path: root/drivers/hwmon/smsc47m1.c
2008-02-17hwmon: (smsc47m1) Add individual alarm filesJean Delvare
The new libsensors needs these individual alarm files. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Juerg Haefliger <juergh at gmail.com> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2008-02-07hwmon: Let the user override the detected Super-I/O device IDJean Delvare
While it is possible to force SMBus-based hardware monitoring chip drivers to drive a not officially supported device, we do not have this possibility for Super-I/O-based drivers. That's unfortunate because sometimes newer chips are fully compatible and just forcing the driver to load would work. Instead of that we have to tell the users to recompile the kernel driver, which isn't an easy task for everyone. So, I propose that we add a module parameter to all Super-I/O based hardware monitoring drivers, letting advanced users force the driver to load on their machine. The user has to provide the device ID of a supposedly compatible device. This requires looking at the source code or a datasheet, so I am confident that users can't randomly force a driver without knowing what they are doing. Thus this should be relatively safe. As you can see from the code, the implementation is pretty simple and unintrusive. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Hans de Goede <j.w.r.degoede@hhs.nl> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2007-10-09hwmon: Convert from class_device to deviceTony Jones
Convert from class_device to device for hwmon_device_register/unregister Signed-off-by: Tony Jones <tonyj@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2007-10-09hwmon: (smsc47m1) No confusing debugging messagesJean Delvare
It's confusing to display debugging messages for fan3 and pwm3 for chips which don't have them. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2007-08-12hwmon: (smsc47m1) restore missing name attributeJean Delvare
The smsc47m1 driver no longer creates the name attribute used by libsensors to identify chip types. It was lost during the conversion to a platform driver. I was fooled by the fact that we do have a group with all attributes, but only to delete them all at once. The group is not used to create the attributes, so we have to explicitly create the name attribute. This fixes lm-sensors ticket #2236: http://lm-sensors.org/ticket/2236 Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2007-07-30hwmon: Add missing __devexit tags in various driversJean Delvare
On Sun, 22 Jul 2007 00:30:56 +0200, Gabriel C wrote: > I noticed this warnings on current git: > > drivers/hwmon/pc87360.c:1082: warning: 'pc87360_remove' defined but not used > drivers/hwmon/sis5595.c:580: warning: 'sis5595_remove' defined but not used > drivers/hwmon/smsc47m1.c:608: warning: 'smsc47m1_remove' defined but not used > drivers/hwmon/via686a.c:648: warning: 'via686a_remove' defined but not used > drivers/hwmon/vt8231.c:755: warning: 'vt8231_remove' defined but not used Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2007-07-19hwmon: Fix a potential race condition on unloadJean Delvare
Fix a potential race condition when some hardware monitoring platform drivers are being unloaded. I believe that the driver data pointer shouldn't be cleared before all the sysfs files are removed, otherwise a sysfs callback might attempt to dereference a NULL pointer. I'm not sure exactly what the driver core protects drivers against, so let's play it safe. While we're here, clear the driver data pointer when probe fails, so as to not leave an invalid pointer behind us. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2007-07-19hwmon: Use platform_device_add_data()Jean Delvare
Use platform_device_add_data() in hardware monitoring drivers. This makes the code nicer and smaller too. Reported by David Hubbard. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: David Hubbard <david.c.hubbard@gmail.com>
2007-05-08hwmon/smsc47m1: Use dynamic sysfs callbacksJean Delvare
This lets us get rid of macro-generated functions and shrinks the driver size by about 7%. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2007-05-08hwmon/smsc47m1: Use DRVNAME consistentlyJean Delvare
Also use pr_info instead of printk. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2007-05-08hwmon/smsc47m1: Convert to a platform driverJean Delvare
Convert the smsc47m1 driver from the nonsensical i2c-isa hack to a regular platform driver. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2007-05-08hwmon/smsc47m1: Get rid of a useless mutexJean Delvare
The smsc47m1 driver uses a mutex to protect the accesses to the hardware registers. It really doesn't need any protection, as the register space is flat. Get rid of that mutex for a smaller and faster driver. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2007-05-08hwmon/smsc47m1: Add support for the LPC47M292Jean Delvare
The new SMSC LPC47M292 Super-I/O chip is a bit different from the previous ones, it supports a 3rd fan, but unfortunately the pin configuration registers are different. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2006-10-18smsc47m1: List the SMSC LPC47M112 as supportedJean Delvare
The SMSC LPC47M112 Super-I/O chip appears to be compatible with the LPC47M10x and LPC47M13x as far as hardware monitoring is concerned. The device ID is even the same, so it's really only a documentation update. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-28hwmon: Fix unchecked return status, SMSC chipsJean Delvare
hwmon: Fix unchecked return status, SMSC chips Fix up 2 more hwmon drivers so that they no longer ignore return status from device_create_file(). Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-28smsc47m1: dev_warn fixJean Delvare
smsc47m1: dev_warn fix We can't use dev_warn on an i2c client before it is attached. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-26i2c-isa: Restore driver ownerJean Delvare
i2c-isa: Restore driver owner Commit 2b48716d1d2f2edb1e7cbc5ecf1cb2cb39373e33 back in January 2006 was a bit overzealous. It removed .owner from all i2c drivers, including i2c-isa ones, while they still need it. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-26spelling fixesAndreas Mohr
acquired (aquired) contiguous (contigious) successful (succesful, succesfull) surprise (suprise) whether (weather) some other misspellings Signed-off-by: Andreas Mohr <andi@lisas.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-03-23[PATCH] hwmon: Semaphore to mutex conversionsIngo Molnar
convert drivers/hwmon/*.c semaphore use to mutexes. the conversion was generated via scripts, and the result was validated automatically via a script as well. all affected hwmon drivers were build-tested. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-05[PATCH] I2C: Remove .owner setting from i2c_driver as it's no longer neededGreg Kroah-Hartman
Now that i2c_add_driver() doesn't need the module owner to be set by hand, we can delete it from the drivers. This patch catches all of the drivers that I found in the current tree (if a driver sets the .owner by hand, it's not a problem, just not needed.) Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Cc: Jean Delvare <khali@linux-fr.org>
2006-01-05[PATCH] i2c: Drop i2c_driver.{owner,name}, 3 of 11Laurent Riffard
We should use the i2c_driver.driver's .name and .owner fields instead of the i2c_driver's ones. This patch updates the hwmon drivers. Signed-off-by: Laurent Riffard <laurent.riffard@free.fr> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] hwmon: smsc47m1 documentation updateJean Delvare
The SMSC LPC47M997 Super-I/O chip seems to be compatible with the LPC47M192, so it is supported by the smsc47m1 driver. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] hwmon: kzalloc conversionDeepak Saxena
Use kzalloc instead of kmalloc+memset in all hardware monitoring drivers. Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-09[PATCH] hwmon: Update smsc47m1 head commentJean Delvare
Update the head comment of the smsc47m1 driver to mention all the supported devices. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-05[PATCH] hwmon: hwmon vs i2c, second round (06/11)Jean Delvare
The only thing left in i2c-sensor.h are module parameter definition macros. It's only an extension of what i2c.h offers, and this extension is not sensors-specific. As a matter of fact, a few non-sensors drivers use them. So we better merge them in i2c.h, and get rid of i2c-sensor.h altogether. Signed-off-by: Jean Delvare <khali@linux-fr> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-05[PATCH] hwmon: tag super-i/o find functions __initJean Delvare
Super-I/O find functions in hardware monitoring drivers can be tagged __init as they are only called from functions themselves tagged __init. Two of them (smsc47b397 and w83627ehf) already do, but the other four of them (it87, pc87360, smsc47m1 and w83627hf) did not. This saves a few bytes of memory after the drivers are loaded, 192 in the case of the it87 driver. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-05[PATCH] I2C: refactor message in i2c_detach_clientJean Delvare
We could refactor the error message 34 different i2c drivers print if i2c_detach_client() fails in this function itself. Saves quite a few lines of code. Documentation is updated to reflect that change. Note that this patch should be applied after Rudolf Marek's w83792d patches. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-05[PATCH] I2C: Separate non-i2c hwmon drivers from i2c-core (5/9)Jean Delvare
Call the ISA chip drivers detection function directly instead of relying on i2c_detect. The net effect is that address lists won't be handled anymore, but they were mostly useless in the ISA case anyway (pc87360, smsc47m1, smsc47b397 had already dropped them). We don't need to handle multiple devices, all we may need is a way to force a given address instead of the original one (some drivers already do: sis5595, via686a, w83627hf), and, for drivers supporting multiple chips, a way to force one given kind. All this may be added later on demand, but I actually don't think there will be much demand. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-05[PATCH] I2C: Separate non-i2c hwmon drivers from i2c-core (3/9)Jean Delvare
Convert the 10 ISA hardware monitoring drivers (it87, lm78, pc87360, sis5595, smsc47b397, smsc47m1, via686a, w83627hf, w83627ehf, w83781d) to explicitely register with i2c-isa. For hybrid drivers (it87, lm78, w83781d), we now have two separate instances of i2c_driver, one for the I2C interface of the chip, and one for ISA interface. In the long run, the one for ISA will be replaced with a different driver type. At this point, all drivers are working again, except for missing dependencies in Kconfig. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-05[PATCH] I2C hwmon: add hwmon sysfs class to driversMark M. Hoffman
This patch modifies sensors chip drivers to make use of the new sysfs class "hwmon". Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-08-26[PATCH] drivers/hwmon/*: kfree() correct pointersAlexey Dobriyan
The adm9240 driver, in adm9240_detect(), allocates a structure. The error path attempts to kfree() ->client field of it (second one), resulting in an oops (or slab corruption) if the hardware is not present. ->client field in adm1026, adm1031, smsc47b397 and smsc47m1 is the first in ${HWMON}_data structure, but fix them too. Signed-off-by: Jonathan Corbet <corbet@lwn.net Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-11[PATCH] I2C: Move hwmon drivers (2/3)Jean Delvare
Part 2: Move the driver files themselves. Note that the patch "adds trailing whitespace", because it does move the files as-is, and some files happen to have trailing whitespace. From: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
