path: root/drivers/hwmon/pcf8591.c
2009-12-14i2c: Drop I2C_CLIENT_INSMOD_1Jean Delvare
This macro simply declares an enum, so drivers might as well declare it themselves. Signed-off-by: Jean Delvare <khali@linux-fr.org> Tested-by: Wolfram Sang <w.sang@pengutronix.de>
2009-12-14i2c: Get rid of struct i2c_client_address_dataJean Delvare
Struct i2c_client_address_data only contains one field at this point, which makes its usefulness questionable. Get rid of it and pass simple address lists around instead. Signed-off-by: Jean Delvare <khali@linux-fr.org> Tested-by: Wolfram Sang <w.sang@pengutronix.de>
2009-12-14i2c: Drop the kind parameter from detect callbacksJean Delvare
The "kind" parameter always has value -1, and nobody is using it any longer, so we can remove it. Signed-off-by: Jean Delvare <khali@linux-fr.org> Tested-by: Wolfram Sang <w.sang@pengutronix.de>
2009-03-30Move the pcf8591 driver to hwmonJean Delvare
Directory drivers/i2c/chips is going away, so drivers there must find new homes. For the pcf8591 driver, the best choice seems to be the hwmon subsystem. While the Philips PCF8591 device isn't a typical hardware monitoring chip, its DAC interface is compatible with the hwmon one, so it fits somewhat. If a better subsystem is ever created for ADC/DAC chips, the driver could be moved there. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Aurelien Jarno <aurelien@aurel32.net>
