2019-05-16 | hwmon: (pwm-fan) Disable PWM if fetching cooling data fails | Stefan Wahren | |
commit 53f1647da3e8fb3e89066798f0fdc045064d353d upstream. In case pwm_fan_of_get_cooling_data() fails we should disable the PWM just like in the other error cases. Fixes: 2e5219c77183 ("hwmon: (pwm-fan) Read PWM FAN configuration from device tree") Cc: <stable@vger.kernel.org> # 4.14+ Reported-by: Guenter Rock <linux@roeck-us.net> Signed-off-by: Stefan Wahren <stefan.wahren@i2se.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> | |||
2018-12-16 | hwmon: (pwm-fan) Auto-convert to use SENSOR_DEVICE_ATTR_{RO, RW, WO} | Guenter Roeck | |
Conversion was done done using the coccinelle script at https://github.com/groeck/coccinelle-patches/raw/master/hwmon/sensor-devattr-w6.cocci Signed-off-by: Guenter Roeck <linux@roeck-us.net> | |||
2018-10-10 | hwmon: (pwm-fan) Set fan speed to 0 on suspend | Thierry Reding | |
Technically this is not required because disabling the PWM should be enough. However, when support for atomic operations was implemented in the PWM subsystem, only actual changes to the PWM channel are applied during pwm_config(), which means that during after resume from suspend the old settings won't be applied. One possible solution is for the PWM driver to implement its own PM operations such that settings from before suspend get applied on resume. This has the disadvantage of completely ignoring any particular ordering requirements that PWM user drivers might have, so it is best to leave it up to the user drivers to apply the settings that they want at the appropriate time. Another way to solve this would be to read back the current state of the PWM at the time of resume. That way, in case the configuration was lost during suspend, applying the old settings in PWM user drivers would actually get them applied because they differ from the current settings. However, not all PWM drivers support reading the hardware state, and not all hardware may support it. The best workaround at this point seems to be to let PWM user drivers tell the PWM subsystem that the PWM is turned off by, in addition to disabling it, also setting the duty cycle to 0. This causes the resume operation to apply a configuration that is different from the current configuration, resulting in the proper state from before suspend getting restored. Signed-off-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net> | |||
2018-10-10 | hwmon: (pwm-fan) Silence error on probe deferral | Thierry Reding | |
Probe deferrals aren't actual errors, so silence the error message in case the PWM cannot yet be acquired. Signed-off-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net> | |||
2018-06-12 | treewide: devm_kzalloc() -> devm_kcalloc() | Kees Cook | |
The devm_kzalloc() function has a 2-factor argument form, devm_kcalloc(). This patch replaces cases of: devm_kzalloc(handle, a * b, gfp) with: devm_kcalloc(handle, a * b, gfp) as well as handling cases of: devm_kzalloc(handle, a * b * c, gfp) with: devm_kzalloc(handle, array3_size(a, b, c), gfp) as it's slightly less ugly than: devm_kcalloc(handle, array_size(a, b), c, gfp) This does, however, attempt to ignore constant size factors like: devm_kzalloc(handle, 4 * 1024, gfp) though any constants defined via macros get caught up in the conversion. Any factors with a sizeof() of "unsigned char", "char", and "u8" were dropped, since they're redundant. Some manual whitespace fixes were needed in this patch, as Coccinelle really liked to write "=devm_kcalloc..." instead of "= devm_kcalloc...". The Coccinelle script used for this was: // Fix redundant parens around sizeof(). @@ expression HANDLE; type TYPE; expression THING, E; @@ ( devm_kzalloc(HANDLE, - (sizeof(TYPE)) * E + sizeof(TYPE) * E , ...) | devm_kzalloc(HANDLE, - (sizeof(THING)) * E + sizeof(THING) * E , ...) ) // Drop single-byte sizes and redundant parens. @@ expression HANDLE; expression COUNT; typedef u8; typedef __u8; @@ ( devm_kzalloc(HANDLE, - sizeof(u8) * (COUNT) + COUNT , ...) | devm_kzalloc(HANDLE, - sizeof(__u8) * (COUNT) + COUNT , ...) | devm_kzalloc(HANDLE, - sizeof(char) * (COUNT) + COUNT , ...) | devm_kzalloc(HANDLE, - sizeof(unsigned char) * (COUNT) + COUNT , ...) | devm_kzalloc(HANDLE, - sizeof(u8) * COUNT + COUNT , ...) | devm_kzalloc(HANDLE, - sizeof(__u8) * COUNT + COUNT , ...) | devm_kzalloc(HANDLE, - sizeof(char) * COUNT + COUNT , ...) | devm_kzalloc(HANDLE, - sizeof(unsigned char) * COUNT + COUNT , ...) ) // 2-factor product with sizeof(type/expression) and identifier or constant. @@ expression HANDLE; type TYPE; expression THING; identifier COUNT_ID; constant COUNT_CONST; @@ ( - devm_kzalloc + devm_kcalloc (HANDLE, - sizeof(TYPE) * (COUNT_ID) + COUNT_ID, sizeof(TYPE) , ...) | - devm_kzalloc + devm_kcalloc (HANDLE, - sizeof(TYPE) * COUNT_ID + COUNT_ID, sizeof(TYPE) , ...) | - devm_kzalloc + devm_kcalloc (HANDLE, - sizeof(TYPE) * (COUNT_CONST) + COUNT_CONST, sizeof(TYPE) , ...) | - devm_kzalloc + devm_kcalloc (HANDLE, - sizeof(TYPE) * COUNT_CONST + COUNT_CONST, sizeof(TYPE) , ...) | - devm_kzalloc + devm_kcalloc (HANDLE, - sizeof(THING) * (COUNT_ID) + COUNT_ID, sizeof(THING) , ...) | - devm_kzalloc + devm_kcalloc (HANDLE, - sizeof(THING) * COUNT_ID + COUNT_ID, sizeof(THING) , ...) | - devm_kzalloc + devm_kcalloc (HANDLE, - sizeof(THING) * (COUNT_CONST) + COUNT_CONST, sizeof(THING) , ...) | - devm_kzalloc + devm_kcalloc (HANDLE, - sizeof(THING) * COUNT_CONST + COUNT_CONST, sizeof(THING) , ...) ) // 2-factor product, only identifiers. @@ expression HANDLE; identifier SIZE, COUNT; @@ - devm_kzalloc + devm_kcalloc (HANDLE, - SIZE * COUNT + COUNT, SIZE , ...) // 3-factor product with 1 sizeof(type) or sizeof(expression), with // redundant parens removed. @@ expression HANDLE; expression THING; identifier STRIDE, COUNT; type TYPE; @@ ( devm_kzalloc(HANDLE, - sizeof(TYPE) * (COUNT) * (STRIDE) + array3_size(COUNT, STRIDE, sizeof(TYPE)) , ...) | devm_kzalloc(HANDLE, - sizeof(TYPE) * (COUNT) * STRIDE + array3_size(COUNT, STRIDE, sizeof(TYPE)) , ...) | devm_kzalloc(HANDLE, - sizeof(TYPE) * COUNT * (STRIDE) + array3_size(COUNT, STRIDE, sizeof(TYPE)) , ...) | devm_kzalloc(HANDLE, - sizeof(TYPE) * COUNT * STRIDE + array3_size(COUNT, STRIDE, sizeof(TYPE)) , ...) | devm_kzalloc(HANDLE, - sizeof(THING) * (COUNT) * (STRIDE) + array3_size(COUNT, STRIDE, sizeof(THING)) , ...) | devm_kzalloc(HANDLE, - sizeof(THING) * (COUNT) * STRIDE + array3_size(COUNT, STRIDE, sizeof(THING)) , ...) | devm_kzalloc(HANDLE, - sizeof(THING) * COUNT * (STRIDE) + array3_size(COUNT, STRIDE, sizeof(THING)) , ...) | devm_kzalloc(HANDLE, - sizeof(THING) * COUNT * STRIDE + array3_size(COUNT, STRIDE, sizeof(THING)) , ...) ) // 3-factor product with 2 sizeof(variable), with redundant parens removed. @@ expression HANDLE; expression THING1, THING2; identifier COUNT; type TYPE1, TYPE2; @@ ( devm_kzalloc(HANDLE, - sizeof(TYPE1) * sizeof(TYPE2) * COUNT + array3_size(COUNT, sizeof(TYPE1), sizeof(TYPE2)) , ...) | devm_kzalloc(HANDLE, - sizeof(TYPE1) * sizeof(THING2) * (COUNT) + array3_size(COUNT, sizeof(TYPE1), sizeof(TYPE2)) , ...) | devm_kzalloc(HANDLE, - sizeof(THING1) * sizeof(THING2) * COUNT + array3_size(COUNT, sizeof(THING1), sizeof(THING2)) , ...) | devm_kzalloc(HANDLE, - sizeof(THING1) * sizeof(THING2) * (COUNT) + array3_size(COUNT, sizeof(THING1), sizeof(THING2)) , ...) | devm_kzalloc(HANDLE, - sizeof(TYPE1) * sizeof(THING2) * COUNT + array3_size(COUNT, sizeof(TYPE1), sizeof(THING2)) , ...) | devm_kzalloc(HANDLE, - sizeof(TYPE1) * sizeof(THING2) * (COUNT) + array3_size(COUNT, sizeof(TYPE1), sizeof(THING2)) , ...) ) // 3-factor product, only identifiers, with redundant parens removed. @@ expression HANDLE; identifier STRIDE, SIZE, COUNT; @@ ( devm_kzalloc(HANDLE, - (COUNT) * STRIDE * SIZE + array3_size(COUNT, STRIDE, SIZE) , ...) | devm_kzalloc(HANDLE, - COUNT * (STRIDE) * SIZE + array3_size(COUNT, STRIDE, SIZE) , ...) | devm_kzalloc(HANDLE, - COUNT * STRIDE * (SIZE) + array3_size(COUNT, STRIDE, SIZE) , ...) | devm_kzalloc(HANDLE, - (COUNT) * (STRIDE) * SIZE + array3_size(COUNT, STRIDE, SIZE) , ...) | devm_kzalloc(HANDLE, - COUNT * (STRIDE) * (SIZE) + array3_size(COUNT, STRIDE, SIZE) , ...) | devm_kzalloc(HANDLE, - (COUNT) * STRIDE * (SIZE) + array3_size(COUNT, STRIDE, SIZE) , ...) | devm_kzalloc(HANDLE, - (COUNT) * (STRIDE) * (SIZE) + array3_size(COUNT, STRIDE, SIZE) , ...) | devm_kzalloc(HANDLE, - COUNT * STRIDE * SIZE + array3_size(COUNT, STRIDE, SIZE) , ...) ) // Any remaining multi-factor products, first at least 3-factor products, // when they're not all constants... @@ expression HANDLE; expression E1, E2, E3; constant C1, C2, C3; @@ ( devm_kzalloc(HANDLE, C1 * C2 * C3, ...) | devm_kzalloc(HANDLE, - (E1) * E2 * E3 + array3_size(E1, E2, E3) , ...) | devm_kzalloc(HANDLE, - (E1) * (E2) * E3 + array3_size(E1, E2, E3) , ...) | devm_kzalloc(HANDLE, - (E1) * (E2) * (E3) + array3_size(E1, E2, E3) , ...) | devm_kzalloc(HANDLE, - E1 * E2 * E3 + array3_size(E1, E2, E3) , ...) ) // And then all remaining 2 factors products when they're not all constants, // keeping sizeof() as the second factor argument. @@ expression HANDLE; expression THING, E1, E2; type TYPE; constant C1, C2, C3; @@ ( devm_kzalloc(HANDLE, sizeof(THING) * C2, ...) | devm_kzalloc(HANDLE, sizeof(TYPE) * C2, ...) | devm_kzalloc(HANDLE, C1 * C2 * C3, ...) | devm_kzalloc(HANDLE, C1 * C2, ...) | - devm_kzalloc + devm_kcalloc (HANDLE, - sizeof(TYPE) * (E2) + E2, sizeof(TYPE) , ...) | - devm_kzalloc + devm_kcalloc (HANDLE, - sizeof(TYPE) * E2 + E2, sizeof(TYPE) , ...) | - devm_kzalloc + devm_kcalloc (HANDLE, - sizeof(THING) * (E2) + E2, sizeof(THING) , ...) | - devm_kzalloc + devm_kcalloc (HANDLE, - sizeof(THING) * E2 + E2, sizeof(THING) , ...) | - devm_kzalloc + devm_kcalloc (HANDLE, - (E1) * E2 + E1, E2 , ...) | - devm_kzalloc + devm_kcalloc (HANDLE, - (E1) * (E2) + E1, E2 , ...) | - devm_kzalloc + devm_kcalloc (HANDLE, - E1 * E2 + E1, E2 , ...) ) Signed-off-by: Kees Cook <keescook@chromium.org> | |||
2017-06-11 | hwmon: (pwm-fan) Switch to new atomic PWM API | Bartlomiej Zolnierkiewicz | |
Switch pwm-fan driver to new atomic PWM API. Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net> | |||
2016-05-17 | hwmon: pwm-fan: Use pwm_get_args() where appropriate | Boris Brezillon | |
The PWM framework has clarified the concept of reference PWM config (the platform dependent config retrieved from the DT or the PWM lookup table) and real PWM state. Use pwm_get_args() when the PWM user wants to retrieve this reference config and not the current state. This is part of the rework allowing the PWM framework to support hardware readout and expose real PWM state even when the PWM has just been requested (before the user calls pwm_config/enable/disable()). Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com> Acked-by: Kamil Debski <k.debski@samsung.com> Signed-off-by: Thierry Reding <thierry.reding@gmail.com> | |||
2015-09-20 | hwmon: (pwm-fan) Fix module autoload for OF platform driver | Luis de Bethencourt | |
This platform driver has a OF device ID table but the OF module alias information is not created so module autoloading won't work. Signed-off-by: Luis de Bethencourt <luisbg@osg.samsung.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net> | |||
2015-04-12 | hwmon: (pwm-fan) Update the duty cycle inorder to control the pwm-fan | Anand Moon | |
pwm_config() must be called with a duty cycle of 0 prior to calling pwm_disable() to ensure that the pwm signal is set to low. Reported-by: Markus Reichl <m.reichl@fivetechno.de> Tested-by: Markus Reichl <m.reichl@fivetechno.de> Reviewed-by: Lukasz Majewski <l.majewski@samsung.com> Reviewed-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk> Signed-off-by: Anand Moon <linux.amoon@gmail.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net> | |||
2015-03-16 | hwmon: (pwm-fan, vexpress) Constify of_device_id array | Fabian Frederick | |
of_device_id is always used as const. (See driver.of_match_table and open firmware functions) Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Guenter Roeck <linux@roeck-us.net> | |||
2015-03-09 | hwmon: (pwm-fan) Declare pwm_fan_of_get_cooling_data static | Guenter Roeck | |
Address the following sparse warnings. drivers/hwmon/pwm-fan.c:176:5: warning: symbol 'pwm_fan_of_get_cooling_data' was not declared. Should it be static? drivers/hwmon/pwm-fan.c:176:5: warning: no previous prototype for 'pwm_fan_of_get_cooling_data' pwm_fan_of_get_cooling_data is only used in the pwm-fan driver and thus should be declared static. Cc: Lukasz Majewski <l.majewski@samsung.com> Acked-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net> | |||
2015-03-09 | hwmon: (pwm-fan) Add support for using PWM FAN as a cooling device | Lukasz Majewski | |
The PWM FAN device can now be used as a thermal cooling device. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Acked-by: Eduardo Valentin <edubezval@gmail.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net> | |||
2015-03-09 | hwmon: (pwm-fan) Read PWM FAN configuration from device tree | Lukasz Majewski | |
This patch provides code for reading PWM FAN configuration data via device tree. The pwm-fan can work with full speed when configuration is not provided. However, errors are propagated when wrong DT bindings are found. Additionally the struct pwm_fan_ctx has been extended. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net> | |||
2015-03-09 | hwmon: (pwm-fan) Extract __set_pwm() function to only modify PWM duty cycle | Lukasz Majewski | |
It was necessary to decouple code handling writing to sysfs from the one responsible for setting PWM of the fan. Due to that, new __set_pwm() method was extracted, which is responsible for only setting new PWM duty cycle. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net> | |||
2014-11-11 | hwmon: (pwm-fan) Fix suspend/resume behavior | Kamil Debski | |
The state of a PWM output is not clearly defined after resume. Some PWM drivers do not restore the duty cycle upon resume, thus it is necessary to manually restore the correct value. Signed-off-by: Kamil Debski <k.debski@samsung.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net> | |||
2014-08-04 | hwmon: (pwm-fan) Remove duplicate dev_set_drvdata call | Axel Lin | |
The dev_set_drvdata() call is equivalent to the platform_set_drvdata() call in next line. Signed-off-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net> | |||
2014-08-04 | hwmon: Add pwm-fan driver | Kamil Debski | |
The pwm-fan driver enables control of fans connected to PWM lines. This driver uses the PWM framework, so it is compatible with all PWM devices that provide drivers through the PWM framework. Signed-off-by: Kamil Debski <k.debski@samsung.com> Reviewed-by: Varka Bhadram <varkabhadram@gmail.com> Reviewed-by: Tobias Klauser <tklauser@distanz.ch> [Guenter Roeck: Last argument to devm_of_pwm_get is pointer, use NULL] Signed-off-by: Guenter Roeck <linux@roeck-us.net> |
