path: root/drivers/i2c/busses/i2c-pca-isa.c
2008-04-22i2c-algo-pca: Extend for future driversWolfram Sang
The separation between algorithm and adapter was unsharp at places. This was partly hidden by the fact, that the ISA-driver allowed just one instance and had all private data in static variables. This patch makes neccessary preparations to add a platform driver on top of the algorithm, while still supporting ISA. Note: Due to lack of hardware, the ISA-driver could not be tested except that it builds. Concerning the core struct i2c_algo_pca_data: - A private data field was added, all hardware dependant data may go here. Similar to other algorithms, now a pointer to this data is passed to the adapter's functions. In order to make as less changes as possible to the ISA-driver, it leaves the private data empty and still only uses its static variables. - A "reset_chip" function pointer was added; such a functionality must come from the adapter, not the algorithm. - use a variable "i2c_clock" instead of a function pointer "get_clock", allowing for write access to a default in case a wrong value was supplied. In the algorithm-file: - move "i2c-pca-algo.h" into "linux/i2c-algo-pca.h" - now using per_instance timeout values (i2c_adap->timeout) - error messages specify the device, not only the driver name - restructure initialization to easily support "i2c_add_numbered_adapter" - drop "retries" and "own" (i2c address) as they were unused (The state-machine for I2C-communication was not touched.) In the ISA-driver: - adapt to new algorithm Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-04-22i2c-algo-pca: Remove trailing whitespaces and unnecessary UTFWolfram Sang
Remove trailing whitespaces to make further patches more readable. Also remove an unnecessary UTF-char for simplicity ("us" for microseconds is fine enough). Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-02-24i2c-pca-isa: Add access check to legacy ioportsChristian Krafft
When probing i2c-pca-isa writes to legacy ioports, which crashes the kernel if there is no device at that port. This patch adds a check_legacy_ioport call, so probe fails gracefully and thus prevents the oops. Signed-off-by: Christian Krafft <krafft@de.ibm.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2007-05-04Merge master.kernel.org:/pub/scm/linux/kernel/git/gregkh/pci-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/gregkh/pci-2.6: (59 commits) PCI: Free resource files in error path of pci_create_sysfs_dev_files() pci-quirks: disable MSI on RS400-200 and RS480 PCI hotplug: Use menuconfig objects PCI: ZT5550 CPCI Hotplug driver fix PCI: rpaphp: Remove semaphores PCI: rpaphp: Ensure more pcibios_add/pcibios_remove symmetry PCI: rpaphp: Use pcibios_remove_pci_devices() symmetrically PCI: rpaphp: Document is_php_dn() PCI: rpaphp: Document find_php_slot() PCI: rpaphp: Rename rpaphp_register_pci_slot() to rpaphp_enable_slot() PCI: rpaphp: refactor tail call to rpaphp_register_slot() PCI: rpaphp: remove rpaphp_set_attention_status() PCI: rpaphp: remove print_slot_pci_funcs() PCI: rpaphp: Remove setup_pci_slot() PCI: rpaphp: remove a call that does nothing but a pointer lookup PCI: rpaphp: Remove another wrappered function PCI: rpaphp: Remve another call that is a wrapper PCI: rpaphp: remove a function that does nothing but wrap debug printks PCI: rpaphp: Remove un-needed goto PCI: rpaphp: Fix a memleak; slot->location string was never freed ...
2007-05-02PCI: Cleanup the includes of <linux/pci.h>Jean Delvare
I noticed that many source files include <linux/pci.h> while they do not appear to need it. Here is an attempt to clean it all up. In order to find all possibly affected files, I searched for all files including <linux/pci.h> but without any other occurence of "pci" or "PCI". I removed the include statement from all of these, then I compiled an allmodconfig kernel on both i386 and x86_64 and fixed the false positives manually. My tests covered 66% of the affected files, so there could be false positives remaining. Untested files are: arch/alpha/kernel/err_common.c arch/alpha/kernel/err_ev6.c arch/alpha/kernel/err_ev7.c arch/ia64/sn/kernel/huberror.c arch/ia64/sn/kernel/xpnet.c arch/m68knommu/kernel/dma.c arch/mips/lib/iomap.c arch/powerpc/platforms/pseries/ras.c arch/ppc/8260_io/enet.c arch/ppc/8260_io/fcc_enet.c arch/ppc/8xx_io/enet.c arch/ppc/syslib/ppc4xx_sgdma.c arch/sh64/mach-cayman/iomap.c arch/xtensa/kernel/xtensa_ksyms.c arch/xtensa/platform-iss/setup.c drivers/i2c/busses/i2c-at91.c drivers/i2c/busses/i2c-mpc.c drivers/media/video/saa711x.c drivers/misc/hdpuftrs/hdpu_cpustate.c drivers/misc/hdpuftrs/hdpu_nexus.c drivers/net/au1000_eth.c drivers/net/fec_8xx/fec_main.c drivers/net/fec_8xx/fec_mii.c drivers/net/fs_enet/fs_enet-main.c drivers/net/fs_enet/mac-fcc.c drivers/net/fs_enet/mac-fec.c drivers/net/fs_enet/mac-scc.c drivers/net/fs_enet/mii-bitbang.c drivers/net/fs_enet/mii-fec.c drivers/net/ibm_emac/ibm_emac_core.c drivers/net/lasi_82596.c drivers/parisc/hppb.c drivers/sbus/sbus.c drivers/video/g364fb.c drivers/video/platinumfb.c drivers/video/stifb.c drivers/video/valkyriefb.c include/asm-arm/arch-ixp4xx/dma.h sound/oss/au1550_ac97.c I would welcome test reports for these files. I am fine with removing the untested files from the patch if the general opinion is that these changes aren't safe. The tested part would still be nice to have. Note that this patch depends on another header fixup patch I submitted to LKML yesterday: [PATCH] scatterlist.h needs types.h http://lkml.org/lkml/2007/3/01/141 Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-05-01i2c-pca-isa: Port to the new device driver modelJean Delvare
Port the i2c-pca-isa driver to the new device driver model. I'm using Rene Herman's new isa bus type, as it fits the needs nicely. One benefit is that we can now give a proper parent to our i2c adapter. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2006-12-10i2c: Discard the i2c algo del_bus wrappersJean Delvare
They are all only calling i2c_del_adapter, so we may as well do it directly. Signed-off-by: Jean Delvare <khali@linux-fr.org>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2005-06-21[PATCH] I2C: drivers/i2c/*: #include <linux/config.h> cleanupAlexey Dobriyan
Files that don't use CONFIG_* stuff shouldn't include config.h Files that use CONFIG_* stuff should include config.h It's that simple. ;-) Signed-off-by: Alexey Dobriyan <adobriyan@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
