Bug 1024886
Resolved compilation error for unused code.
Signed-off-by: Nagaraja Kolur <nkolur@nvidia.com>
Change-Id: I9167d8129a9cba0fc6cb203180e07192d66db439
Reviewed-on: http://git-master/r/120581
Reviewed-by: Nagaraj Kolur <nkolur@nvidia.com>
Tested-by: Nagaraj Kolur <nkolur@nvidia.com>
Reviewed-by: Vijaya Bhaskar <vbhaskar@nvidia.com>
Reviewed-by: Wahed Syed <wsyed@nvidia.com>
Reviewed-by: Dan Willemsen <dwillemsen@nvidia.com>
Simplify the temp to counter conversion in tsensor,
Also it can improve a little bit accuracy of temp to
counter conversion.
Change-Id: I5764334d5d94e317dd9400bc03cb5d7a64096ee0
Signed-off-by: Daniel Fu <danifu@nvidia.com>
Reviewed-on: http://git-master/r/115340
GVS: Gerrit_Virtual_Submit
Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
When set threshold of tsensor,convert the temp to counter.
The counter convert from temp is with ~1.8C average error.
Improved the accuracy, make it to be ~0.1C.
Bug 1015288
Change-Id: Icab03b559eaeb8846dd1191869afe39c9965f934
Reviewed-on: http://git-master/r/114904
Changed the low temp to 0C since 20C is very easy to trigger thermal
alert under -15C to 15C environment temperature. And the thermal alert
will run into endless alert from tsensor_work_func.
Also revised suspend and resume routine to cancel the work when suspending
and disable/enable irq.
Bug 999175
Signed-off-by: Linqiang Pu <dpu@nvidia.com>
(cherry picked from commit 6a909bfa690991438be298d4933946a92e4929c4)
Change-Id: Icafc6d5f0164204cc0cb7bea64bef2fadadbfbfd
Reviewed-on: http://git-master/r/111550
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
tsensor driver uses fixed point approximations.
Improved accuracy of tsensor temperature reading
- adding support to handle negative temperature to counter
conversions and vice-versa
bug 1001632
bug 999175
Signed-off-by: Bitan Biswas <bbiswas@nvidia.com>
(cherry picked from commit 86ae0bdc3fbd34a5a1d0e08f7721ed527ddf5408)
Change-Id: I5f6df85611d502a6dda1186234078fe973d7ca75
Reviewed-on: http://git-master/r/100576
Tested-by: Bitan Biswas <bbiswas@nvidia.com>
bug 949219
Change-Id: I5942ba86bd1cbe1f1bd06a7c9f51a10d83e6cabb
Signed-off-by: Sanjay Singh Rawat <srawat@nvidia.com>
Reviewed-on: http://git-master/r/92819
Enabled hw reset in tsensor if temperature exceeds given
temperature limit.
bug 966994
Change-Id: I2444c97c97c45b2d190a224388876d592d983c7f
Signed-off-by: Joshua Primero <jprimero@nvidia.com>
Reviewed-on: http://git-master/r/93030
Reviewed-by: Diwakar Tundlam <dtundlam@nvidia.com>
Added function to retrieve tsensor driver's lowest
temperature support
Reviewed-on: http://git-master/r/70931
(cherry picked from commit f81c5b945b2104969fd1a391d0e5df8f0900710d)
Change-Id: I8bf3f7c7fb3ab4730bfb6700b2ae5edec44c7da2
Reviewed-on: http://git-master/r/85960
Reviewed-by: Joshua Primero <jprimero@nvidia.com>
Tested-by: Joshua Primero <jprimero@nvidia.com>
Only enable one sensor at a time to save power.
bug 928188
Reviewed-on: http://git-master/r/76025
Change-Id: I1d3c21783cbe579568ff9e9ef3ce2e48220e7edb
Reviewed-on: http://git-master/r/76823
Enabled probe callback in probe function now
that callback function parameter was added
to tsensor data structure.
Reviewed-on: http://git-master/r/62022
(cherry picked from commit 388f5aa8ac8b84bf247db8ebd3dcd05b2788b3d5)
Reviewed-on: http://git-master/r/64560
(cherry picked from commit c58aad90a5226b1a13c4e5397de800d5d7fdfa84)
Change-Id: I4cd66ebdf33e54048166207ab7012e4b74b5350d
Reviewed-on: http://git-master/r/67239
Added support for EDP in tsensor. Since low limit
interrupts are not supported in hardware TH2 was
used for upper limit and TH0/TH1 as lower limit.
Also added generic functions to enable tsensor for
thermal refactoring.
Bug 912597
Change-Id: I8f1e126e1fe11c69aa03dee0a20a26ef2b7dc6a0
Reviewed-on: http://git-master/r/66554
Reviewed-by: Colin McCabe <cmccabe@nvidia.com>
* when outputting to sysfs, we only have to worry about not overflowing
a single page in memory.
* don't use strcat
* avoid passing data between functions by mutating global strings
Change-Id: I8914a9ee282c63a4259c1bcaf9e550328a5664ec
Signed-off-by: Colin Patrick McCabe <cmccabe@nvidia.com>
Reviewed-on: http://git-master/r/63672
Rebase-Id: Rd3426d0c534a846624a4d55be851a88c67ba6d67
m, n and p coefficients updated for fuse revision 21 and beyond.
- code cleanup done. fixed checkpatch warnings.
bug 842208
Reviewed-on: http://git-master/r/53808
(cherry picked from commit 488785f279a5642fffde3d48d62c77f46a20b63a)
Reviewed-on: http://git-master/r/55026
(cherry picked from commit 49a5b4cf51ed43e2a9d25a2603e84ed835446832)
Change-Id: I83db5a746d5960c799fbf09e2334ecc608c44d39
Reviewed-on: http://git-master/r/57367
Rebase-Id: R49c36a57132c60260e1ab9d9f2aa68bf3602c962
Tsensor driver had support for chip revisions 1 and 2 only.
Updated the driver to support later chip revisions.
- Additionally error handling code corrected
bug 864922
Original-Change-Id: I58230b7aa6c343930739f27bcc26e129092a9b4d
Reviewed-on: http://git-master/r/47728
Reviewed-by: Hanumanth Venkateswa Moganty <vmoganty@nvidia.com>
Rebase-Id: Rc4cd2ebc90e7e6cbfd48bdcade89c02626a2629c
In case of tsensor probe failure in temperature
calculation sanity test step, added more prints.
bug 865024
Original-Change-Id: Ie74b25cc162fc17c83127d832c14dbd1c603a8e5
Reviewed-on: http://git-master/r/47518
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
Rebase-Id: Rec20a2726eae6e0779761beb6510f59ef3aab6f1
tsensor functionality is enabled based on fuse revision.
The fuse revision is to be interpreted as an unsigned integer
while it is interpreted as a decimal number. Corrected this.
bug 863460
Original-Change-Id: I42dbfe406c3ee5b016664410db1b916997e1fe60
Reviewed-on: http://git-master/r/46899
Rebase-Id: R52f072ab4fc835ae803f4e44fcca768c751d9e4c
tsensor resume was taking ~20msec because of msleep call.
Removed the unnecessary delay.
bug 862265
Original-Change-Id: I6138a5cd1f19e947cdbfdc8e8d0d236e7c3c8824
Reviewed-on: http://git-master/r/46683
Rebase-Id: R047a7044707b35fc4e1743f2272aef7e275e92a1
tsensor probe was not propagating error from a called function.
Later suspend/resume was getting called causing crash. Fixed the code.
bug 863316
Original-Change-Id: I1851d75aeeee332bc582fe45fd7c1c8f0521b5c7
Reviewed-on: http://git-master/r/46890
Reviewed-by: Venu Byravarasu <vbyravarasu@nvidia.com>
Rebase-Id: R77a15193c8ae51746ff477f3d877825dd81ecd34
Formatted the tsensor driver log message's new line location
to match prints from other drivers.
bug 860513
Original-Change-Id: I4a03ecce246ac9847fb1562159bfd9cbcf95ab14
Reviewed-on: http://git-master/r/45501
Rebase-Id: R1f3169b9a05d51ddb81d5066d78afc342f2199fb
Hardware reset and clock divide feature of tsensor is disabled as
the temperature readings are not accurate. Incorrect threshold
calculations and temperature readings are seen to show tsensor
reset during boot up.
bug 860513
Original-Change-Id: Ib64259f3e400eddde54056dae495983930b5c107
Reviewed-on: http://git-master/r/45487
Rebase-Id: R01841af1297ed369ea52e6207358cc13296c93e3
Though tsensor driver was registered as hwmon driver,
sys nodes were not geting created under /sys/class/hwmon.
Hence fixing it.
bug 858158
Original-Change-Id: I6ca226c2a22385c4d0d9ef747267ab0e3060d905
Reviewed-on: http://git-master/r/44313
Tested-by: Venu Byravarasu <vbyravarasu@nvidia.com>
Rebase-Id: Ra210ae46da9c4598014ad3dce31fb7472aa304d3
tsensor setup function error path corrected to return error.
bug 857074
Original-Change-Id: I8c4be4868546d39c6c49de9eee4d20afe75f075a
Reviewed-on: http://git-master/r/43714
Rebase-Id: Rac3c6ffe339d05186ea38e07e03c517a5d5319ba
tsensor driver changed as follows:
1. conversion of temperature reading into tsensor counter was not
working earlier. Fixed this.
2. supported tsensor0 usage for upcoming fuse revision 21
3. tsensor specific fuse data extracted using public fuse APIs
bug 851791
bug 855165
Original-Change-Id: I53247f3e029396d5fde479ea168eb279fcae6135
Reviewed-on: http://git-master/r/41037
Reviewed-by: Scott Williams <scwilliams@nvidia.com>
Reviewed-by: Narendra Damahe <ndamahe@nvidia.com>
Rebase-Id: R8261421f7a6fd72b14488ac536b98c48e8329c58
tsensor configuration needs to be saved before lp0 and restored
after lp0 resume else POR values are seen after lp0 resume.
- Config0, Config1 and Config2 registers are saved and restored
bug 851791
Original-Change-Id: I95532d995af4fa71e169209bb1788fc4152290fe
Reviewed-on: http://git-master/r/41819
Rebase-Id: Raceac7154fc86486f2726cdd13637d7e8d1e6828
tsensor STOP bit is set before suspend. This disables the
counters and prevents OVERFLOW interrupt in LP1 mode
bug 850683
Original-Change-Id: I01fbc9529ecc25ce96f50a5fbf599c9bce2157b5
Reviewed-on: http://git-master/r/40656
Rebase-Id: Rbdf02380a72c8f75449a0a3e52007e5883f62d4b
Tegra integrated temperature sensor(tsensor) driver added
- TH3 counter < current counter causes hardware reset
- TH2 counter < current counter causes CPU clock to be halved
- sysfs interface provided for select operations
- interrupts TH1 TH2 and TH3 working
- used recommended N,M and clk source settings
- tsensor counter to temperature conversion added
tsensor1 counter being used for temperature computations.
Bug 661228
Original-Change-Id: I0fa405c0f542d1b215162291bd913a9ccd55a0f5
Reviewed-on: http://git-master/r/36083
Rebase-Id: R3c910b4fdc630ffee2135d3d649e25015d2b7206
