path: root/drivers/hwmon/lm95241.c
2016-09-13hwmon: (lm95241) Update module description to include LM95231Axel Lin
This driver also supports LM95231. Signed-off-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2016-09-08hwmon: (lm95241) Convert to use new hwmon registration APIGuenter Roeck
Simplify code and reduce code size by using the new hwmon registration API. Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2016-09-08hwmon: (lm95241) Use more accurate limitsGuenter Roeck
The lower temperature limit is -128 degrees C. The supported upper limits are 127.875 or 255.875 degrees C. Also, don't fail if a value outside the supported range is provided when setting a temperature limit. Instead, clamp the provided value to the available value range. Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2016-09-08hwmon: (lm95241) Use BIT macro where appropriateGuenter Roeck
Drop some of the SHIFT defines since shift is implied with BIT(). Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2016-09-08hwmon: (lm95241) Drop FSF addressGuenter Roeck
The FSF address may change, and providing it does not add any value. Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2016-09-08hwmon: (lm95241) Order include files alphabeticallyGuenter Roeck
Simplify detecting duplicate include files and finding the right place for adding new ones. Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2016-09-08hwmon: (lm95241) Add support for fault attributesGuenter Roeck
The chip reports if remote diodes are present, which can be used for the fault attrributes. Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2016-09-08hwmon: (lm95241) Fix overflow problems, write conversion rate to chipGuenter Roeck
Writing the update_interval attribute could result in an overflow if a number close to the maximum unsigned long was written. At the same time, even though the chip supports setting the conversion rate, the selected conversion rate was not actually written to the chip. Fix the second problem by selecting valid (supported) conversion rates, and writing the selected conversion rate to the chip. This also fixes the first problem, since arbitrary conversion rates are now converted to actually supported conversion rates. Also, set the default chip conversion rate to 1 second. Previously, the chip was configured for continuous conversion, but readings were only retrieved every seond, which doesn't make much sense. If we only read a value from the chip every second, we can as well save some power and only convert in one-second intervals. Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2014-03-03hwmon: (lm95241) Avoid initializing the same field twiceJean Delvare
data is kzalloc'd, so data->valid and data->model are already 0. Signed-off-by: Jean Delvare <jdelvare@suse.de> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2014-03-03hwmon: (lm95241) Convert to use devm_hwmon_device_register_with_groupsGuenter Roeck
Simplify code, reduce code size, and attach hwmon attributes to hwmon device. Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2012-09-23hwmon: (lm95241) Convert to use devm_ functionsGuenter Roeck
Convert to use devm_ functions to reduce code size and simplify the code. Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2012-03-18hwmon: convert drivers/hwmon/* to use module_i2c_driver()Axel Lin
This patch converts the drivers in drivers/hwmon/* to use the module_i2c_driver() macro which makes the code smaller and a bit simpler. Signed-off-by: Axel Lin <axel.lin@gmail.com> Cc: Corentin Labbe <corentin.labbe@geomatys.fr> Cc: Dirk Eibach <eibach@gdsys.de> Cc: "Mark M. Hoffman" <mhoffman@lightlink.com> Cc: Steve Glendinning <steve.glendinning@smsc.com> Cc: Riku Voipio <riku.voipio@iki.fi> Cc: Guillaume Ligneul <guillaume.ligneul@gmail.com> Cc: David George <david.george@ska.ac.za> Cc: "Hans J. Koch" <hjk@hansjkoch.de> Cc: Marc Hulsman <m.hulsman@tudelft.nl> Cc: Rudolf Marek <r.marek@assembler.cz> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2012-01-05hwmon: replaced strict_str* with kstr*Frans Meulenbroeks
replaced strict_strtol with kstrtol and replaced strict_strtuol with kstrtuol This satisfies checkpatch -f Compile tested only: no warnings or errors given Signed-off-by: Frans Meulenbroeks <fransmeulenbroeks@gmail.com> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2011-07-28hwmon: (lm95241) Add support for LM95231Guenter Roeck
LM95231 is fully compatible to LM95241; only necessary change is to add chip detection. Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Acked-by: Jean Delvare <khali@linux-fr.org>
2011-07-10hwmon: (lm95241) Fix negative temperature resultsGuenter Roeck
Negative temperatures were returned in degrees C instead of milli-Degrees C. Also, negative temperatures were reported for remote temperature sensors even if the chip was configured for positive-only results. Fix by detecting temperature modes, and by treating negative temperatures similar to positive temperatures, with appropriate sign extension. Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Acked-by: Jean Delvare <khali@linux-fr.org> Cc: stable@kernel.org # 2.6.30+
2011-07-08hwmon: (lm95241) Fix chip detection codeGuenter Roeck
The LM95241 driver accepts every chip ID equal to or larger than 0xA4 as its own, and other chips such as LM95245 use chip IDs in the accepted ID range. This results in false chip detection. Fix problem by accepting only the known LM95241 chip ID. Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Acked-by: Jean Delvare <khali@linux-fr.org> Cc: stable@kernel.org # 2.6.30+
2011-01-08hwmon: (lm95241) Rewrite to avoid using macrosDavide Rizzo
Signed-off-by: Davide Rizzo <elpa.rizzo@gmail.com> [guenter.roeck@ericsson.com: Formatting changes] Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2010-11-15hwmon: (lm95241) Check validity of input valuesJean Delvare
This clears the following build-time warnings I was seeing: drivers/hwmon/lm95241.c: In function "set_interval": drivers/hwmon/lm95241.c:132:15: warning: ignoring return value of "strict_strtol", declared with attribute warn_unused_result drivers/hwmon/lm95241.c: In function "set_max2": drivers/hwmon/lm95241.c:278:1: warning: ignoring return value of "strict_strtol", declared with attribute warn_unused_result drivers/hwmon/lm95241.c: In function "set_max1": drivers/hwmon/lm95241.c:277:1: warning: ignoring return value of "strict_strtol", declared with attribute warn_unused_result drivers/hwmon/lm95241.c: In function "set_min2": drivers/hwmon/lm95241.c:249:1: warning: ignoring return value of "strict_strtol", declared with attribute warn_unused_result drivers/hwmon/lm95241.c: In function "set_min1": drivers/hwmon/lm95241.c:248:1: warning: ignoring return value of "strict_strtol", declared with attribute warn_unused_result drivers/hwmon/lm95241.c: In function "set_type2": drivers/hwmon/lm95241.c:220:1: warning: ignoring return value of "strict_strtol", declared with attribute warn_unused_result drivers/hwmon/lm95241.c: In function "set_type1": drivers/hwmon/lm95241.c:219:1: warning: ignoring return value of "strict_strtol", declared with attribute warn_unused_result This also fixes a small race in set_interval() as a side effect: by working with a temporary local variable we prevent data->interval from being accessed at a time it contains the interval value in the wrong unit. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Davide Rizzo <elpa.rizzo@gmail.com>
2010-09-17hwmon: (lm95241) Replace rate sysfs attribute with update_intervalGuenter Roeck
update_interval is the matching attribute defined in the hwmon sysfs ABI. Use it. Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-06-03i2c: Remove all i2c_set_clientdata(client, NULL) in driversWolfram Sang
I2C drivers can use the clientdata-pointer to point to private data. As I2C devices are not really unregistered, but merely detached from their driver, it used to be the drivers obligation to clear this pointer during remove() or a failed probe(). As a couple of drivers forgot to do this, it was agreed that it was cleaner if the i2c-core does this clearance when appropriate, as there is no guarantee for the lifetime of the clientdata-pointer after remove() anyhow. This feature was added to the core with commit e4a7b9b04de15f6b63da5ccdd373ffa3057a3681 to fix the faulty drivers. As there is no need anymore to clear the clientdata-pointer, remove all current occurrences in the drivers to simplify the code and prevent confusion. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: Richard Purdie <rpurdie@linux.intel.com> Acked-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2009-12-14i2c: Drop I2C_CLIENT_INSMOD_1Jean Delvare
This macro simply declares an enum, so drivers might as well declare it themselves. Signed-off-by: Jean Delvare <khali@linux-fr.org> Tested-by: Wolfram Sang <w.sang@pengutronix.de>
2009-12-14i2c: Get rid of struct i2c_client_address_dataJean Delvare
Struct i2c_client_address_data only contains one field at this point, which makes its usefulness questionable. Get rid of it and pass simple address lists around instead. Signed-off-by: Jean Delvare <khali@linux-fr.org> Tested-by: Wolfram Sang <w.sang@pengutronix.de>
2009-12-14i2c: Drop the kind parameter from detect callbacksJean Delvare
The "kind" parameter always has value -1, and nobody is using it any longer, so we can remove it. Signed-off-by: Jean Delvare <khali@linux-fr.org> Tested-by: Wolfram Sang <w.sang@pengutronix.de>
2009-12-09hwmon: Clean up detect functionsJean Delvare
As kind is now hard-coded to -1, there is room for code clean-ups. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Corentin Labbe <corentin.labbe@geomatys.fr> Cc: "Mark M. Hoffman" <mhoffman@lightlink.com> Cc: Juerg Haefliger <juergh@gmail.com> Cc: Riku Voipio <riku.voipio@iki.fi> Acked-by: "Hans J. Koch" <hjk@linutronix.de> Cc: Rudolf Marek <r.marek@assembler.cz>
2009-04-07hwmon: (lm95241) Convert to new-style i2c driverJean Delvare
The legacy i2c binding model is going away really soon now, so convert the lm95241 driver to the new binding model or it will break. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Davide Rizzo <elpa.rizzo@gmail.com>
2009-04-01hwmon: LM95241 driverDavide Rizzo
An hwmon driver for the National Semiconductor LM95241 triple temperature sensors chip Signed-off-by: Davide Rizzo <elpa-rizzo@gmail.com> Cc: Jean Delvare <khali@linux-fr.org> Cc: "Mark M. Hoffman" <mhoffman@lightlink.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
