path: root/drivers/hwmon/ads7828.c
2009-12-14i2c: Drop I2C_CLIENT_INSMOD_1Jean Delvare
This macro simply declares an enum, so drivers might as well declare it themselves. Signed-off-by: Jean Delvare <khali@linux-fr.org> Tested-by: Wolfram Sang <w.sang@pengutronix.de>
2009-12-14i2c: Get rid of struct i2c_client_address_dataJean Delvare
Struct i2c_client_address_data only contains one field at this point, which makes its usefulness questionable. Get rid of it and pass simple address lists around instead. Signed-off-by: Jean Delvare <khali@linux-fr.org> Tested-by: Wolfram Sang <w.sang@pengutronix.de>
2009-12-14i2c: Drop the kind parameter from detect callbacksJean Delvare
The "kind" parameter always has value -1, and nobody is using it any longer, so we can remove it. Signed-off-by: Jean Delvare <khali@linux-fr.org> Tested-by: Wolfram Sang <w.sang@pengutronix.de>
2009-12-09hwmon: Clean up detect functionsJean Delvare
As kind is now hard-coded to -1, there is room for code clean-ups. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Corentin Labbe <corentin.labbe@geomatys.fr> Cc: "Mark M. Hoffman" <mhoffman@lightlink.com> Cc: Juerg Haefliger <juergh@gmail.com> Cc: Riku Voipio <riku.voipio@iki.fi> Acked-by: "Hans J. Koch" <hjk@linutronix.de> Cc: Rudolf Marek <r.marek@assembler.cz>
2008-07-16hwmon: (ads7828) Convert to a new-style i2c driverJean Delvare
The new-style ads7828 driver implements the optional detect() callback to cover the use cases of the legacy driver. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-04-30drivers: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-18hwmon: normal_i2c arrays should be constMark M. Hoffman
Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2008-02-07hwmon: Add support for Texas Instruments/Burr-Brown ADS7828Steve Hardy
Signed-off-by: Steve Hardy <steve@linuxrealtime.co.uk> Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
