Convert various spin_lock_irqsave() callers to correctly use `unsigned long'
It is possible for i2c_add_adapter() to fail. Several I2C algorithm
drivers ignore that fact. This (compile-tested only) patch fixes them.
Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
Fix recent i2c-ixp4xx compilation breakage. Sorry for overlooking it.
i2c_bit_add_bus() returns -E;
-E != 0 => err = 1
probe fails with positive error code
Signed-off-by: Alexey Dobriyan <adobriyan@openvz.org>
The scx200_acb i2c bus driver pretends to support SMBus block
transactions, but in fact it implements the more simple I2C block
transactions. Additionally, it lacks sanity checks on the length
of the block transactions, which could lead to a buffer overrun.
This fixes an oops reported by Alexander Atanasov:
http://marc.theaimsgroup.com/?l=linux-kernel&m=114970382125094
Thanks to Ben Gardner for fixing my bugs :)
* Nack was sent one byte too late on reads >= 2 bytes.
* Stop bit was set one byte too late on reads.
This patch fixes a bug in the handling of 'ignore' module parameters of I2C
client drivers.
We can't pass a string on the stack to request_region. As soon as we
leave the function that stack is gone and the string is lost. Let's
use the same string we identify the i2c_adapter with instead, it's
more simple, more consistent, and just works.
This is the second half of fix to bug #6445.
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
Fix the bitmasks used when writing to the M41T00 registers.
The original code used a mask of 0x7f when writing to each register,
this is incorrect and probably the result of a copy-paste error. As a
result years from 1980 to 1999 will be read back as 2000 to 2019.
Signed-off-by: David Barksdale <amatus@ocgnet.org>
Acked-by: Jean Delvare <khali@linux-fr.org>
Fix for bug #6395:
Fail to resume on Tecra M2 with ADM1032 and Intel 82801DBM
The BIOS of the Tecra M2 doesn't like it when it has to reboot or
resume after the i2c-i801 driver has left the SMBus in PEC mode.
I have a more complete fix for 2.6.17 but the simple approach of
leaving the SMBus in non-PEC mode after every transaction should do
for -stable. That's what the i2c-i801 driver was doing up to 2.6.15
(inclusive).
Probe and remove methods are now defined at bus level. No more need to
redefine them at driver level in i2c-isa.
This lets us get rid of these annoying messages:
Driver 'it87-isa' needs updating - please use bus_type methods
Thanks to Nicolas Mailhot for reporting the problem and testing the fix.
Use ARRAY_SIZE macro instead of sizeof(x)/sizeof(x[0]). Some trailing
whitespaces are also removed.
Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch>
Cc: Russell King <rmk+kernel@arm.linux.org.uk>
this patch changes MODULE_PARM usage
to module_param in i2c-algo-sibyte.c
Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de>
This patch adds the Intel ICH8 DID to the i2c-i801.c and Kconfig files for I2C
support.
Signed-off-by: Jason Gaston <Jason.d.gaston@intel.com>
Patch from Richard Purdie
This patch adds a check to see if the pxa i2c interface is enabled
before allowing it to be used and resets it if found to be disabled.
This automatically restores the interface if the device has been
suspended and resumed without causing any suspend/resume call ordering
issues.
The patch also fixes a build warning and adds an appropriate module
licence (the module is gpl according to the header).
Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
This is the continuation of the previous patch. This one removes the old
PowerMac i2c drivers (i2c-keywest and i2c-pmac-smu) and replaces them
both with a single stub driver that uses the new PowerMac low i2c layer.
Now that i2c-keywest is gone, the low-i2c code is extended to support
interrupt driver transfers. All i2c busses now appear as platform
devices. Compatibility with existing drivers should be maintained as the
i2c bus names have been kept identical, except for the SMU bus but in
that later case, all users has been fixed.
With that patch added, matching a device node to an i2c_adapter becomes
trivial.
This is the first part of a rework of the PowerMac i2c code. It
completely reworks the "low_i2c" layer. It is now more flexible,
supports KeyWest, SMU and PMU i2c busses, and provides functions to
match device nodes to i2c busses and adapters.
This patch also extends & fix some bugs in the SMU driver related to i2c
support and removes the clock spreading hacks from the pmac feature code
rather than adapting them to the new API since they'll be replaced by
the platform function code completely in patch 3/5
Some ARM platforms have the ability to program the interrupt controller to
detect various interrupt edges and/or levels. For some platforms, this is
critical to setup correctly, particularly those which the setting is dependent
on the device.
Currently, ARM drivers do (eg) the following:
err = request_irq(irq, ...);
set_irq_type(irq, IRQT_RISING);
However, if the interrupt has previously been programmed to be level sensitive
(for whatever reason) then this will cause an interrupt storm.
Hence, if we combine set_irq_type() with request_irq(), we can then safely set
the type prior to unmasking the interrupt. The unfortunate problem is that in
order to support this, these flags need to be visible outside of the ARM
architecture - drivers such as smc91x need these flags and they're
cross-architecture.
Finally, the SA_TRIGGER_* flag passed to request_irq() should reflect the
property that the device would like. The IRQ controller code should do its
best to select the most appropriate supported mode.
This patch unifies udbg for both ppc32 and ppc64 when building the
merged achitecture. xmon now has a single "back end". The powermac udbg
stuff gets enriched with some ADB capabilities and btext output. In
addition, the early_init callback is now called on ppc32 as well,
approx. in the same order as ppc64 regarding device-tree manipulations.
The init sequences of ppc32 and ppc64 are getting closer, I'll unify
them in a later patch.
For now, you can force udbg to the scc using "sccdbg" or to btext using
"btextdbg" on powermacs. I'll implement a cleaner way of forcing udbg
output to something else than the autodetected OF output device in a
later patch.
This is needs to be visible to other architectures using the AMBA
bus and peripherals.
When the i2c-mv64xxx i2c driver is signalled to abort a transaction,
it aborts it immediately by issuing a stop condition on the bus.
This violates the i2c protocol and can cause what appears to be an i2c
bus hang. This patch delays issuing the stop condition until the i2c
device can reasonably expect a stop condition.
Also includes a minor fixup.
Signed-off-by: Mark A. Greer <mgreer@mvista.com>
One more supported PCI ID for the i2c-nforce2 driver.
Add the ibm_iic driver to the HWMON class so it will scan the
bus for connected hardware monitor sensors.
Signed-off-by: Martin Hicks <mort@bork.org>
The removal of I2C_DF_NOTIFY left some out of date comments in the
code. Drop them.
Given that implementing i2c_driver.command is optional, there is no
point in an empty implementation thereof.
Signed-off-by: Laurent Riffard <laurent.riffard@free.fr>
Cc: Michael Geng <linux@MichaelGeng.de>
Cc: Petr Vandrovec <vandrove@vc.cvut.cz>
i2c-dev doesn't use the reference counting logic of struct class_device so move
it to the dynamic method. This makes the code paths simpler and the driver
smaller.
Cc: Jean Delvare <khali@linux-fr.org>
Now that i2c_add_driver() doesn't need the module owner to be set by
hand, we can delete it from the drivers. This patch catches all of the
drivers that I found in the current tree (if a driver sets the .owner by
hand, it's not a problem, just not needed.)
This prevents i2c drivers from messing up and forgetting to set the
module owner of their driver. It also reduces the size of their drivers
by one line :)
We should use the i2c_driver.driver's .name and .owner fields
instead of the i2c_driver's ones.
This patch updates the miscellaneaous i2c chip drivers.
This patch updates the core of the i2c drivers: it removes .name and
.owner fields from the struct i2c_device and modify various
functions to use struct device fields instead.
Do not limit the usage count of i2c clients to 1. In other words,
change the client usage count behavior from the old I2C_CLIENT_ALLOW_USE
to the old I2C_CLIENT_ALLOW_MULTIPLE_USE. The rationale is that no
driver actually needs the limiting behavior, and the unlimiting
behavior is slightly easier to implement.
Update the documentation to reflect this change.
Make I2C_CLIENT_ALLOW_USE the default for all i2c clients. It doesn't
hurt if the usage count is actually never used for any given driver,
and allows for nice code simplifications in i2c-core.
No i2c client uses the I2C_CLIENT_ALLOW_MULTIPLE_USE flag, drop it.
Just about every i2c chip driver sets the I2C_DF_NOTIFY flag, so we
can simply make it the default and drop the flag. If any driver really
doesn't want to be notified when i2c adapters are added, that driver
can simply omit to set .attach_adapter. This approach is also more
robust as it prevents accidental NULL pointer dereferences.
The following patch adds support for the Barco LPT->DVI I2C adapter to
the i2c-parport driver.
Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk>
Remove duplicate of BCD macros.
Signed-off-by: Nicolas Kaiser <nikai@nikai.net>
Add code to handle case where board firmware does not start the
RTC.
CC: James Chapman <jchapman@katalix.com>
This patch tweaks i2c-i801.c so that the driver always sets the SMBAUXCTL
register (which enables/disables PEC) explicitly before each transaction.
It seems that clk_use() and clk_unuse() are additional complexity
which isn't required anymore. Remove them from the clock framework
to avoid the additional confusion which they cause, and update all
ARM machine types except for OMAP.
The busses/i2c-mv64xxx.c driver doesn't currently compile because of an
incorrect argument to dev_err(). This patch fixes that.
This allows us to eliminate the casts in the drivers, and eventually
remove the use of the device_driver function pointer methods for
platform device drivers.
The big i2c-viapro SMBus driver update which went into 2.6.14-git1
introduced a few minor issues. Nothing critical, but I would like a
few adjustments to be merged in to fix the following problems:
* VIA should not be spelled Via.
* Frodo Looijaard and Philip Edelbrock did not write the i2c-viapro
driver.
* When debugging is disabled, half of messages would be logged.
* Drop an unneeded masking.
* Some port reads can be avoided now that the transaction size is
passed as a parameter to vt596_transaction().
* SMBus Receive Byte transactions are used for probing too (for
EEPROMs), so hide errors on these too.
