path: root/drivers/i2c/busses/i2c-davinci.c
2009-07-15i2c: Use resource_sizeJulia Lawall
Use the function resource_size, which reduces the chance of introducing off-by-one errors in calculating the resource size. The semantic patch that makes this change is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @@ struct resource *res; @@ - (res->end - res->start) + 1 + resource_size(res) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2009-07-15i2c-davinci: behave with i2cdetectDavid Brownell
Make i2c-davinci cope properly with "i2cdetect": don't spew syslog spam on perfectly normal behaviors, or respond to any address other than the one reserved for the SMBus host. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2009-07-15i2c-davinci: convert clock usage after clkdev conversionKevin Hilman
DaVinci core code has converted to the new clkdev API so clock name strings are not needed. Instead, just the a 'struct device' pointer is needed. Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2009-03-28i2c-davinci: Fix timeout handlingJean Delvare
Properly set the adapter timeout value in jiffies, and then use that value in the driver, rather than a hard-coded constant. Signed-off-by: Jean Delvare <khali@linux-fr.org> Tested-by: Troy Kisky <troy.kisky@boundarydevices.com> Cc: Kevin Hilman <khilman@mvista.com>
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Remove asm/hardware.h, use asm/arch/hardware.h insteadRussell King
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h. Then, since asm/hardware.h only exists to include asm/arch/hardware.h, update everything to directly include asm/arch/hardware.h and remove asm/hardware.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Eliminate useless includes of asm/mach-types.hRussell King
There are 43 includes of asm/mach-types.h by files that don't reference anything from that file. Remove these unnecessary includes. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-14i2c-davinci: Initialize cmd_complete soonerTroy Kisky
If an interrupt happens before an I2c master read/write, complete is called on uninitialized structure. Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com> Signed-off-by: Kevin Hilman <khilman@mvista.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-07-14i2c-davinci: Fix signal handling bugTroy Kisky
If wait_for_completion_interruptible_timeout exits due to a signal, the i2c bus was locking up. Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com> Signed-off-by: Kevin Hilman <khilman@mvista.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-07-14i2c-davinci: Remove useless IVR readTroy Kisky
Interrupts are enabled at the point where the DAVINCI_I2C_IVR_REG is read, so unless an interrupt happened just at that moment, no interrupt would be pending. Even though documentation implies you should do this, I see no reason. If slave support is added, this read would cause a hard to reproduce bug. Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com> Signed-off-by: Kevin Hilman <khilman@mvista.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-07-14i2c-davinci: Move dev_dbg statement for more outputTroy Kisky
Previously the dev_dbg only printed if no error. Printing also on an error is more useful Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com> Signed-off-by: Kevin Hilman <khilman@mvista.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-07-14i2c-davinci: Ensure clock between 7-12 MHzTroy Kisky
Ensure psc value gives a clock between 7-12 MHz Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com> Signed-off-by: Kevin Hilman <khilman@mvista.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-04-22i2c: Fix platform driver hotplug/coldplugKay Sievers
Since 43cc71eed1250755986da4c0f9898f9a635cb3bf, the platform modalias is prefixed with "platform:". Add MODULE_ALIAS() to the hotpluggable I2C platform drivers, to allow module auto loading. [ db: add some more drivers ] Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-04-22i2c: Replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-04-11i2c-davinci: Fix lost interruptTroy Kisky
DAVINCI_I2C_STR_REG is a write 1 to clear register, so don't use a read/modify/write cycle. Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com> Acked-by: Dirk Behme <dirk.behme@gmail.com> Signed-off-by: Kevin Hilman <khilman@mvista.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-01-27i2c: Don't uselessly set i2c_adapter.retriesJean Delvare
I2C adapter drivers are supposed to handle retries on nack by themselves if they do, so there's no point in setting .retries if they don't. As this retry mechanism is going away (at least in its current form), clean this up now so that we don't get build failures later. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2007-12-12i2c: Add missing spaces in split log messagesJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2007-10-13i2c: Add DaVinci I2C controller supportVladimir Barinov
Signed-off-by: Vladimir Barinov <vbarinov@ru.mvista.com> Acked-by: Trilok Soni <soni.trilok@gmail.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
