path: root/drivers/hwmon
2011-03-29drivers: Final irq namespace conversionThomas Gleixner
Scripted with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-27Merge branch 'hwmon-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/staging * 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/staging: hwmon: (pmbus) Fix temperature limit register access
2011-03-26hwmon: (pmbus) Fix temperature limit register accessGuenter Roeck
Commit 8677011 added auto-update to temperature limit registers. Unfortunately, the update flag is also used to determine if an attribute is writable, which results in read-only temperature limit registers. To fix the problem, pass 'readonly' as separate flag to the function used to add sensor attributes. Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2011-03-26hwmon: (f71882fg) Add support for the F71889AHans de Goede
Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Guenter Roeck <guenter.roeck@ericsson.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2011-03-26hwmon: (f71882fg) Add support for the F81865FJean Delvare
Add support for the Fintek F81865F. It's essentially compatible with the F71882FG, but has fewer inputs: 7 voltage, 2 temperature and 2 fan inputs only. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Guenter Roeck <guenter.roeck@ericsson.com>
2011-03-26hwmon: (f71882fg) Document all supported devicesJean Delvare
The list of supported devices was not always well documented in all places. Clarify and list all devices in documentation, Kconfig and the driver itself. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Guenter Roeck <guenter.roeck@ericsson.com>
2011-03-26hwmon: (f71882fg) Per-chip fan/temperature input count tablesJean Delvare
Use tables to list the count of fan and temperature inputs for all supported chips, almost similar to (but more simple than) what is already done for voltage inputs. This avoids repeating the same tests in different functions, and will make it easier to add support for chips with a different count of fan or temperature inputs. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Guenter Roeck <guenter.roeck@ericsson.com>
2011-03-26hwmon: (f71882fg) Secure chip property definition arraysJean Delvare
Using C99-style array initialization will ensure definitions won't drift if the chips enum gets new values added. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Guenter Roeck <guenter.roeck@ericsson.com>
2011-03-23jz4740: silence warnings related to mfd_get_cell changesAndres Salomon
mfd_get_cell returns a const, so change the jz4740 clients to store a const mfd cell. This silences type mismatch warnings. Signed-off-by: Andres Salomon <dilinger@queued.net> Acked-by: Anton Vorontsov <cbouatmailru@gmail.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-03-23hwmon: twl4030: Hwmon Driver for TWL4030 MADCKeerthy
This driver exposes the sysfs nodes of the TWL4030 MADC module. All the voltage channel values are expressed in terms of mV. Channel 13 and channel 14 are reserved. There are channels which represent temperature and current the output is represented by celcius and mA respectively. Signed-off-by: Keerthy <j-keerthy@ti.com> Acked-by: Guenter Roeck <guenter.roeck@ericsson.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-03-23mfd: mfd_cell is now implicitly available to jz4740 driversAndres Salomon
No need to explicitly set the cell's platform_data/data_size. Modify clients to use mfd_get_cell helper function instead of accessing platform_data directly. Signed-off-by: Andres Salomon <dilinger@queued.net> Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-03-21hwmon: (ads1015) Make gain and datarate configurableDirk Eibach
Configuration for ads1015 gain and datarate is possible via devicetree or platform data. This is a followup patch to previous ads1015 patches on Jean Delvares tree. Signed-off-by: Dirk Eibach <eibach@gdsys.de> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2011-03-21hwmon: (ads1015) Drop dynamic attribute groupJean Delvare
It is cheaper to handle attributes individually. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Dirk Eibach <eibach@gdsys.de>
2011-03-21hwmon: Add support for Texas Instruments ADS1015Dirk Eibach
2011-03-21hwmon: New driver for SMSC SCH5627Hans de Goede
SMSC SCH5627 Super I/O chips include complete hardware monitoring capabilities. They can monitor up to 5 voltages, 4 fans and 8 temperatures. The hardware monitoring part of the SMSC SCH5627 is accessed by talking through an embedded microcontroller. An application note describing the protocol for communicating with the microcontroller is available upon request. Please mail me if you want a copy. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2011-03-21hwmon: (abituguru*) Update my email addressHans de Goede
2011-03-21hwmon: (lm75) Speed up detectionJean Delvare
Make the LM75/LM75A device detection faster: * Don't read the current temperature value when we don't use it. * Check for unused bits in the configuration register as soon as we have read its value. * Don't use word reads, not all devices support this, and some which don't misbehave when you try. * Check for cycling register values every 40 register addresses instead of every 8, it's 5 times faster and just as efficient. Some of these improvements come straight from the user-space sensors-detect script, so both detection routines are in line now. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Len Sorensen <lsorense@csclub.uwaterloo.ca> Acked-by: Guenter Roeck <guenter.roeck@ericsson.com>
2011-03-21hwmon: (lm75) Add detection of the National Semiconductor LM75ALen Sorensen
Add support for detection of the National Semiconductor LM75A using the ID register value. Signed-off-by: Len Sorensen <lsorense@csclub.uwaterloo.ca> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2011-03-21Move lis3lv02d drivers to drivers/miscJean Delvare
The lis3lv02d drivers aren't hardware monitoring drivers, so the don't belong to drivers/hwmon. Move them to drivers/misc, short of a better home. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Guenter Roeck <guenter.roeck@ericsson.com> Acked-by: Eric Piel <eric.piel@tremplin-utc.net> Acked-by: Jonathan Cameron <jic23@cam.ac.uk> Tested-by: Eric Piel <eric.piel@tremplin-utc.net> Tested-by: Takashi Iwai <tiwai@suse.de>
2011-03-21Move hp_accel to drivers/platform/x86Jean Delvare
The hp_accel driver isn't a hardware monitoring driver, so it doesn't belong to drivers/hwmon. Move it to drivers/platform/x86, assuming HP doesn't ship non-x86 laptops. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Guenter Roeck <guenter.roeck@ericsson.com> Acked-by: Eric Piel <eric.piel@tremplin-utc.net> Acked-by: Jonathan Cameron <jic23@cam.ac.uk> Tested-by: Eric Piel <eric.piel@tremplin-utc.net> Tested-by: Takashi Iwai <tiwai@suse.de>
2011-03-21Let Kconfig handle lis3lv02d dependenciesJean Delvare
The dependencies between the various lis3lv02d drivers make it impossible to split them to different directories, while we really want to do this. Move handling of dependencies from Makefile to Kconfig, to make the move possible at all. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Guenter Roeck <guenter.roeck@ericsson.com> Acked-by: Eric Piel <eric.piel@tremplin-utc.net> Acked-by: Jonathan Cameron <jic23@cam.ac.uk> Tested-by: Eric Piel <eric.piel@tremplin-utc.net> Tested-by: Takashi Iwai <tiwai@suse.de>
2011-03-21hwmon: (sht15) Fix integer overflow in humidity calculationVivien Didelot
An integer overflow occurs in the calculation of RHlinear when the relative humidity is greater than around 30%. The consequence is a subtle (but noticeable) error in the resulting humidity measurement. Signed-off-by: Vivien Didelot <vivien.didelot@savoirfairelinux.com> Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: stable@kernel.org Cc: Jonathan Cameron <jic23@cam.ac.uk>
2011-03-21hwmon: (sht15) Spelling fixJustin P. Mattock
Remove one too many "n" in a word. Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Acked-by: Jean Delvare <khali@linux-fr.org>
2011-03-20Merge branch 'trivial' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'trivial' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: (25 commits) video: change to new flag variable scsi: change to new flag variable rtc: change to new flag variable rapidio: change to new flag variable pps: change to new flag variable net: change to new flag variable misc: change to new flag variable message: change to new flag variable memstick: change to new flag variable isdn: change to new flag variable ieee802154: change to new flag variable ide: change to new flag variable hwmon: change to new flag variable dma: change to new flag variable char: change to new flag variable fs: change to new flag variable xtensa: change to new flag variable um: change to new flag variables s390: change to new flag variable mips: change to new flag variable ... Fix up trivial conflict in drivers/hwmon/Makefile
2011-03-17Merge branch 'hwmon-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/staging * 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/staging: (44 commits) hwmon: (lineage-pem): Fix in1 voltage alarm sysfs attributes hwmon/f71882fg: Add support for f71808e hwmon/f71882fg: Add support for f71869f and f71869e hwmon/f71882fg: Add support for f71889ed hwmon/f71882fg: Break out test for auto pwm's controlled by digital readings hwmon/f71882fg: Separate temp beep sysfs attr from the other temp sysfs attr hwmon/f71882fg: Remove bogus temp2_type for certain models hwmon/f71882fg: Make number of temps configurable hwmon/f71882fg: Make creation of in sysfs attributes more generic hwmon/f71882fg: Only allow negative auto point temps if fan_neg_temp is enabled hwmon/f71882fg: Fix temp1 sensor type reporting hwmon: (w83627ehf) Display correct temperature sensor labels for systems with NCT6775F hwmon: (w83627ehf) Add fan debounce support for NCT6775F and NCT6776F hwmon: (w83627ehf) Update Kconfig for W83677HG-B, NCT6775F and NCT6776F hwmon: (w83627ehf) Store rpm instead of raw fan speed data hwmon: (w83627ehf) Use 16 bit fan count registers if supported hwmon: (w83627ehf) Add support for Nuvoton NCT6775F and NCT6776F hwmon: (w83627ehf) Permit enabling SmartFan IV mode if configured at startup hwmon: (w83627ehf) Convert register arrays to 16 bit, and convert access to pointers hwmon: (w83627ehf) Remove references to datasheets which no longer exist ...
2011-03-17hwmon: change to new flag variablematt mooney
Replace EXTRA_CFLAGS with ccflags-y. Signed-off-by: matt mooney <mfm@muteddisk.com> Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Acked-by: Guenter Roeck <guenter.roeck@ericsson.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-03-16Merge branch 'devicetree/next' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'devicetree/next' of git://git.secretlab.ca/git/linux-2.6: (21 commits) tty: serial: altera_jtaguart: Add device tree support tty: serial: altera_uart: Add devicetree support dt: eliminate of_platform_driver shim code dt: Eliminate of_platform_{,un}register_driver dt/serial: Eliminate users of of_platform_{,un}register_driver dt/usb: Eliminate users of of_platform_{,un}register_driver dt/video: Eliminate users of of_platform_{,un}register_driver dt/net: Eliminate users of of_platform_{,un}register_driver dt/sound: Eliminate users of of_platform_{,un}register_driver dt/spi: Eliminate users of of_platform_{,un}register_driver dt: uartlite: merge platform and of_platform driver bindings dt: xilinx_hwicap: merge platform and of_platform driver bindings ipmi: convert OF driver to platform driver leds/leds-gpio: merge platform_driver with of_platform_driver dt/sparc: Eliminate users of of_platform_{,un}register_driver dt/powerpc: Eliminate users of of_platform_{,un}register_driver dt/powerpc: move of_bus_type infrastructure to ibmebus drivercore/dt: add a match table pointer to struct device dt: Typo fix. altera_ps2: Add devicetree support ...
2011-03-16hwmon: (lineage-pem): Fix in1 voltage alarm sysfs attributesGuenter Roeck
The alarm bit assumed to be a low voltage alarm bit is not set for low voltage alarms, and the alarm bit assumed to be a high voltage alarm turns out to be a general alarm bit which is set for both low and high voltage alarms. Remove the in1_min_alarm sysfs attribute and rename in1_max_alarm to in1_alarm to reflect the situation. Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Acked-by: Jean Delvare <khali@linux-fr.org>
2011-03-14hwmon/f71882fg: Add support for f71808eHans de Goede
Signed-off-by: Hans de Goede <hdegoede@redhat.com> Tested-by: Jonathan Michalon <johndescs@gmail.com> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2011-03-14hwmon/f71882fg: Add support for f71869f and f71869eHans de Goede
Note that these 2 are register compatible and report the same superio id, but they are 2 distinct chips / models! Signed-off-by: Hans de Goede <hdegoede@redhat.com> Tested-by: Thomas Faber <thfabba@gmx.de> Tested-by: Alexey Sychev <owl@umail.ru> Tested-by: Dieter Bloms <dieter@bloms.de> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2011-03-14hwmon/f71882fg: Add support for f71889edHans de Goede
Note that this patch also makes 2 changes to the code paths for the f71889fg to keep the code unified between the 2 (for simplicities sake). Both of these are harmless for then f71889fg: 1) The first change is to always set the FAN_PROG_SEL bit to 0. This influences accesses to some banked fan / pwm registers. On the f71889fg no registers which we use are banked. On the f71889ed however some more fan registers have been banked including one which we use, by making the FAN_PROG_SEL bit 0, address 0x96 will point to the right register. 2) The second change is to see a FANx_TEMP_SEL value of 0 as pointing to a PECI / AMDSI value, and thus disable our pwm related sysfs attr. This is correct for the f71889ed and on the f71889fg 0 is a reserved value, so we should never see it and if we do, disabling the pwm related sysfs attr is a sane thing to do. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Tested-by: Thomas Greve <tg42@gmx.net> Tested-by: Sander Eikelenboom <linux@eikelenboom.it> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2011-03-14hwmon/f71882fg: Break out test for auto pwm's controlled by digital readingsHans de Goede
Putting this check in its own switch case rather then in the switch case for adding pwm auto point sysfs attr is cleaner. This is a preparation patch for adding support for more different models. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2011-03-14hwmon/f71882fg: Separate temp beep sysfs attr from the other temp sysfs attrHans de Goede
2011-03-14hwmon/f71882fg: Remove bogus temp2_type for certain modelsHans de Goede
Remove the temp2_type sysfs files for f8000 / f71858fg models, this got in accidentally and is wrong as these models don't have a Temperature Sensor Type Register at all. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2011-03-14hwmon/f71882fg: Make number of temps configurableHans de Goede
Make the temp sysattr array for the standard models a 2d array, which allows to use it for models with less temperatures too. This is a preparation patch for adding support for more different models. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2011-03-14hwmon/f71882fg: Make creation of in sysfs attributes more genericHans de Goede
This is a preparation patch for adding support for more different models, some of which have a sparse list of used voltage pins. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2011-03-14hwmon/f71882fg: Only allow negative auto point temps if fan_neg_temp is enabledHans de Goede
2011-03-14hwmon/f71882fg: Fix temp1 sensor type reportingHans de Goede
The code for determining a sensort type for temp1 was based on me misreading the datasheet, the tested registers do not determine what kind of sensor is actually reported as temp1. Instead the enable / disable certain additional digital sensor readouts throug PECI / AMDSI, etc. Independent of these settings temp1 is still reading an external BJT or thermistor as configured by the Temperature Sensor Type Register (0x6b). Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2011-03-14hwmon: (w83627ehf) Display correct temperature sensor labels for systems ↵Guenter Roeck
with NCT6775F Systems with NCT6775F reported temperature sensor labels for systems with NCT6776F. This patch fixes the problem. Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2011-03-14hwmon: (w83627ehf) Add fan debounce support for NCT6775F and NCT6776FIan Dobson
NCT6776F and NCT6775F support debouncing the fan RPM signal. This can help improve the stability of th RPM signal for some fans (Arctic cooling fans for example). This patch adds a module parameter fan_debounce, which when set to 1 enables debounce for all fans that the chip supports. Signed-off-by: Ian Dobson <i.dobson@planet-ian.com> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2011-03-14hwmon: (w83627ehf) Update Kconfig for W83677HG-B, NCT6775F and NCT6776FGuenter Roeck
Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Acked-by: Ian Dobson <i.dobson@planet-ian.com>
2011-03-14hwmon: (w83627ehf) Store rpm instead of raw fan speed dataGuenter Roeck
Since the fan speed value can be above 0xff, we can no longer use that value to determine if the fan speed reading is valid. This makes it difficult to manipulate the stored fan speed register value. If we store rpm instead of the fan speed register value, we do not need to correct it if the fan divisor value is changed, and the above mentioned problem no longer exists. Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Acked-by: Ian Dobson <i.dobson@planet-ian.com>
2011-03-14hwmon: (w83627ehf) Use 16 bit fan count registers if supportedGuenter Roeck
Some of the chips supported by this driver have 13 bit or 16 bit fan count registers. This patch improves support for those registers, specifically for NCT6775F. With the changes in this patch, fan speed is reported correctly even if the fan divider is set to a low value, which results in a fan speed reading above 0xff. With this patch, the width of fan count registers is no longer used to determine if the chip has fan divider register(s) or not. A dedicated flag is used instead to determine if this is the case. Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Acked-by: Ian Dobson <i.dobson@planet-ian.com>
2011-03-14hwmon: (w83627ehf) Add support for Nuvoton NCT6775F and NCT6776FGuenter Roeck
This patch adds support for NCT6775F and NCT6776F to the w83627ehf driver. Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Tested-by: Ian Dobson <i.dobson@planet-ian.com> (NCT6776F) Tested-by: Zachary Marzec <zmarzec@gmail.com> (ASUS P8P67 PRO/NCT6776F) Acked-by: Ian Dobson <i.dobson@planet-ian.com>
2011-03-14hwmon: (w83627ehf) Permit enabling SmartFan IV mode if configured at startupGuenter Roeck
If SmartFan IV mode was configured at startup, it should be possible to re-enable it later on. Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Acked-by: Ian Dobson <i.dobson@planet-ian.com>
2011-03-14hwmon: (w83627ehf) Convert register arrays to 16 bit, and convert access to ↵Guenter Roeck
pointers For newer chips, several registers are banked and thus need to be 16 bit. Also, register addresses change. To prepare for those chips, convert affected register arrays to 16 bit, and change access to those registers to array pointers in struct w83627ehf_data. Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Acked-by: Ian Dobson <i.dobson@planet-ian.com>
2011-03-14hwmon: (w83627ehf) Improve support for W83667HG-BGuenter Roeck
Add support for 4th temperature sensor on W83677HG-B. Display temperature labels on W83677HG-B to report temperature sources. Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Acked-by: Ian Dobson <i.dobson@planet-ian.com>
2011-03-14hwmon: (w83627ehf) Optimize multi-bank register accessGuenter Roeck
Assume that each register is banked, and set the bank for each access. Cache the bank number so it only needs to be set if it changes. Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Acked-by: Ian Dobson <i.dobson@planet-ian.com>
2011-03-14hwmon: (w83627ehf) Fixed most checkpatch warnings and errorsGuenter Roeck
This cleanup fixes most of the checkpatch warnings and errors in the w83627ehf driver. Remaining warnings and errors are left untouched on purpose to avoid making the code less readable. Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Acked-by: Ian Dobson <i.dobson@planet-ian.com>
2011-03-14hwmon: (w83627ehf) Unify temperature register access, and use strict string ↵Guenter Roeck
conversions This patch unifies temperature register access, and replaces simple_strtoXXX with strict_strtoXXX throughout the driver. Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Acked-by: Ian Dobson <i.dobson@planet-ian.com>
