path: root/drivers/hwmon/atxp1.c
2008-02-18hwmon: normal_i2c arrays should be constMark M. Hoffman
Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2007-10-09hwmon: Convert from class_device to deviceTony Jones
Convert from class_device to device for hwmon_device_register/unregister Signed-off-by: Tony Jones <tonyj@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2006-09-28hwmon: Fix unchecked return status, batch 6Jean Delvare
hwmon: Fix unchecked return status, batch 6 Fix up 5 more hwmon drivers so that they no longer ignore return status from device_create_file(). Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-28atxp1: Signed/unsigned char bug fixAlexey Dobriyan
vid_to_reg() can return -1 and char can be unsigned. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-23[PATCH] hwmon: Semaphore to mutex conversionsIngo Molnar
convert drivers/hwmon/*.c semaphore use to mutexes. the conversion was generated via scripts, and the result was validated automatically via a script as well. all affected hwmon drivers were build-tested. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-05[PATCH] I2C: Remove .owner setting from i2c_driver as it's no longer neededGreg Kroah-Hartman
Now that i2c_add_driver() doesn't need the module owner to be set by hand, we can delete it from the drivers. This patch catches all of the drivers that I found in the current tree (if a driver sets the .owner by hand, it's not a problem, just not needed.) Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Cc: Jean Delvare <khali@linux-fr.org>
2006-01-05[PATCH] i2c: Drop i2c_driver.{owner,name}, 3 of 11Laurent Riffard
We should use the i2c_driver.driver's .name and .owner fields instead of the i2c_driver's ones. This patch updates the hwmon drivers. Signed-off-by: Laurent Riffard <laurent.riffard@free.fr> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-05[PATCH] i2c: Drop i2c_driver.flags, 2 of 3Jean Delvare
Just about every i2c chip driver sets the I2C_DF_NOTIFY flag, so we can simply make it the default and drop the flag. If any driver really doesn't want to be notified when i2c adapters are added, that driver can simply omit to set .attach_adapter. This approach is also more robust as it prevents accidental NULL pointer dereferences. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] hwmon: kzalloc conversionDeepak Saxena
Use kzalloc instead of kmalloc+memset in all hardware monitoring drivers. Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] hwmon: Missing class check in two hwmon driversJean Delvare
The atxp1 and ds1621 drivers should make sure they do not probe non-hwmon i2c adapters. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-05[PATCH] hwmon: hwmon vs i2c, second round (07/11)Jean Delvare
The only part left in i2c-sensor is the VRM/VRD/VID handling code. This is in no way related to i2c, so it doesn't belong there. Move the code to hwmon, where it belongs. Note that not all hardware monitoring drivers do VRM/VRD/VID operations, so less drivers depend on hwmon-vid than there were depending on i2c-sensor. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-05[PATCH] hwmon: hwmon vs i2c, second round (06/11)Jean Delvare
The only thing left in i2c-sensor.h are module parameter definition macros. It's only an extension of what i2c.h offers, and this extension is not sensors-specific. As a matter of fact, a few non-sensors drivers use them. So we better merge them in i2c.h, and get rid of i2c-sensor.h altogether. Signed-off-by: Jean Delvare <khali@linux-fr> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-05[PATCH] hwmon: hwmon vs i2c, second round (04/11)Jean Delvare
i2c_probe and i2c_detect now do the exact same thing and operate on the same data structure, so we can have everyone call i2c_probe. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-05[PATCH] I2C: Separate non-i2c hwmon drivers from i2c-core (7/9)Jean Delvare
Kill normal_isa in header files, documentation and all chip drivers, as it is no more used. normal_i2c could be renamed to normal, but I decided not to do so at the moment, so as to limit the number of changes. This might be done later as part of the i2c_probe/i2c_detect merge. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-05[PATCH] I2C hwmon: add hwmon sysfs class to driversMark M. Hoffman
This patch modifies sensors chip drivers to make use of the new sysfs class "hwmon". Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-07-29[PATCH] I2C: use time_after in 3 chip driversJean Delvare
A few i2c drivers were not updated to use time_after() yet. Signed-off-by: Marcelo Feitoza Parisi <marcelo@feitoza.com.br> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-11[PATCH] I2C: Move hwmon drivers (2/3)Jean Delvare
Part 2: Move the driver files themselves. Note that the patch "adds trailing whitespace", because it does move the files as-is, and some files happen to have trailing whitespace. From: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
