path: root/drivers/i2c/busses/i2c-nforce2.c
2014-11-07i2c: remove FSF addressWolfram Sang
We have a central copy of the GPL for that. Some addresses were already outdated. Signed-off-by: Wolfram Sang <wsa+renesas@sang-engineering.com>
2014-03-13i2c: remove DEFINE_PCI_DEVICE_TABLE macroJingoo Han
Don't use DEFINE_PCI_DEVICE_TABLE macro, because this macro is not preferred. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2014-01-24i2c: delete non-required instances of include <linux/init.h>Paul Gortmaker
None of these files are actually using any __init type directives and hence don't need to include <linux/init.h>. Most are just a left over from __devinit and __cpuinit removal, or simply due to code getting copied from one driver to the next. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2013-01-28i2c: nforce2: fix coding style issuesLaurent Navet
avoid these checkpatch.pl issues : - ERROR: "foo * bar" should be "foo *bar" - ERROR: switch and case should be at the same indent - ERROR: "(foo*)" should be "(foo *)" - ERROR: do not use assignment in if condition - ERROR: space required before the open parenthesis '(' - WARNING: suspect code indent for conditional statements - WARNING: quoted string split across lines - WARNING: space prohibited between function name and open parenthesis '(' - WARNING: line over 80 characters also add spaces around some "+", "=", "*" Signed-off-by: Laurent Navet <laurent.navet@gmail.com> Reviewed-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
2012-12-22i2c: remove __dev* attributes from subsystemBill Pemberton
CONFIG_HOTPLUG is going away as an option. As result the __dev* markings will be going away. Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Acked-by: Peter Korsgaard <peter.korsgaard@barco.com> (for ocores and mux-gpio) Acked-by: Havard Skinnemoen <hskinnemoen@gmail.com> (for i2c-gpio) Acked-by: Guan Xuetao <gxt@mprc.pku.edu.cn> (for puf3) Acked-by: Barry Song <baohua.song@csr.com> (for sirf) Reviewed-by: Jean Delvare <khali@linux-fr.org> [wsa: Fixed "foo* bar" flaws while we are here] Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
2012-07-24i2c/busses: Use module_pci_driverAxel Lin
Convert the drivers in drivers/i2c/busses/* to usemodule_pci_driver() macro which makes the code smaller and a bit simpler. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Rudolf Marek <r.marek@assembler.cz> Cc: Olof Johansson <olof@lixom.net> Cc: "Mark M. Hoffman" <mhoffman@lightlink.com> Cc: Tomoya MORINAGA <tomoya.rohm@gmail.com>
2012-01-12i2c: Convert to DEFINE_PCI_DEVICE_TABLEAxel Lin
Convert static struct pci_device_id *[] to static DEFINE_PCI_DEVICE_TABLE tables. Use DEFINE_PCI_DEVICE_TABLE ensures we make the pci_device_id table const and marked as __devinitconst. This also fixes some warnings from checkpatch: e.g. WARNING: Use DEFINE_PCI_DEVICE_TABLE for struct pci_device_id #1096: FILE: i2c/busses/i2c-intel-mid.c:1096: +static struct pci_device_id intel_mid_i2c_ids[] = { Signed-off-by: Axel Lin <axel.lin@gmail.com> Cc: Rudolf Marek <r.marek@assembler.cz> Cc: Ben Dooks <ben-linux@fluff.org> Acked-by: Olof Johansson <olof@lixom.net> Cc: "Mark M. Hoffman" <mhoffman@lightlink.com> Acked-by: Dirk Brandewie <dirk.brandewie@gmail.com> Cc: Tomoya MORINAGA <tomoya-linux@dsn.lapis-semi.com> Acked-by: Wolfram Sang <w.sang@pengutronix.de> Cc: Feng Tang <feng.tang@intel.com> Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2012-01-12i2c: Fix error value returned by several bus driversJean Delvare
When adding checks for ACPI resource conflicts to many bus drivers, not enough attention was paid to the error paths, and for several drivers this causes 0 to be returned on error in some cases. Fix this by properly returning a non-zero value on every error. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: stable@kernel.org
2011-01-10i2c-nforce2: Remove unnecessary cast of pci_get_drvdataJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-05-21i2c-nforce2: Remove redundant error messages on ACPI conflictChase Douglas
The ACPI subsystem strictly checks for resource conflicts. When there's a conflict, it outputs a warning message with all the details needed to properly diagnose the underlying issue. However, the i2c-nforce2 driver also prints its own message. Not only is the message redundant, it is at the KERN_ERR level, which overrides some bootsplash screens for no good reason. This change removes the two lines that print out the error messages. Signed-off-by: Chase Douglas <chase.douglas@canonical.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-05-21i2c: Use <linux/io.h> instead of <asm/io.h>H Hartley Sweeten
As warned by checkpatch.pl, <linux/io.h> should be used instead of <asm/io.h>. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-02i2c: Make PCI device ids constantMárton Németh
The id_table field of the struct pci_driver is constant in <linux/pci.h> so it is worth to make initialization data also constant. The semantic match that finds this kind of pattern is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r@ disable decl_init,const_decl_init; identifier I1, I2, x; @@ struct I1 { ... const struct I2 *x; ... }; @s@ identifier r.I1, y; identifier r.x, E; @@ struct I1 y = { .x = E, }; @c@ identifier r.I2; identifier s.E; @@ const struct I2 E[] = ... ; @depends on !c@ identifier r.I2; identifier s.E; @@ + const struct I2 E[] = ...; // </smpl> Signed-off-by: Márton Németh <nm127@freemail.hu> Cc: Julia Lawall <julia@diku.dk> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2009-05-05i2c: Timeouts off by 1Roel Kluin
with while (timeout++ < MAX_TIMEOUT); timeout reaches MAX_TIMEOUT + 1 after the loop, so the tests below are off by one. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2009-03-28i2c-nforce2: Add support for MCP67, MCP73, MCP78S and MCP79Jean Delvare
The MCP78S and MCP79 appear to be compatible with the previous nForce chips as far as the SMBus controller is concerned. The MCP67 and MCP73 were not tested yet but I'd be very surprised if they weren't compatible too. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Oleg Ryjkov <olegr@olegr.ca> Cc: Malcolm Lalkaka <mlalkaka@gmail.com> Cc: Zbigniew Luszpinski <zbiggy@o2.pl>
2009-01-26i2c: Delete many unused adapter IDsJean Delvare
2008-07-14i2c: Check for ACPI resource conflictsJean Delvare
Check for ACPI resource conflicts in i2c bus drivers. I've included all recent SMBus master drivers for PC hardware. I've voluntarily left out: * Drivers that don't run on PCs: they can't conflict with ACPI. * Bit-banged bus device drivers: it's very unlikely that ACPI would deal with such buses. Signed-off-by: Jean Delvare <jdelvare@suse.de>
2008-07-14i2c: Let bus drivers add SPD to their classJean Delvare
Let general purpose I2C/SMBus bus drivers add SPD to their class. Once this is done, we will be able to tell the eeprom driver to only probe for SPD EEPROMs and similar on these buses. Note that I took a conservative approach here, adding I2C_CLASS_SPD to many drivers that have no idea whether they can host SPD EEPROMs or not. This is to make sure that the eeprom driver doesn't stop probing buses where SPD EEPROMs or equivalent live. So, bus driver maintainers and users should feel free to remove the SPD class from drivers those buses never have SPD EEPROMs or they don't want the eeprom driver to bind to them. Likewise, feel free to add the SPD class to any bus driver I might have missed. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-07-14i2c: Bus drivers return -Errno not -1David Brownell
Tighten error paths used by various i2c adapters (mostly x86) so they return real fault/errno codes instead of a "-1" (which is most often interpreted as "-EPERM"). Build tested, with eyeball review. One minor initial goal is to have adapters consistently return the code "-ENXIO" when addressing a device doesn't get an ACK response, at least in the probe paths where they are already good at stifling related logspam. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-07-14i2c-nforce2: Add support for multiplexing on the Tyan S4985Jean Delvare
Just like the Tyan S4882, the S4985 uses a multiplexer to give access to all 16 memory module SPD EEPROMs. This specific i2c-nforce2-s4985 driver adds support for this. It is heavily based on the older i2c-amd756-s4882 driver. As more mainboards will use multiplexer chips, we will have to find a way to support them without having to write a new specfic driver for each. The recent changes to the i2c subsystem should help us, and the new gpio subsystem might help, too. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-05-18i2c-nforce2: Disable the second SMBus channel on the DFI Lanparty NF4 ExpertJean Delvare
There is a strange chip at 0x2e on the second SMBus channel of the DFI Lanparty NF4 Expert motherboard. Accessing the chip reboots the system. As there's nothing interesting on this SMBus channel, the easiest and safest thing to do is to disable it on that board. This is a better fix to bug #5889 than the it87 driver update that was done originally: http://bugzilla.kernel.org/show_bug.cgi?id=5889 Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-01-27i2c-nforce2: The nForce2 can do block transactionsJean Delvare
My guess is that all the chips supported by this driver support block transactions and reset, but for now we play it safe and only list the ones for which this was actually tested. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Oleg Ryjkov <olegr@olegr.ca>
2007-10-13i2c-nforce2: Declare PEC as supportedJean Delvare
The i2c-nforce2 driver has SMBus PEC support, so it should say so. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2007-10-13i2c-nforce2: Abort the transaction on errorOleg Ryjkov
This patch is to add an abort function that will bring back the MCP51/55 controller if it was blocked by a block-read operation, in particular. (When a slave sends a wrong byte count on a byte read, the host gets locked up). I've only tested it on an MCP51 and MCP55. However, I'm almost certain it will also work on MCP65, I just did not have the board to test it on. Thus for now the abort function will only be called if an MCP51/55 was detected. Signed-off-by: Oleg Ryjkov <olegr@olegr.ca> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2007-10-13i2c-nforce2: Move status checking to a separate functionOleg Ryjkov
This is the first part of the patch that adds a function to reset the nvidia MCP51/55 i2c controller, if something bad happens to it (e.g. a slave sends a wrong byte count during a block transaction). This patch just adds nforce2_check_status function. It was originally written by Hans-Frieder Vogt. The reason that I'm the one sending it is: - I relied on it for the second part of the patch, - It makes the driver code cleaner/better. Signed-off-by: Oleg Ryjkov <olegr@olegr.ca> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2007-07-12i2c-nforce2: Add support for SMBus block transactionsOleg Ryjkov
Add support for SMBus block read/write transactions to i2c-nforce2 driver, in particular to host controllers MCP51 and MCP55. Signed-off-by: Oleg Ryjkov <olegr@google.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2007-05-01i2c-nforce2: Add support for the MCP61 and MCP65Jean Delvare
Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Hans-Frieder Vogt <hfvogt@gmx.net>
2007-05-01i2c: Shrink struct i2c_clientDavid Brownell
This shrinks the size of "struct i2c_client" by 40 bytes: - Substantially shrinks the string used to identify the chip type - The "flags" don't need to be so big - Removes some internal padding It also adds kerneldoc for that struct, explaining how "name" is really a chip type identifier; it's otherwise potentially confusing. Because the I2C_NAME_SIZE symbol was abused for both i2c_client.name and for i2c_adapter.name, this needed to affect i2c_adapter too. The adapters which used that symbol now use the more-obviously-correct idiom of taking the size of that field. JD: Shorten i2c_adapter.name from 50 to 48 bytes while we're here, to avoid wasting space in padding. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2007-02-13i2c: Add IDs to adaptersStephen Hemminger
IDs have been defined but not used by most of the I2C adapters. By having a unique ID, clients can check for correct connection during probe. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2007-02-13i2c-nforce2: Drop unused reference to pci_devJean Delvare
2006-12-10i2c: Cleanups to the i2c-nforce2 bus driverHans-Frieder Vogt
Summary of changes: - fixes: o legacy I/O region size is 64 bytes, not 8 bytes - general cleanup: o removed code for the unsupported I2C block data, block data, proc call and block proc call transfer modes o removed detail warnings about unsupported modes that are covered in a general warning (unsupported transaction...) anyway o removed necessity of a definition of struct i2c_adapter o moved definition of struct i2c_algorithm, making forward declarations of nforce2_access and nforce2_func unnecessary - minor changes: o in the description mention the nForce 5xx chipsets o changes my e-mail address in MODULE_AUTHOR Theses cleanups shrink the driver binary size from 4.0 kB to 2.7 kB on i386. Signed-off-by: Hans-Frieder Vogt <hfvogt@gmx.net> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2006-09-26i2c: Constify i2c_algorithm declarations, part 2Jean Delvare
i2c: Constify i2c_algorithm declarations, part 2 Make struct i2c_algorithm declarations const in all i2c bus drivers where it is possible. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-22[PATCH] I2C: i2c-nforce2: Add support for the nForce4 MCP51 and MCP55Jean Delvare
Add support for the new nForce4 MCP51 (also known as nForce 410 or 430) and nForce4 MCP55 to the i2c-nforce2 driver. Some code changes were required because the base I/O address registers have changed in these versions. Standard BARs are now being used, while the original nForce2 chips used non-standard ones. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-05[PATCH] i2c: i2c-nforce2 add nforce4 MCP-04 device IDJean Delvare
One more supported PCI ID for the i2c-nforce2 driver. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-11-10[PATCH] PCI: removed unneeded .owner field from struct pci_driverGreg Kroah-Hartman
2005-10-28[PATCH] i2c: SMBus PEC support rewrite, 3 of 3Jean Delvare
The new SMBus PEC implementation doesn't support PEC emulation on non-PEC non-I2C SMBus masters, so we can drop all related code. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] i2c: kzalloc cleanups, 1 of 2Jean Delvare
Drop useless casts on kzalloc returned values, as suggested by Jiri Slaby. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] i2c: kzalloc conversion, other driversDeepak Saxena
Use kzalloc instead of kmalloc+memset in all remaining i2c bus and chip drivers. Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] Owner field additions to many i2c drivers, 1 of 5Laurent Riffard
This patch updates .owner field for various struct pci_driver variables. Signed-off-by: Laurent Riffard <laurent.riffard@free.fr> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] i2c: Reuse name strings in i2c bus driversJean Delvare
Clean up name string usage in 12 i2c bus drivers: * Use the i2c_adapter name for requesting the I/O region rather than redefining a new string. * Do not initialize the i2c_adapter name to "unset". This should save a few data bytes here and there. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> drivers/i2c/busses/i2c-ali1535.c | 6 +++--- drivers/i2c/busses/i2c-ali1563.c | 6 ++++-- drivers/i2c/busses/i2c-ali15x3.c | 5 +++-- drivers/i2c/busses/i2c-amd756.c | 5 ++--- drivers/i2c/busses/i2c-amd8111.c | 4 +++- drivers/i2c/busses/i2c-i801.c | 4 ++-- drivers/i2c/busses/i2c-nforce2.c | 4 ++-- drivers/i2c/busses/i2c-piix4.c | 4 ++-- drivers/i2c/busses/i2c-sis5595.c | 5 +++-- drivers/i2c/busses/i2c-sis630.c | 6 ++++-- drivers/i2c/busses/i2c-sis96x.c | 5 +++-- drivers/i2c/busses/i2c-via.c | 4 ++-- 12 files changed, 33 insertions(+), 25 deletions(-)
2005-09-09[PATCH] I2C: i2c-nforce2: drop unused defineJean Delvare
One more cleanup in i2c-nforce2. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-05[PATCH] I2C: Kill i2c_algorithm.id (4/7)Jean Delvare
There are no more users of i2c_algorithm.id, so we can finally drop this structure member. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-05[PATCH] I2C: Kill i2c_algorithm.name (1/7)Jean Delvare
The name member of the i2c_algorithm is never used, although all drivers conscientiously fill it. We can drop it completely, this structure doesn't need to have a name. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-05[PATCH] I2C: cleanup of i2c-nforce2Hans-Frieder Vogt
attached is a small patch that removes unused code from i2c-nforce2 and adds a single debug message. The patch is against 2.6.13-rc3-mm1. I have tested the patch with 2.6.13-rc3: compiles cleanly and works as without the patch (as expected). Signed-off-by: Hans-Frieder Vogt <hfvogt@arcor.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-21[PATCH] I2C: drivers/i2c/*: #include <linux/config.h> cleanupAlexey Dobriyan
Files that don't use CONFIG_* stuff shouldn't include config.h Files that use CONFIG_* stuff should include config.h It's that simple. ;-) Signed-off-by: Alexey Dobriyan <adobriyan@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
