commit f7c77a3dc4683659b6f0d1b6cbc82b6253d095e0 upstream.
The recent addition of threaded irq handler causes a NULL dereference
when used with hp_accel driver, which has NULL pdata.
Acked-by: Samu Onkalo <samu.p.onkalo@nokia.com>
Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
commit c3b327d60bbba3f5ff8fd87d1efc0e95eb6c121b upstream.
All bits in the values read from registers to be used for the next
write were getting overwritten, avoid doing so to not mess with the
current configuration.
Signed-off-by: Guillem Jover <guillem@hadrons.org>
Cc: Riku Voipio <riku.voipio@iki.fi>
commit 96f3640894012be7dd15a384566bfdc18297bc6c upstream.
The spec notes that fan0 and fan1 control mode bits are located in bits
7-6 and 5-4 respectively, but the FAN_CTRL_MODE macro was making the
bits shift by 5 instead of by 4.
commit f17c811d1433aa1966f9c5a744841427e9a97ecf upstream.
It is unnecessary and wrong to call hwmon_device_unregister in error
handling before hwmon_device_register is called.
Signed-off-by: Yong Wang <yong.y.wang@intel.com>
Reviewed-by: Guenter Roeck <guenter.roeck@ericsson.com>
commit 4e70598c3b56e6fec551454c495d4d4025834749 upstream.
Added missing axis-mapping for HP ProBook 532x and HP Mini 5102.
Cc: Eric Piel <eric.piel@tremplin-utc.net>
commit a05e93f3b3fc2f53c1d0de3b17019e207c482349 upstream.
Commit 8bf0223ed515be24de0c671eedaff49e78bebc9c (hwmon, k8temp: Fix
temperature reporting for ASB1 processor revisions) fixed temperature
reporting for ASB1 CPUs. But those CPU models (model 0x6b, 0x6f, 0x7f)
were packaged both as AM2 (desktop) and ASB1 (mobile). Thus the commit
leads to wrong temperature reporting for AM2 CPU parts.
The solution is to determine the package type for models 0x6b, 0x6f,
0x7f.
This is done using BrandId from CPUID Fn8000_0001_EBX[15:0]. See
"Constructing the processor Name String" in "Revision Guide for AMD
NPT Family 0Fh Processors" (Rev. 3.46).
Cc: Rudolf Marek <r.marek@assembler.cz>
Reported-by: Vladislav Guberinic <neosisani@gmail.com>
Signed-off-by: Andreas Herrmann <andreas.herrmann3@amd.com>
commit c12c507d7185fe4e8ada7ed9832957576eefecf8 upstream.
1. remove 'status' variable
2. remove unneeded initialization of 'err' variable
3. return missing error code if sysfs_create_group fail.
4. fix the init sequence as:
- check hardware existence
- kzalloc for ads7871_data
- sysfs_create_group
- hwmon_device_register
commit b9783dcebe952bf73449fe70a19ee4814adc81a0 upstream.
It's not OK to call platform_device_add_resources() multiple times
in a row. Despite its name, this functions sets the resources, it
doesn't add them. So we have to prepare an array with all the
resources, and then call platform_device_add_resources() once.
Before this fix, only the last I/O resource would be actually
registered. The other I/O resources were leaked.
Cc: Jim Cromie <jim.cromie@gmail.com>
Don't assume that CPU entry number and core ID always match. It
worked in the simple cases (single CPU, no HT) but fails on
multi-CPU systems.
Acked-by: Huaxu Wan <huaxu.wan@intel.com>
Cc: stable@kernel.org
On hyper-threaded CPUs, each core appears twice in the CPU list. Skip
the second entry to avoid duplicate sensors.
The IT8720F has no VIN7 pin, so VCCH should always be routed
internally to VIN7 with an internal divider. Curiously, there still
is a configuration bit to control this, which means it can be set
incorrectly. And even more curiously, many boards out there are
improperly configured, even though the IT8720F datasheet claims that
the internal routing of VCCH to VIN7 is the default setting. So we
force the internal routing in this case.
It turns out that all boards with the wrong setting are from Gigabyte,
so I suspect a BIOS bug. But it's easy enough to workaround in the
driver, so let's do it.
Cc: Jean-Marc Spaggiari <jean-marc@spaggiari.org>
Reported temperature for ASB1 CPUs is too high.
Add ASB1 CPU revisions (these are also non-desktop variants) to the
list of CPUs for which the temperature fixup is not required.
Example: (from LENOVO ThinkPad Edge 13, 01972NG, system was idle)
Current kernel reports
$ sensors
k8temp-pci-00c3
Adapter: PCI adapter
Core0 Temp: +74.0 C
Core0 Temp: +70.0 C
Core1 Temp: +69.0 C
Core1 Temp: +70.0 C
With this patch I have
$ sensors
k8temp-pci-00c3
Core0 Temp: +54.0 C
Core0 Temp: +51.0 C
Core1 Temp: +48.0 C
Core1 Temp: +49.0 C
Cc: stable@kernel.org [.32.x .33.x, .34.x]
Commit a2e066bba2aad6583e3ff648bf28339d6c9f0898 introduced core
swapping for CPU models 64 and later. I recently had a report about
a Sempron 3200+, model 95, for which this patch broke temperature
reading. It happens that this is a single-core processor, so the
effect of the swapping was to read a temperature value for a core
that didn't exist, leading to an incorrect value (-49 degrees C.)
Disabling core swapping on singe-core processors should fix this.
Additional comment from Andreas:
The BKDG says
Thermal Sensor Core Select (ThermSenseCoreSel)-Bit 2. This bit
selects the CPU whose temperature is reported in the CurTemp
field. This bit only applies to dual core processors. For
single core processors CPU0 Thermal Sensor is always selected.
k8temp_probe() correctly detected that SEL_CORE can't be used on single
core CPU. Thus k8temp did never update the temperature values stored
in temp[1][x] and -49 degrees was reported. For single core CPUs we
must use the values read into temp[0][x].
Tested-by: Rick Moritz <rhavin@gmx.net>
Acked-by: Andreas Herrmann <andreas.herrmann3@amd.com>
i5k_amb.ko uses dynamically allocated memory (by kmalloc) for
attributes passed to sysfs. So, sysfs_attr_init() should be called
for working happy with lockdep.
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Cc: stable@kernel.org [2.6.34 only]
When detecting AM2+ or AM3 socket with DDR2, only blacklist cores
which are known to exist in AM2+ format.
Acked-by: Clemens Ladisch <clemens@ladisch.de>
Cc: Andreas Herrmann <andreas.herrmann3@amd.com>
I2C drivers can use the clientdata-pointer to point to private data. As I2C
devices are not really unregistered, but merely detached from their driver, it
used to be the drivers obligation to clear this pointer during remove() or a
failed probe(). As a couple of drivers forgot to do this, it was agreed that it
was cleaner if the i2c-core does this clearance when appropriate, as there is
no guarantee for the lifetime of the clientdata-pointer after remove() anyhow.
This feature was added to the core with commit
e4a7b9b04de15f6b63da5ccdd373ffa3057a3681 to fix the faulty drivers.
As there is no need anymore to clear the clientdata-pointer, remove all current
occurrences in the drivers to simplify the code and prevent confusion.
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Acked-by: Richard Purdie <rpurdie@linux.intel.com>
Acked-by: Dmitry Torokhov <dtor@mail.ru>
Add support for the Texas Instruments TMP105 temperature sensor
device.
Signed-off-by: Shubhrajyoti Datta <shubhrajyoti@ti.com>
Acked-by: Jonathan Cameron <jic23@cam.ac.uk>
Read only one of the GPIO pins as an analog voltage. The ADC can be
switched to a different GPIO pin at runtime, but this is not supported.
Previously, this driver would report the analog voltage of the currently
selected GPIO pin as all three GPIO voltages: in9_input, in10_input and
in11_input.
Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu>
Add support for the hardware monitoring capabilities of the SCH5127
chip to the dme1737 driver.
Signed-off-by: Juerg Haefliger <juergh@gmail.com>
Tested-by: Jeff Rickman <jrickman@myamigos.us>
Only stop the chip at driver exit if it was stopped when driver was
loaded. Leave it running otherwise.
Also restore the device configuration if probe failed, to not leave
the system in a dangling state.
Cc: Steven King <sfking@fdwdc.com>
Suspend and resume functions shouldn't overwrite the configuration
register. They should only alter the one bit they have to touch.
Also don't assume that register reads and writes always succeed.
Handle errors properly, shall they happen.
Fixes from my driver review:
http://lists.lm-sensors.org/pipermail/lm-sensors/2010-March/028051.html
Only the small changes are in there, more important changes will come
later separately as time permits.
* Drop the remnants of the now gone detect function
* The TMP102 has no known compatible chip
* Include the right header files
* Clarify why byte swapping of register values is needed
* Strip resolution info bit from temperature register value
* Set cache lifetime to 1/3 second
* Don't arbitrarily reject limit values; clamp as needed
* Make limit writing unconditional
* Don't check for transaction types the driver doesn't use
* Properly check for error when setting configuration
* Report error on failed probe
* Make the driver load automatically where needed
* Various other minor fixes
Driver for the TI TMP102.
The TI TMP102 is similar to the LM75. It differs from the LM75 by
having a 16-bit conf register and the temp registers have a minimum
resolution of 12 bits; the extended conf register can select 13-bit
resolution (which this driver does) and also change the update rate
(which this driver currently doesn't use).
[JD: Fix tmp102_exit tag, must be __exit, not __init.]
Signed-off-by: Steven King <sfking@fdwdc.com>
Provides support for the EMC1403 thermal sensor. Only reporting of values
is supported. The various Moorestown specific extras to do with thermal
alerts and the like are not in this version of the driver.
Considerably edited and tidied up by Alan Cox, plus fixes and detection
bits from Jean Delvare.
Signed-off-by: Kalhan Trisal <kalhan.trisal@intel.com>
Signed-off-by: Alan Cox <alan@linux.intel.com>
The Apple SMC uses a systematic labeling scheme for the hardware
temperature sensors. This scheme is currently hidden from
userland. Since the sensor set, and consequently the numbering,
differs between models, an extensive database of configurations is
required for an application such as fan control. This patch adds the
SMC labels to the hwmon sysfs interface, allowing applications to use
the sensors more intelligibly.
[rydberg@euromail.se: fixed error handling]
Signed-off-by: Alex Murray <murray.alex@gmail.com>
Signed-off-by: Henrik Rydberg <rydberg@euromail.se>
This patch adds generic support for the MacBook Pro 7 family
based on the 7,1 model.
This patch adds generic support for the MacBook Pro 6 family
based on the 6,2 model.
[rydberg@euromail.se: patch cleanup]
Signed-off-by: Bernhard Froemel <froemel@vmars.tuwien.ac.at>
The MacBookPro 5,3 model has two fans, whereas the 5,4 model has
only one. This patch adds explicit support for the 5,3 and 5,4 models.
Signed-off-by: Andre Prendel <andre.prendel@gmx.de>
Acked-by: Hans de Goede <hdegoede@redhat.com>
Replace octal representation of file permissions by the corresponding
constants.
Based on earlier work by Ira W. Snyder.
The adm1031 chip is capable of using a runtime configurable sampling rate,
using the fan filter register. Add support for reading and setting the
update rate via sysfs.
Acked-by: Ira W. Snyder <iws@ovro.caltech.edu>
The lm90 driver programs the sensor chip to update its readings at 2 Hz
(500 ms between readings). However, the driver only does reads from the
chip at intervals of 2 * HZ (2000 ms between readings). Change the driver
update rate to the programmed update rate.
Acquire the I/O region for the Super I/O chip while we're working on it.
Signed-off-by: Giel van Schijndel <me@mortis.eu>
Cc: Hans de Goede <hdegoede@redhat.com>
Some code cleanup: properly use previously defined functions, rather
than duplicating their code.
Use the strict_strol and strict_stroul functions instead of simple_strol
and simple_stroul respectively in sysfs functions.
Fixed several coding style issues.
The LM64 appears to be an LM63 with added GPIO lines. Add support for the
hwmon functionality - GPIO can be added at some later stage if someone
has a need for them.
When the user passes the kernel parameter acpi_enforce_resources=lax,
the ACPI resources are no longer protected, so a native driver can
make use of them. In that case, we do not want the asus_atk0110 to be
loaded. Unfortunately, this driver loads automatically due to its
MODULE_DEVICE_TABLE, so the user ends up with two drivers loaded for
the same device - this is bad.
So I suggest that we prevent the asus_atk0110 driver from loading if
acpi_enforce_resources=lax.
Acked-by: Luca Tettamanti <kronos.it@gmail.com>
Cc: Len Brown <lenb@kernel.org>
The MSR IA32_TEMPERATURE_TARGET contains the TjMax value in the newer
Intel processors.
Signed-off-by: Huaxu Wan <huaxu.wan@linux.intel.com>
Signed-off-by: Carsten Emde <C.Emde@osadl.org>
Cc: Jean Delvare <khali@linux-fr.org>
Cc: Valdis Kletnieks <valdis.kletnieks@vt.edu>
Cc: Henrique de Moraes Holschuh <hmh@hmh.eng.br>
Cc: Yong Wang <yong.y.wang@linux.intel.com>
The thermal sensors of Intel(R) CPUs can be detected by CPUID instruction,
indicated by CPUID.06H.EAX[0].
Reviewed-by: Valdis Kletnieks <valdis.kletnieks@vt.edu>
Signed-off-by: Paul Thomas <pthomas8589@gmail.com>
Cc: Jonathan Cameron <jic23@cam.ac.uk>
Set valid adjustment window (0 - 2000ms).
Signed-off-by: Samu Onkalo <samu.p.onkalo@nokia.com>
Acked-by: Eric Piel <eric.piel@tremplin-utc.net>
Cc: Daniel Mack <daniel@caiaq.de>
Cc: Pavel Machek <pavel@ucw.cz>
Content for the 8bit device threaded interrupt handlers. Depending on the
interrupt line and chip configuration, either click or wakeup / freefall
handler is called. In case of click, BTN_ event is sent via input device.
In case of wakeup or freefall, input device ABS_ events are updated
immediatelly.
It is still possible to configure interrupt line 1 for fast freefall
detection and use the second line either for click or threshold based
interrupts. Or both lines can be used for click / threshold interrupts.
Polled input device can be set to stopped state and still get coordinate
updates via input device using interrupt based method. Polled mode and
interrupt mode can also be used parallel.
BTN_ events are remapped based on existing axis remapping information.
Original lis3 driver didn't provide interrupt handler(s) for click or
threshold event handling. This patch adds threaded handlers for one or
two interrupt lines for 8 bit device. Actual content for interrupt
handling is provided in the separate patch.
Tested-by: Daniel Mack <daniel@caiaq.de>
8 bit device has two wakeup / free fall units. It was not possible to
configure the second unit. This patch introduces configuration entry to
the platform data and also corresponding changes to the 8 bit setup
function.
High pass filters were enabled by default. Patch introduces configuration
option for high pass filter cut off frequency and also possibility to
disable or enable the filter via platform data. Since the control is a
new one and default state was filter enabled, new option is used to
disable the filter. This way old platform data is still compatible with
the change.
Separate configuration function for 8 bit version of the chip. This way
generic part of the init function stays little bit more readable.
Definitions for click were missing.
git://git.kernel.org/pub/scm/linux/kernel/git/frederic/random-tracing
* 'bkl/ioctl' of git://git.kernel.org/pub/scm/linux/kernel/git/frederic/random-tracing:
uml: Pushdown the bkl from harddog_kern ioctl
sunrpc: Pushdown the bkl from sunrpc cache ioctl
sunrpc: Pushdown the bkl from ioctl
autofs4: Pushdown the bkl from ioctl
uml: Convert to unlocked_ioctls to remove implicit BKL
ncpfs: BKL ioctl pushdown
coda: Clean-up whitespace problems in pioctl.c
coda: BKL ioctl pushdown
drivers: Push down BKL into various drivers
isdn: Push down BKL into ioctl functions
scsi: Push down BKL into ioctl functions
dvb: Push down BKL into ioctl functions
smbfs: Push down BKL into ioctl function
coda/psdev: Remove BKL from ioctl function
um/mmapper: Remove BKL usage
sn_hwperf: Kill BKL usage
hfsplus: Push down BKL into ioctl function
Merging in current state of Linus' tree to deal with merge conflicts and
build failures in vio.c after merge.
drivers/i2c/busses/i2c-cpm.c
drivers/i2c/busses/i2c-mpc.c
drivers/net/gianfar.c
Also fixed up one line in arch/powerpc/kernel/vio.c to use the
correct node pointer.
.name, .match_table and .owner are duplicated in both of_platform_driver
and device_driver. This patch is a removes the extra copies from struct
of_platform_driver and converts all users to the device_driver members.
This patch is a pretty mechanical change. The usage model doesn't change
and if any drivers have been missed, or if anything has been fixed up
incorrectly, then it will fail with a compile time error, and the fixup
will be trivial. This patch looks big and scary because it touches so
many files, but it should be pretty safe.
Acked-by: Sean MacLennan <smaclennan@pikatech.com>
