This patch fixes obvious copy-past error in wake up irq parsing
code which leads to the fact that dev_pm_set_wake_irq() will
be called with wrong IRQ number when "wakeup" IRQ is not
defined in DT.
Fixes: 3fffd1283927 ("i2c: allow specifying separate wakeup interrupt in device tree")
Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com>
Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
Cc: <stable@vger.kernel.org> # v4.3
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux
Pull i2c updates from Wolfram Sang:
- New drivers: UniPhier (with and without FIFO)
- some drivers got some bigger rework: ismt, designware, img-scb (rcar
had to be reverted because issues were showing up just lately)
- ACPI: reworked the device scanning and added support for muxes
... and quite a lot of driver bugfixes and cleanups this time. All
files touched outside of the i2c realm have proper acks.
* 'i2c/for-4.4' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: (70 commits)
i2c: rcar: Revert the latest refactoring series
i2c: pnx: remove superfluous assignment
MAINTAINERS: i2c: drop i2c-pnx maintainer
MAINTAINERS: i2c: mark also subdirectories as maintained
i2c: cadence: enable driver for ARM64
i2c: i801: Document Intel DNV and Broxton
i2c: at91: manage unexpected RXRDY flag when starting a transfer
i2c: pnx: Use setup_timer instead of open coding it
i2c: add ACPI support for I2C mux ports
acpi: add acpi_preset_companion() stub
i2c: pxa: Add support for pxa910/988 & new configuration features
i2c: au1550: Convert to devm_kzalloc and devm_ioremap_resource
i2c-dev: Fix I2C_SLAVE ioctl comment
i2c-dev: Fix typo in ioctl name reference
i2c: sirf: tune the divider to make i2c bus freq more accurate
i2c: imx: Use -ENXIO as error in the NACK case
i2c: i801: Add support for Intel Broxton
i2c: i801: Add support for Intel DNV
i2c: mediatek: add i2c resume support
i2c: imx: implement bus recovery
Although I2C mux devices are easily enumerated using ACPI (_HID/_CID or
device property compatible string match), enumerating I2C client devices
connected through an I2C mux needs a little extra work.
This change implements a method for describing an I2C device hierarchy that
includes mux devices by using an ACPI Device() for each mux channel along
with an _ADR to set the channel number for the device. See
Documentation/acpi/i2c-muxes.txt for a simple example.
To make this work the ismt, i801, and designware pci/platform devs now
share an ACPI companion with their I2C adapter dev similar to how it's done
in OF. This is done on the assumption that power management functions will
not be called directly on the I2C dev that is sharing the ACPI node.
Acked-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Tested-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Signed-off-by: Dustin Byford <dustin@cumulusnetworks.com>
The way we currently scan I2C devices behind an I2C host controller does not
work in cases where the I2C device in question is not declared directly below
the host controller ACPI node.
This is perfectly legal according the ACPI 6.0 specification and some existing
systems are doing this.
To be able to enumerate all devices which are connected to a certain I2C host
controller we need to rework the current I2C scanning routine a bit. Instead of
scanning directly below the host controller we scan the whole ACPI namespace
for present devices with valid I2cSerialBus() connection pointing to the host
controller in question.
Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
Tested-by: Dustin Byford <dustin@cumulusnetworks.com>
A change of return status was introduced in commit 3fffd1283927
The commit prevents the defer status being passed up the call stack
appropriately when dev_pm_domain_attach returns -EPROBE_DEFER.
Catch the PROBE_DEFER and clear up the IRQ wakeup status
Signed-off-by: Kieran Bingham <kieranbingham@gmail.com>
Reviewed-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Instead of having each i2c driver individually parse device tree data in
case it or platform supports separate wakeup interrupt, and handle
enabling and disabling wakeup interrupts in their power management
routines, let's have i2c core do that for us.
Platforms wishing to specify separate wakeup interrupt for the device
should use named interrupt syntax in their DTSes:
interrupt-parent = <&intc1>;
interrupts = <5 0>, <6 0>;
interrupt-names = "irq", "wakeup";
This patch is inspired by work done by Vignesh R <vigneshr@ti.com> for
pixcir_i2c_ts driver.
Note that the original code tried to preserve any existing wakeup
settings from userspace but was not quite right in that regard:
it would preserve wakeup flag set by userspace upon driver rebinding;
but it would re-arm the wakeup flag if it was disabled by userspace.
We think that resetting the flag upon re-binding the driver is proper
behavior as the driver is responsible for setting up and handling
wakeups.
Tested-by: Vignesh R <vigneshr@ti.com>
[wsa: updated the commit message]
There are devices that need to handle block transactions
regardless of the capabilities exported by the adapter.
For performance reasons, they need to use i2c read blocks
if available, otherwise emulate the block transaction with word
or byte transactions.
Add support for a helper function that would read a data block
using the best transfer available: I2C_FUNC_SMBUS_READ_I2C_BLOCK,
I2C_FUNC_SMBUS_READ_WORD_DATA or I2C_FUNC_SMBUS_READ_BYTE_DATA.
Signed-off-by: Irina Tirdea <irina.tirdea@intel.com>
Address collisions will be rare, but we should let the user know that
slaves have their own address space nonetheless.
Signed-off-by: Wolfram Sang <wsa+renesas@sang-engineering.com>
We now have seperate address spaces for 10 bit and we-are-slave clients.
Update the sysfs device instantiation method to support these types by
accepting the address offsets that are assigned to the extra address
spaces. Update the documentation, too.
It is not enough to compare the plain address value, we also need to
check the flags enabling a different address space. E.g. it is valid to
have address 0x50 as a 7-bit address and 0x050 as 10-bit address on the
same bus. Same for addresses when we are the slave.
Tested-by: Andrey Danin <danindrey@mail.ru>
Check for slave and 10-bit flags when probing and mark the client when
found. Improve the address validity check, too
We want to use this function with struct boardinfo soon, so let's just
pass the parameters really needed. We also extend the type of addr, so
more types can be input. Remove a superfluous dangling comment while
here.
The current naming is based on the arguments of the functions and not on
what they do. Even I as the maintainer find this confusing, so let's
rename them to something more descriptive.
We want a separate address range for being an I2C slave. Add an offset
of 0x1000, so it can be combined with ten bit addresses as well. Add a
separate function to create the address value, we will need it later in
other places.
of_find_i2c_adapter_by_node() call requires quite often missing
put_device(), and i2c_put_adapter() releases a device locked by
i2c_get_adapter() only. In general module_put(adapter->owner) and
put_device(dev) are not interchangeable.
This is a common error reproduction scenario as a result of the
misusage described above (for clearness this is run on iMX6 platform
with HDMI and I2C bus drivers compiled as kernel modules):
root@mx6q:~# lsmod | grep i2c
i2c_imx 10213 0
root@mx6q:~# lsmod | grep dw_hdmi_imx
dw_hdmi_imx 3631 0
dw_hdmi 11846 1 dw_hdmi_imx
imxdrm 8674 3 dw_hdmi_imx,imx_ipuv3_crtc,imx_ldb
drm_kms_helper 113765 5 dw_hdmi,imxdrm,imx_ipuv3_crtc,imx_ldb
root@mx6q:~# rmmod dw_hdmi_imx
i2c_imx 10213 -1
root@mx6q:~# rmmod i2c_imx
rmmod: ERROR: Module i2c_imx is in use
To fix existing users of these interfaces and to avoid any further
confusion and misusage in future, add one more interface
of_get_i2c_adapter_by_node(), it is similar to i2c_get_adapter() in
sense that an I2C bus device driver found and locked by user can be
correctly unlocked by i2c_put_adapter().
Signed-off-by: Vladimir Zapolskiy <vladimir_zapolskiy@mentor.com>
In addition to module_get()/module_put() add get_device()/put_device()
calls into i2c_get_adapter()/i2c_put_adapter() exported
interfaces. This is done to lock I2C bus device, if it is in use by a
client.
If of_find_i2c_device_by_node() or of_find_i2c_adapter_by_node() find
a device by node, but its type does not match, a reference to that
device is still held. This change fixes the problem.
Using set_scl may be ineffective before calling the driver specific
prepare_recovery callback, which might change into a test mode. So
instead of setting SCL in i2c_generic_scl_recovery, move it to
i2c_generic_recovery (after the optional prepare_recovery).
Signed-off-by: Jan Luebbe <jlu@pengutronix.de>
Acked-by: Alexander Sverdlin <alexander.sverdlin@nokia.com>
Tested-by: Alexander Sverdlin <alexander.sverdlin@gmail.com>
Mark (and unmark) device nodes with the POPULATE flag as appropriate.
This is required to avoid multi probing when using I2C and device
overlays containing a mux.
This patch is also more careful with the release of the adapter device
which caused a deadlock with muxes, and does not break the build
on !OF since the node flag accessors are not defined then.
Signed-off-by: Pantelis Antoniou <pantelis.antoniou@konsulko.com>
"Highlights:
- new drivers for Mediatek I2C, APM X-Gene, Broadcom Settop
- major updates to at91, davinci
- bugfixes to the mux infrastructure when dealing with the new quirk
mechanism
- more users for the bus recovery feature
- further improvements to the slave framework
Plus the usual bunch of smaller driver and core improvements and
fixes.
There is one patch removing old code from an ARM platform. This has
been acked by the sh_mobile maintainer Simon Horman"
* 'i2c/for-4.2' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: (48 commits)
i2c: busses: i2c-bcm2835: limits cdiv to allowed values
i2c: sh_mobile: use proper type for timeout
i2c: sh_mobile: use adapter default for timeout
i2c: rcar: use proper type for timeout
i2c: rcar: use adapter default for timeout
i2c: designware: Make sure the device is suspended before disabling runtime PM
i2c: tegra: apply size limit quirk
i2c: tegra: don't advertise SMBUS_QUICK
i2c: octeon: remove unused signal handling
i2c: davinci: Optimize SCL generation
i2c: mux: pca954x: Use __i2c_transfer because of quirks
i2c: mux: Use __i2c_transfer() instead of calling parent's master_xfer()
i2c: use parent adapter quirks in mux
i2c: bcm2835: clear reserved bits in S-Register
ARM: shmobile: r8a7740: remove I2C errata handling
i2c: sh_mobile: add errata workaround
i2c: at91: fix code checker warnings
i2c: busses: xgene-slimpro: fix incorrect __init declation for probe
i2c: davinci: Avoid sending to own address
i2c: davinci: Refactor i2c_davinci_wait_bus_not_busy()
sizeof(struct i2c_client) is 1088 bytes on a CONFIG_X86_64=y build and
produces following warning when CONFIG_FRAME_WARN is set to 1024:
drivers/i2c/i2c-core.c: In function ‘acpi_i2c_space_handler’:
drivers/i2c/i2c-core.c:367:1: warning: the frame size of 1152 bytes is
larger than 1024 bytes [-Wframe-larger-than=]
This is not critical given that kernel stack is 16 kB on x86_64 but lets
reduce the stack usage by allocating the struct i2c_client from the heap.
Signed-off-by: Jarkko Nikula <jarkko.nikula@linux.intel.com>
Signed-off-by: Shailendra Verma <shailendra.capricorn@gmail.com>
int is vague, let's simply use the type of the variable in question.
Reviewed-by: Simon Horman <horms+renesas@verge.net.au>
Inform users what went wrong from the core, so drivers don't have to do
it.
Acked-by: Geert Uytterhoeven <geert+renesas@glider.be>
Following what DT already does. If the device does not have ACPI Interrupt
resource but instead it has one or more GpioInt resources listed below it,
we take the first GpioInt resource, convert it to suitable Linux IRQ number
and pass it to the driver instead.
This makes drivers simpler because the don't need to care about GPIOs at
all if only thing they need is interrupt.
Acked-by: Wolfram Sang <wsa@the-dreams.de>
This is the convention used in most parts of the kernel including DT
counterpart of I2C slave enumeration. To make things consistent do the same
for ACPI I2C slave enumeration path as well.
Commit 523c5b89640e ("i2c: Remove support for legacy PM") removed the PM
ops from the bus type, which causes the pm operations on the s3c2410
adapter device to fail (-ENOSUPP in rpm_callback). The adapter device
doesn't get bound to a driver and as such can't have its own pm_runtime
callbacks. Previously this was fine as the bus callbacks would have been
used, but now this can cause devices which use PM runtime and are
attached over I2C to fail to resume.
This commit fixes this issue by marking all adapter devices with
pm_runtime_no_callbacks, since they can't have any.
Signed-off-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com>
Acked-by: Beata Michalska <b.michalska@samsung.com>
Fixes: 523c5b89640e
Cc: stable@kernel.org
Current -next fails to link an ARM allmodconfig because drivers that use
the core recovery functions can be built as modules but those functions
are not exported:
ERROR: "i2c_generic_gpio_recovery" [drivers/i2c/busses/i2c-davinci.ko] undefined!
ERROR: "i2c_generic_scl_recovery" [drivers/i2c/busses/i2c-davinci.ko] undefined!
ERROR: "i2c_recover_bus" [drivers/i2c/busses/i2c-davinci.ko] undefined!
Add exports to fix this.
Fixes: 5f9296ba21b3c (i2c: Add bus recovery infrastructure)
Signed-off-by: Mark Brown <broonie@kernel.org>
Pull power management and ACPI updates from Rafael Wysocki:
"These are mostly fixes and cleanups all over, although there are a few
items that sort of fall into the new feature category.
First off, we have new callbacks for PM domains that should help us to
handle some issues related to device initialization in a better way.
There also is some consolidation in the unified device properties API
area allowing us to use that inferface for accessing data coming from
platform initialization code in addition to firmware-provided data.
We have some new device/CPU IDs in a few drivers, support for new
chips and a new cpufreq driver too.
Specifics:
- Generic PM domains support update including new PM domain callbacks
to handle device initialization better (Russell King, Rafael J
Wysocki, Kevin Hilman)
- Unified device properties API update including a new mechanism for
accessing data provided by platform initialization code (Rafael J
Wysocki, Adrian Hunter)
- ARM cpuidle update including ARM32/ARM64 handling consolidation
(Daniel Lezcano)
- intel_idle update including support for the Silvermont Core in the
Baytrail SOC and for the Airmont Core in the Cherrytrail and
Braswell SOCs (Len Brown, Mathias Krause)
- New cpufreq driver for Hisilicon ACPU (Leo Yan)
- intel_pstate update including support for the Knights Landing chip
(Dasaratharaman Chandramouli, Kristen Carlson Accardi)
- QorIQ cpufreq driver update (Tang Yuantian, Arnd Bergmann)
- powernv cpufreq driver update (Shilpasri G Bhat)
- devfreq update including Tegra support changes (Tomeu Vizoso,
MyungJoo Ham, Chanwoo Choi)
- powercap RAPL (Running-Average Power Limit) driver update including
support for Intel Broadwell server chips (Jacob Pan, Mathias Krause)
- ACPI device enumeration update related to the handling of the
special PRP0001 device ID allowing DT-style 'compatible' property
to be used for ACPI device identification (Rafael J Wysocki)
- ACPI EC driver update including limited _DEP support (Lan Tianyu,
Lv Zheng)
- ACPI backlight driver update including a new mechanism to allow
native backlight handling to be forced on non-Windows 8 systems and
a new quirk for Lenovo Ideapad Z570 (Aaron Lu, Hans de Goede)
- New Windows Vista compatibility quirk for Sony VGN-SR19XN (Chen Yu)
- Assorted ACPI fixes and cleanups (Aaron Lu, Martin Kepplinger,
Masanari Iida, Mika Westerberg, Nan Li, Rafael J Wysocki)
- Fixes related to suspend-to-idle for the iTCO watchdog driver and
the ACPI core system suspend/resume code (Rafael J Wysocki, Chen Yu)
- PM tracing support for the suspend phase of system suspend/resume
transitions (Zhonghui Fu)
- Configurable delay for the system suspend/resume testing facility
(Brian Norris)
- PNP subsystem cleanups (Peter Huewe, Rafael J Wysocki)"
* tag 'pm+acpi-4.1-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (74 commits)
ACPI / scan: Fix NULL pointer dereference in acpi_companion_match()
ACPI / scan: Rework modalias creation when "compatible" is present
intel_idle: mark cpu id array as __initconst
powercap / RAPL: mark rapl_ids array as __initconst
powercap / RAPL: add ID for Broadwell server
intel_pstate: Knights Landing support
intel_pstate: remove MSR test
cpufreq: fix qoriq uniprocessor build
ACPI / scan: Take the PRP0001 position in the list of IDs into account
ACPI / scan: Simplify acpi_match_device()
ACPI / scan: Generalize of_compatible matching
device property: Introduce firmware node type for platform data
device property: Make it possible to use secondary firmware nodes
PM / watchdog: iTCO: stop watchdog during system suspend
cpufreq: hisilicon: add acpu driver
ACPI / EC: Call acpi_walk_dep_device_list() after installing EC opregion handler
cpufreq: powernv: Report cpu frequency throttling
intel_idle: Add support for the Airmont Core in the Cherrytrail and Braswell SOCs
intel_idle: Update support for Silvermont Core in Baytrail SOC
PM / devfreq: tegra: Register governor on module init
"Most notable:
- introducing the i2c_quirk infrastructure. Now, flaws of I2C
controllers can be described and the core will check if the flaws
collide with the messages to be sent
- wait_for_completion return type cleanup series
- new drivers for Digicolor, Netlogic XLP, Ingenic JZ4780
- updates to the I2C slave framework which include API changes. Its
only user was updated, too. Documentation was finally added
- changed dynamic bus numbering for the DT case. This could change
bus numbers for users. However, it fixes a collision where dynamic
and static busses request the same id.
- driver bugfixes, cleanups"
* 'i2c/for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: (52 commits)
i2c: xlp9xx: Driver for Netlogic XLP9XX/5XX I2C controller
of: Add vendor prefix 'netlogic'
i2c: davinci: use ICPFUNC to toggle I2C as gpio for bus recovery
i2c: davinci: use bus recovery infrastructure
i2c: change input parameter to i2c_adapter for prepare/unprepare_recovery
i2c: i2c-mux-gpio: remove error messages for probe deferrals
i2c: jz4780: Add i2c bus controller driver for Ingenic JZ4780
i2c: dln2: set the device tree node of the adapter
i2c: davinci: fixup wait_for_completion_timeout handling
i2c: mpc: Fix ISR return value
i2c: slave-eeprom: add more info when to increase the pointer
i2c: slave: add documentation for i2c-slave-eeprom
Documentation: i2c: describe the new slave mode
i2c: slave: rework the slave API
i2c: add support for the Digicolor I2C controller
i2c: busses with dynamic ids should start after fixed ids for DT
of: base: add function to get highest id of an alias stem
i2c: designware: Suppress error message if platform_get_irq() < 0
i2c: mpc: assign the correct prescaler from SVR
i2c: img-scb: fixup of wait_for_completion_timeout return handling
This patch changes type of input parameter for
prepare/unprepare_recovery() callbacks from struct i2c_bus_recovery_info
* to struct i2c_adapter *. This allows to simplify implementation of
these callbacks and avoid type conversations from i2c_bus_recovery_info
to i2c_adapter. The i2c_bus_recovery_info can be simply retrieved from
struct i2c_adapter which contains pointer on it. There are no users
currently, so this is safe to do.
Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
Make sure dynamic ids do not interfere with fixed ones and let them
start after the highest fixed id. This patch might cause different
bus-numbers than before for dynamic ids, however it fixes a bug. Assume:
- fixed id0 defers probe
- fixed id1 succeeds and registers a muxed bus with dynamic id
- muxed bus gets id0
- fixed id0 wants to probe again, but its fixed id is gone now
- fixed id0 probe fails
With this patch, the fixed ids are always reserved in the DT case.
For legacy board init, we already have a mechanism like this in
i2c_register_board_info().
Reported-by: Bob Feretich <bob.feretich@rafresearch.com>
Now that we have struct fwnode_handle, we can use that to point to
ACPI companions from struct device objects instead of pointing to
struct acpi_device directly.
There are two benefits from that. First, the somewhat ugly and
hackish struct acpi_dev_node can be dropped and, second, the same
struct fwnode_handle pointer can be used in the future to point
to other (non-ACPI) firmware device node types.
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Acked-by: Grant Likely <grant.likely@linaro.org>
Let the core do the checks if HW quirks prevent a transfer. Saves code
from drivers and adds consistency.
Tested-by: Ray Jui <rjui@broadcom.com>
Tested-by: Ivan T. Ivanov <iivanov@mm-sol.com>
Tested-by: Neelesh Gupta <neelegup@linux.vnet.ibm.com>
Tested-By: Ludovic Desroches <ludovic.desroches@atmel.com>
This reverts commit e4df3a0b6228
("i2c: core: Dispose OF IRQ mapping at client removal time")
Calling irq_dispose_mapping() will destroy the mapping and disassociate
the IRQ from the IRQ chip to which it belongs. Keeping it is OK, because
existent mappings are reused properly.
Also, this commit breaks drivers using devm* for IRQ management on
OF-based systems because devm* cleanup happens in device code, after
bus's remove() method returns.
Signed-off-by: Jakub Kicinski <kubakici@wp.pl>
Reported-by: Sébastien Szymanski <sebastien.szymanski@armadeus.com>
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
[wsa: updated the commit message with findings fromt the other bug report]
Fixes: e4df3a0b6228
"Summary:
- legacy PM code removed from the core, there were no users anymore
(thanks to Lars-Peter Clausen)
- new driver for Broadcom iProc
- bigger driver updates for designware, rk3x, cadence, ocores
- a bunch of smaller updates and bugfixes"
* 'i2c/for-3.20' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: (31 commits)
i2c: ocores: rework clk code to handle NULL cookie
i2c: designware-baytrail: another fixup for proper Kconfig dependencies
i2c: fix reference to functionality constants definition
i2c: iproc: Add Broadcom iProc I2C Driver
i2c: designware-pci: update Intel copyright line
i2c: ocores: add common clock support
i2c: hix5hd2: add COMPILE_TEST
i2c: clarify comments about the dev_released completion
i2c: ocores: fix clock-frequency binding usage
i2c: tegra: Maintain CPU endianness
i2c: designware-baytrail: use proper Kconfig dependencies
i2c: designware: Do not calculate SCL timing parameters needlessly
i2c: do not try to load modules for of-registered devices
i2c: designware: Add Intel Baytrail PMIC I2C bus support
i2c: designware: Add i2c bus locking support
of: i2c: Add i2c-mux-idle-disconnect DT property to PCA954x mux driver
i2c: designware: use {readl|writel}_relaxed instead of readl/writel
i2c: designware-pci: no need to provide clk_khz
i2c: designware-pci: remove Moorestown support
i2c: imx: whitespace and checkpatch cleanup
There was quite some confusion why this completion is there and if it is
still necessary. Sadly, it is. However, let's improve the comments and
share what we rediscovered.
Make the slave support depend on CONFIG_I2C_SLAVE. Otherwise it gets
included unconditionally, even when it is not needed.
I2C bus drivers which implement slave support must select
I2C_SLAVE.
Signed-off-by: Jean Delvare <jdelvare@suse.de>
Trying to register an I2C device asynchronously (via async_schedule() call)
results in an ugly warning from request_module() warning about potential
deadlock (because request_module tries to wait for async works to
complete). While we could try to switch to request_module_nowait(), other
buses, as well as I2C itself when not using device tree, do not try to load
modules, but rather rely on the standard infrastructure (udev) to execute
module loading, and we should be doing the same.
Declaring attribute groups can be done with macros these days, let's use
them for consistency and readability reasons. Also, put the ATTR macros
directly below the referenced functions while we are here.
ACPI specification allows I2C devices with multiple addresses. The current
implementation goes over all addresses and assigns the last one to the
device. This is typically not the primary address of the device.
Instead of doing that we assign the first address to the device and then
let the driver handle rest of the addresses as it wishes.
There haven't been any I2C driver that use the legacy suspend/resume
callbacks for a while now and new drivers are supposed to use PM ops. So
remove support for legacy suspend/resume for I2C drivers.
Since there aren't any special bus specific things to do during
suspend/resume and since the PM core will automatically fallback directly to
using the device's PM ops if no bus PM ops are specified there is no need to
have any I2C bus PM ops.
"For 3.19, the I2C subsystem has to offer special candy this time.
Right in time for Christmas :)
- I2C slave framework: finally, a generic mechanism for Linux being
an I2C slave (if the bus driver supports that). Docs are still
missing but will come later this cycle, the code is good enough to
go.
- I2C muxes represent their topology in sysfs much more detailed.
This will help users to navigate around much easier.
- irq population of i2c clients is now done at probe time, not device
creation time, to have better support for deferred probing.
- new drivers for Imagination SCB, Amlogic Meson
- DMA support added for Freescale IMX, Renesas SHMobile
- slightly bigger driver updates to OMAP, i801, AT91, and rk3x
(mostly quirk handling, timing updates, and using better kernel
interfaces)
- eeprom driver can now write with byte-access (very slow, but OK to
have)
- and the bunch of smaller fixes, cleanups, ID updates..."
* 'i2c/for-3.19' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: (56 commits)
i2c: sh_mobile: remove unneeded DMA mask
i2c: rcar: add slave support
i2c: slave-eeprom: add eeprom simulator driver
i2c: core changes for slave support
MAINTAINERS: add I2C dt bindings also to I2C realm
i2c: designware: Fix falling time bindings doc
i2c: davinci: switch to use platform_get_irq
Documentation: i2c: Use PM ops instead of legacy suspend/resume
i2c: sh_mobile: optimize irq entry
i2c: pxa: add support for SCCB devices
omap: i2c: don't check bus state IP rev3.3 and earlier
i2c: s3c2410: Handle i2c sys_cfg register in i2c driver
i2c: rk3x: add Kconfig dependency on COMMON_CLK
i2c: omap: add notes related to i2c multimaster mode
i2c: omap: don't reset controller if Arbitration Lost detected
i2c: omap: implement workaround for handling invalid BB-bit values
i2c: omap: cleanup register definitions
i2c: rk3x: handle dynamic clock rate changes correctly
i2c: at91: enable probe deferring on dma channel request
i2c: at91: remove legacy DMA support
Finally(!), make Linux support being an I2C slave. Most of the existing
infrastructure is reused. We mainly add i2c_slave_register/unregister()
calls which tells i2c bus drivers to activate the slave mode. Then, they
also get a callback to report slave events to.
git://git.kernel.org/pub/scm/linux/kernel/git/glikely/linux
Pull devicetree changes from Grant Likely:
"Lots of activity in the devicetree code for v3.18. Most of it is
related to getting all of the overlay support code in place, but there
are other important things in there.
Highlights:
- OF_RECONFIG notifiers for SPI, I2C and Platform devices. Those
subsystems can now respond to live changes to the device tree.
- CONFIG_OF_OVERLAY method for applying live changes to the device
tree
- Removal of the of_allnodes list. This used to be used to iterate
over all the nodes in the device tree, but it is unnecessary
because the same thing can be done by iterating over the list of
child pointers. Getting rid of of_allnodes saves some memory and
avoids the possibility of of_allnodes being sorted differently from
the child lists.
- Support for retrieving original DTB blob via sysfs. Needed by
kexec.
- More unittests
- Documentation and minor bug fixes"
* tag 'devicetree-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/glikely/linux: (42 commits)
of: Delete unnecessary check before calling "of_node_put()"
of: Drop ->next pointer from struct device_node
spi: Check for spi_of_notifier when CONFIG_OF_DYNAMIC=y
of: support passing console options with stdout-path
of: add optional options parameter to of_find_node_by_path()
of: Add bindings for chosen node, stdout-path
of: Remove unneeded and incorrect MODULE_DEVICE_TABLE
ARM: dt: fix up PL011 device tree bindings
of: base, fix of_property_read_string_helper kernel-doc
of: remove select of non-existant OF_DEVICE config symbol
spi/of: Add OF notifier handler
spi/of: Create new device registration method and accessors
i2c/of: Add OF_RECONFIG notifier handler
i2c/of: Factor out Devicetree registration code
of/overlay: Add overlay unittests
of/overlay: Introduce DT overlay support
of/reconfig: Add OF_DYNAMIC notifier for platform_bus_type
of/reconfig: Always use the same structure for notifiers
of/reconfig: Add debug output for OF_RECONFIG notifiers
of/reconfig: Add empty stubs for the of_reconfig methods
CONFIG_OF_DYNAMIC enables runtime changes to the device tree which in
turn may trigger addition or removal of devices from Linux. Add an
OF_RECONFIG notifier handler to receive tree change events and to
creating or destroy i2c devices as required.
[grant.likely: clean up #ifdefs and drop unneeded error handling]
Signed-off-by: Grant Likely <grant.likely@linaro.org>
Reviewed-by: Wolfram Sang <wsa@the-dreams.de>
Cc: Rob Herring <robh+dt@kernel.org>
Cc: linux-i2c@vger.kernel.org
Dynamically inserting i2c client device nodes requires the use
of a single device registration method. Factor out the loop body of
of_i2c_register_devices() so that it can be called for individual
device_nodes instead of for all the children of a node.
Note: The diff of this commit looks far more complicated than it
actually is due the indentation being changed for a large block of code.
When viewed using the diff -w flag to ignore whitespace changes it can
be seen that the change is actually quite simple.
[grant.likely: Made new function static and removed changes to header]
ACPI 5.0 introduces _DEP (Operation Region Dependencies) to designate
device objects that OSPM should assign a higher priority in start
ordering due to future operation region accesses.
On Asus T100TA, ACPI battery info are read from a I2C slave device via
I2C operation region. Before I2C operation region handler is installed,
battery _STA always returns 0. There is a _DEP method of designating
start order under battery device node.
This patch is to implement _DEP feature to fix battery issue on the
Asus T100TA. Introducing acpi_dep_list and adding dep_unmet count
in struct acpi_device. During ACPI namespace scan, create struct
acpi_dep_data for a valid pair of master (device pointed to by _DEP)/
slave(device with _DEP), record master's and slave's ACPI handle in
it and put it into acpi_dep_list. The dep_unmet count will increase
by one if there is a device under its _DEP. Driver's probe() should
return EPROBE_DEFER when find dep_unmet is larger than 0. When I2C
operation region handler is installed, remove all struct acpi_dep_data
on the acpi_dep_list whose master is pointed to I2C host controller
and decrease slave's dep_unmet. When dep_unmet decreases to 0, all
_DEP conditions are met and then do acpi_bus_attach() for the device
in order to resolve battery _STA issue on the Asus T100TA.
Link: https://bugzilla.kernel.org/show_bug.cgi?id=69011
Tested-by: Jan-Michael Brummer <jan.brummer@tabos.org>
Tested-by: Adam Williamson <adamw@happyassassin.net>
Tested-by: Michael Shigorin <shigorin@gmail.com>
Signed-off-by: Lan Tianyu <tianyu.lan@intel.com>
No need to initialize 'ret' if it gets assigned directly after that.
Since commit 2fd36c55264926e2 ("i2c: core: Map OF IRQ at probe time"),
i2c slaves without interrupts (e.g. da9210 and at24 on r8a7791/koelsch)
fail to probe:
at24: probe of 2-0050 failed with error -22
da9210: probe of 6-0068 failed with error -22
This happens because the call to of_irq_get() in i2c_device_probe()
returns -EINVAL.
If a device node does not have an "interrupts" property,
of_irq_parse_one() fails. Unlike irq_of_parse_and_map(), of_irq_get()
does not ignore errors from of_irq_parse_one(), but forwards them.
Make i2c_device_probe() ignore all errors but -EPROBE_DEFER to fix this,
just like platform_get_irq() and platform_get_irq_byname() already do.
Fixes: 2fd36c55264926e2 ("i2c: core: Map OF IRQ at probe time")
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
Tested-by: Fabio Estevam <fabio.estevam@freescale.com>
