We have a central copy of the GPL for that. Some addresses were already
outdated.
Signed-off-by: Wolfram Sang <wsa+renesas@sang-engineering.com>
i2c_parport_irq is only called internally so it can be static.
* Fix white space.
* Rename labels to something meaningful.
* Prefix defines with PORT_ to avoid collision with macros from
<linux/parport.h>.
* Add const markers where possible.
Use a standard list with proper locking to handle the list of
adapters. Thankfully it only matters on systems with more than one
parallel port, which are very rare.
Thanks to Lukasz Kapiec for reporting the problem to me.
Cc: stable@kernel.org
parport_algo_data is a template so it can be marked const.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Add support for the SMBus alert mechanism to the i2c-parport driver.
The ADM1032 evaluation board at least is properly wired for this.
Cc: David Brownell <dbrownell@users.sourceforge.net>
Cc: Trent Piepho <tpiepho@freescale.com>
When the i2c-parport adapter is reponsible for powering devices, it
would seem reasonable to give them some time to settle before trying
to access them.
We shouldn't release the parallel port until we are actually done with
it.
* Convert files to UTF-8.
* Also correct some people's names
(one example is Eißfeldt, which was found in a source file.
Given that the author used an ß at all in a source file
indicates that the real name has in fact a 'ß' and not an 'ss',
which is commonly used as a substitute for 'ß' when limited to
7bit.)
* Correct town names (Goettingen -> Göttingen)
* Update Eberhard Mönkeberg's address (http://lkml.org/lkml/2007/1/8/313)
Signed-off-by: Jan Engelhardt <jengelh@gmx.de>
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Update some of the layered parport_driver code to use parport->dev:
- i2c-parport (parent of i2c_adapter)
- spi_butterfly (parent of spi_master, allowing cruft removal)
- lp (creating class_device)
- ppdev (parent of parportN device)
- tipar (creating class_device)
There are still drivers that should be updated, like some of the input
drivers; but they won't be any worse off than they are today.
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
Cc: Greg KH <greg@kroah.com>
Cc: Jean Delvare <khali@linux-fr.org>
When unloading the driver, we really want to unregister the i2c adapter
before we power it off, rather than the other way around.
Also speed up the bus a bit when we can sense SCL. The slaves will
stretch the line as needed.
Initialize the fields of the i2c_adapter structure individually,
rather than copying a whole static template structure. This shaves
off 474 bytes or 14% (on i386) from the binary size.
They are all only calling i2c_del_adapter, so we may as well do
it directly.
i2c-algo-bit: Discard the mdelay data struct member
The i2c_algo_bit_data structure has an mdelay member, which is not
used by the algorithm code (the code has always been ifdef'd out.)
Let's discard it to save some code and memory.
Acked-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
Cc: Adrian Bunk <bunk@stusta.de>
This patch forces the user to specify what type of adapter is present when
loading i2c-parport or i2c-parport-light. If none is specified, the driver
init simply fails - instead of assuming adapter type 0.
This alleviates the sometimes lengthy boot time delays which can be caused
by accidentally building one of these into a kernel along with several i2c
slave drivers that have lengthy probe routines (e.g. hwmon drivers).
Kconfig and documentation updated accordingly.
Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
Use ARRAY_SIZE macro instead of sizeof(x)/sizeof(x[0]). Some trailing
whitespaces are also removed.
Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch>
Cc: Russell King <rmk+kernel@arm.linux.org.uk>
Use kzalloc instead of kmalloc+memset in all remaining i2c bus and
chip drivers.
Signed-off-by: Deepak Saxena <dsaxena@plexity.net>
It's a bit confusing to name a variable the same as an unrelated
structure. The compiler doesn't complain, but it certainly makes the
code harder to understand, and could confuse grep and LXR among
others.
This patch fixes a double "the" in a comment section.
Files that don't use CONFIG_* stuff shouldn't include config.h
Files that use CONFIG_* stuff should include config.h
It's that simple. ;-)
Signed-off-by: Alexey Dobriyan <adobriyan@mail.ru>
infrastructure for it.
Let it rip!
