When doing a REP_START after a read message, the driver used to trigger
a STOP first which would then be overwritten by REP_START. This was the
only stable method found when doing the last refactoring. However, this
was not in accordance with the documentation.
After research from our BSP team and myself, we now can implement a
version which works and is according to the documentation. The new
approach ensures the ICMCR register is only changed when really needed.
Tested on a R-Car Gen2 (H2) and Gen3 with DMA (M3N).
Signed-off-by: Hiromitsu Yamasaki <hiromitsu.yamasaki.ym@renesas.com>
Signed-off-by: Wolfram Sang <wsa+renesas@sang-engineering.com>
Reviewed-by: Ulrich Hecht <uli+renesas@fpond.eu>
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
Use BIT macro to avoid shift-31-problem, indent a little more and use
GENMASK to make it easier to add new flags.
Currently acpi_gsb_i2c_read_bytes() directly returns i2c_transfer's return
value. i2c_transfer returns a value < 0 on error and 2 (for 2 successfully
executed transfers) on success. But the ACPI code expects 0 on success, so
currently acpi_gsb_i2c_read_bytes()'s caller does:
if (status > 0)
status = 0;
This commit makes acpi_gsb_i2c_read_bytes() return a value which can be
directly consumed by the ACPI code, mirroring acpi_gsb_i2c_write_bytes(),
this commit also makes acpi_gsb_i2c_read_bytes() explitcly check that
i2c_transfer returns 2, rather then accepting any value > 0.
Acked-by: Mika Westerberg <mika.westerberg@linux.intel.com>
acpi_gsb_i2c_write_bytes() returns i2c_transfer()'s return value, which
is the number of transfers executed on success, so 1.
The ACPI code expects us to store 0 in gsb->status for success, not 1.
Specifically this breaks the following code in the Thinkpad 8 DSDT:
ECWR = I2CW = ECWR /* \_SB_.I2C1.BAT0.ECWR */
If ((ECST == Zero))
ECRD = I2CR /* \_SB_.I2C1.I2CR */
Before this commit we set ECST to 1, causing the read to never happen
breaking battery monitoring on the Thinkpad 8.
This commit makes acpi_gsb_i2c_write_bytes() return 0 when i2c_transfer()
returns 1, so the single write transfer completed successfully, and
makes it return -EIO on for other (unexpected) return values >= 0.
Cc: stable@vger.kernel.org
Always update the stopped state when busy status have been checked.
This is identical to what was done before, with the exception of error
handling.
Without this change, some errors cause the stopped state to be left in
incorrect state in i2c_imx_stop(), i2c_imx_dma_read(), i2c_imx_read() and
i2c_imx_xfer().
Signed-off-by: Esben Haabendal <eha@deif.com>
Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
This fixes a race condition, where the DMAEN bit ends up being set after
I2C slave has transmitted a byte following the dummy read. When that
happens, an interrupt is generated instead, and no DMA request is generated
to kickstart the DMA read, and a timeout happens after DMA_TIMEOUT (1 sec).
Fixed by setting the DMAEN bit before the dummy read.
Cc: stable@kernel.org
The pasemi smbus controller uses PCI_FUNC(dev->devfn) to define which
number bus to attach to, however this fails when something else is
probed first, for example an ATI Radeon graphics card will claim 9 or
10 busses, including the ones the pasemi wants.
Patch the driver to call i2c_add_adapter rather than
i2c_add_numbered_adapter.
Signed-off-by: Darren Stevens <darren@stevens-zone.net>
Replace short statement in comment with proper SPDX license tag.
Note, for i2c-desingware-slave.c the identifier is chosen
in accordance with MODULE_LICENSE() macro since it is visible to user.
Another point to this choice is that the header seems to be copy'n'paste
from the other file of this very driver.
Acked-by: Luis Oliveira <Luis.Oliveira@synopsys.com>
Acked-by: Jarkko Nikula <jarkko.nikula@linux.intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regmap
Pull regmap updates from Mark Brown:
"Several small new features for regmap this time around:
- Support for SCCB, an I2C variant used on some media cards. This has
also pulled in an I2C commit from Peter Rosin as a dependency.
- Addition of an API for reading repeatedly from registers where the
address doesn't automatically increment like some ADC outputs or
GPIO status registers.
- Support for bulk I/O on Slimbus"
* tag 'regmap-v4.19' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regmap:
regmap: Add regmap_noinc_read API
regmap: sccb: fix typo and sort headers alphabetically
i2c: smbus: add unlocked __i2c_smbus_xfer variant
regmap: add SCCB support
regmap: slimbus: add support to multi read/write
During ipmi stress tests we see occasional failure of transactions
at the boot time. This happens in the case of a I2C_M_RECV_LEN
transactions, when the read transfer completes (with the initial
read length of 34) before the driver gets a chance to handle interrupts.
The current driver code expects at least 2 interrupts for I2C_M_RECV_LEN
transactions. The length is updated during the first interrupt, and the
buffer contents are only copied during subsequent interrupts. In case of
just one interrupt, we will complete the transaction without copying
out the bytes from RX fifo.
Update the code to drain the RX fifo after the length update,
so that the transaction completes correctly in all cases.
Signed-off-by: George Cherian <george.cherian@cavium.com>
Instead of using custom variables and parser, convert the driver to use
the ones provided by I2C core.
No functional change intended.
Reviewed-by: Alexandre Belloni <alexandre.belloni@bootlin.com>
Tested-by: Alexandre Belloni <alexandre.belloni@bootlin.com>
There are two drivers already using the SDA hold time setting.
It might be more in the future, thus, make I2C core to parse the setting
for us if provided by firmware.
Acked-by: Ludovic Desroches <ludovic.desroches@microchip.com>
In preparation to enabling -Wimplicit-fallthrough, mark switch cases
where we are expecting to fall through.
Signed-off-by: Gustavo A. R. Silva <gustavo@embeddedor.com>
Acked-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
And don't reimplement in the driver.
Reviewed-by: Niklas Söderlund <niklas.soderlund+renesas@ragnatech.se>
Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com>
Tested-by: Jarkko Nikula <jarkko.nikula@linux.intel.com>
Some adapters do not support a message length of 0. Add this as a quirk
so drivers don't have to open code it.
This commit fixes this sparse warning:
drivers/i2c/busses/i2c-aspeed.c:875:38: warning: incorrect type in assignment (different modifiers)
drivers/i2c/busses/i2c-aspeed.c:875:38: expected unsigned int ( *get_clk_reg_val )( ... )
drivers/i2c/busses/i2c-aspeed.c:875:38: got void const *const data
Reported-by: Wolfram Sang <wsa@the-dreams.de>
Signed-off-by: Jae Hyun Yoo <jae.hyun.yoo@linux.intel.com>
Reviewed-by: Brendan Higgins <brendanhiggins@google.com>
i2c/for-4.19
Simplify the probe function of the pca954x driver
Add Actions Semiconductor Owl family S900 I2C driver.
Signed-off-by: Manivannan Sadhasivam <manivannan.sadhasivam@linaro.org>
Acked-by: Peter Rosin <peda@axentia.se>
This bus driver supports the GENI based i2c hardware controller in the
Qualcomm SOCs. The Qualcomm Generic Interface (GENI) is a programmable
module supporting a wide range of serial interfaces including I2C. The
driver supports FIFO mode and DMA mode of transfer and switches modes
dynamically depending on the size of the transfer.
Signed-off-by: Karthikeyan Ramasubramanian <kramasub@codeaurora.org>
Signed-off-by: Sagar Dharia <sdharia@codeaurora.org>
Signed-off-by: Girish Mahadevan <girishm@codeaurora.org>
Reviewed-by: Douglas Anderson <dianders@chromium.org>
Reviewed-by: Stephen Boyd <swboyd@chromium.org>
Tested-by: Stephen Boyd <swboyd@chromium.org>
[wsa: squashed the MAINTAINER addition and a RPM fix by Evan Green]
Pull locking fixes from Ingo Molnar:
"A paravirt UP-patching fix, and an I2C MUX driver lockdep warning fix"
* 'locking-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
locking/pvqspinlock/x86: Use LOCK_PREFIX in __pv_queued_spin_unlock() assembly code
i2c/mux, locking/core: Annotate the nested rt_mutex usage
locking/rtmutex: Allow specifying a subclass for nested locking
This creates a struct device *dev helper variable in probe()
which IMO makes the code less cluttered and easier to read.
Also rename the of_node veriable to the common shortform "np"
(node pointer).
[peda: slightly edited commit message and removed some surplus newlines]
Signed-off-by: Peter Rosin <peda@axentia.se>
If an i2c topology has instances of nested muxes, then a lockdep splat
is produced when when i2c_parent_lock_bus() is called. Here is an
example:
WARNING: possible recursive locking detected
insmod/68159 is trying to acquire lock:
(i2c_register_adapter#2){+.+.}, at: i2c_parent_lock_bus+0x32/0x50 [i2c_mux]
but task is already holding lock:
Possible unsafe locking scenario:
CPU0
lock(i2c_register_adapter#2);
*** DEADLOCK ***
May be due to missing lock nesting notation
1 lock held by insmod/68159:
#0: (i2c_register_adapter#2){+.+.}, at: i2c_parent_lock_bus+0x32/0x50 [i2c_mux]
stack backtrace:
CPU: 13 PID: 68159 Comm: insmod Tainted: G O
Call Trace:
dump_stack+0x67/0x98
__lock_acquire+0x162e/0x1780
lock_acquire+0xba/0x200
rt_mutex_lock+0x44/0x60
i2c_parent_lock_bus+0x3e/0x50 [i2c_mux]
i2c_smbus_xfer+0xf0/0x700
i2c_smbus_read_byte+0x42/0x70
my2c_init+0xa2/0x1000 [my2c]
do_one_initcall+0x51/0x192
do_init_module+0x62/0x216
load_module+0x20f9/0x2b50
SYSC_init_module+0x19a/0x1c0
SyS_init_module+0xe/0x10
do_syscall_64+0x6c/0x1a0
entry_SYSCALL_64_after_hwframe+0x42/0xb7
Reported-by: John Sperbeck <jsperbeck@google.com>
Tested-by: John Sperbeck <jsperbeck@google.com>
Cc: Davidlohr Bueso <dave@stgolabs.net>
Cc: Deepa Dinamani <deepadinamani@google.com>
Cc: Peter Chang <dpf@google.com>
Cc: Philippe Ombredanne <pombredanne@nexb.com>
Cc: Wolfram Sang <wsa@the-dreams.de>
Link: http://lkml.kernel.org/r/20180720083914.1950-3-peda@axentia.se
I2C is open drain, so request the GPIO accordingly, even if pinmux did
set it up correctly for in-kernel users in this case.
Reviewed-by: Lucas Stach <l.stach@pengutronix.de>
On Gen3, we can only do RXDMA once per transfer reliably. For that, we
must reset the device, then we can have RXDMA once. This patch
implements this. When there is no reset controller or the reset fails,
RXDMA will be blocked completely. Otherwise, it will be disabled after
the first RXDMA transfer. Based on a commit from the BSP by Hiromitsu
Yamasaki, yet completely refactored to handle multiple read messages
within one transfer.
Reviewed-by: Geert Uytterhoeven <geert+renesas@glider.be>
Make sure to call reinit_completion() before dma is started to avoid race
condition where reinit_completion() is called after complete() and before
wait_for_completion_timeout().
Fixes: ce1a78840ff7 ("i2c: imx: add DMA support for freescale i2c driver")
Reviewed-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
If CLKH is set to 0 I2C clock is not generated at all, so avoid this value
and stretch the clock in this case.
Signed-off-by: Alexander Sverdlin <alexander.sverdlin@nokia.com>
Acked-by: Sekhar Nori <nsekhar@ti.com>
This patch adjusts spinlock scope to make it wrap the whole irq
handler using a single lock/unlock which covers both master and
slave handlers.
This patch changes the order of enum aspeed_i2c_master_state and
enum aspeed_i2c_slave_state defines to make their initial value to
ASPEED_I2C_MASTER_INACTIVE and ASPEED_I2C_SLAVE_STOP respectively.
In case of multi-master use, if a slave data comes ahead of the
first master xfer, master_state starts from an invalid state so
this change fixes the issue.
There are some log printing without a newline character. This
patch adds the missing newline characters.
The driver supports multiple hardware variants of Exynos I2C controller
which differ in FIFO depth, handling of interrupts and bus recovery in
HSI2C_MASTER_ST_LOSE state.
The difference in variant was a single bit set for Exynos7 variants and
implicit lack of this bit for other variants.
Make each variant explicit which also fixes the GCC warning about
documentation:
drivers/i2c/busses/i2c-exynos5.c:223: warning: Function parameter or member 'hw' not described in 'exynos_hsi2c_variant'
No change in functionality.
Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org>
Reviewed-by: Andrzej Hajda <a.hajda@samsung.com>
When we initialize the pins, make sure it looks like STOP by dividing
the delay into halves. It shouldn't matter because SDA is expected to be
held low by a device, but for super-safety, let's do it.
Reviewed-by: Ulrich Hecht <ulrich.hecht+renesas@gmail.com>
Reviewed-by: Peter Rosin <peda@axentia.se>
Bus recovery should reset the bus with the standard i2c recovery
procedure. Populate the necessary fields so that the standard procedure
can perform the reset.
Signed-off-by: Eddie James <eajames@linux.vnet.ibm.com>
Tested-by: Joel Stanley <joel@jms.id.au>
Since there are many ports per master, each with it's own adapter and
chardev, we need some locking to prevent transfers from changing the
master state while other transfers are in progress.
Execute I2C transfers from the FSI-attached I2C master. Use polling
instead of interrupts as we have no hardware IRQ over FSI.
Add abort procedure for failed transfers. Add engine reset procedure
that is executed during the abort to recover from various fault
conditions.
Add and initialize I2C adapters for each port on the FSI-attached I2C
master. Ports for each master are defined in the devicetree.
Add register definitions for FSI-attached I2C master and functions to
access those registers over FSI. Add an FSI driver so that our I2C bus
is probed up during an FSI scan.
Removes all locking from i2c_smbus_xfer and renames it to __i2c_smbus_xfer,
then adds a new i2c_smbus_xfer function that simply grabs the lock while
calling the unlocked variant.
This is not perfectly equivalent, since i2c_smbus_xfer was callable from
atomic/irq context if you happened to end up emulating SMBus with an I2C
transfer, and that is no longer the case with this patch. It is unknown
(to me) if anything depends on that quirk, but it seems fragile enough to
simply break those cases and require them to call i2c_transfer directly
instead.
While at it, for consistency rename the 2nd to last argument (size) of
the i2c_smbus_xfer declaration to protocol and remove the surplus extern
marker.
While refactoring the routine before, it occurred to me that this will
make the code much easier to understand.
To break out of recovery as early as possible, feed back the bus_free
logic state.
Some IP cores have an internal 'bus free' logic which may be more
advanced than just checking if SDA is high. Add a separate callback to
get this status. Filling it is optional.
