commit c1c21f4e60ed4523292f1a89ff45a208bddd3849 upstream.
Current -next fails to link an ARM allmodconfig because drivers that use
the core recovery functions can be built as modules but those functions
are not exported:
ERROR: "i2c_generic_gpio_recovery" [drivers/i2c/busses/i2c-davinci.ko] undefined!
ERROR: "i2c_generic_scl_recovery" [drivers/i2c/busses/i2c-davinci.ko] undefined!
ERROR: "i2c_recover_bus" [drivers/i2c/busses/i2c-davinci.ko] undefined!
Add exports to fix this.
Fixes: 5f9296ba21b3c (i2c: Add bus recovery infrastructure)
Signed-off-by: Mark Brown <broonie@kernel.org>
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
commit 9ea359f7314132cbcb5a502d2d8ef095be1f45e4 upstream.
According to I2C specification the NACK should be handled as follows:
"When SDA remains HIGH during this ninth clock pulse, this is defined as the Not
Acknowledge signal. The master can then generate either a STOP condition to
abort the transfer, or a repeated START condition to start a new transfer."
[I2C spec Rev. 6, 3.1.6: http://www.nxp.com/documents/user_manual/UM10204.pdf]
Currently the Davinci i2c driver interrupts the transfer on receipt of a
NACK but fails to send a STOP in some situations and so makes the bus
stuck until next I2C IP reset (idle/enable).
For example, the issue will happen during SMBus read transfer which
consists from two i2c messages write command/address and read data:
S Slave Address Wr A Command Code A Sr Slave Address Rd A D1..Dn A P
<--- write -----------------------> <--- read --------------------->
The I2C client device will send NACK if it can't recognize "Command Code"
and it's expected from I2C master to generate STP in this case.
But now, Davinci i2C driver will just exit with -EREMOTEIO and STP will
not be generated.
Hence, fix it by generating Stop condition (STP) always when NACK is received.
This patch fixes Davinci I2C in the same way it was done for OMAP I2C
commit cda2109a26eb ("i2c: omap: query STP always when NACK is received").
Reviewed-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
Reported-by: Hein Tibosch <hein_tibosch@yahoo.es>
Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com>
commit ccfc866356674cb3a61829d239c685af6e85f197 upstream.
commit 6d9939f651419a63e091105663821f9c7d3fec37 (i2c: omap: split out [XR]DR
and [XR]RDY) changed the way how errata i207 (I2C: RDR Flag May Be Incorrectly
Set) get handled. 6d9939f6514 code doesn't correspond to workaround provided by
errata.
According to errata ISR must filter out spurious RDR before data read not after.
ISR must read RXSTAT to get number of bytes available to read. Because RDR
could be set while there could no data in the receive FIFO.
Restored pre 6d9939f6514 way of handling errata.
Found by code review. Real impact haven't seen.
Tested on Beagleboard XM C.
Signed-off-by: Alexander Kochetkov <al.kochet@gmail.com>
Fixes: 6d9939f651419a63e09110 i2c: omap: split out [XR]DR and [XR]RDY
Tested-by: Felipe Balbi <balbi@ti.com>
Reviewed-by: Felipe Balbi <balbi@ti.com>
commit 27caca9d2e01c92b26d0690f065aad093fea01c7 upstream.
commit 1d7afc95946487945cc7f5019b41255b72224b70 (i2c: omap: ack IRQ in parts)
changed the interrupt handler to complete transfers without clearing
XRDY (AL case) and ARDY (NACK case) flags. XRDY or ARDY interrupts will be
fired again. As a result, ISR keep processing transfer after it was already
complete (from the driver code point of view).
A didn't see real impacts of the 1d7afc9, but it is really bad idea to
have ISR running on user data after transfer was complete.
It looks, what 1d7afc9 violate TI specs in what how AL and NACK should be
handled (see Note 1, sprugn4r, Figure 17-31 and Figure 17-32).
According to specs (if I understood correctly), in case of NACK and AL driver
must reset NACK, AL, ARDY, RDR, and RRDY (Master Receive Mode), and
NACK, AL, ARDY, and XDR (Master Transmitter Mode).
All that is done down the code under the if condition:
if (stat & (OMAP_I2C_STAT_ARDY | OMAP_I2C_STAT_NACK | OMAP_I2C_STAT_AL)) ...
The patch restore pre 1d7afc9 logic of handling NACK and AL interrupts, so
no interrupts is fired after ISR informs the rest of driver what transfer
complete.
Note: instead of removing break under NACK case, we could just replace 'break'
with 'continue' and allow NACK transfer to finish using ARDY event. I found
that NACK and ARDY bits usually set together. That case confirm TI wiki:
http://processors.wiki.ti.com/index.php/I2C_Tips#Detecting_and_handling_NACK
In order if someone interested in the event traces for NACK and AL cases,
I sent them to mailing list.
Fixes: 1d7afc9 i2c: omap: ack IRQ in parts
Acked-by: Felipe Balbi <balbi@ti.com>
Tested-by: Aaro Koskinen <aaro.koskinen@iki.fi>
commit 11cfbfb098b22d3e57f1f2be217cad20e2d48463 upstream.
iowait is for blkio [1]. I2C shouldn't use it.
[1] https://lkml.org/lkml/2014/11/3/317
Acked-by: Ludovic Desroches <ludovic.desroches@atmel.com>
commit 6721f28a26efd6368497abbdef5dcfc59608d899 upstream.
There is a race condition in at91_do_twi_xfer when signals arrive.
If a signal is recieved while waiting for a transfer to complete
wait_for_completion_interruptible_timeout() will return -ERESTARTSYS.
This is not handled correctly resulting in interrupts still being
enabled and a transfer being in flight when we return.
Symptoms include a range of oopses and bus lockups. Oopses can happen
when the transfer completes because the interrupt handler will corrupt
the stack. If a new transfer is started before the interrupt fires
the controller will start a new transfer in the middle of the old one,
resulting in confused slaves and a locked bus.
To avoid this, use wait_for_completion_io_timeout instead so that we
don't have to deal with gracefully shutting down the transfer and
disabling the interrupts.
Signed-off-by: Simon Lindgren <simon@aqwary.com>
commit 75b81f339c6af43f6f4a1b3eabe0603321dade65 upstream.
The driver was not bound checking the received length byte to ensure it was within the
the buffer size that is allocated for SMBus blocks. This resulted in buffer overflows
whenever an invalid length byte was received.
It also failed to ensure the length byte was not zero. If it received zero, it would end up
in an infinite loop as the at91_twi_read_next_byte function returned immediately without
allowing RHR to be read to clear the RXRDY interrupt.
Tested agaisnt a SMBus compliant battery.
Signed-off-by: Marek Roszko <mark.roszko@gmail.com>
commit 28772ac8711e4d7268c06e765887dd8cb6924f98 upstream.
dma_{un}map_* uses 'enum dma_data_direction' not 'enum dma_transfer_direction'.
commit ce78cc071f5f541480e381cc0241d37590041a9d upstream.
Don't unmark the device as suspended until after it's been re-setup.
The main race would be w.r.t. an i2c driver that gets resumed at the same
time (asyncronously), that is allowed to do a transfer since suspended
is set to 0 before reinit, but really should have seen the -EIO return
instead.
Signed-off-by: Doug Anderson <dianders@chromium.org>
Acked-by: Kukjin Kim <kgene.kim@samsung.com>
commit 47bb27e78867997040a228328f2a631c3c7f2c82 upstream.
There have been "i2c_designware 80860F41:00: controller timed out" errors
on a number of Baytrail platforms. The issue is caused by incorrect value in
Interrupt Mask Register (DW_IC_INTR_MASK) when i2c core is being enabled.
This causes call to __i2c_dw_enable() to immediately start the transfer which
leads to timeout. There are 3 failure modes observed:
1. Failure in S0 to S3 resume path
The default value after reset for DW_IC_INTR_MASK is 0x8ff. When we start
the first transaction after resuming from system sleep, TX_EMPTY interrupt
is already unmasked because of the hardware default.
2. Failure in normal operational path
This failure happens rarely and is hard to reproduce. Debug trace showed that
DW_IC_INTR_MASK had value of 0x254 when failure occurred, which meant
TX_EMPTY was unmasked.
3. Failure in S3 to S0 suspend path
This failure also happens rarely and is hard to reproduce. Adding debug trace
that read DW_IC_INTR_MASK made this failure not reproducible. But from ISR
call trace we could conclude TX_EMPTY was unmasked when problem occurred.
The patch masks all interrupts before the controller is enabled to resolve the
faulty DW_IC_INTR_MASK conditions.
Signed-off-by: Wenkai Du <wenkai.du@intel.com>
Acked-by: Mika Westerberg <mika.westerberg@linux.intel.com>
[wsa: improved the comment and removed typo in commit msg]
commit d7653964c590ba846aa11a8f6edf409773cbc492 upstream.
This hardware does not support zero length transfers. Instead, the
driver does one (random) byte transfers currently with undefined results
for the slaves. We now bail out.
Signed-off-by: Wolfram Sang <wsa+renesas@sang-engineering.com>
commit 1b31e9b76ef8c62291e698dfdb973499986a7f68 upstream.
Add Device ID of Intel BayTrail SMBus Controller.
Signed-off-by: Chew, Kean ho <kean.ho.chew@intel.com>
Signed-off-by: Chew, Chiau Ee <chiau.ee.chew@intel.com>
Reviewed-by: Jean Delvare <jdelvare@suse.de>
Cc: "Chang, Rebecca Swee Fun" <rebecca.swee.fun.chang@intel.com>
commit afc659241258b40b683998ec801d25d276529f43 upstream.
This patch adds the SMBus Device IDs for the Intel Wildcat Point-LP PCH.
Signed-off-by: James Ralston <james.d.ralston@intel.com>
commit f39901c1befa556bc91902516a3e2e460000b4a8 upstream.
This patch adds the i801 SMBus Controller DeviceIDs for the Intel Coleto Creek PCH.
Signed-off-by: Seth Heasley <seth.heasley@intel.com>
Cc: "Chan, Wei Sern" <wei.sern.chan@intel.com>
commit 250ad590d6f12d93f4d85be305b0a598d609232e upstream.
Some gpio chips may have get/set operations that
can sleep. gpio_set_value() only works for chips
which do not sleep, for the others we will get a
kernel warning. Using gpio_set_value_cansleep()
will work for both chips that do sleep and those
who don't.
Signed-off-by: Ionut Nicu <ioan.nicu.ext@nsn.com>
Acked-by: Peter Korsgaard <peter.korsgaard@barco.com>
commit 8c0ec2500eeb89749341884a972860d7f9e56f9c upstream.
The i2c-mux driver requires that the chan_id parameter
passed to the i2c_add_mux_adapter() function is equal
to the reg value for that adapter:
for_each_child_of_node(mux_dev->of_node, child) {
ret = of_property_read_u32(child, "reg", ®);
if (ret)
continue;
if (chan_id == reg) {
priv->adap.dev.of_node = child;
break;
The i2c-mux-gpio driver uses an internal logical index
for chan_id when calling i2c_add_mux_adapter() instead
of using the reg value.
Because of this, there will problems in selecting the
right adapter when the i2c-mux-gpio's index into
mux->data.values doesn't match the reg value.
An example of such a case:
mux->data.values = { 1, 0 }
For chan_id = 0, i2c-mux will bind the adapter to the
of_node with reg = <0>, but when it will call the
select() callback with chan_id set to 0, the i2c-mux-gpio
will use it as an index into mux->data.values and it will
actually select the bus with reg = <1>.
Acked-by: Alexander Sverdlin <alexander.sverdlin@nsn.com>
commit bf4169100c909667ede6af67668b3ecce6928343 upstream.
This patch adds code to initialize the DMA buffer to compensate for
possible hardware data corruption.
[wsa: changed to use 'sizeof']
Cc: Jean Delvare <jdelvare@suse.de>
commit 4cdbf7d346e7461c3b93a26707c852e2c9db3753 upstream.
Initially commit cb527ede1bf6ff2008a025606f25344b8ed7b4ac
"i2c-omap: Double clear of ARDY status in IRQ handler"
added a workaround for undocumented errata ProDB0017052.
But then commit 1d7afc95946487945cc7f5019b41255b72224b70
"i2c: omap: ack IRQ in parts" refactored code and missed
one of ARDY clearings. So current code violates errata.
It causes often i2c bus timeouts on my Pandaboard.
This patch adds a second clearing in place.
Signed-off-by: Taras Kondratiuk <taras.kondratiuk@linaro.org>
commit d6e102f498cbcc8dd2e36721a01213f036397112 upstream.
Recently we have been seing some reports about PIO mode not working properly.
- http://www.spinics.net/lists/linux-i2c/msg11985.html
- http://marc.info/?l=linux-i2c&m=137235593101385&w=2
- https://lkml.org/lkml/2013/6/24/430
Let's use DMA mode even for small transfers.
Without this patch, i2c reads the incorrect sgtl5000 version on a mx28evk when
touchscreen is enabled:
[ 5.856270] sgtl5000 0-000a: Device with ID register 0 is not a sgtl5000
[ 9.877307] sgtl5000 0-000a: ASoC: failed to probe CODEC -19
[ 9.883528] mxs-sgtl5000 sound.12: ASoC: failed to instantiate card -19
[ 9.892955] mxs-sgtl5000 sound.12: snd_soc_register_card failed (-19)
[wsa: we have a proper solution for -next, so this non intrusive
solution is OK for now]
Acked-by: Shawn Guo <shawn.guo@linaro.org>
Acked-by: Lucas Stach <l.stach@pengutronix.de>
commit b996ac90f595dda271cbd858b136b45557fc1a57 upstream.
To add AMD CZ SMBus controller device ID.
[bhelgaas: drop pci_ids.h update]
Signed-off-by: Shane Huang <shane.huang@amd.com>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Reviewed-by: Tejun Heo <tj@kernel.org>
Reviewed-by: Jean Delvare <khali@linux-fr.org>
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux
Pull i2c bugfixes from Wolfram Sang:
"These should have been in rc2 but I missed it due to working on devm
longer than expected.
There is one ID addition, since we are touching the driver anyhow.
And the feature bit documentation is one outcome of a debug session
and will make it easier for users to work around problems. The rest
is typical driver bugfixes."
* 'i2c/for-current' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux:
i2c: suppress lockdep warning on delete_device
i2c: mv64xxx: work around signals causing I2C transactions to be aborted
i2c: i801: Document feature bits in modinfo
i2c: designware: add Intel BayTrail ACPI ID
i2c: designware: always clear interrupts before enabling them
i2c: designware: fix RX FIFO overrun
devm_ioremap_resource does sanity checks on the given resource. No need to
duplicate this in the driver.
Acked-by: Barry Song <Baohua.Song@csr.com>
Since commit 846f99749ab68bbc7f75c74fec305de675b1a1bf the following lockdep
warning is thrown in case i2c device is removed (via delete_device sysfs
attribute) which contains subdevices (e.g. i2c multiplexer):
[ INFO: possible recursive locking detected ]
3.8.7-0-sampleversion-fct #8 Tainted: G O
bash/3743 is trying to acquire lock:
(s_active#110){++++.+}, at: [<ffffffff802b3048>] sysfs_hash_and_remove+0x58/0xc8
but task is already holding lock:
(s_active#110){++++.+}, at: [<ffffffff802b3cb8>] sysfs_write_file+0xc8/0x208
Possible unsafe locking scenario:
CPU0
lock(s_active#110);
lock(s_active#110);
*** DEADLOCK ***
May be due to missing lock nesting notation
4 locks held by bash/3743:
#0: (&buffer->mutex){+.+.+.}, at: [<ffffffff802b3c3c>] sysfs_write_file+0x4c/0x208
#1: (s_active#110){++++.+}, at: [<ffffffff802b3cb8>] sysfs_write_file+0xc8/0x208
#2: (&adap->userspace_clients_lock/1){+.+.+.}, at: [<ffffffff80454a18>] i2c_sysfs_delete_device+0x90/0x238
#3: (&__lockdep_no_validate__){......}, at: [<ffffffff803dcc24>] device_release_driver+0x24/0x48
stack backtrace:
Call Trace:
[<ffffffff80575cc8>] dump_stack+0x8/0x34
[<ffffffff801b50fc>] __lock_acquire+0x161c/0x2110
[<ffffffff801b5c3c>] lock_acquire+0x4c/0x70
[<ffffffff802b60cc>] sysfs_addrm_finish+0x19c/0x1e0
[<ffffffff802b7d8c>] sysfs_remove_group+0x64/0x148
[<ffffffff803d990c>] device_remove_attrs+0x9c/0x1a8
[<ffffffff803d9b1c>] device_del+0x104/0x1d8
[<ffffffff803d9c18>] device_unregister+0x28/0x70
[<ffffffff8045505c>] i2c_del_adapter+0x1cc/0x328
[<ffffffff8045802c>] i2c_del_mux_adapter+0x14/0x38
[<ffffffffc025c108>] pca954x_remove+0x90/0xe0 [pca954x]
[<ffffffff804542f8>] i2c_device_remove+0x80/0xe8
[<ffffffff803dca9c>] __device_release_driver+0x74/0xf8
[<ffffffff803dcc2c>] device_release_driver+0x2c/0x48
[<ffffffff803dbc14>] bus_remove_device+0x13c/0x1d8
[<ffffffff803d9b24>] device_del+0x10c/0x1d8
[<ffffffff80454b08>] i2c_sysfs_delete_device+0x180/0x238
[<ffffffff802b3cd4>] sysfs_write_file+0xe4/0x208
[<ffffffff8023ddc4>] vfs_write+0xbc/0x160
[<ffffffff8023df6c>] SyS_write+0x54/0xd8
[<ffffffff8013d424>] handle_sys64+0x44/0x64
The problem is already known for USB and PCI subsystems. The reason is that
delete_device attribute is defined statically in i2c-core.c and used for all
devices in i2c subsystem.
Discussion of original USB problem:
http://lkml.indiana.edu/hypermail/linux/kernel/1204.3/01160.html
Commit 356c05d58af05d582e634b54b40050c73609617b introduced new macro to suppress
lockdep warnings for this special case and included workaround for USB code.
LKML discussion of the workaround:
http://lkml.indiana.edu/hypermail/linux/kernel/1205.1/03634.html
As i2c case is in principle the same, the same workaround could be used here.
Signed-off-by: Alexander Sverdlin <alexander.sverdlin@nsn.com>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
Cc: Eric W. Biederman <ebiederm@xmission.com>
Cc: Tejun Heo <tj@kernel.org>
Do not use interruptible waits in an I2C driver; if a process uses
signals (eg, Xorg uses SIGALRM and SIGPIPE) then these signals can
cause the I2C driver to abort a transaction in progress by another
driver, which can cause that driver to fail. I2C drivers are not
expected to abort transactions on signals.
Duplicate the feature bits documentation in modinfo, as not every user
will read the driver's source code or documentation file.
This is the same controller as on Intel Lynxpoint but the ACPI ID is
different (8086F41). Add support for this.
Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com>
If the I2C bus is put to a low power state by an ACPI method it might pull
the SDA line low (as its power is removed). Once the bus is put to full
power state again, the SDA line is pulled back to high. This transition
looks like a STOP condition from the controller point-of-view which sets
STOP detected bit in its status register causing the driver to fail
subsequent transfers.
Fix this by always clearing all interrupts before we start a transfer.
Cc: stable@kernel.org
i2c_dw_xfer_msg() pushes a number of bytes to transmit/receive
to/from the bus into the TX FIFO.
For master-rx transactions, the maximum amount of data that can be
received is calculated depending solely on TX and RX FIFO load.
This is racy - TX FIFO may contain master-rx data yet to be
processed, which will eventually land into the RX FIFO. This
data is not taken into account and the function may request more
data than the controller is actually capable of storing.
This patch ensures the driver takes into account the outstanding
master-rx data in TX FIFO to prevent RX FIFO overrun.
Signed-off-by: Josef Ahmad <josef.ahmad@linux.intel.com>
Pull removal of GENERIC_GPIO from Grant Likely:
"GENERIC_GPIO now synonymous with GPIOLIB. There are no longer any
valid cases for enableing GENERIC_GPIO without GPIOLIB, even though it
is possible to do so which has been causing confusion and breakage.
This branch does the work to completely eliminate GENERIC_GPIO."
* tag 'gpio-for-linus' of git://git.secretlab.ca/git/linux:
gpio: update gpio Chinese documentation
Remove GENERIC_GPIO config option
Convert selectors of GENERIC_GPIO to GPIOLIB
blackfin: force use of gpiolib
m68k: coldfire: use gpiolib
mips: pnx833x: remove requirement for GENERIC_GPIO
openrisc: default GENERIC_GPIO to false
avr32: default GENERIC_GPIO to false
xtensa: remove explicit selection of GENERIC_GPIO
sh: replace CONFIG_GENERIC_GPIO by CONFIG_GPIOLIB
powerpc: remove redundant GENERIC_GPIO selection
unicore32: default GENERIC_GPIO to false
unicore32: remove unneeded select GENERIC_GPIO
arm: plat-orion: use GPIO driver on CONFIG_GPIOLIB
arm: remove redundant GENERIC_GPIO selection
mips: alchemy: require gpiolib
mips: txx9: change GENERIC_GPIO to GPIOLIB
mips: loongson: use GPIO driver on CONFIG_GPIOLIB
mips: remove redundant GENERIC_GPIO select
Pull ARM SoC device tree updates (part 2) from Arnd Bergmann:
"These are mostly new device tree bindings for existing drivers, as
well as changes to the device tree source files to add support for
those devices, and a couple of new boards, most notably Samsung's
Exynos5 based Chromebook.
The changes depend on earlier platform specific updates and touch the
usual platforms: omap, exynos, tegra, mxs, mvebu and davinci."
* tag 'dt-for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (169 commits)
ARM: exynos: dts: cros5250: add EC device
ARM: dts: Add sbs-battery for exynos5250-snow
ARM: dts: Add i2c-arbitrator bus for exynos5250-snow
ARM: dts: add mshc controller node for Exynos4x12 SoCs
ARM: dts: Add chip-id controller node on Exynos4/5 SoC
ARM: EXYNOS: Create virtual I/O mapping for Chip-ID controller using device tree
ARM: davinci: da850-evm: add SPI flash support
ARM: davinci: da850: override SPI DT node device name
ARM: davinci: da850: add SPI1 DT node
spi/davinci: add DT binding documentation
spi/davinci: no wildcards in DT compatible property
ARM: dts: mvebu: Convert mvebu device tree files to 64 bits
ARM: dts: mvebu: introduce internal-regs node
ARM: dts: mvebu: Convert all the mvebu files to use the range property
ARM: dts: mvebu: move all peripherals inside soc
ARM: dts: mvebu: fix cpus section indentation
ARM: davinci: da850: add EHRPWM & ECAP DT node
ARM/dts: OMAP3: fix pinctrl-single configuration
ARM: dts: Add OMAP3430 SDP NOR flash memory binding
ARM: dts: Add NOR flash bindings for OMAP2420 H4
This is support for the ARM Chromebook, originally scheduled
as a "late" pull request. Since it's already late now, we
can combine this into the existing next/dt2 branch.
* late/dt:
Pull i2c changes from Wolfram Sang:
- an arbitration driver. While the driver is quite simple, it caused
discussion if we need additional arbitration on top of the one
specified in the I2C standard. Conclusion is that I accept a few
generic mechanisms, but not very specific ones.
- the core lost the detach_adapter() call. It has no users anymore and
was in the way for other cleanups. attach_adapter() is sadly still
there since there are users waiting to be converted.
- the core gained a bus recovery infrastructure. I2C defines a way to
recover if the data line is stalled. This mechanism is now in the
core and drivers can now pass some data to make use of it.
- bigger driver cleanups for designware, s3c2410
- removing superfluous refcounting from drivers
- removing Ben Dooks as second maintainer due to inactivity. Thanks
for all your work so far, Ben!
- bugfixes, feature additions, devicetree fixups, simplifications...
* 'i2c/for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: (38 commits)
i2c: xiic: must always write 16-bit words to TX_FIFO
i2c: octeon: use HZ in timeout value
i2c: octeon: Fix i2c fail problem when a process is terminated by a signal
i2c: designware-pci: drop superfluous {get|put}_device
i2c: designware-plat: drop superfluous {get|put}_device
i2c: davinci: drop superfluous {get|put}_device
MAINTAINERS: Ben Dooks is inactive regarding I2C
i2c: mux: Add i2c-arb-gpio-challenge 'mux' driver
i2c: at91: convert to dma_request_slave_channel_compat()
i2c: mxs: do error checking and handling in PIO mode
i2c: mxs: remove races in PIO code
i2c-designware: switch to use runtime PM autosuspend
i2c-designware: use usleep_range() in the busy-loop
i2c-designware: enable/disable the controller properly
i2c-designware: use dynamic adapter numbering on Lynxpoint
i2c-designware-pci: use managed functions pcim_* and devm_*
i2c-designware-pci: use dev_err() instead of printk()
i2c-designware: move to managed functions (devm_*)
i2c: remove CONFIG_HOTPLUG ifdefs
i2c: s3c2410: Add SMBus emulation for block read
Pull trivial tree updates from Jiri Kosina:
"Usual stuff, mostly comment fixes, typo fixes, printk fixes and small
code cleanups"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (45 commits)
mm: Convert print_symbol to %pSR
gfs2: Convert print_symbol to %pSR
m32r: Convert print_symbol to %pSR
iostats.txt: add easy-to-find description for field 6
x86 cmpxchg.h: fix wrong comment
treewide: Fix typo in printk and comments
doc: devicetree: Fix various typos
docbook: fix 8250 naming in device-drivers
pata_pdc2027x: Fix compiler warning
treewide: Fix typo in printks
mei: Fix comments in drivers/misc/mei
treewide: Fix typos in kernel messages
pm44xx: Fix comment for "CONFIG_CPU_IDLE"
doc: Fix typo "CONFIG_CGROUP_CGROUP_MEMCG_SWAP"
mmzone: correct "pags" to "pages" in comment.
kernel-parameters: remove outdated 'noresidual' parameter
Remove spurious _H suffixes from ifdef comments
sound: Remove stray pluses from Kconfig file
radio-shark: Fix printk "CONFIG_LED_CLASS"
doc: put proper reference to CONFIG_MODULE_SIG_ENFORCE
The TX_FIFO register is 10 bits wide. The lower 8 bits are the data to be
written, while the upper two bits are flags to indicate stop/start.
The driver apparently attempted to optimize write access, by only writing a
byte in those cases where the stop/start bits are zero. However, we have
seen cases where the lower byte is duplicated onto the upper byte by the
hardware, which causes inadvertent stop/starts.
This patch changes the write access to the transmit FIFO to always be 16 bits
wide.
Signed off by: Steven A. Falco <sfalco@harris.com>
HZ based value is better than a magic number.
Signed-off-by: Eunbong Song <eunb.song@samsung.com>
I've been debugging the abnormal operation of i2c on octeon. If a process is
terminated by signal in the middle of i2c operation, next i2c read operation
which is done by another process was failed. So i changed to ignore signal in
the middle of i2c operation. After that the problem was not reproduced.
Driver core already takes care of refcounting, no need to do this on
driver level again.
Tested-by: Mika Westerberg <mika.westerberg@linux.intel.com>
driver level again.
driver level again.
Tested-by: Sekhar Nori <nsekhar@ti.com>
The i2c-arb-gpio-challenge driver implements an I2C arbitration scheme
where masters need to claim the bus with a GPIO before they can start
a transaction. This should generally only be used when standard I2C
multimaster isn't appropriate for some reason (errata/bugs).
This driver is based on code that Simon Glass added to the i2c-s3c2410
driver in the Chrome OS kernel 3.4 tree. The current incarnation as a
mux driver is as suggested by Grant Likely. See
<https://patchwork.kernel.org/patch/1877311/> for some history.
Signed-off-by: Naveen Krishna Chatradhi <ch.naveen@samsung.com>
Acked-by: Olof Johansson <olof@lixom.net>
GENERIC_GPIO is now equivalent to GPIOLIB and features that depended on
GENERIC_GPIO can now depend on GPIOLIB to allow removal of this option.
Signed-off-by: Alexandre Courbot <acourbot@nvidia.com>
Use generic DMA DT helper. Platforms booting with or without DT populated are
both supported.
Signed-off-by: Ludovic Desroches <ludovic.desroches@atmel.com>
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
In PIO mode we can end up with the same errors as in DMA mode, but as IRQs
are disabled there we have to check for them manually after each command.
Also don't use the big controller reset hammer when receiving a NAK from a
slave. It's sufficient to tell the controller to continue at a clean state.
Signed-off-by: Lucas Stach <l.stach@pengutronix.de>
Tested-by: Marek Vasut <marex@denx.de>
This commit fixes the three following races in PIO code:
- The CTRL0 register is racy in itself, when programming transfer state and
run bit in the same cycle the hardware sometimes ends up using the state
from the last transfer. Fix this by programming state in one cycle, make
sure the write is flushed down APBX bus by reading back the reg and only
then trigger the run bit.
- Only clear the DMAREQ bit in DEBUG0 after the read/write to the data reg
happened. Otherwise we are racing with the hardware about who touches
the data reg first.
- When checking for completion of a transfer it's not sufficient to check
if the data engine finished, but also a check for i2c bus idle is needed.
In PIO mode we are really fast to program the next transfer after a finished
one, so the controller possibly tries to start a new transfer while the
clkgen engine is still busy writing the NAK/STOP from the last transfer to
the bus.
Using autosuspend helps to reduce the resume latency in situations where
another I2C message is going to be started soon. For example with HID over
I2C touch panels we get several messages in a short period of time while
the touch panel is in use.
This is not an atomic context so there is no need to use mdelay() but
instead use usleep_range().
The correct way to disable or enable the controller is to wait until the
DW_IC_ENABLE_STATUS register bit matches the bit we program into DW_IC_ENABLE
register. This procedure is described in the DesignWare I2C databook.
By doing this we can be sure that the controller is in correct state once
the function returns.
It is not good idea to mix static and dynamic I2C adapter numbering. In
this particular case on Lynxpoint we had graphics I2C adapter which took
the first numbers preventing the designware I2C driver from using the
adapter numbers it preferred.
Since Lynxpoint support was just introduced and there is no hardware available
outside Intel we can fix this by switching to use dynamic adapter numbering
instead of static.
This makes the error handling much more simpler than open-coding everything
and in addition makes the probe function smaller an tidier.
With dev_err() we can get the device instance printed as well and is pretty
much standard to use dev_* macros in the drivers anyway. In addition
correct the indentation of probe() arguments.
