path: root/drivers/hwmon/smsc47m192.c
2008-02-18hwmon: normal_i2c arrays should be constMark M. Hoffman
Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2008-02-07hwmon: VRM is not written to registersJean Delvare
What was true of reading the VRM value is also true of writing it: not being a register value, it doesn't need hardware access, so we don't need a reference to the i2c client. This allows for a minor code cleanup. As gcc appears to be smart enough to simplify the generated code by itself, this cleanup only affects the source code, the generated binaries are unchanged. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2007-10-09hwmon: VRM is not read from registersJean Delvare
The VRM value is not read from chip registers, so there's no need to update the device data cache before exporting the VRM value to user-space. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Hans de Goede <j.w.r.degoede@hhs.nl> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2007-10-09hwmon: Convert from class_device to deviceTony Jones
Convert from class_device to device for hwmon_device_register/unregister Signed-off-by: Tony Jones <tonyj@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2007-07-19hwmon: Fault files naming conventionJean Delvare
We have the following naming convention documented in Documentation/hwmon/sysfs-interface for fault files: in[0-*]_input_fault fan[1-*]_input_fault temp[1-*]_input_fault Some drivers follow this convention (lm63, lm83, lm90, smsc47m192). However some drivers omit the "input" part and create files named fan1_fault (pc87427) or temp1_fault (dme1737). And the new "generic" libsensors follows this second (non-standard) convention, so it fails to report fault conditions for drivers which follow the standard. We want a single naming scheme, and everyone seems to prefer the shorter variant, so let's go for it. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2007-07-19hwmon/smsc47m192: Semaphore to mutex conversionJean Delvare
2007-05-08hwmon/smsc47m192: Document the LPC47M292 as supportedJean Delvare
The new SMSC LPC47M292 Super-I/O chip includes a hardware monitoring block which is compatible with those of the LPC47M192. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Hartmut Rick <linux@rick.claranet.de>
2006-09-28hwmon: Fix unchecked return status, SMSC chipsJean Delvare
hwmon: Fix unchecked return status, SMSC chips Fix up 2 more hwmon drivers so that they no longer ignore return status from device_create_file(). Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-22[PATCH] smsc47m192: New hwmon driver for SMSC LPC47M192/997Hartmut Rick
New driver (smsc47m192) which supports voltage and temperature measurement features of SMSC LPC47M192 and LPC47M997 chips. Signed-off-by: Hartmut Rick <linux@rick.claranet.de> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
