path: root/drivers/hwmon
2007-11-08hwmon: (i5k_amb) Convert macros to C functionsDarrick J. Wong
akpm objected to some of the macros, so convert them into functions. Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2007-11-08hwmon: (w83781d) Add missing curly bracesJean Delvare
Missing curly braces cause an if statement to be evaluated when it shouldn't. It happens to be harmless, but that's still worth fixing. Thanks to Riku Voipio for reporting. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-By: Riku Voipio <riku.voipio@movial.fi> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2007-11-08hwmon: (abituguru3) Identify ABit IP35 Pro as suchHans de Goede
This patch changes the identification string for motherboards with an id of 0x001A from unknown to "Abit IP35 Pro". Thanks to James Scott who has an Abit IP35 Pro. Signed-off-by: Hans de Goede <j.w.r.degoede@hhs.nl> Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2007-11-08hwmon: (f75375s) pwmX_mode sysfs files writable for f75375 variantRiku Voipio
Fix value check in set_pwm_mode(). Instead of checking for chip variant there, make pwmX_mode sysfs nodes only writable on f75375 variant. Signed-off-by: Riku Voipio <riku.voipio@movial.fi> Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2007-11-08hwmon: (f75375s) Allow setting up fans with platform_dataRiku Voipio
Allow initializing fans on systems where BIOS does not do that by default. - define f75375s_platform_data in new file f75375s.h - if platform_data was provided, set fans accordingly in f75375_init() - split set_pwm_enable() to a sysfs callback and directly usable set_pwm_enable_direct() Signed-off-by: Riku Voipio <riku.voipio@movial.fi> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2007-11-08hwmon: (f75375s) Add new style bindingsRiku Voipio
Following the example of David Brownell's work on lm75: - Create a second driver struct, using new-style driver binding methods. - Rename the old driver struct as f75375_legacy_driver. - Make the legacy bind/unbind logic delegate all its work. Signed-off-by: Riku Voipio <riku.voipio@movial.fi> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2007-11-08hwmon: (lm70) Convert semaphore to mutexMatthias Kaehlcke
Signed-off-by: Matthias Kaehlcke <matthias.kaehlcke@gmail.com> Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2007-11-08hwmon: (applesmc) Add support for Mac Pro 2 x Quad-CoreRené Rebe
At least the 2x Quad-Core Apple Mac Pro appears to have some over-heat protection which suddenly powers off the whole box under load. This adds support for the fans and temerature sensors in the Mac Pro - later some "windwarm" a-like code should probably monitor the values. For now manually tweaking the fans prevents the sudden shutdown for me. cd /sys/devices/platform/applesmc.768 for x in fan{1,2,3,4}; do echo 1 > ${x}_manual echo 1285 > ${x}_output done Two sensors are 0, while four are 129 °C, those might be removed again, later. Signed-off-by: René Rebe <rene@exactcode.de> Cc: Nicolas Boichat <nicolas@boichat.ch> Cc: Jean Delvare <khali@linux-fr.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2007-11-08hwmon: (abituguru3) Add support for 2 new motherboardsHans de Goede
Signed-of-by: Hans de Goede <j.w.r.degoede@hhs.nl> Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2007-11-08hwmon: (ibmpex) Change printk to dev_{info,err} macrosDarrick J. Wong
Clean up printk use in ibmpex. Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2007-11-08hwmon: (i5k_amb) New memory temperature sensor driverDarrick J. Wong
New driver to read FB-DIMM temperature sensors on systems with the Intel 5000 series chipsets. Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2007-11-08hwmon: (f75375s) fix pwm mode settingRiku Voipio
Spotted by the Coverity checker. (Thanks Adrian Bunk) Signed-off-by: Riku Voipio <riku.voipio@iki.fi> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2007-11-08hwmon: (ibmpex.c) fix NULL dereferenceAdrian Bunk
Don't dereference "data" when we know for sure it's NULL. Spotted by the Coverity checker. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2007-11-08hwmon: (sis5595) Split sis5595_attributes_optIvo Manca
Use sysfs_create_group instead of individual calls to device_create_file by splitting sis5595_attributes_opt into sis5595_attributes_in4 and sis5595_attributes_temp1. Signed-off-by: Ivo Manca <pinkel@gmail.com> Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2007-11-08hwmon: (sis5595) Add individual alarm filesIvo Manca
Add individual alarm files needed by the new libsensors. Signed-off-by: Ivo Manca <pinkel@gmail.com> Acked-by: Jean Delvare <khali@linux.org> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2007-11-08hwmon: (w83627hf) push nr+1 offset into *_REG_FAN macros and simplifyJim Cromie
patch changes 2 macros to incorporate the +1, and drops the +1 from all the callers. This also allows a 'reroll' of an expanded loop, and adjusting indexes and loop limits on another. Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2007-11-08hwmon: (w83627hf) hoist nr-1 offset out of show-store-temp-XJim Cromie
This hoists nr-1 offset out of (show|store)_temp_*(.*) callbacks, and into SENSOR_DEVICE_ATTRs for sysfs tempN_X files. It also combines temp[1] and temp_add[2] (array) fields in w83627hf_data into 3 elem arrays, which simplifies special-case handling of nr, allowing simplification of callback bodies and rerolling a flattened loop in w83627hf_update_device(struct device *dev). The array conversion changes temp[1] from u8 to u16, but this was happening implicitly via the helper functions anyway. Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2007-10-19Merge git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivialLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivial: (74 commits) fix do_sys_open() prototype sysfs: trivial: fix sysfs_create_file kerneldoc spelling mistake Documentation: Fix typo in SubmitChecklist. Typo: depricated -> deprecated Add missing profile=kvm option to Documentation/kernel-parameters.txt fix typo about TBI in e1000 comment proc.txt: Add /proc/stat field small documentation fixes Fix compiler warning in smount example program from sharedsubtree.txt docs/sysfs: add missing word to sysfs attribute explanation documentation/ext3: grammar fixes Documentation/java.txt: typo and grammar fixes Documentation/filesystems/vfs.txt: typo fix include/asm-*/system.h: remove unused set_rmb(), set_wmb() macros trivial copy_data_pages() tidy up Fix typo in arch/x86/kernel/tsc_32.c file link fix for Pegasus USB net driver help remove unused return within void return function Typo fixes retrun -> return x86 hpet.h: remove broken links ...
2007-10-19Merge ssh://master.kernel.org/pub/scm/linux/kernel/git/tglx/linux-2.6-x86Linus Torvalds
* ssh://master.kernel.org/pub/scm/linux/kernel/git/tglx/linux-2.6-x86: (33 commits) x86: convert cpuinfo_x86 array to a per_cpu array x86: introduce frame_pointer() and stack_pointer() x86 & generic: change to __builtin_prefetch() i386: do not BUG_ON() when MSR is unknown x86: acpi use cpu_physical_id x86: convert cpu_llc_id to be a per cpu variable x86: convert cpu_to_apicid to be a per cpu variable i386: introduce "used_vectors" bitmap which can be used to reserve vectors. x86: use raw locks during oopses x86: honor _PAGE_PSE bit on page walks i386: do cpuid_device_create() in CPU_UP_PREPARE instead of CPU_ONLINE. x86: implement missing x86_64 function smp_call_function_mask() x86: use descriptor's functions instead of inline assembly i386: consolidate show_regs and show_registers for i386 i386: make callgraph use dump_trace() on i386/x86_64 x86: enable iommu_merge by default i386: i386 add AMD64 Barcelona PMU MSR definitions to msr.h x86: Unify i386 and x86-64 early quirks x86: enable HPET on ICH3 and ICH4 x86: force enable HPET on VT8235/8237 chipsets ... Manually fix trivial conflict with task pid container helper changes in arch/x86/kernel/process_32.c
2007-10-19Convert files to UTF-8 and some cleanupsJan Engelhardt
* Convert files to UTF-8. * Also correct some people's names (one example is Eißfeldt, which was found in a source file. Given that the author used an ß at all in a source file indicates that the real name has in fact a 'ß' and not an 'ss', which is commonly used as a substitute for 'ß' when limited to 7bit.) * Correct town names (Goettingen -> Göttingen) * Update Eberhard Mönkeberg's address (http://lkml.org/lkml/2007/1/8/313) Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-19get rid of input BIT* duplicate definesJiri Slaby
get rid of input BIT* duplicate defines use newly global defined macros for input layer. Also remove includes of input.h from non-input sources only for BIT macro definiton. Define the macro temporarily in local manner, all those local definitons will be removed further in this patchset (to not break bisecting). BIT macro will be globally defined (1<<x) Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: <dtor@mail.ru> Acked-by: Jiri Kosina <jkosina@suse.cz> Cc: <lenb@kernel.org> Acked-by: Marcel Holtmann <marcel@holtmann.org> Cc: <perex@suse.cz> Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: <vernux@us.ibm.com> Cc: <malattia@linux.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19x86: convert cpuinfo_x86 array to a per_cpu arrayMike Travis
cpu_data is currently an array defined using NR_CPUS. This means that we overallocate since we will rarely really use maximum configured cpus. When NR_CPU count is raised to 4096 the size of cpu_data becomes 3,145,728 bytes. These changes were adopted from the sparc64 (and ia64) code. An additional field was added to cpuinfo_x86 to be a non-ambiguous cpu index. This corresponds to the index into a cpumask_t as well as the per_cpu index. It's used in various places like show_cpuinfo(). cpu_data is defined to be the boot_cpu_data structure for the NON-SMP case. Signed-off-by: Mike Travis <travis@sgi.com> Acked-by: Christoph Lameter <clameter@sgi.com> Cc: Andi Kleen <ak@suse.de> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Dmitry Torokhov <dtor@mail.ru> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Mark M. Hoffman <mhoffman@lightlink.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-10-18Add missing newlines to some uses of dev_<level> messagesJoe Perches
Found these while looking at printk uses. Add missing newlines to dev_<level> uses Add missing KERN_<level> prefixes to multiline dev_<level>s Fixed a wierd->weird spelling typo Added a newline to a printk Signed-off-by: Joe Perches <joe@perches.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Mark M. Hoffman <mhoffman@lightlink.com> Cc: Roland Dreier <rolandd@cisco.com> Cc: Tilman Schmidt <tilman@imap.cc> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Jeff Garzik <jeff@garzik.org> Cc: Stephen Hemminger <shemminger@linux-foundation.org> Cc: Greg KH <greg@kroah.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Cc: James Smart <James.Smart@Emulex.Com> Cc: Andrew Vasquez <andrew.vasquez@qlogic.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Jaroslav Kysela <perex@suse.cz> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-15Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (40 commits) Input: use full RCU API Input: remove tsdev interface Input: add support for Blackfin BF54x Keypad controller Input: appletouch - another fix for idle reset logic HWMON: hdaps - switch to using input-polldev Input: add support for SEGA Dreamcast keyboard Input: omap-keyboard - don't pretend we support changing keymap Input: lifebook - fix X and Y axis range Input: usbtouchscreen - add support for GeneralTouch devices Input: fix open count handling in input interfaces Input: keyboard - add CapsShift lock Input: adbhid - produce all CapsLock key events Input: ALPS - add signature for ThinkPad R61 Input: jornada720_kbd - send MSC_SCAN events Input: add support for the HP Jornada 7xx (710/720/728) touchscreen Input: add support for HP Jornada 7xx onboard keyboard Input: add support for HP Jornada onboard keyboard (HP6XX) Input: ucb1400_ts - use schedule_timeout_uninterruptible Input: xpad - fix dependancy on LEDS class Input: auto-select INPUT for MAC_EMUMOUSEBTN option ... Resolved conflicts manually in drivers/hwmon/applesmc.c: converting from a class device to a device and converting to use input-polldev created a few apparently trivial clashes..
2007-10-14Merge branch 'release' of git://lm-sensors.org/kernel/mhoffman/hwmon-2.6Linus Torvalds
* 'release' of git://lm-sensors.org/kernel/mhoffman/hwmon-2.6: (53 commits) hwmon: (vt8231) fix sparse warning hwmon: (sis5595) fix sparse warning hwmon: (w83627hf) don't assume bank 0 hwmon: (w83627hf) Fix setting fan min right after driver load hwmon: (w83627hf) De-macro sysfs callback functions hwmon: Add new combined driver for FSC chips hwmon: (ibmpex) Release IPMI user if hwmon registration fails hwmon: (dme1737) Add sch311x support hwmon: (dme1737) group functions logically hwmon: (dme1737) cleanups hwmon: IBM power meter driver hwmon: (coretemp) Add support for Celeron 4xx hwmon: (lm87) Disable VID when it should be hwmon: (w83781d) Add individual alarm and beep files hwmon: VRM is not read from registers MAINTAINERS: update hwmon subsystem git trees hwmon: Fix the code examples in documentation hwmon: update sysfs interface document - error handling hwmon: (thmc50) Fix a debug message hwmon: (thmc50) Don't create temp3 if not enabled ...
2007-10-14hwmon: (vt8231) fix sparse warningMark M. Hoffman
2007-10-14hwmon: (sis5595) fix sparse warningMark M. Hoffman
2007-10-13hwmon: (w83627hf) don't assume bank 0Jean Delvare
The bank switching code assumes that the bank selector is set to 0 when the driver is loaded. This might not be the case. This is exactly the same bug as was fixed in the w83627ehf driver two months ago: http://git.kernel.org/?p=linux/kernel/git/torvalds/linux-2.6.git;a=commit;h=0956895aa6f8dc6a33210967252fd7787652537d In practice, this bug was causing the sensor thermal types to be improperly reported for my W83627THF the first time I was loading the w83627hf driver. From the driver history, I'd say that it has been broken since September 2005 (when we stopped resetting the chip by default at driver load.) Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2007-10-13hwmon: (w83627hf) Fix setting fan min right after driver loadJean Delvare
We need to read the fan clock dividers at initialization time, otherwise the code in store_fan_min() may use uninitialized values. That's pretty much the same bug and same fix as for the w83627ehf driver last month. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2007-10-13hwmon: (w83627hf) De-macro sysfs callback functionsJim Cromie
This patch to drivers/hwmon/w83627hf converts many sysfs items from DEVICE_ATTRs to SENSOR_DEVICE_ATTRs, and replaces macros which expand to define redundant callbacks, with callbacks which use the SENSOR_DEV.nr to know what to do. Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2007-10-12HWMON: hdaps - switch to using input-polldevDmitry Torokhov
Switch to using input-polldev skeleton instead of implementing polling loop by itself. This also fixes problem with trylock on a mutex in atomic context. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2007-10-12Merge master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6Dmitry Torokhov
Conflicts: drivers/macintosh/adbhid.c
2007-10-11hwmon: Add new combined driver for FSC chipsHans de Goede
This patch adds a new merged driver for FSC sensor chips, it merges the fscher and fscpos drivers and adds support for the FSC Scylla, Heracles and Heimdall chips. Signed-off-by: Hans de Goede <j.w.r.degoede@hhs.nl> Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2007-10-11hwmon: (ibmpex) Release IPMI user if hwmon registration failsDarrick J. Wong
Roel Kluin <12o3l@tiscali.nl> found a minor defect in the init code if hwmon device registration fails. Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2007-10-10hwmon: (dme1737) Add sch311x supportJuerg Haefliger
This patch adds support for the SMSC SCH3112, SCH3114, and SCH3116 Super-I/O chips. These chips feature identical hardware monitoring capabilites with the expection that some of the fan inputs and pmw outputs don't exist. The hardware monitoring features of the SCH311x chips can only be accessed via the ISA bus. The driver therefore registers as a platform driver, if such a chip is detected. Signed-off-by: Juerg Haefliger <juergh at gmail.com> Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2007-10-10hwmon: (dme1737) Fix some merge conflictsMark M. Hoffman
class_dev -> hwmon_dev Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2007-10-10hwmon: (dme1737) group functions logicallyJuerg Haefliger
Move functions to group them logically. Device and I2C functions go in separate places. No functional changes (really!). Signed-off-by: Juerg Haefliger <juergh at gmail.com> Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2007-10-10hwmon: (dme1737) cleanupsJuerg Haefliger
This patch cleans up and prepares the dme1737 driver for support of the sch311x chips. (Almost) no functional changes. - Replaced whitespaces with tabs. - Removed empty lines. - Added _i2c_ to names of functions that are strictly I2C related. - Added 4 new functions: dme1737_create_files, dme1737_remove_files, dme1737_sio_enter, and dme1737_sio_exit. - Added error messages in case client attach/detach fails. Signed-off-by: Juerg Haefliger <juergh at gmail.com> Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2007-10-09hwmon: IBM power meter driverDarrick J. Wong
Add a driver to export IBM PowerExecutive power meter sensors. Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2007-10-09hwmon: (coretemp) Add support for Celeron 4xxRudolf Marek
This patch adds support for the Celeron 4xx based on Core 2 core. Signed-off-by: Rudolf Marek <r.marek@assembler.cz> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2007-10-09hwmon: (lm87) Disable VID when it should beJean Delvare
A stupid bit shifting bug caused the VID value to be always exported even when the hardware is configured for something different. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2007-10-09hwmon: (w83781d) Add individual alarm and beep filesJean Delvare
The upcoming libsensors 3 needs these individual alarm and beep files. For the W83781D, this is quirky because this chip has a single alarm bit for both temp2 and temp3. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Hans de Goede <j.w.r.degoede@hhs.nl> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2007-10-09hwmon: VRM is not read from registersJean Delvare
The VRM value is not read from chip registers, so there's no need to update the device data cache before exporting the VRM value to user-space. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Hans de Goede <j.w.r.degoede@hhs.nl> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2007-10-09hwmon: (thmc50) Fix a debug messageJean Delvare
type_name was used before being set. See why I don't like play-it-safe variable initializations: they prevent the compiler from warning you about such mistakes. So fix that as well. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2007-10-09hwmon: (thmc50) Don't create temp3 if not enabledJean Delvare
Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2007-10-09hwmon: (lm87) Add individual alarm filesJean Delvare
Add individual alarm files to the lm87 driver. The new libsensors needs this. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Hans de Goede <j.w.r.degoede@hhs.nl> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2007-10-09hwmon: (lm87) Fix a division by zeroJean Delvare
Missing parentheses in the definition of FAN_FROM_REG cause a division by zero for a specific register value. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Hans de Goede <j.w.r.degoede@hhs.nl> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2007-10-09hwmon: (lm78) Add individual alarm filesJean Delvare
Add individual alarm files to the lm78 driver, these are needed by the next version of libsensors. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Hans de Goede <j.w.r.degoede@hhs.nl> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2007-10-09hwmon: (lm90) Export temperature offset valuesJean Delvare
Now that we have standard sysfs names to export temperature offset values, add this feature to the lm90 driver. All supported chips except the MAX6657, MAX6658 and MAX6659 support it. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Hans de Goede <j.w.r.degoede@hhs.nl> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2007-10-09hwmon: Kconfig dependency cleanupsJean Delvare
* Drop HWMON from the dependency list of ABITUGURU3 and LM93: this is now handled at menu level. * Make the Abit, Asus and FSC chip drivers depend on X86. These are custom chips which can only be found on their respective manufacturer's systems, and these manufacturers only do x86 hardware AFAIK. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Hans de Goede <j.w.r.degoede@hhs.nl> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
