This reverts commit 70121f7f3725 ("i2c: octeon: thunderx: Limit register access retries").
Using readq_poll_timeout instead of __raw_readq triggers the following
debug warning:
[ 78.871568] ipmi_ssif: Trying hotmod-specified SSIF interface at i2c address 0x12, adapter Cavium ThunderX i2c adapter at 0000:01:09.4, slave address 0x0
[ 78.886107] do not call blocking ops when !TASK_RUNNING; state=2 set at [<fffffc00080e0088>] prepare_to_wait_event+0x58/0x10c
[ 78.897436] ------------[ cut here ]------------
[ 78.902050] WARNING: CPU: 6 PID: 2235 at kernel/sched/core.c:7718 __might_sleep+0x80/0x88
[ 79.133553] [<fffffc00080c3aac>] __might_sleep+0x80/0x88
[ 79.138862] [<fffffc0000e30138>] octeon_i2c_test_iflg+0x4c/0xbc [i2c_thunderx]
[ 79.146077] [<fffffc0000e30958>] octeon_i2c_test_ready+0x18/0x70 [i2c_thunderx]
[ 79.153379] [<fffffc0000e30b04>] octeon_i2c_wait+0x154/0x1a4 [i2c_thunderx]
[ 79.160334] [<fffffc0000e310bc>] octeon_i2c_xfer+0xf4/0xf60 [i2c_thunderx]
Signed-off-by: Jan Glauber <jglauber@cavium.com>
Acked-by: Steven J. Hill <steven.hill@cavium.com>
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
Do not infinitely retry register readq and writeq operations
in order to not lock up the CPU in case the TWSI gets stuck.
Return -ETIMEDOUT in case of a failed data read. For all other
cases just return so subsequent operations will fail.
The register offsets are different between Octeon and ThunderX so move
them into the algorithm struct and get rid of the define.
Add SMBUS alert interrupt support. For now only device tree is
supported for specifying the alert. In case of ACPI an error
is returned.
The ThunderX SOC uses the same i2c block as the Octeon SOC.
The main difference is that on ThunderX the device is a PCI device
so device probing is done via PCI, interrupts are MSI-X. The
clock rates can be set via device tree or ACPI.
Move common functionality into a separate file in preparation of the
re-use from the ThunderX i2c driver.
Functions are slightly re-ordered but no other changes are included.
