpi-cpufreq driver. Specifics: - ACPI core changes to make it create a struct acpi_device object for every device represented in the ACPI tables during all namespace scans regardless of the current status of that device. In accordance with this, ACPI hotplug operations will not delete those objects, unless the underlying ACPI tables go away. - On top of the above, new sysfs attribute for ACPI device objects allowing user space to check device status by triggering the execution of _STA for its ACPI object. From Srinivas Pandruvada. - ACPI core hotplug changes reducing code duplication, integrating the PCI root hotplug with the core and reworking container hotplug. - ACPI core simplifications making it use ACPI_COMPANION() in the code "glueing" ACPI device objects to "physical" devices. - ACPICA update to upstream version 20131218. This adds support for the DBG2 and PCCT tables to ACPICA, fixes some bugs and improves debug facilities. From Bob Moore, Lv Zheng and Betty Dall. - Init code change to carry out the early ACPI initialization earlier. That should allow us to use ACPI during the timekeeping initialization and possibly to simplify the EFI initialization too. From Chun-Yi Lee. - Clenups of the inclusions of ACPI headers in many places all over from Lv Zheng and Rashika Kheria (work in progress). - New helper for ACPI _DSM execution and rework of the code in drivers that uses _DSM to execute it via the new helper. From Jiang Liu. - New Win8 OSI blacklist entries from Takashi Iwai. - Assorted ACPI fixes and cleanups from Al Stone, Emil Goode, Hanjun Guo, Lan Tianyu, Masanari Iida, Oliver Neukum, Prarit Bhargava, Rashika Kheria, Tang Chen, Zhang Rui. - intel_pstate driver updates, including proper Baytrail support, from Dirk Brandewie and intel_pstate documentation from Ramkumar Ramachandra. - Generic CPU boost ("turbo") support for cpufreq from Lukasz Majewski. - powernow-k6 cpufreq driver fixes from Mikulas Patocka. - cpufreq core fixes and cleanups from Viresh Kumar, Jane Li, Mark Brown. - Assorted cpufreq drivers fixes and cleanups from Anson Huang, John Tobias, Paul Bolle, Paul Walmsley, Sachin Kamat, Shawn Guo, Viresh Kumar. - cpuidle cleanups from Bartlomiej Zolnierkiewicz. - Support for hibernation APM events from Bin Shi. - Hibernation fix to avoid bringing up nonboot CPUs with ACPI EC disabled during thaw transitions from Bjørn Mork. - PM core fixes and cleanups from Ben Dooks, Leonardo Potenza, Ulf Hansson. - PNP subsystem fixes and cleanups from Dmitry Torokhov, Levente Kurusa, Rashika Kheria. - New tool for profiling system suspend from Todd E Brandt and a cpupower tool cleanup from One Thousand Gnomes" * tag 'pm+acpi-3.14-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (153 commits) thermal: exynos: boost: Automatic enable/disable of BOOST feature (at Exynos4412) cpufreq: exynos4x12: Change L0 driver data to CPUFREQ_BOOST_FREQ Documentation: cpufreq / boost: Update BOOST documentation cpufreq: exynos: Extend Exynos cpufreq driver to support boost cpufreq / boost: Kconfig: Support for software-managed BOOST acpi-cpufreq: Adjust the code to use the common boost attribute cpufreq: Add boost frequency support in core intel_pstate: Add trace point to report internal state. cpufreq: introduce cpufreq_generic_get() routine ARM: SA1100: Create dummy clk_get_rate() to avoid build failures cpufreq: stats: create sysfs entries when cpufreq_stats is a module cpufreq: stats: free table and remove sysfs entry in a single routine cpufreq: stats: remove hotplug notifiers cpufreq: stats: handle cpufreq_unregister_driver() and suspend/resume properly cpufreq: speedstep: remove unused speedstep_get_state platform: introduce OF style 'modalias' support for platform bus PM / tools: new tool for suspend/resume performance optimization ACPI: fix module autoloading for ACPI enumerated devices ACPI: add module autoloading support for ACPI enumerated devices ACPI: fix create_modalias() return value handling ...
2013-12-18drivers: hv: Mark the function hv_synic_free_cpu() as static in hv.cRashika Kheria
This patch marks the function hv_synic_free_cpu() as static in hv.c because it is not used outside this file. Thus, it also eliminates the following warning in hv.c: drivers/hv/hv.c:304:6: warning: no previous prototype for ‘hv_synic_free_cpu’ [-Wmissing-prototypes] Signed-off-by: Rashika Kheria <rashika.kheria@gmail.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-07ACPI: Clean up inclusions of ACPI header filesLv Zheng
Replace direct inclusions of <acpi/acpi.h>, <acpi/acpi_bus.h> and <acpi/acpi_drivers.h>, which are incorrect, with <linux/acpi.h> inclusions and remove some inclusions of those files that aren't necessary. First of all, <acpi/acpi.h>, <acpi/acpi_bus.h> and <acpi/acpi_drivers.h> should not be included directly from any files that are built for CONFIG_ACPI unset, because that generally leads to build warnings about undefined symbols in !CONFIG_ACPI builds. For CONFIG_ACPI set, <linux/acpi.h> includes those files and for CONFIG_ACPI unset it provides stub ACPI symbols to be used in that case. Second, there are ordering dependencies between those files that always have to be met. Namely, it is required that <acpi/acpi_bus.h> be included prior to <acpi/acpi_drivers.h> so that the acpi_pci_root declarations the latter depends on are always there. And <acpi/acpi.h> which provides basic ACPICA type declarations should always be included prior to any other ACPI headers in CONFIG_ACPI builds. That also is taken care of including <linux/acpi.h> as appropriate. Signed-off-by: Lv Zheng <lv.zheng@intel.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Matthew Garrett <mjg59@srcf.ucam.org> Cc: Tony Luck <tony.luck@intel.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Acked-by: Bjorn Helgaas <bhelgaas@google.com> (drivers/pci stuff) Acked-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> (Xen stuff) Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-10-19Drivers: hv: vmbus: Fix a bug in channel rescind codeK. Y. Srinivasan
Rescind of subchannels were not being correctly handled. Fix the bug. Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Cc: <stable@vger.kernel.org> [3.11+] Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-16drivers: hv: Fix wrong check for synic_event_pageFelipe Pena
The check for calling free_page() on hv_context.synic_event_page[cpu] is the same for hv_context.synic_message_page[cpu], like a copy-paste error. Signed-off-by: Felipe Pena <felipensp@gmail.com> Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-29Merge 3.12-rc3 into char-misc-nextGreg Kroah-Hartman
We need/want the mei fixes in here so we can apply other updates that are depending on them. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-26hv: vmbus: fix vmbus_recvpacket_raw() return codeDan Carpenter
Don't return success if the buffer has not been initialized. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-26Drivers: hv: vmbus: Terminate vmbus version negotiation on timeoutK. Y. Srinivasan
commit 666b9adc801ef012612c4e43e0f44b2cdc1979cf terminated vmbus version negotiation incorrectly. We need to terminate the version negotiation only if the current negotiation were to timeout. Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Cc: Olaf Hering <ohering@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-26Drivers: hv: util: Correctly support ws2008R2 and earlierK. Y. Srinivasan
The current code does not correctly negotiate the version numbers for the util driver when hosted on earlier hosts. The version numbers presented by this driver were not compatible with the version numbers supported by Windows Server 2008. Fix this problem. I would like to thank Olaf Hering (ohering@suse.com) for identifying the problem. Reported-by: Olaf Hering <ohering@suse.com> Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-26hv: move ringbuffer bus attributes to dev_groupsGreg Kroah-Hartman
This moves the ringbuffer bus attributes to the dev_groups structure, deletes the now unneeded struct hv_device_info, and removes some now unused functions, and variables as everything is now moved to the dev_groups structure, dev_attrs is no longer needed. Tested-by: "K. Y. Srinivasan" <kys@microsoft.com> Cc: Haiyang Zhang <haiyangz@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-26hv: delete struct hv_dev_port_infoGreg Kroah-Hartman
It's no longer needed, and the struct hv_ring_buffer_debug_info structure shouldn't be "global" so move it to the local .h file instead. Tested-by: "K. Y. Srinivasan" <kys@microsoft.com> Cc: Haiyang Zhang <haiyangz@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-26hv: delete vmbus_get_debug_info()Greg Kroah-Hartman
It's only used once, only contains 2 function calls, so just make those calls directly, deleting the function, and the now unneeded structure entirely. Tested-by: "K. Y. Srinivasan" <kys@microsoft.com> Cc: Haiyang Zhang <haiyangz@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-26hv: move "client/server_monitor_conn_id" bus attributes to dev_groupsGreg Kroah-Hartman
This moves the "client_monitor_conn_id" and "server_monitor_conn_id" bus attributes to the dev_groups structure, removing the need for it to be in a temporary structure. Tested-by: "K. Y. Srinivasan" <kys@microsoft.com> Cc: Haiyang Zhang <haiyangz@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-26hv: move "client/server_monitor_latency" bus attributes to dev_groupsGreg Kroah-Hartman
This moves the "client_monitor_latency" and "server_monitor_latency" bus attributes to the dev_groups structure, removing the need for it to be in a temporary structure. Tested-by: "K. Y. Srinivasan" <kys@microsoft.com> Cc: Haiyang Zhang <haiyangz@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-26hv: move "client/server_monitor_pending" bus attributes to dev_groupsGreg Kroah-Hartman
This moves the "client_monitor_pending" and "server_monitor_pending" bus attributes to the dev_groups structure, removing the need for it to be in a temporary structure. Tested-by: "K. Y. Srinivasan" <kys@microsoft.com> Cc: Haiyang Zhang <haiyangz@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-26hv: make "monitor_pages" a "real" pointer arrayGreg Kroah-Hartman
monitor_pages was a void pointer, containing an unknown number of arrays that we just "knew" were a child and parent array of a specific size. Instead of that implicit knowledge, let's make them a real pointer, allowing us to have type safety, and a semblance of sane addressing schemes. Tested-by: "K. Y. Srinivasan" <kys@microsoft.com> Cc: Haiyang Zhang <haiyangz@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-26hv: move "device_id" bus attribute to dev_groupsGreg Kroah-Hartman
This moves the "device_id" bus attribute to the dev_groups structure, removing the need for it to be in a temporary structure. Tested-by: "K. Y. Srinivasan" <kys@microsoft.com> Cc: Haiyang Zhang <haiyangz@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-26hv: move "class_id" bus attribute to dev_groupsGreg Kroah-Hartman
This moves the "class_id" bus attribute to the dev_groups structure, removing the need for it to be in a temporary structure. Tested-by: "K. Y. Srinivasan" <kys@microsoft.com> Cc: Haiyang Zhang <haiyangz@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-26hv: move "modalias" bus attribute to dev_groupsGreg Kroah-Hartman
This moves the "state" bus attribute to the dev_groups structure. Tested-by: "K. Y. Srinivasan" <kys@microsoft.com> Cc: Haiyang Zhang <haiyangz@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-26hv: move "monitor_id" bus attribute to dev_groupsGreg Kroah-Hartman
This moves the "state" bus attribute to the dev_groups structure, removing the need for it to be in a temporary structure. Tested-by: "K. Y. Srinivasan" <kys@microsoft.com> Cc: Haiyang Zhang <haiyangz@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-26hv: move "state" bus attribute to dev_groupsGreg Kroah-Hartman
2013-09-26hv: use dev_groups for device attributesGreg Kroah-Hartman
This patch is the first in a series that moves the hv bus code to use the dev_groups field instead of dev_attrs, as dev_attrs is going away in future kernel releases. It moves the id sysfs file to the dev_groups structure, and creates the needed show/store functions, instead of relying on one "universal" function for this. By doing this, it removes the need for this to be in a temporary structure. Tested-by: "K. Y. Srinivasan" <kys@microsoft.com> Cc: Haiyang Zhang <haiyangz@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-26hv: Change variable type to boolPeter Senna Tschudin
The variable execute_shutdown is only assigned the values true and false. Change its type to bool. The simplified semantic patch that find this problem is as follows (http://coccinelle.lip6.fr/): @exists@ type T; identifier b; @@ - T + bool b = ...; ... when any b = \(true\|false\) Signed-off-by: Peter Senna Tschudin <peter.senna@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-30Drivers: hv: vmbus: Do not attempt to negoatiate a new version prematurelyK. Y. Srinivasan
The current code would attempt to negotiate a different protocol version if the current negotiation timed out. This triggers an assert in the host (on debug builds). Avoid this by negotiating a newer version only if the host properly rejects the current version being negotiated. Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-27Drivers: hv: vmbus: Fix a bug in the handling of channel offersK. Y. Srinivasan
The channel state should be correctly set before registering the device. In the current code the driver probe would fail for channels that have been rescinded and subsequently re-offered. Fix the bug. Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Cc: stable <stable@vger.kernel.org> # 3.11 Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-02Drivers: hv: remove HV_DRV_VERSIONOlaf Hering
Remove HV_DRV_VERSION, it has no meaning for upstream drivers. Initially it was supposed to show the "Linux Integration Services" version, now it is not in sync anymore with the out-of-tree drivers available from the MSFT website. The only place where a version string is still required is the KVP command "IntegrationServicesVersion" which is handled by tools/hv/hv_kvp_daemon.c. To satisfy such KVP request from the host pass the current string to the daemon during KVP userland registration. Signed-off-by: Olaf Hering <olaf@aepfle.de> Acked-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-29Merge 3.11-rc3 into char-misc-next.Greg Kroah-Hartman
This resolves a merge issue with: drivers/misc/mei/init.c Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
