path: root/drivers/hwmon/lm75.c
2015-10-14hwmon: (lm75) Add support for TMP75CBen Gardner
The TMP75C has a different control register layout and only supports 12-bit temperature samples (0.0625 deg C). The continuous sample rate is ~12 Hz. Signed-off-by: Ben Gardner <gardner.ben@gmail.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2015-08-03thermal: consistently use int for temperaturesSascha Hauer
The thermal code uses int, long and unsigned long for temperatures in different places. Using an unsigned type limits the thermal framework to positive temperatures without need. Also several drivers currently will report temperatures near UINT_MAX for temperatures below 0°C. This will probably immediately shut the machine down due to overtemperature if started below 0°C. 'long' is 64bit on several architectures. This is not needed since INT_MAX °mC is above the melting point of all known materials. Consistently use a plain 'int' for temperatures throughout the thermal code and the drivers. This only changes the places in the drivers where the temperature is passed around as pointer, when drivers internally use another type this is not changed. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Geert Uytterhoeven <geert+renesas@glider.be> Reviewed-by: Jean Delvare <jdelvare@suse.de> Reviewed-by: Lukasz Majewski <l.majewski@samsung.com> Reviewed-by: Darren Hart <dvhart@linux.intel.com> Reviewed-by: Heiko Stuebner <heiko@sntech.de> Reviewed-by: Peter Feuerer <peter@piie.net> Cc: Punit Agrawal <punit.agrawal@arm.com> Cc: Zhang Rui <rui.zhang@intel.com> Cc: Eduardo Valentin <edubezval@gmail.com> Cc: linux-pm@vger.kernel.org Cc: linux-kernel@vger.kernel.org Cc: Jean Delvare <jdelvare@suse.de> Cc: Peter Feuerer <peter@piie.net> Cc: Heiko Stuebner <heiko@sntech.de> Cc: Lukasz Majewski <l.majewski@samsung.com> Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: Thierry Reding <thierry.reding@gmail.com> Cc: linux-acpi@vger.kernel.org Cc: platform-driver-x86@vger.kernel.org Cc: linux-arm-kernel@lists.infradead.org Cc: linux-omap@vger.kernel.org Cc: linux-samsung-soc@vger.kernel.org Cc: Guenter Roeck <linux@roeck-us.net> Cc: Rafael J. Wysocki <rjw@rjwysocki.net> Cc: Maxime Ripard <maxime.ripard@free-electrons.com> Cc: Darren Hart <dvhart@infradead.org> Cc: lm-sensors@lm-sensors.org Signed-off-by: Zhang Rui <rui.zhang@intel.com>
2014-12-17Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux Pull thermal management update from Zhang Rui: "Summary: - of-thermal extension to allow drivers to register and use its functionality in a better way, without exploiting thermal core. From Lukasz Majewski. - Fix a bug in intel_soc_dts_thermal driver which calls a sleep function in interrupt handler. From Maurice Petallo. - add a thermal UAPI header file for exporting the thermal generic netlink information to user-space. From Florian Fainelli. - First round of refactoring in Exynos driver. Bartlomiej and Lukasz are attempting to make it lean and easier to understand. - New thermal driver for Rockchip (rk3288), with support for DT thermal. From Caesar Wang. - New thermal driver for Nvidia, Tegra124 SOCTHERM driver, with support for DT thermal. From Mikko Perttunen. - New cooling device, based on common clock framework. From Eduardo Valentin. - a couple of small fixes in thermal core framework. From Srinivas Pandruvada, Javi Merino, Luis Henriques. - Dropping Armada A375-Z1 SoC thermal support as the chip is not in the market, armada folks decided to drop its support. - a couple of small fixes and cleanups in int340x thermal driver" * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux: (58 commits) thermal: provide an UAPI header file Thermal/int340x: Clear the error value of the last acpi_bus_get_device() call thermal/powerclamp: add id for braswell cpu thermal: Intel SoC DTS: Don't do thermal zone update inside spin_lock Thermal: fix platform_no_drv_owner.cocci warnings Thermal/int340x: avoid unnecessary pointer casting thermal: int3403: Delete a check before thermal_zone_device_unregister() thermal/int3400: export uuids thermal: of: Extend current of-thermal.c code to allow setting emulated temp thermal: of: Extend of-thermal to export table of trip points thermal: of: Rename struct __thermal_trip to struct thermal_trip thermal: of: Extend of-thermal.c to provide check if trip point is valid thermal: of: Extend of-thermal.c to provide number of trip points thermal: Fix error path in thermal_init() thermal: lock the thermal zone when switching governors thermal: core: ignore invalid trip temperature thermal: armada: Remove support for A375-Z1 SoC thermal: rockchip: add driver for thermal dt-bindings: document Rockchip thermal thermal: exynos: remove exynos_tmu_data.h include ...
2014-12-05hwmon: (lm75) Strengthen detect functionGuenter Roeck
A chip returning 0x00 in all registers is erroneously detected as LM75. Check hysteresis and temperature limit registers and abort if both are 0 to reduce the likelyhood for this to happen. Reviewed-by: Rob Coulson <rob.coulson@gmail.com> Reviewed-by: Jean Delvare <jdelvare@suse.de> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2014-11-30hwmon: (lm75) Add support for the NXP LM75BMichael Thalmeier
It is basically a faster lm75 with improved (11 bit) resolution. Signed-off-by: Michael Thalmeier <michael.thalmeier@hale.at> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2014-11-20thermal: of: improve of-thermal sensor registration APIEduardo Valentin
Different drivers request API extensions in of-thermal. For this reason, additional callbacks are required to fit the new drivers needs. The current API implementation expects the registering sensor driver to provide a get_temp and get_trend callbacks as function parameters. As the amount of callbacks is growing, this patch changes the existing implementation to use a .ops field to hold all the of thermal callbacks to sensor drivers. This patch also changes the existing of-thermal users to fit the new API design. No functional change is introduced in this patch. Cc: Alexandre Courbot <gnurou@gmail.com> Cc: devicetree@vger.kernel.org Cc: Grant Likely <grant.likely@linaro.org> Cc: Guenter Roeck <linux@roeck-us.net> Cc: Jean Delvare <jdelvare@suse.de> Cc: linux-kernel@vger.kernel.org Cc: linux-pm@vger.kernel.org Cc: linux-tegra@vger.kernel.org Cc: lm-sensors@lm-sensors.org Cc: Rob Herring <robh+dt@kernel.org> Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: Thierry Reding <thierry.reding@gmail.com> Cc: Zhang Rui <rui.zhang@intel.com> Acked-by: Guenter Roeck <linux@roeck-us.net> Tested-by: Mikko Perttunen <mikko.perttunen@kapsi.fi> Reviewed-by: Mikko Perttunen <mikko.perttunen@kapsi.fi> Reviewed-by: Alexandre Courbot <acourbot@nvidia.com> Reviewed-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Eduardo Valentin <edubezval@gmail.com>
2014-08-04hwmon: (lm75) Add support for TMP112Frans Klaver
TMP112 is compatible to LM75. Signed-off-by: Frans Klaver <frans.klaver@xsens.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2014-05-21hwmon: (lm75) Convert to use hwmon_device_register_with_groupsGuenter Roeck
Simplify code and attach hwmon attributes to hwmon device. Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2013-12-04hwmon: lm75: expose to thermal fw via DT nodesEduardo Valentin
This patch adds to lm75 temperature sensor the possibility to expose itself as thermal zone device, registered on the thermal framework. The thermal zone is built only if a device tree node describing a thermal zone for this sensor is present inside the lm75 DT node. Otherwise, the driver behavior will be the same. Note: This patch has also been reviewed by Jean D. He has requested to perform a wider inspection of possible users of thermal and hwmon interaction API. On the other hand, the change on this patch is acceptable on first step of overall code change. Cc: Jean Delvare <khali@linux-fr.org> Cc: lm-sensors@lm-sensors.org Cc: linux-kernel@vger.kernel.org Acked-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Eduardo Valentin <eduardo.valentin@ti.com>
2013-11-18hwmon: (lm75) Add support for GMT G751 chipArnaud Ebalard
This was tested on a NETGEAR ReadyNAS 2120 device (Marvell Armada XP based board, via DT). Signed-off-by: Arnaud Ebalard <arno@natisbad.org> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2013-05-04hwmon: (lm75) Add support for the Dallas/Maxim DS7505Jean Delvare
Basically it's the same as the original DS75 but much faster. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Guenter Roeck <linux@roeck-us.net>
2013-05-04hwmon: (lm75) Tune resolution and sample time per chipJean Delvare
Most LM75-compatible chips can either sample much faster or with a much better resolution than the original LM75 chip. So far the lm75 driver did not let the user take benefit of these improvements. Do it now. I decided to almost always configure the chip to use the best resolution possible, which also means the longest sample time. The only chips for which I didn't are the DS75, DS1775 and STDS75, because they are really too slow in 12-bit mode (1.2 to 1.5 second worst case) so I went for 11-bit mode as a more reasonable tradeoff. This choice is dictated by the fact that the hwmon subsystem is meant for system monitoring, it has never been supposed to be ultra-fast, and as a matter of fact we do cache the sampled values in almost all drivers. If anyone isn't pleased with these default settings, they can always introduce a platform data structure or DT support for the lm75. That being said, it seems nobody ever complained that the driver wouldn't refresh the value faster than every 1.5 second, and the change made it faster for all chips even in 12-bit mode, so I don't expect any complaint. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Guenter Roeck <linux@roeck-us.net>
2013-05-04hwmon: (lm75) Prepare to support per-chip resolution and sample timeJean Delvare
Prepare the lm75 driver to support per-chip resolution and sample time. For now we only make the code generic enough to support it, but we still use the same, unchanged resolution (9-bit) and sample time (1.5 s) for all chips. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Guenter Roeck <linux@roeck-us.net>
2013-05-04hwmon: (lm75) Per-chip configuration register initializationJean Delvare
There is no standard for the configuration register bits of LM75-like chips. We shouldn't blindly clear bits setting the resolution as they are either unused or used for something else on some of the supported chips. So, switch to per-chip configuration initialization. This will allow for better tuning later, for example using more resolution bits when available. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Guenter Roeck <linux@roeck-us.net>
2012-07-21hwmon: (lm75) Convert to use devm_ functionsGuenter Roeck
Convert to use devm_ functions to reduce code size and simplify the code. Signed-off-by: Guenter Roeck <linux@roeck-us.net> Acked-by: Jean Delvare <khali@linux-fr.org>
2012-03-18hwmon: convert drivers/hwmon/* to use module_i2c_driver()Axel Lin
This patch converts the drivers in drivers/hwmon/* to use the module_i2c_driver() macro which makes the code smaller and a bit simpler. Signed-off-by: Axel Lin <axel.lin@gmail.com> Cc: Corentin Labbe <corentin.labbe@geomatys.fr> Cc: Dirk Eibach <eibach@gdsys.de> Cc: "Mark M. Hoffman" <mhoffman@lightlink.com> Cc: Steve Glendinning <steve.glendinning@smsc.com> Cc: Riku Voipio <riku.voipio@iki.fi> Cc: Guillaume Ligneul <guillaume.ligneul@gmail.com> Cc: David George <david.george@ska.ac.za> Cc: "Hans J. Koch" <hjk@hansjkoch.de> Cc: Marc Hulsman <m.hulsman@tudelft.nl> Cc: Rudolf Marek <r.marek@assembler.cz> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2012-01-05hwmon: (lm75) fix checkpatch warningFrans Meulenbroeks
Fixed this: WARNING: strict_strtol is obsolete, use kstrtol instead + error = strict_strtol(buf, 10, &temp); by replacing strict_strtol with kstrtol. Signed-off-by: Frans Meulenbroeks <fransmeulenbroeks@gmail.com> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2012-01-05hwmon: (lm75) added error handlingFrans Meulenbroeks
Add error handling so if lm75_update_device fails an error is returned when reading the value through sysfs. This is closely modeled after the way this is handled in ltc4261. Signed-off-by: Frans Meulenbroeks <fransmeulenbroeks@gmail.com> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2011-11-04hwmon: Use i2c_smbus_{read,write}_word_swappedJean Delvare
Make use of the new i2c_smbus_{read,write}_word_swapped functions. This makes the driver code more compact and readable. It also ensures proper error handling. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Jonathan Cameron <jic23@cam.ac.uk> Acked-by: Guenter Roeck <guenter.roeck@ericsson.com> Cc: Dirk Eibach <eibach@gdsys.de> Cc: "Mark M. Hoffman" <mhoffman@lightlink.com> Cc: Guillaume Ligneul <guillaume.ligneul@gmail.com>
2011-10-24hwmon: (lm75) Document why clones are not detectedJean Delvare
Explain why clones of the LM75 are generally not detected by the driver, and why this isn't going to change. Also update the documentation to reflect the list of chip names currently supported by the driver. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2011-10-24hwmon: (lm75) Add support for Analog Devices ADT75Michael Hennerich
Add datasheet reference and device ID for ADT75. The ADT75, like some other LM75 derivatives, needs to be instantiated using methods 1, 2, or 4. For more information see Documentation/i2c/instantiating-devices. Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Acked-by: Jonathan Cameron <jic23@cam.ac.uk> Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2011-03-21hwmon: (lm75) Speed up detectionJean Delvare
Make the LM75/LM75A device detection faster: * Don't read the current temperature value when we don't use it. * Check for unused bits in the configuration register as soon as we have read its value. * Don't use word reads, not all devices support this, and some which don't misbehave when you try. * Check for cycling register values every 40 register addresses instead of every 8, it's 5 times faster and just as efficient. Some of these improvements come straight from the user-space sensors-detect script, so both detection routines are in line now. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Len Sorensen <lsorense@csclub.uwaterloo.ca> Acked-by: Guenter Roeck <guenter.roeck@ericsson.com>
2011-03-21hwmon: (lm75) Add detection of the National Semiconductor LM75ALen Sorensen
Add support for detection of the National Semiconductor LM75A using the ID register value. Signed-off-by: Len Sorensen <lsorense@csclub.uwaterloo.ca> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-10-28hwmon: (lm75) Trivial changes to pacify the checkpatchShubhrajyoti D
Some trivial changes to pacify the checkpatch. Signed-off-by: Shubhrajyoti D <shubhrajyoti@ti.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-10-28hwmon: (lm75) Make the writing to sysfs more robustShubhrajyoti D
Currently we get the checkpatch warning consider using strict_strtol in preference to simple_strtol. Also we should not allow any partially numeric values. Signed-off-by: Shubhrajyoti D <shubhrajyoti@ti.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-08-14hwmon: (lm75) Add suspend/resume featureShubhrajyoti Datta
There is a shutdown feature at suspend it can be enabled to reduce current consumption and resume it can be switched off. Signed-off-by: Shubhrajyoti Datta <shubhrajyoti@ti.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-06-03i2c: Remove all i2c_set_clientdata(client, NULL) in driversWolfram Sang
I2C drivers can use the clientdata-pointer to point to private data. As I2C devices are not really unregistered, but merely detached from their driver, it used to be the drivers obligation to clear this pointer during remove() or a failed probe(). As a couple of drivers forgot to do this, it was agreed that it was cleaner if the i2c-core does this clearance when appropriate, as there is no guarantee for the lifetime of the clientdata-pointer after remove() anyhow. This feature was added to the core with commit e4a7b9b04de15f6b63da5ccdd373ffa3057a3681 to fix the faulty drivers. As there is no need anymore to clear the clientdata-pointer, remove all current occurrences in the drivers to simplify the code and prevent confusion. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: Richard Purdie <rpurdie@linux.intel.com> Acked-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-05-27hwmon: (lm75) Add support for the Texas Instruments TMP105Shubhrajyoti Datta
Add support for the Texas Instruments TMP105 temperature sensor device. Signed-off-by: Shubhrajyoti Datta <shubhrajyoti@ti.com> Acked-by: Jonathan Cameron <jic23@cam.ac.uk> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2009-12-14i2c: Drop I2C_CLIENT_INSMOD_1Jean Delvare
This macro simply declares an enum, so drivers might as well declare it themselves. Signed-off-by: Jean Delvare <khali@linux-fr.org> Tested-by: Wolfram Sang <w.sang@pengutronix.de>
2009-12-14i2c: Get rid of struct i2c_client_address_dataJean Delvare
Struct i2c_client_address_data only contains one field at this point, which makes its usefulness questionable. Get rid of it and pass simple address lists around instead. Signed-off-by: Jean Delvare <khali@linux-fr.org> Tested-by: Wolfram Sang <w.sang@pengutronix.de>
2009-12-14i2c: Drop the kind parameter from detect callbacksJean Delvare
The "kind" parameter always has value -1, and nobody is using it any longer, so we can remove it. Signed-off-by: Jean Delvare <khali@linux-fr.org> Tested-by: Wolfram Sang <w.sang@pengutronix.de>
2009-12-09hwmon: Clean up detect functionsJean Delvare
As kind is now hard-coded to -1, there is room for code clean-ups. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Corentin Labbe <corentin.labbe@geomatys.fr> Cc: "Mark M. Hoffman" <mhoffman@lightlink.com> Cc: Juerg Haefliger <juergh@gmail.com> Cc: Riku Voipio <riku.voipio@iki.fi> Acked-by: "Hans J. Koch" <hjk@linutronix.de> Cc: Rudolf Marek <r.marek@assembler.cz>
2009-01-06hwmon: struct device - replace bus_id with dev_name(), dev_set_name()Kay Sievers
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-08-10hwmon: (lm75) Drop legacy i2c driverJean Delvare
Drop the legacy lm75 driver, and add a detect callback to the new-style driver to achieve the same functionality. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: David Brownell <david-b@pacbell.net>
2008-07-31hwmon: (lm75) add new-style driver bindingDavid Brownell
More LM75 updates: - Teach the LM75 driver to use new-style driver binding: * Create a second driver struct, using new-style driver binding methods cribbed from the legacy code. * Add a MODULE_DEVICE_TABLE (for "newER-style binding") * The legacy probe logic delegates its work to this new code. * The legacy driver now uses the name "lm75_legacy". - More careful initialization. Chips are put into 9-bit mode so the current interconversion routines will never fail. - Save the original chip configuration, and restore it on exit. (Among other things, this normally turns off the mode where the chip is constantly sampling ... and thus saves power.) So the new-style code should catch all chips that boards declare, while the legacy code catches others. This particular coexistence strategy may need some work yet ... legacy modes might best be set up explicitly by some tool not unlike "sensors-detect". (Or else completely eradicated...) Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2008-07-31hwmon: (lm75) cleanup/reorgDavid Brownell
Minor cleanup and reorg of the lm75 code. - Kconfig provides a larger list of lm75-compatible chips - A top comment now says what the driver does (!) ... as in, just what sort of sensor is this?? - Section comments now delineate the various sections of the driver: hwmon attributes, driver binding, register access, module glue. One driver binding function moved out of the attribute section, as did the driver struct itself. - Minor tweaks to legacy probe logic: correct a comment, and remove a pointless variable. - Whitespace, linelength, and comment fixes. This patch should include no functional changes. It's preparation for adding new-style (driver model) I2C driver binding. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Jean Delvare <khali@linux-fr.org> Acked-by: Laurent Pinchart <laurentp@cse-semaphore.com> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2008-06-19hwmon: (lm75) sensor reading bugfixDavid Brownell
LM75 sensor reading bugfix: never save error status as valid sensor output. This could be improved, but at least this prevents certain rude failure modes. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2008-04-27hwmon: (lm75) Fix an incorrect commentJean Delvare
High-byte first is not opposite to the usual practice - that's what almost all hardware monitoring drivers do. It is opposite to the SMBus standard though. Also delete a duplicate comment. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2008-02-18hwmon: normal_i2c arrays should be constMark M. Hoffman
2008-02-07hwmon: Discard useless I2C driver IDsJean Delvare
Many I2C hwmon drivers define a driver ID but no other code references these, meaning that they are useless. Discard them, along with a few IDs which are defined but never used at all. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2007-10-09hwmon: Convert from class_device to deviceTony Jones
Convert from class_device to device for hwmon_device_register/unregister Signed-off-by: Tony Jones <tonyj@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2007-10-09hwmon: Allow writing of negative trigger temperaturesChristian Hohnstaedt
- replace differing temperature variable types by long - use strtol() instead of strtoul() for conversion Signed-off-by: Christian Hohnstaedt <chohnstaedt@innominate.com> Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2007-05-08hwmon/lm75: Use dynamic sysfs callbacksJean Delvare
This lets us get rid of macro-generated functions and shrinks the driver size by about 8%. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2006-09-28hwmon: Fix unchecked return status, batch 1Mark M. Hoffman
hwmon: Fix unchecked return status, batch 1 Fix up some hwmon drivers so that they no longer ignore return status from device_create_file(). Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-23[PATCH] hwmon: Semaphore to mutex conversionsIngo Molnar
convert drivers/hwmon/*.c semaphore use to mutexes. the conversion was generated via scripts, and the result was validated automatically via a script as well. all affected hwmon drivers were build-tested. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-05[PATCH] I2C: Remove .owner setting from i2c_driver as it's no longer neededGreg Kroah-Hartman
Now that i2c_add_driver() doesn't need the module owner to be set by hand, we can delete it from the drivers. This patch catches all of the drivers that I found in the current tree (if a driver sets the .owner by hand, it's not a problem, just not needed.) Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Cc: Jean Delvare <khali@linux-fr.org>
2006-01-05[PATCH] i2c: Drop i2c_driver.{owner,name}, 3 of 11Laurent Riffard
We should use the i2c_driver.driver's .name and .owner fields instead of the i2c_driver's ones. This patch updates the hwmon drivers. Signed-off-by: Laurent Riffard <laurent.riffard@free.fr> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-05[PATCH] i2c: Drop i2c_driver.flags, 2 of 3Jean Delvare
Just about every i2c chip driver sets the I2C_DF_NOTIFY flag, so we can simply make it the default and drop the flag. If any driver really doesn't want to be notified when i2c adapters are added, that driver can simply omit to set .attach_adapter. This approach is also more robust as it prevents accidental NULL pointer dereferences. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] hwmon: kzalloc conversionDeepak Saxena
Use kzalloc instead of kmalloc+memset in all hardware monitoring drivers. Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-05[PATCH] hwmon: hwmon vs i2c, second round (06/11)Jean Delvare
The only thing left in i2c-sensor.h are module parameter definition macros. It's only an extension of what i2c.h offers, and this extension is not sensors-specific. As a matter of fact, a few non-sensors drivers use them. So we better merge them in i2c.h, and get rid of i2c-sensor.h altogether. Signed-off-by: Jean Delvare <khali@linux-fr> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
