It is unnecessary to calculate and update i2c divider during
every transaction. Only do it if current i2c clock is different
with the previous clock frequency.
Signed-off-by: Fugang Duan <B38611@freescale.com>
Kernel crash log:
Unable to handle kernel NULL pointer dereference at
virtual address 00000001 pgd = d02ec000
[00000001] *pgd=00000000
Internal error: Oops: 1 [#1] PREEMPT SMP
Modules linked in:
CPU: 0 Not tainted (3.0.35-05332-ga7a1dec-dirty #38)
PC is at i2c_imx_probe+0xdc/0x434
LR is at i2c_imx_xfer+0x53c/0x75c
pc : [<c002645c>] lr : [<c03b1e98>] psr: 20000013
sp : d41c3dd8 ip : 00000001 fp : 00000001
r10: 00000001 r9 : ffff8fcc r8 : d41c3e48
r7 : c08f4dc0 r6 : 00000001 r5 : d41c3e48 r4 : d447f000
r3 : d417cbe0 r2 : 00000001 r1 : 000186a0 r0 : d447f000
Flags:nzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel
Process kworker/0:3 (pid: 1254, stack limit = 0xd41c22f0)
Stack: (0xd41c3dd8 to 0xd41c4000)
3dc0: 00000000
I2C driver call the function "static void __init i2c_imx_set_clk()"
in runtime, the function is linked to init.text section, and don't
be used after kernel bootup. Remove the "__init" statement to fix
the issue.
Currently on Arik/Rigel, the I2C clk is from IPG_PERCLK which is
sourced from IPG_CLK. Under normal operation, ipg_perclk is at 22MHz
so that we can get 400KHz i2c speed. In low bus freq mode, IPG_CLK is
at 12MHz and IPG_PERCLK is down to 4MHz.
So the I2C driver must update the divider register for each transaction.
i2c device (isl29023) can not suspend once during hdmi
audio suspend/resume test, and print log:
pm_op(): i2c_device_pm_suspend+0x0/0x38 returns -4 PM: Device
2-0044 failed to suspend: error -4 PM: Some devices failed to
suspend PM: resume of devices complete after 40.936 msecs
Restarting tasks ... done.
Because suspend function in isl29023 driver requires i2c bus
to write isl29023 device. I2C apdater driver process any signal
as exception during waiting the bus idle, so once user space sent
out signal during suspend, I2C device cannot request bus.
Using "fatal_signal_pending()" instead of "signal_pending()"
to avoid the waiting of bus idle to be terminated by general
signals except SIGKILL. After the change, i2c adapter can be
terminated by kill signal from user space with "CTRL+C" or
kill command operation.
commit 9868a060ccf769c08ec378a9829137e272e9a92c upstream.
The freed IRQ is not necessary the one requested in probe.
Even if it was, with two or more i2c-controllers it will fails anyway.
Signed-off-by: Marcus Folkesson <marcus.folkesson@gmail.com>
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
commit 6c557cfee08751d22aed34840f389b846f0f4508 upstream.
In the driver's suspend function, clk_enable() was used instead of
clk_disable(). This is corrected with this patch.
Signed-off-by: Roland Stigge <stigge@antcom.de>
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
[wsa: reworded commit header slightly]
commit 8ee161ce5e0cfc689eb677f227a6248191165fac upstream.
When the system is under heavy load, there can be a significant delay
between the getscl() and time_after() calls inside sclhi(). That delay
may cause the time_after() check to trigger after SCL has gone high,
causing sclhi() to return -ETIMEDOUT.
To fix the problem, double check that SCL is still low after the
timeout has been reached, before deciding to return -ETIMEDOUT.
Signed-off-by: Ville Syrjala <syrjala@sci.fi>
commit 844990daa2e69a4258049ba9c2bae1180657dac3 upstream.
The hardware generates an interrupt for every completed command in the
queue while the code assumed that it will only generate one interrupt
when the queue is empty. So, explicitly check if the queue is really
empty. This patch fixed problems which occurred due to high traffic on
the bus. While we are here, move the completion-initialization after the
parameter error checking.
Cc: Shawn Guo <shawn.guo@linaro.org>
Cc: Marek Vasut <marek.vasut@gmail.com>
Cc: Lothar Waßmann <LW@KARO-electronics.de>
commit ff35e8b18984ad2a82cbd259fc07f0be4b34b1aa upstream.
This patch modified the setting value of
I2C Bus Transfer Rate Setting Counter regisrer.
Signed-off-by: Toshiharu Okada <toshiharu-linux@dsn.okisemi.com>
Signed-off-by: Ben Dooks <ben-linux@fluff.org>
commit 2727b1753934e154931d6b3bdf20c9b2398457a2 upstream.
Correct OMAP_I2C_SYSC_REG offset in omap4 register map.
Offset 0x20 is reserved and OMAP_I2C_SYSC_REG has 0x10 as offset.
Signed-off-by: Alexander Aring <a.aring@phytec.de>
[khilman@ti.com: minor changelog edits]
Signed-off-by: Kevin Hilman <khilman@ti.com>
commit 7c1f59c9d5caf3a84f35549b5d58f3c055a68da5 upstream.
When adding checks for ACPI resource conflicts to many bus drivers,
not enough attention was paid to the error paths, and for several
drivers this causes 0 to be returned on error in some cases. Fix this
by properly returning a non-zero value on every error.
commit cc6bcf7d2ec2234e7b41770185e4dc826390185e upstream.
The wrong bits were put on the wire, fix that.
This fixes kernel bug #42562.
Signed-off-by: Sheng-Hui J. Chu <jeffchu@broadcom.com>
* 'for-30-rc5/all-i2c' of git://git.fluff.org/bjdooks/linux:
i2c-bfin-twi: abort transfer is MEM bit is reset unexpectedly
i2c-s3c2410: Remove useless break code
i2c-s3c2410: Fix typo 'i2s' -> 'i2c'
i2c: tegra: Assign unused slave address
pca954x power-on default is channel 0 connected. If multiple pca954x
muxes are connected to the same physical I2C bus, the parent bus will
see channel 0 devices behind both muxes by default. This is bad.
Scenario:
-- pca954x @ 0x70 -- ch 0 (I2C-bus-101) -- EEPROM @ 0x50
I2C-bus-1 ---
-- pca954x @ 0x71 -- ch 0 (I2C-bus-111) -- EEPROM @ 0x50
1. Load I2C bus driver: creates I2C-bus-1
2. Load pca954x driver: creates virtual I2C-bus-101 and I2C-bus-111
3. Load eeprom driver
4. Try to read EEPROM @ 0x50 on I2C-bus-101. The transaction will also bleed
onto I2C-bus-111 because pca954x @ 0x71 channel 0 is connected by default.
Fix: Initialize pca954x to disconnected state in pca954x_probe()
Signed-off-by: Petri Gynther <pgynther@google.com>
Cc: stable@kernel.org
* Print all error and information messages even when debugging is
disabled.
* Don't use adapter device to log messages before it is ready.
'for-30-rc4/i2c-s3c' and 'for-30-rc4/i2c-tegra' into for-30-rc5/all-i2c
Sometimes, the first I2C transmit interrupt is not serviced in time (like
when higher priority interrupts take too long). Since the RESTART bit is
not set before the next I2C clock, when the TWI handler is finally called,
the I2C session is aborted (MEM bit is reset) and both SMITSERV and MCOMP
int status bits are set.
So when this happens, abort the transfer.
Reported-by: Isabelle Leonardi <i.leonardi@detracom.fr>
Signed-off-by: Sonic Zhang <sonic.zhang@analog.com>
Signed-off-by: Jonghwan Choi <jhbird.choi@samsung.com>
Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
Signed-off-by: Huisung Kang <hs1218.kang@samsung.com>
On Tegra, we should always use the "new" I2C slave controller, to avoid
issues with the old controller. This was implemented in commit 65a1a0a
"i2c: tegra: Enable new slave mode."
There is currently no driver for the Tegra I2C slave controller upstream.
Additionally, the controller cannot be completely disabled. Instead, we
need to:
a) Set I2C_SL_CNFG_NACK to make the controller automatically NACK any
incoming transactions.
b) The controller's definition of NACK isn't identical to the I2C
protocol's definition. Specifically, it will perform a standard NACK, but
*also* continue to hold the clock line low in expectation of receiving
more data. This can hang the bus, or at least cause transaction timeouts,
if something starts a transaction that matches the controller's slave
address. Since the default address is 0x00, the general call address,
this does occur in practice.
To avoid this, we explicitly program a slave address that is reserved for
future expansion. For current boards, this guarantees the address will
never be used. If a future board ever needs to use this address, we can
add platform data to determine a board-specific safe address. 0xfc is
picked by this patch.
This patch is based on a change previously posted by: Wei Ni <wni@nvidia.com>
http://www.spinics.net/lists/linux-i2c/msg05437.html
In turned based on internal changes by: Bharat Nihalani <bnihalani@nvidia.com>
A semantically equivalent change has been contained in the various
ChromeOS kernels for a while.
I tested this change on top of 3.0-rc2 on Harmony, and interacted with
the WM8903 I2C-based audio codec.
With the addition of a device platform mfd_cell pointer, MFD drivers
can go back to passing platform data back to their sub drivers.
This allows for an mfd_cell->mfd_data removal and thus keep the
sub drivers MFD agnostic. This is mostly needed for non MFD aware
sub drivers.
Acked-by: Richard Röjfors <richard.rojfors@pelagicore.com>
* 'for-linus/2640/i2c' of git://git.fluff.org/bjdooks/linux: (21 commits)
mach-ux500: set proper I2C platform data from MOP500s
i2c-nomadik: break out single messsage transmission
i2c-nomadik: reset the hw after status check
i2c-nomadik: remove the unnecessary delay
i2c-nomadik: change the TX and RX threshold
i2c-nomadik: add code to retry on timeout failure
i2c-nomadik: use pm_runtime API
i2c-nomadik: print abort cause only on abort tag
i2c-nomadik: correct adapter timeout initialization
i2c-nomadik: remove the redundant error message
i2c-nomadik: corrrect returned error numbers
i2c-nomadik: fix speed enumerator
i2c-nomadik: make i2c timeout specific per i2c bus
i2c-nomadik: add regulator support
i2c: i2c-sh_mobile bus speed platform data V2
i2c: i2c-sh_mobile clock string removal
i2c-eg20t: Support new device ML7223 IOH
i2c: tegra: Add de-bounce cycles.
i2c: tegra: fix repeated start handling
i2c: tegra: recover from spurious interrupt storm
'for-2639/i2c-tegra' and 'for-2639/i2c-nomadik2' into for-linus/2640/i2c
Reduce code size in the message transfer function by factoring out
a single-message transfer function.
In case of I2C timeout, reset the HW only after the HW status
is read, otherwise the staus will be lost.
Signed-off-by: Virupax Sadashivpetimath <virupax.sadashivpetimath@stericsson.com>
Reviewed-by: Jonas Aberg <jonas.aberg@stericsson.com>
Reviewed-by: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com>
The delay in the driver seems to be not needed, so remove it.
Reviewed-by: Markus Grape <markus.grape@stericsson.com>
Tested-by: Per Persson <per.xb.persson@stericsson.com>
Tested-by: Chethan Krishna N <chethan.krishna@stericsson.com>
1) Increase RX FIFO threshold so that there is a reduction in
the number of interrupts handled to complete a transaction.
2) Fill TX FIFO in the write function.
It is seen that i2c-nomadik controller randomly stops generating the
interrupts leading to a i2c timeout. As a workaround to this problem,
add retries to the on going transfer on failure.
Reviewed-by: Jonas ABERG <jonas.aberg@stericsson.com>
Use the pm_runtime API for pins control.
Signed-off-by: Rabin Vincent <rabin.vincent@stericsson.com>
[deleted some surplus runtime PM code]
Modify the code to:
1)Print the cause of i2c failure only if the status is set to ABORT.
2)Print slave address on send/receive fail, will help in which slave
failed.
Correct the incorrect initialization of adapter timeout not to be
in milliseconds, as it needs to be done in jiffies.
The abort cause string itself is an error, so remove the redundant
explicit error message.
Signed-off-by: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com>
The code was returning bad error numbers or just -1 in some cases.
Add option to have different i2c timeout delay for different i2c buses
specified in platform data. Default to the old value unless specified.
This on-chip I2C controller needs to fetch the regulator
representing its voltage domain so that it won't be switched off.
Signed-off-by: Jonas Aberg <jonas.aberg@stericsson.com>
* Fix white space.
* Rename labels to something meaningful.
* Prefix defines with PORT_ to avoid collision with macros from
<linux/parport.h>.
* Add const markers where possible.
Don't let other driver config options influence us, as it makes the
code more complex and fragile for a small benefit. There's nothing
wrong with instantiating I2C devices even if they don't have a driver.
And we're talking about 835 extra bytes in the binary on x86-64,
that's hardly worth arguing about.
Cc: David Woodhouse <david.woodhouse@intel.com>
Cc: Hans de Goede <hdegoede@redhat.com>
Scanning the BIOS memory for the apanel information is costly, so
avoid doing it on non-Fujitsu machines.
I don't know if Fujitsu is ever going to produce Patsburg-based
machines, but if they do, I'd rather not probe the secondary (IDF)
SMBus channels. At least not until we have a good reason for doing so.
On a side note, I'm not even sure if it is right to enable detection
of HWMON and DDC devices on the IDF channels. Time will tell...
Acked-by: Hans de Goede <hdegoede@redhat.com>
Acked-by: David Woodhouse <David.Woodhouse@intel.com>
This patch adds the SMBus controller DeviceID for the Intel Panther Point PCH.
Signed-off-by: Seth Heasley <seth.heasley@intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6
* 'sh-latest' of git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: (23 commits)
sh: Ignore R_SH_NONE module relocations.
SH: SE7751: Fix pcibios_map_platform_irq prototype.
sh: remove warning and warning_symbol from struct stacktrace_ops
sh: wire up sys_sendmmsg.
clocksource: sh_tmu: Runtime PM support
clocksource: sh_tmu: __clocksource_updatefreq_hz() update
clocksource: sh_cmt: Runtime PM support
clocksource: sh_cmt: __clocksource_updatefreq_hz() update
dmaengine: shdma: synchronize RCU before freeing, simplify spinlock
dmaengine: shdma: add runtime- and system-level power management
dmaengine: shdma: fix locking
sh: sh-sci: sh7377 and sh73a0 build fixes
sh: cosmetic improvement: use an existing pointer
serial: sh-sci: suspend/resume wakeup support V2
serial: sh-sci: Runtime PM support
sh: select IRQ_FORCED_THREADING.
sh: intc: Set virtual IRQs as nothread.
sh: fixup fpu.o compile order
i2c: add a module alias to the sh-mobile driver
ALSA: add a module alias to the FSI driver
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6
* 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: (27 commits)
PCI: Don't use dmi_name_in_vendors in quirk
PCI: remove unused AER functions
PCI/sysfs: move bus cpuaffinity to class dev_attrs
PCI: add rescan to /sys/.../pci_bus/.../
PCI: update bridge resources to get more big ranges when allocating space (again)
KVM: Use pci_store/load_saved_state() around VM device usage
PCI: Add interfaces to store and load the device saved state
PCI: Track the size of each saved capability data area
PCI/e1000e: Add and use pci_disable_link_state_locked()
x86/PCI: derive pcibios_last_bus from ACPI MCFG
PCI: add latency tolerance reporting enable/disable support
PCI: add OBFF enable/disable support
PCI: add ID-based ordering enable/disable support
PCI hotplug: acpiphp: assume device is in state D0 after powering on a slot.
PCI: Set PCIE maxpayload for card during hotplug insertion
PCI/ACPI: Report _OSC control mask returned on failure to get control
x86/PCI: irq and pci_ids patch for Intel Panther Point DeviceIDs
PCI: handle positive error codes
PCI: check pci_vpd_pci22_wait() return
PCI: Use ICH6_GPIO_EN in ich6_lpc_acpi_gpio
Fix up trivial conflicts in include/linux/pci_ids.h: commit a6e5e2be4461
moved the intel SMBUS ID definitons to the i2c-i801.c driver.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
b43: fix comment typo reqest -> request
Haavard Skinnemoen has left Atmel
cris: typo in mach-fs Makefile
Kconfig: fix copy/paste-ism for dell-wmi-aio driver
doc: timers-howto: fix a typo ("unsgined")
perf: Only include annotate.h once in tools/perf/util/ui/browsers/annotate.c
md, raid5: Fix spelling error in comment ('Ofcourse' --> 'Of course').
treewide: fix a few typos in comments
regulator: change debug statement be consistent with the style of the rest
Revert "arm: mach-u300/gpio: Fix mem_region resource size miscalculations"
audit: acquire creds selectively to reduce atomic op overhead
rtlwifi: don't touch with treewide double semicolon removal
treewide: cleanup continuations and remove logging message whitespace
ath9k_hw: don't touch with treewide double semicolon removal
include/linux/leds-regulator.h: fix syntax in example code
tty: fix typo in descripton of tty_termios_encode_baud_rate
xtensa: remove obsolete BKL kernel option from defconfig
m68k: fix comment typo 'occcured'
arch:Kconfig.locks Remove unused config option.
treewide: remove extra semicolons
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 into sh-latest
Haavard's e-mail address at Atmel is no longer valid.
Acked-by: Havard Skinnemoen <hskinnemoen@gmail.com>
Commit b826291c, "drivercore/dt: add a match table pointer to struct
device" added an of_match pointer to struct device to cache the
of_match_table entry discovered at driver match time. This was unsafe
because matching is not an atomic operation with probing a driver. If
two or more drivers are attempted to be matched to a driver at the
same time, then the cached matching entry pointer could get
overwritten.
This patch reverts the of_match cache pointer and reworks all users to
call of_match_device() directly instead.
alg_data is already a pointer which must be passed directly.
Reported-by: Dieter Ripp <ripp@systecnet.com>
Cc: Ben Dooks <ben-i2c@fluff.org>
Add support to the i2c-sh_mobile driver for setting
the I2C bus speed using platform data.
Signed-off-by: Magnus Damm <damm@opensource.se>
Remove the clock string magic from the i2c-sh_mobile driver
now when all platforms support clkdev properly.
Support new device OKI SEMICONDUCTOR ML7223 IOH(Input/Output Hub).
The ML7223 IOH is for MP(Media Phone) use.
The ML7223 is companion chip for Intel Atom E6xx series.
The ML7223 is completely compatible for Intel EG20T PCH.
Signed-off-by: Tomoya MORINAGA <tomoya-linux@dsn.okisemi.com>
