path: root/drivers/hwmon/adm1021.c
2009-12-14i2c: Drop I2C_CLIENT_INSMOD_2 to 8Jean Delvare
These macros simply declare an enum, so drivers might as well declare it themselves. This puts an end to the arbitrary limit of 8 chip types per i2c driver. Signed-off-by: Jean Delvare <khali@linux-fr.org> Tested-by: Wolfram Sang <w.sang@pengutronix.de>
2009-12-14i2c: Get rid of struct i2c_client_address_dataJean Delvare
Struct i2c_client_address_data only contains one field at this point, which makes its usefulness questionable. Get rid of it and pass simple address lists around instead. Signed-off-by: Jean Delvare <khali@linux-fr.org> Tested-by: Wolfram Sang <w.sang@pengutronix.de>
2009-12-14i2c: Drop the kind parameter from detect callbacksJean Delvare
The "kind" parameter always has value -1, and nobody is using it any longer, so we can remove it. Signed-off-by: Jean Delvare <khali@linux-fr.org> Tested-by: Wolfram Sang <w.sang@pengutronix.de>
2009-12-09hwmon: (adm1021) Clean up detect functionJean Delvare
As kind is now hard-coded to -1, there is room for code clean-ups. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2009-09-22drivers/hwmon/adm1021.c: add low_power support for adm1021 driverMichael Abbott
Occasionally it is helpful to be able to turn a temperature sensor off (for example if it's making unwanted electrical noise). This patch adds a sysfs node to put any adm1021 compatible device into low power mode. Signed-off-by: Michael Abbott <michael.abbott@diamond.ac.uk> Cc: Jean Delvare <khali@linux-fr.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22drivers/hwmon/adm1021.c: support high precision ADM1023 remote sensorMichael Abbott
The ADM1023 temperature sensor supports higher resolution for its external sensor (sensitivity of 1/8 deg C). This patch makes this higher resolution available through the appropriate temperature sysfs nodes. Curiously, this functionality was available in the 2.4 kernel driver (but formatted in a less helpful manner). Cc: Jean Delvare <khali@linux-fr.org> Signed-off-by: Michael Abbott <michael.abbott@diamond.ac.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-16hwmon: (adm1021) Convert to a new-style i2c driverJean Delvare
The new-style adm1021 driver implements the optional detect() callback to cover the use cases of the legacy driver. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-02-18hwmon: normal_i2c arrays should be constMark M. Hoffman
Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2008-02-07hwmon: Discard useless I2C driver IDsJean Delvare
Many I2C hwmon drivers define a driver ID but no other code references these, meaning that they are useless. Discard them, along with a few IDs which are defined but never used at all. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2007-10-09hwmon: (adm1021) individual alarm filesKrzysztof Helt
This patch converts the driver to individual alarm files as required by the new lmsensors library. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2007-10-09hwmon: (adm1021) dynamic sysfs callbacks conversionKrzysztof Helt
This is conversion of the driver to the dynamic sysfs callbacks. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2007-10-09hwmon: Convert from class_device to deviceTony Jones
Convert from class_device to device for hwmon_device_register/unregister Signed-off-by: Tony Jones <tonyj@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2007-10-09hwmon: Allow writing of negative trigger temperaturesChristian Hohnstaedt
- replace differing temperature variable types by long - use strtol() instead of strtoul() for conversion Signed-off-by: Christian Hohnstaedt <chohnstaedt@innominate.com> Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2007-10-09hwmon: adm1021 clean upsKrzysztof Helt
This patch provides some coding standard cleanups and general code improvements (more debug info, signed values for temperatures, changed names of ADM1023 regs, removed read/write_value functions). Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2006-09-28hwmon: Fix unchecked return status, batch 3Mark M. Hoffman
hwmon: Fix unchecked return status, batch 3 Fix up some hwmon drivers so that they no longer ignore return status from device_create_file(). Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-23[PATCH] hwmon: Semaphore to mutex conversionsIngo Molnar
convert drivers/hwmon/*.c semaphore use to mutexes. the conversion was generated via scripts, and the result was validated automatically via a script as well. all affected hwmon drivers were build-tested. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-05[PATCH] I2C: Remove .owner setting from i2c_driver as it's no longer neededGreg Kroah-Hartman
Now that i2c_add_driver() doesn't need the module owner to be set by hand, we can delete it from the drivers. This patch catches all of the drivers that I found in the current tree (if a driver sets the .owner by hand, it's not a problem, just not needed.) Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Cc: Jean Delvare <khali@linux-fr.org>
2006-01-05[PATCH] i2c: Drop i2c_driver.{owner,name}, 3 of 11Laurent Riffard
We should use the i2c_driver.driver's .name and .owner fields instead of the i2c_driver's ones. This patch updates the hwmon drivers. Signed-off-by: Laurent Riffard <laurent.riffard@free.fr> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-05[PATCH] i2c: Drop i2c_driver.flags, 2 of 3Jean Delvare
Just about every i2c chip driver sets the I2C_DF_NOTIFY flag, so we can simply make it the default and drop the flag. If any driver really doesn't want to be notified when i2c adapters are added, that driver can simply omit to set .attach_adapter. This approach is also more robust as it prevents accidental NULL pointer dereferences. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] hwmon: kzalloc conversionDeepak Saxena
Use kzalloc instead of kmalloc+memset in all hardware monitoring drivers. Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] hwmon: Discard explicit static initializations to 0Jean Delvare
Kill explicit static initializations to 0 in 2 hwmon drivers. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> drivers/hwmon/adm1021.c | 2 +- drivers/hwmon/via686a.c | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
2005-09-05[PATCH] hwmon: hwmon vs i2c, second round (06/11)Jean Delvare
The only thing left in i2c-sensor.h are module parameter definition macros. It's only an extension of what i2c.h offers, and this extension is not sensors-specific. As a matter of fact, a few non-sensors drivers use them. So we better merge them in i2c.h, and get rid of i2c-sensor.h altogether. Signed-off-by: Jean Delvare <khali@linux-fr> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-05[PATCH] hwmon: hwmon vs i2c, second round (04/11)Jean Delvare
i2c_probe and i2c_detect now do the exact same thing and operate on the same data structure, so we can have everyone call i2c_probe. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-05[PATCH] I2C: refactor message in i2c_detach_clientJean Delvare
We could refactor the error message 34 different i2c drivers print if i2c_detach_client() fails in this function itself. Saves quite a few lines of code. Documentation is updated to reflect that change. Note that this patch should be applied after Rudolf Marek's w83792d patches. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-05[PATCH] I2C: Separate non-i2c hwmon drivers from i2c-core (8/9)Jean Delvare
Kill all uses of i2c_is_isa_adapter except for the hybrid drivers (it87, lm78, w83781d). The i2c-isa adapter not being registered with the i2c core anymore, drivers don't have to fear being erroneously attached to it. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-05[PATCH] I2C: Separate non-i2c hwmon drivers from i2c-core (7/9)Jean Delvare
Kill normal_isa in header files, documentation and all chip drivers, as it is no more used. normal_i2c could be renamed to normal, but I decided not to do so at the moment, so as to limit the number of changes. This might be done later as part of the i2c_probe/i2c_detect merge. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-05[PATCH] I2C hwmon: add hwmon sysfs class to driversMark M. Hoffman
This patch modifies sensors chip drivers to make use of the new sysfs class "hwmon". Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-07-11[PATCH] I2C: Move hwmon drivers (2/3)Jean Delvare
Part 2: Move the driver files themselves. Note that the patch "adds trailing whitespace", because it does move the files as-is, and some files happen to have trailing whitespace. From: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
