Add support for the temperature sensor(s) found in AMD K8 CPUs.
Signed-off-by: Rudolf Marek <r.marek@sh.cvut.cz>
This is my f71805f hardware monitoring driver ported from lm_sensors
to Linux 2.6. This new driver differs from the other hardware monitoring
drivers in that it is implemented as a platform driver. This might not
be optimal yet (we would probably need a generic infrastructure and bus
type for Super-I/O logical devices) but it is certainly much better than
the i2c-isa solution.
Note that this driver requires lm_sensors CVS. I hope to get it
released as 2.10.0 soon.
Port the vt8231 hardware monitoring driver from lm_sensors CVS to
Linux 2.6.
Signed-off-by: Roger Lucas <roger@planbit.co.uk>
Driver for the IBM Hard Drive Active Protection System (HDAPS), an
accelerometer found in most modern ThinkPads.
Signed-off-by: Robert Love <rml@novell.com>
The only part left in i2c-sensor is the VRM/VRD/VID handling code.
This is in no way related to i2c, so it doesn't belong there. Move
the code to hwmon, where it belongs.
Note that not all hardware monitoring drivers do VRM/VRD/VID
operations, so less drivers depend on hwmon-vid than there were
depending on i2c-sensor.
I would like to announce support for W83792D chip. This driver was developed
by Winbond Electronics Corp. I added sysfs attributes callbacks infrastructure
plus various code fixes and codingstyle cleanups. I would like to thank Winbond
for supporting free software.
This patch is against 2.6.13rc3 plus hwmon-class and hwmon-split.
Separate patch for documantation and hwmon class register will follow.
Signed-off-by: Chunhao Huang <DZShen@Winbond.com.tw>
This patch adds the sysfs class "hwmon" for use by hardware monitoring
(sensors) chip drivers. It also fixes up the related Kconfig/Makefile
bits.
Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
Part 1: Configuration files and Makefiles.
