path: root/drivers/i2c/busses/i2c-au1550.c
2014-01-24i2c: delete non-required instances of include <linux/init.h>Paul Gortmaker
None of these files are actually using any __init type directives and hence don't need to include <linux/init.h>. Most are just a left over from __devinit and __cpuinit removal, or simply due to code getting copied from one driver to the next. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2013-02-22i2c: Remove unneeded xxx_set_drvdata(..., NULL) callsDoug Anderson
There is simply no reason to be manually setting the private driver data to NULL in the remove/fail to probe cases. This is just extra cruft code that can be removed. A few notes: * Nothing relies on drvdata being set to NULL. * The __device_release_driver() function eventually calls dev_set_drvdata(dev, NULL) anyway, so there's no need to do it twice. * I verified that there were no cases where xxx_get_drvdata() was being called in these drivers and checking for / relying on the NULL return value. This could be cleaned up kernel-wide but for now just take the baby step and remove from the i2c subsystem. Reported-by: Wolfram Sang <wsa@the-dreams.de> Reported-by: Stephen Warren <swarren@wwwdotorg.org> Signed-off-by: Doug Anderson <dianders@chromium.org> Reviewed-by: Jean Delvare <khali@linux-fr.org> Acked-by: Peter Korsgaard <jacmet@sunsite.dk> Reviewed-by: Mika Westerberg <mika.westerberg@linux.intel.com> Reviewed-by: Marek Vasut <marex@denx.de> Signed-off-by: Wolfram Sang <wolfram@the-dreams.de>
2012-12-22i2c: remove __dev* attributes from subsystemBill Pemberton
CONFIG_HOTPLUG is going away as an option. As result the __dev* markings will be going away. Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Acked-by: Peter Korsgaard <peter.korsgaard@barco.com> (for ocores and mux-gpio) Acked-by: Havard Skinnemoen <hskinnemoen@gmail.com> (for i2c-gpio) Acked-by: Guan Xuetao <gxt@mprc.pku.edu.cn> (for puf3) Acked-by: Barry Song <baohua.song@csr.com> (for sirf) Reviewed-by: Jean Delvare <khali@linux-fr.org> [wsa: Fixed "foo* bar" flaws while we are here] Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
2012-01-12i2c/busses: Use module_platform_driver()Axel Lin
Convert the drivers in drivers/i2c/busses/* to use the module_platform_driver() macro which makes the code smaller and a bit simpler. Cc: Ben Dooks <ben-linux@fluff.org> Acked-by: Jochen Friedrich <jochen@scram.de> Acked-by: Peter Korsgaard <jacmet@sunsite.dk> Acked-by: Wolfram Sang <w.sang@pengutronix.de> Cc: Manuel Lauss <manuel.lauss@googlemail.com> Cc: Barry Song <21cnbao@gmail.com> Cc: Linus Walleij <linus.walleij@linaro.org> Cc: Yong Zhang <yong.zhang0@gmail.com> Cc: Lucas De Marchi <lucas.demarchi@profusion.mobi> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2011-11-03Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
* 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (37 commits) MIPS: O32: Provide definition of registers ta0 .. ta3. MIPS: perf: Add Octeon support for hardware perf. MIPS: perf: Add support for 64-bit perf counters. MIPS: perf: Reorganize contents of perf support files. MIPS: perf: Cleanup formatting in arch/mips/kernel/perf_event.c MIPS: Add accessor macros for 64-bit performance counter registers. MIPS: Add probes for more Octeon II CPUs. MIPS: Add more CPU identifiers for Octeon II CPUs. MIPS: XLR, XLS: Add comment for smp setup MIPS: JZ4740: GPIO: Check correct IRQ in demux handler MIPS: JZ4740: GPIO: Simplify IRQ demuxer MIPS: JZ4740: Use generic irq chip MIPS: Alchemy: remove all CONFIG_SOC_AU1??? defines MIPS: Alchemy: kill au1xxx.h header MIPS: Alchemy: clean DMA code of CONFIG_SOC_AU1??? defines MIPS, IDE: Alchem, au1xxx-ide: Remove pb1200/db1200 header dep MIPS: Alchemy: Redo PCI as platform driver MIPS: Alchemy: more base address cleanup MIPS: Alchemy: rewrite USB platform setup. MIPS: Alchemy: abstract USB block control register access ... Fix up trivial conflicts in: arch/mips/alchemy/devboards/db1x00/platform.c drivers/ide/Kconfig drivers/mmc/host/au1xmmc.c drivers/video/Kconfig sound/mips/Kconfig
2011-10-29i2c-au1550: dev_pm_ops conversionManuel Lauss
use newer dev_pm_ops for PM Signed-off-by: Manuel Lauss <manuel.lauss@googlemail.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-10-29i2c-au1550: increase timeout waiting for master doneManuel Lauss
Double the timeout in the loop which busy-waits for the "master-done" bit to be set. This bit indicates whether an i2c transaction has completed; on the DB1300 and DB1550 boards this timeout is slightly too short and causes transactions to the WM8731 codec to be falsely flagged as failed. The timeout itself is necessary since transactions to non-existant slaves never set this bit in the first place (and cause i2cdetect to hang). With this change the WM8731 codec on the DB1300/DB1550 boards is correctly detected and initialized. Signed-off-by: Manuel Lauss <manuel.lauss@googlemail.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-10-29i2c-au1550: remove unused ack_timeoutManuel Lauss
The ack_timeout context member is unused, get rid of it. Signed-off-by: Manuel Lauss <manuel.lauss@googlemail.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-10-29i2c-au1550: remove usage of volatile keywordManuel Lauss
Replace the usage of "volatile"s with register accessor functions. Signed-off-by: Manuel Lauss <manuel.lauss@googlemail.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-10-24MIPS: Alchemy: kill au1xxx.h headerManuel Lauss
No longer required Signed-off-by: Manuel Lauss <manuel.lauss@googlemail.com> To: Linux-MIPS <linux-mips@linux-mips.org> Patchwork: https://patchwork.linux-mips.org/patch/2705/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> delete mode 100644 arch/mips/include/asm/mach-au1x00/au1xxx.h
2009-06-16i2c: Use resource_size macroLinus Walleij
This replace all instances in the i2c busses tree of res->end - res->start + 1 with the handy macro resource_size(res) from ioport.h (coming in from platform_device.h). This was created with a simple sed -i -e 's/\([a-z]*\)->end *- *[a-z]*->start *+ *1/resource_size(\1)/g' Then manually replacing the PXA redefiniton of the same kind of macro manually. Recompiled some ARM defconfigs I could find to make a rough test so it shouldn't break anything, though I couldn't see exactly which configs you need for all the drivers. Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2009-01-26i2c: Delete many unused adapter IDsJean Delvare
2008-07-14i2c-au1550: Fix PM supportManuel Lauss
Fix driver power management: - suspend the PSC while driver is idle. - move PSC init/deinit to separate functions, as PSC must be initialized/shutdown on resume/suspend. Signed-off-by: Manuel Lauss <mano@roarinelk.homelinux.net> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-05-12[MIPS] Alchemy: SMBus resource fixSergei Shtylyov
The Alchemy platform code registers the SMBus device using the virtual address of its registers instead of the physical one -- fix this, taking into account that actually the whole megabyte is decoded by any of the programmable serial controllers (one of which is SMBus), and that all the Alchemy peripherals are directly mappable into KSEG1 kernel space and therefore ioremap() call would just boil down to CKSEG1ADDR() invocation. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-22i2c: Fix platform driver hotplug/coldplugKay Sievers
Since 43cc71eed1250755986da4c0f9898f9a635cb3bf, the platform modalias is prefixed with "platform:". Add MODULE_ALIAS() to the hotpluggable I2C platform drivers, to allow module auto loading. [ db: add some more drivers ] Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-01-27i2c-au1550: Convert to platform driverManuel Lauss
Convert the i2c-au1550 bus driver to platform driver, and register a platform device for the Alchemy Db/Pb series of boards. Signed-off-by: Manuel Lauss <mano@roarinelk.homelinux.net> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-01-27i2c-au1550: properly terminate zero-byte transfersManuel Lauss
Zero-bytes transfers would leave the bus transaction unfinished (no i2c stop is sent), with the following transfer actually sending the slave address to the previously addressed device, resulting in weird device failures (e.g. reset minute register values in my RTC). This patch instructs the controller to send an I2C STOP right after the slave address in case of a zero-byte transfer. Signed-off-by: Manuel Lauss <mano@roarinelk.homelinux.net> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2007-10-13i2c-au1550: Fix a misused register problemChris David
Fix a "mis-used register" problem on the AMD MIPS Alchemy au1550 I2C interface. In summary, the programmable serial controller seems to hang the kernel when I send a single 'address' byte on the I2C bus. The patch essentially uses the PSC_SMBSTAT register's TE (transmit FIFO empty) bit to check when the transmit FIFO is empty, instead of using the PSC_SMBEVNT register's TU (transmit underflow) bit. Using the TE bit fixed the hang problem. Signed-off-by: Chris David <cd@chrisdavid.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2006-09-26i2c: Constify i2c_algorithm declarations, part 2Jean Delvare
i2c: Constify i2c_algorithm declarations, part 2 Make struct i2c_algorithm declarations const in all i2c bus drivers where it is possible. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-26i2c-au1550: Add I2C support for Au1200Domen Puncer
i2c-au1550: Add I2C support for Au1200 Signed-off-by: Domen Puncer <domen.puncer@ultra.si> Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-26i2c-au1550: Add SMBus functionality flagDomen Puncer
i2c-au1550: Add SMBus functionality flag Add SMBus functionality flag, so we can use eeprom and similar drivers. Signed-off-by: Domen Puncer <domen.puncer@ultra.si> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-26i2c-au1550: Fix timeout problemDomen Puncer
i2c-au1550: Fix timeout problem Fix from Jordan Crouse: If the transmit and recieve FIFOS are not empty, forceably flush them rather then waiting for them to drain on their own. This solves at least a problem reported by Clem Taylor: http://www.linux-mips.org/archives/linux-mips/2006-05/msg00240.html (1% of I2C transactions would timeout) Signed-off-by: Domen Puncer <domen.puncer@ultra.si> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-05[PATCH] I2C: Kill i2c_algorithm.id (4/7)Jean Delvare
There are no more users of i2c_algorithm.id, so we can finally drop this structure member. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-05[PATCH] I2C: Kill i2c_algorithm.name (1/7)Jean Delvare
The name member of the i2c_algorithm is never used, although all drivers conscientiously fill it. We can drop it completely, this structure doesn't need to have a name. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-21[PATCH] I2C: drivers/i2c/*: #include <linux/config.h> cleanupAlexey Dobriyan
Files that don't use CONFIG_* stuff shouldn't include config.h Files that use CONFIG_* stuff should include config.h It's that simple. ;-) Signed-off-by: Alexey Dobriyan <adobriyan@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
