smatch rightfully says:
drivers/i2c/busses/i2c-imx.c:610 i2c_imx_probe() info: why not propagate 'irq' from platform_get_irq() instead of (-2)?
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
clk_prepare_enable() may fail, so let's check its return value and propagate it
in the case of error.
Subsystems like pinctrl and gpio rightfully make use of deferred probing at
core level. Now, deferred drivers won't be retried if they don't have a .probe
function specified in the driver struct. Fix this driver to have that, so the
devices it supports won't get lost in a deferred probe.
Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
I2C of helpers used to live in of_i2c.c but experience (from SPI) shows
that it is much cleaner to have this in the core. This also removes a
circular dependency between the helpers and the core, and so we can
finally register child nodes in the core instead of doing this manually
in each driver. So, fix the drivers and documentation, too.
Use the wrapper function for retrieving the platform data instead of
accessing dev->platform_data directly.
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
Add Freescale Vybrid VF610 I2C controller support to
imx I2C driver framework.
Signed-off-by: Jason Jin <Jason.jin@freescale.com>
Signed-off-by: Jingchang Lu <b35083@freescale.com>
Reviewed-by: Sascha Hauer <s.hauer@pengutronix.de>
This add struct imx_i2c_hwdata to hold more quirks data
which may vary between SoCs, thus the driver can operate
on more differences to support more SoCs.
This add bits operation macro that differ between SoCs.
Interrupt flags clear operation in I2SR differ between SoCs:
write zero to clear(w0c) INT flag on i.MX,
but write one to clear(w1c) INT flag on Vybrid.
I2C module enable operation in I2CR also differ between SoCs:
set I2CR_IEN bit enable the module on i.MX,
but clear I2CR_IEN bit enable the module on Vybrid.
the I2C register offset may different between SoCs,
to provid support for all these chips, split the
register offset into a fixed base address and a
variable shift value, then the full register offset
will be calculated by
reg_off = ( reg_base_addr << reg_shift)
wrap the readb(), writeb() into inline function calls.
It would make the driver more clearer to support platform
with different register offset.
The id_entry field should be changed by platform driver core,
driver should prevent changing it derectly. Use local variable
to save and extract platform_device_id info of the dts devices
instead.
The module clk should be enabled before write to
its register in probe(), and the clk can be disabled
after.
using struct representing the i2c clk{div, val} pair would
make the i2c_clk_div array more clear.
Allow udev to autoload the module when booting with device-tree
Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org>
devm_ioremap_resource does sanity checks on the given resource. No need to
duplicate this in the driver.
Since commit ab78029 (drivers/pinctrl: grab default handles from device core),
we can rely on device core for handling pinctrl.
So remove devm_pinctrl_get_select_default() from the driver.
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux
Pull i2c updates from Wolfram Sang:
"Highlights:
- new drivers for Intel ismt & Broadcom bcm2835
- a number of drivers got support for more variants and mostly got
cleaned up on the way (sis630, i801, at91, tegra, designware)
- i2c got rid of all *_set_drvdata(..., NULL) on remove/probe failure
- removed the i2c_smbus_process_call from the core since there are no
users
- mxs can now switch between PIO and DMA depending on the message
size and the bus speed can now be arbitrary
In addition, there is the usual bunch of fixes, cleanups, devm_*
conversions, etc"
Fixed conflict (and buggy devm_* conversion) in i2c-s3c2410.c
* 'i2c/for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: (39 commits)
i2c: Remove unneeded xxx_set_drvdata(..., NULL) calls
i2c: pxa: remove incorrect __exit annotations
i2c: ocores: Fix pointer to integer cast warning
i2c: tegra: remove warning dump if timeout happen in transfer
i2c: fix i2c-ismt.c printk format warning
i2c: i801: Add Device IDs for Intel Wellsburg PCH
i2c: add bcm2835 driver
i2c: ismt: Add Seth and Myself as maintainers
i2c: sis630: checkpatch cleanup
i2c: sis630: display unsigned hex
i2c: sis630: use hex to constants for SMBus commands
i2c: sis630: fix behavior after collision
i2c: sis630: clear sticky bits
i2c: sis630: Add SIS964 support
i2c: isch: Add module parameter for backbone clock rate if divider is unset
i2c: at91: fix unsed variable warning when building with !CONFIG_OF
i2c: Adding support for Intel iSMT SMBus 2.0 host controller
i2c: sh_mobile: don't send a stop condition by default inside transfers
i2c: sh_mobile: eliminate an open-coded "goto" loop
i2c: sh_mobile: fix timeout error handling
There is simply no reason to be manually setting the private driver
data to NULL in the remove/fail to probe cases. This is just extra
cruft code that can be removed.
A few notes:
* Nothing relies on drvdata being set to NULL.
* The __device_release_driver() function eventually calls
dev_set_drvdata(dev, NULL) anyway, so there's no need to do it
twice.
* I verified that there were no cases where xxx_get_drvdata() was
being called in these drivers and checking for / relying on the NULL
return value.
This could be cleaned up kernel-wide but for now just take the baby
step and remove from the i2c subsystem.
Reported-by: Wolfram Sang <wsa@the-dreams.de>
Reported-by: Stephen Warren <swarren@wwwdotorg.org>
Signed-off-by: Doug Anderson <dianders@chromium.org>
Reviewed-by: Jean Delvare <khali@linux-fr.org>
Acked-by: Peter Korsgaard <jacmet@sunsite.dk>
Reviewed-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Signed-off-by: Wolfram Sang <wolfram@the-dreams.de>
Convert all uses of devm_request_and_ioremap() to the newly introduced
devm_ioremap_resource() which provides more consistent error handling.
devm_ioremap_resource() provides its own error messages so all explicit
error messages can be removed from the failure code paths.
Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de>
Cc: Ben Dooks <ben-linux@fluff.org>
This is some amount of work left/forgot from device tree conversion.
Instead of checking cpu_is_xxx to determine the controller type, the
driver should use platform_device_id, which should match the device
tree compatible string.
The patch changes the driver to use platform_device_id rather than
cpu_is_xxx to determine the controller type/version. It also updates
the platform code and device tree source accordingly.
As the result, mach/hardware.h inclusion gets removed from the driver.
Acked-by: Sascha Hauer <s.hauer@pengutronix.de>
Cc: Wolfram Sang <w.sang@pengutronix.de>
Cc: linux-i2c@vger.kernel.org
Pull i2c-embedded changes from Wolfram Sang:
"The changes for i2c-embedded include:
- massive rework of the omap driver
- massive rework of the at91 driver. In fact, the old driver gets
removed; I am okay with this approach since the old driver was
depending on BROKEN and its limitations made it practically
unusable, so people used bitbanging instead. But even if there are
users, there is no platform_data or module parameter which would
need to be converted. It is just another driver doing I2C
transfers, just way better. Modifications of arch/arm/at91 related
files have proper acks from the maintainer.
- new driver for R-Car I2C
- devicetree and generic_clock conversions and fixes
- usual driver fixes and changes.
The rework patches have come a long way and lots of people have been
involved in creating/testing them. Most patches have been in
linux-next at least since 3.6-rc5. A few have been added in the last
week, I have to admit.
An unexpected (but welcome :)) peak in private life is the cause for
that. The "late" patches shouldn't cause any merge conflicts and I
will have a special eye on them during the stabilization phase. This
is an exception and I want to have the patches in place properly in
time again for the next kernels."
* 'i2c-embedded/for-next' of git://git.pengutronix.de/git/wsa/linux: (44 commits)
MXS: Implement DMA support into mxs-i2c
i2c: add Renesas R-Car I2C driver
i2c: s3c2410: use clk_prepare_enable and clk_disable_unprepare
ARM: OMAP: convert I2C driver to PM QoS for MPU latency constraints
i2c: nomadik: Add Device Tree support to the Nomadik I2C driver
i2c: algo: pca: Fix chip reset function for PCA9665
i2c: mpc: Wait for STOP to hit the bus
i2c: davinci: preparation for switch to common clock framework
omap-i2c: fix incorrect log message when using a device tree
i2c: omap: sanitize exit path
i2c: omap: switch over to autosuspend API
i2c: omap: remove unnecessary pm_runtime_suspended check
i2c: omap: switch to threaded IRQ support
i2c: omap: remove redundant status read
i2c: omap: get rid of the "complete" label
i2c: omap: resize fifos before each message
i2c: omap: simplify IRQ exit path
i2c: omap: always return IRQ_HANDLED
i2c: omap: simplify errata check
i2c: omap: bus: add a receiver flag
Platform data for device drivers should be defined in
include/linux/platform_data/*.h, not in the architecture
and platform specific directories.
This moves such data out of the imx include directories
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Acked-by: Nicolas Pitre <nico@linaro.org>
Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com>
Acked-by: Sascha Hauer <kernel@pengutronix.de>
Acked-by: Vinod Koul <vinod.koul@linux.intel.com>
Cc: Dan Williams <djbw@fb.com>
Cc: "Ben Dooks (embedded platforms)" <ben-linux@fluff.org>
Cc: "Wolfram Sang (embedded platforms)" <w.sang@pengutronix.de>
Cc: Chris Ball <cjb@laptop.org>
Cc: Grant Likely <grant.likely@secretlab.ca>
Cc: Alan Cox <alan@linux.intel.com>
Cc: Felipe Balbi <balbi@ti.com>
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
Cc: Liam Girdwood <lrg@ti.com>
Cc: Javier Martin <javier.martin@vista-silicon.com>
Cc: Shawn Guo <shawn.guo@linaro.org>
Cc: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Use dev_dbg logging style as it is done in other parts of this driver.
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
It is useful information in dmesg to have a message indicating that the i2c
driver was succesfully registered, so promote it to dev_info.
Pull embedded i2c changes from Wolfram Sang:
"Changes for the "embedded" part of the I2C subsystem:
- lots of devicetree conversions of drivers (and preparations for
that)
- big cleanups for drivers for OMAP, Tegra, Nomadik, Blackfin
- Rafael's struct dev_pm_ops conversion patches for I2C
- usual driver cleanups and fixes
All patches have been in linux-next for an apropriate time and all
patches touching files outside of i2c-folders should have proper acks
from the maintainers."
* 'i2c-embedded/for-next' of git://git.pengutronix.de/git/wsa/linux: (60 commits)
Revert "i2c: tegra: convert normal suspend/resume to *_noirq"
I2C: MV64XYZ: Add Device Tree support
i2c: stu300: use devm managed resources
i2c: i2c-ocores: support for 16bit and 32bit IO
V4L/DVB: mfd: use reg_shift instead of regstep
i2c: i2c-ocores: Use reg-shift property
i2c: i2c-ocores: DT bindings and minor fixes.
i2c: mv64xxxx: remove EXPERIMENTAL tag
i2c-s3c2410: Use plain pm_runtime_put()
i2c: s3c2410: Fix pointer type passed to of_match_node()
i2c: mxs: Set I2C timing registers for mxs-i2c
i2c: i2c-bfin-twi: Move blackfin TWI register access Macro to head file.
i2c: i2c-bfin-twi: Move TWI peripheral pin request array to platform data.
i2c:i2c-bfin-twi: include twi head file
i2c:i2c-bfin-twi: TWI fails to restart next transfer in high system load.
i2c: i2c-bfin-twi: Tighten condition when failing I2C transfer if MEN bit is reset unexpectedly.
i2c: i2c-bfin-twi: Break dead waiting loop if i2c device misbehaves.
i2c: i2c-bfin-twi: Improve the patch for bug "Illegal i2c bus lock upon certain transfer scenarios".
i2c: i2c-bfin-twi: Illegal i2c bus lock upon certain transfer scenarios.
i2c-mv64xxxx: allow more than one driver instance
drivers/i2c/busses/i2c-nomadik.c
sparse found this assignment of u32 to an int. Fix it:
drivers/i2c/busses/i2c-imx.c:540:56: warning: incorrect type in argument 3 (different signedness)
and also fix the type in platform_data. All current users use values
which fit into the old and new type, so it is a safe change.
Reviewed-by: Richard Zhao <richard.zhao@freescale.com>
With the new i.mx clock framework the i2c clock is registered as:
clk_register_clkdev(clk[i2c1_ipg_gate], NULL, "imx-i2c.0")
So we do not need to pass "i2c_clk" string and can use NULL instead.
[wsa: rebased on top of the devm-conversion]
- convert to use devm_request_and_ioremap, devm_kzalloc, devm_clk_get,
devm_request_irq.
- clean up unused variables.
Signed-off-by: Richard Zhao <richard.zhao@freescale.com>
Reviewed-by: Shubhrajyoti D <Shubhrajyoti@ti.com>
Remove unneeded mach/irq.h inclusion from i2c-imx driver.
Acked-by: Dong Aisheng <dong.aisheng@linaro.org>
"Major changes:
- lots of devicetree additions for existing drivers. I tried hard to
make sure the bindings are proper. In more complicated cases, I
requested acks from people having more experience with them than
me. That took a bit of extra time and also some time went into
discussions with developers about what bindings are and what not.
I have the feeling that the workflow with bindings should be
improved to scale better. I will spend some more thought on
this...
- i2c-muxes are succesfully used meanwhile, so we dropped
EXPERIMENTAL for them and renamed the drivers to a standard pattern
to match the rest of the subsystem. They can also be used with
devicetree now.
- ixp2000 was removed since the whole platform goes away.
- cleanups (strlcpy instead of strcpy, NULL instead of 0)
- The rest is typical driver fixes I assume.
All patches have been in linux-next at least since v3.4-rc6."
Fixed up trivial conflict in arch/arm/mach-lpc32xx/common.c due to the
same patch already having come in through the arm/soc trees, with
additional patches on top of it.
* 'i2c-embedded/for-next' of git://git.pengutronix.de/git/wsa/linux: (35 commits)
i2c: davinci: Free requested IRQ in remove
i2c: ocores: register OF i2c devices
i2c: tegra: notify transfer-complete after clearing status.
I2C: xiic: Add OF binding support
i2c: Rename last mux driver to standard pattern
i2c: tegra: fix 10bit address configuration
i2c: muxes: rename first set of drivers to a standard pattern
of/i2c: implement of_find_i2c_adapter_by_node
i2c: implement i2c_verify_adapter
i2c-s3c2410: Add HDMIPHY quirk for S3C2440
i2c-s3c2410: Rework device type handling
i2c: muxes are not EXPERIMENTAL anymore
i2c/of: Automatically populate i2c mux busses from device tree data.
i2c: Add a struct device * parameter to i2c_add_mux_adapter()
of/i2c: call i2c_verify_client from of_find_i2c_device_by_node
i2c: designware: Add clk_{un}prepare() support
i2c: designware: add PM support
i2c: ixp2000: remove driver
i2c: pnx: add device tree support
i2c: imx: don't use strcpy but strlcpy
Pull "ARM: driver specific updates" from Arnd Bergmann:
"These are all specific to some driver. They are typically the
platform side of a change in the drivers directory, such as adding a
new driver or extending the interface to the platform. In cases where
there is no maintainer for the driver, or the maintainer prefers to
have the platform changes in the same branch as the driver changes,
the patches to the drivers are included as well.
A much smaller set of driver updates that depend on other branches
getting merged first will be sent later.
The new export of tegra_chip_uid conflicts with other changes in
fuse.c. In rtc-sa1100.c, the global removal of IRQF_DISABLED
conflicts with the cleanup of the interrupt handling of that driver.
Signed-off-by: Arnd Bergmann <arnd@arndb.de>"
Fixed up aforementioned trivial conflicts.
* tag 'drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (94 commits)
ARM: SAMSUNG: change the name from s3c-sdhci to exynos4-sdhci
mmc: sdhci-s3c: add platform data for the second capability
ARM: SAMSUNG: support the second capability for samsung-soc
ARM: EXYNOS: add support DMA for EXYNOS4X12 SoC
ARM: EXYNOS: Add apb_pclk clkdev entry for mdma1
ARM: EXYNOS: Enable MDMA driver
regulator: Remove bq24022 regulator driver
rtc: sa1100: add OF support
pxa: magician/hx4700: Convert to gpio-regulator from bq24022
ARM: OMAP3+: SmartReflex: fix error handling
ARM: OMAP3+: SmartReflex: fix the use of debugfs_create_* API
ARM: OMAP3+: SmartReflex: micro-optimization for sanity check
ARM: OMAP3+: SmartReflex: misc cleanups
ARM: OMAP3+: SmartReflex: move late_initcall() closer to its argument
ARM: OMAP3+: SmartReflex: add missing platform_set_drvdata()
ARM: OMAP3+: hwmod: add SmartReflex IRQs
ARM: OMAP3+: SmartReflex: clear ERRCONFIG_VPBOUNDINTST only on a need
ARM: OMAP3+: SmartReflex: Fix status masking in ERRCONFIG register
ARM: OMAP3+: SmartReflex: Add a shutdown hook
ARM: OMAP3+: SmartReflex Class3: disable errorgen before disable VP
arch/arm/mach-tegra/Makefile
arch/arm/mach-tegra/fuse.c
drivers/rtc/rtc-sa1100.c
Interrupt a test application for I2C based mc13xxx driven
touch panel, SIGINT, causes open event file descriptor to be
closed, which in turn causes I2C activity to mask PMIC local
interrupts. This eventually ends up in i2c_imx_bus_busy to
wait for some busy flag to toggle, but while waiting it would
find a signal pending and break. The final symptom is the
device is not closed down cleanly and thus not reopenable.
Do without check for pending signal.
Signed-off-by: Oskar Schirmer <oskar@scara.com>
Acked-by: Marc Kleine-Budde <mkl@pengutronix.de>
It's for migrating to generic clk framework API.
Signed-off-by: Richard Zhao <richard.zhao@linaro.org>
It adds device tree probe support for i2c-imx driver.
Cc: Darius Augulis <augulis.darius@gmail.com>
Signed-off-by: Ben Dooks <ben-linux@fluff.org>
The init/exit hooks in platform data are being used nowhere, so can
be removed.
The i2c_imx_trx_complete() function is using
wait_event_interruptible_timeout() to wait for the I2C controller to
signal that it has completed an I2C bus operation. If the process that
causes the I2C operation receives a signal, the wait will be
interrupted, returning an error. It is better to let the I2C operation
finished before handling the signal (i.e. returning into userspace).
It is safe to use wait_event_timeout() instead, because the timeout
will allow the process to exit if the I2C bus hangs. It's also better
to allow the I2C operation to finish, because unacknowledged I2C
operations can cause the I2C bus to hang.
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
Reviewed-by: Wolfram Sang <w.sang@pengutronix.de>
- Return -ETIMEDOUT on bus busy error
- Fix timeout test "time_after(jiffies, orig_jiffies + HZ / 1000)" :
By default, HZ=100 on arm. This means that this test has no chances to
work and may result in a dead loop. Set timeout to 500ms.
- Don't try to send a new message if we failed to transmit
previous one. This was preventing to recover from error on my system
Signed-off-by: Arnaud Patard <apatard@mandriva.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Having a pointer to the probe function is unnecessary when using
platform_driver_probe and yields a section mismatch warning after
removing the white list entry "*driver" for
{ .data$, .data.rel$ } -> { .init.* } mismatches in modpost.
accordingly adapt order of release_mem_region and release_mem_region on
remove.
Cc: Richard Zhao <linuxzsc@gmail.com>
Cc: Sascha Hauer <s.hauer@pengutronix.de>
After generating the stop bit by changing MSTA from 1 to 0,
the i2c_imx->stopped was immediatly set to 1. The second test
on i2c_imx->stopped then is correct and the controller never
waits if the bus is busy. This patch corrects this.
On mx31moboard, stop bit was not generated on single write transfers.
This was kept unnoticed as other transfers are made afterwards that
help the write recipient to resynchronize.
Thanks to Philippe and Michael for the debugging.
Signed-off-by: Valentin Longchamp <valentin.longchamp@epfl.ch>
Signed-off by: Philippe Rétornaz <philippe.retornaz@epfl.ch>
Reported-by: Michael Bonani <michael.bonani@epfl.ch>
Acked-by; Wolfram Sang <w.sang@pengutronix.de>
Enable clock before START, disable it after STOP.
Signed-off-by: Richard Zhao <linuxzsc@gmail.com>
check cpu_is_mx1() when disable delay.
The controller can't do anything else before it actually generates START/STOP.
So we check busy bit to make sure START/STOP is successfully finished.
If we don't check busy bit, START/STOP may fail on some fast CPUs.
As I2C is used by PMICs also, make the busses available early via
subsys_initcall().
'disable_delay' was static which is wrong as it is calculated using the per-device
bus speed. This patch turns 'disable_delay' into a per-device variable.
Reported-by: Sascha Hauer <s.hauer@pengutronix.de>
Acked-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Acked-by: Darius Augulis <augulis.darius@gmail.com>
Signed-off-by: Darius Augulis <augulis.darius@gmail.com>
[ben-linux@fluff.org: fix minor patch fault in remove]
Implementation of I2C Adapter/Algorithm Driver for I2C Bus integrated
in Freescale's i.MX/MXC processors.
Tested-by: Sascha Hauer <s.hauer@pengutronix.de>
