path: root/drivers/i2c/busses/i2c-bcm-kona.c
2014-10-20i2c: busses: drop owner assignment from platform_driversWolfram Sang
A platform_driver does not need to set an owner, it will be populated by the driver core. Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2013-11-26i2c: i2c-bcm-kona: Fix module buildTim Kryger
Correct a typo that prevented the driver from being built as a module. Reported-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Tim Kryger <tim.kryger@linaro.org> Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2013-11-26i2c: bcm-kona: remove duplicated includeWei Yongjun
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Reviewed-by: Markus Mayer <markus.mayer@linaro.org> Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2013-11-18Merge branch 'i2c/for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux Pull i2c changes from Wolfram Sang: - new drivers for exynos5, bcm kona, and st micro - bigger overhauls for drivers mxs and rcar - typical driver bugfixes, cleanups, improvements - got rid of the superfluous 'driver' member in i2c_client struct This touches a few drivers in other subsystems. All acked. * 'i2c/for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: (38 commits) i2c: bcm-kona: fix error return code in bcm_kona_i2c_probe() i2c: i2c-eg20t: do not print error message in syslog if no ACK received i2c: bcm-kona: Introduce Broadcom I2C Driver i2c: cbus-gpio: Fix device tree binding i2c: wmt: add missing clk_disable_unprepare() on error i2c: designware: add new ACPI IDs i2c: i801: Add Device IDs for Intel Wildcat Point-LP PCH i2c: exynos5: Remove incorrect clk_disable_unprepare i2c: i2c-st: Add ST I2C controller i2c: exynos5: add High Speed I2C controller driver i2c: rcar: fixup rcar type naming i2c: scmi: remove some bogus NULL checks i2c: sh_mobile & rcar: Enable the driver on all ARM platforms i2c: sh_mobile: Convert to clk_prepare/unprepare i2c: mux: gpio: use reg value for i2c_add_mux_adapter i2c: mux: gpio: use gpio_set_value_cansleep() i2c: Include linux/of.h header i2c: mxs: Fix PIO mode on i.MX23 i2c: mxs: Rework the PIO mode operation i2c: mxs: distinguish i.MX23 and i.MX28 based I2C controller ...
2013-11-18i2c: bcm-kona: fix error return code in bcm_kona_i2c_probe()Wei Yongjun
Fix to return a negative error code from the bus speed parse error handling case instead of 0. Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Reviewed-by: Tim Kryger <tim.kryger@linaro.org> Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2013-11-15i2c: bcm-kona: Introduce Broadcom I2C DriverTim Kryger
Introduce support for Broadcom Serial Controller (BSC) I2C bus found in the Kona family of Mobile SoCs. FIFO hardware is utilized but only standard mode (100kHz), fast mode (400kHz), fast mode plus (1MHz), and I2C high-speed (3.4 MHz) bus speeds are supported. Signed-off-by: Tim Kryger <tim.kryger@linaro.org> Reviewed-by: Matt Porter <matt.porter@linaro.org> Reviewed-by: Markus Mayer <markus.mayer@linaro.org> [wsa: fixed Kconfig sorting, squashed broken out patches into one] Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
