Fix file references in drivers/ide/
There are a lot of file references to now moved or deleted files in the
whole tree, especially in documentation and Kconfig files. This patch
fixes the references in drivers/ide/.
Signed-off-by: Johann Felix Soden <johfel@users.sourceforge.net>
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
The meaning of CONFIG_EMBEDDED has long since been obsoleted; the option
is used to configure any non-standard kernel with a much larger scope than
only small devices.
This patch renames the option to CONFIG_EXPERT in init/Kconfig and fixes
references to the option throughout the kernel. A new CONFIG_EMBEDDED
option is added that automatically selects CONFIG_EXPERT when enabled and
can be used in the future to isolate options that should only be
considered for embedded systems (RISC architectures, SLOB, etc).
Calling the option "EXPERT" more accurately represents its intention: only
expert users who understand the impact of the configuration changes they
are making should enable it.
Reviewed-by: Ingo Molnar <mingo@elte.hu>
Acked-by: David Woodhouse <david.woodhouse@intel.com>
Signed-off-by: David Rientjes <rientjes@google.com>
Cc: Greg KH <gregkh@suse.de>
Cc: Robin Holt <holt@sgi.com>
Cc: <linux-arch@vger.kernel.org>
The current Kconfig text for CONFIG_IDE doesn't give a hint to users that this
subsystem is currently in maintenance mode and isn't actively developed.
Let's correct this by marking it as deprecated, and also get rid of a bunch of
unnecessary text that doesn't really have anything to do with what the option is
for.
Signed-off-by: Robert Hancock <hancockrwd@gmail.com>
.ko is normally not included in Kconfig help, make it consistent.
Signed-off-by: Pavel Machek <pavel@ucw.cz>
No reason to need IDE built-in to be able to compile pmac driver.
Tested to work on 2.6.29-rc8 and 2.6.28.8 with ide and pmac as modules
inside an initramfs.
Signed-off-by: Gilles Espinasse <g.esp@free.fr>
Cc: sam@ravnborg.org
Cc: benh@kernel.crashing.org
[bart: remove now superfluous IDE check]
Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
Nowadays it is not worth having a separate config option for
Amiga IDE Doubler support so always include it (it still needs
to be explicitly enabled by module parameter).
There is no need for a separate ide_arm host driver nowadays
so merge it into ide_generic one.
While at it:
- return -EBUSY from ide_generic_init() if I/O resources are busy
- scale down ide_generic_check_pci_legacy_iobases() for CONFIG_PCI=n
Cc: Alexander Schulz <alex@shark-linux.de>
* Move xfer mode tuning code to ide-xfer-mode.c.
* Add CONFIG_IDE_XFER_MODE config option to be selected by host drivers
that support xfer mode tuning.
* Add CONFIG_IDE_XFER_MODE=n static inline versions of ide_set_pio()
and ide_set_xfer_rate().
* Make IDE_TIMINGS and BLK_DEV_IDEDMA config options select IDE_XFER_MODE,
also add explicit selects for few host drivers that need it.
* Build/link ide-xfer-mode.o and ide-pio-blacklist.o (it is needed only
by ide-xfer-mode.o) only if CONFIG_IDE_XFER_MODE=y.
This is IDE host driver for AT91 (SAM9, CAP9, AT572D940HF) Static Memory
Controller with Compact Flash True IDE Mode logic.
Driver have to switch 8/16 bit bus width when accessing Task Tile or Data
Register. Moreover some extra things need to be done when setting PIO mode.
Only PIO mode is used, hardware have no DMA support. If interrupt line is
connected through GPIO extra quirk is needed to cope with fake interrupts.
Signed-off-by: Stanislaw Gruszka <stf_xl@wp.pl>
Cc: Andrew Victor <avictor.za@gmail.com>
Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com>
Documentation/kernel-parameters.txt
- ide=nodma is no longer valid.
drivers/ide/Kconfig
- The module is ide-core.ko not ide.
drivers/ide/ide.c
- It took me a while to figure out what the arguments %d.%d:%d to nodma
module parameter ment, so I added a comment to each.
- Added a comment to each of the sscanf lines.
- There is a bug, if j is 0 it would previously clear all the other bits
except the current device, changed in three different places.
mask &= (1 << i) should be mask &= ~(1 << i).
Signed-off-by: David Fries <david@fries.net>
[bart: s/disk/device/ in ide.c, beautify patch description]
This is a port of libata's pata_cs5536.c (written by Martin K. Petersen)
to IDE subsystem.
Changes done while at it:
* Reprogram PIO/MWDMA timings if needed before and after DMA transfer
(chipset uses shared PIO/MWDMA timings).
* Fix cable detection to report 80-wires cable if BIOS set it for any
device on a port (IDE core will do drive-side cable detection later).
* Don't disable UDMA while programming PIO timings.
* Simplify PCI/MSR support.
Pros of having IDE host driver in addition to libata's one:
* IDE is much lighter than SCSI+libata, the host driver itself is also
a bit smaller:
1261 496 4 1761 6e1 drivers/ata/pata_cs5536.o
1242 128 4 1374 55e drivers/ide/cs5536.o
* This allows use of IDE features which are unavailable under libata.
v2:
* Fixes per review from Sergei:
- simplify dependency check in Kconfig
- use IDE_DRV_MASK also for ->drive_data
- disable UDMA when programming MWDMA
- program new DTC timings only when necessary
- fix printk() level in cs5536_init_one()
* Fix patch description according to comments from Alan and Sergei.
v3:
* Smarter masking of UDMA bits per Sergei's suggestion.
Cc: Martin K. Petersen <mkp@mkp.net>
Cc: Karl Auerbach <karl@iwl.com>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Support for the IT8172 IDE controller was removed from the kernel
sometime after 2.6.18. Support for the only boards that used the IT8172
was removed from the kernel after 2.6.18, as they had never compiled
since 2.6.0. However, there are a couple of platforms that use this
chip: the PMC-Sierra Xiao Hu thin-client computer, which is no longer
in production, and the Linksys NSS4000 Network Attached Storage box,
which is based on the Xiao Hu board. I am attempting to add support
for the Xiao Hu to the kernel, and this IT8172 IDE controller is the
first bit of code in this effort.
This patch resurrects the IT8172 IDE controller code. I began with
the 2.6.18 version of the it8172.c file, and have moved it forward so
that it works with the latest version of the kernel. I have run this
driver on a PMC-Sierra Xiao Hu board with the 2.6.28 kernel, and
I have had no problems with it in my configuration. The attached patch
applies cleanly against 2.6.28.
Signed-off-by: Shane McDonald <mcdonald.shane@gmail.com>
Cc: alan@lxorguk.ukuu.org.uk
[bart: s/HWIF(drive)/drive->hwif/]
... by factoring it out of ide_cd_do_request() into a helper, as suggested by
Bart.
There should be no functionality change resulting from this patch.
Signed-off-by: Borislav Petkov <petkovbb@gmail.com>
[bart: BLK_DEV_IDECD needs to select IDE_ATAPI now]
As planed, this removes ide-scsi.
The 2.6 kernel supports direct writing to ide CD drives, which
eliminates the need for ide-scsi. ide-scsi has been unmaintained and
marked as deprecated.
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Cc: James.Bottomley@HansenPartnership.com
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-arm: (407 commits)
[ARM] pxafb: add support for overlay1 and overlay2 as framebuffer devices
[ARM] pxafb: cleanup of the timing checking code
[ARM] pxafb: cleanup of the color format manipulation code
[ARM] pxafb: add palette format support for LCCR4_PAL_FOR_3
[ARM] pxafb: add support for FBIOPAN_DISPLAY by dma braching
[ARM] pxafb: allow pxafb_set_par() to start from arbitrary yoffset
[ARM] pxafb: allow video memory size to be configurable
[ARM] pxa: add document on the MFP design and how to use it
[ARM] sa1100_wdt: don't assume CLOCK_TICK_RATE to be a constant
[ARM] rtc-sa1100: don't assume CLOCK_TICK_RATE to be a constant
[ARM] pxa/tavorevb: update board support (smartpanel LCD + keypad)
[ARM] pxa: Update eseries defconfig
[ARM] 5352/1: add w90p910-plat config file
[ARM] s3c: S3C options should depend on PLAT_S3C
[ARM] mv78xx0: implement GPIO and GPIO interrupt support
[ARM] Kirkwood: implement GPIO and GPIO interrupt support
[ARM] Orion: share GPIO IRQ handling code
[ARM] Orion: share GPIO handling code
[ARM] s3c: define __io using the typesafe version
[ARM] S3C64XX: Ensure CPU_V6 is selected
* Move legacy ISA/VLB ports handling from ide-probe.c to ide-legacy.c.
* Add CONFIG_IDE_LEGACY config option to be selected by host drivers
needing ide-legacy.c.
v2:
Fix CONFIG_IDE_LEGACY not being defined in Kconfig.
(from Takashi Iwai <tiwai@suse.de>)
There should be no functional changes caused by this patch.
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6 into devel
IDE pmac host driver build fails with CONFIG_BLK_DEV_IDEDMA_PMAC=n
as reported by Kamalesh:
> drivers/ide/pmac.c: In function 'pmac_ide_set_pio_mode':
> drivers/ide/pmac.c:527: error: implicit declaration of function 'kauai_lookup_timing'
> drivers/ide/pmac.c:527: error: 'shasta_pio_timings' undeclared (first use in this function)
> drivers/ide/pmac.c:527: error: (Each undeclared identifier is reported only once
> drivers/ide/pmac.c:527: error: for each function it appears in.)
> drivers/ide/pmac.c:534: error: 'kauai_pio_timings' undeclared (first use in this function)
> drivers/ide/pmac.c: In function 'pmac_ide_do_resume':
> drivers/ide/pmac.c:914: error: 'IDE_WAKEUP_DELAY' undeclared (first use in this function)
> drivers/ide/pmac.c: At top level:
> drivers/ide/pmac.c:1007: error: 'pmac_ide_init_dma' undeclared here (not in a function)
> drivers/ide/pmac.c: In function 'pmac_ide_setup_device':
> drivers/ide/pmac.c:1107: error: 'IDE_WAKEUP_DELAY' undeclared (first use in this function)
> drivers/ide/pmac.c: In function 'pmac_ide_macio_attach':
> drivers/ide/pmac.c:1209: error: 'pmac_ide_hwif_t' has no member named 'dma_regs'
> drivers/ide/pmac.c:1210: error: 'pmac_ide_hwif_t' has no member named 'dma_regs'
> make[2]: *** [drivers/ide/pmac.o] Error 1
Fix it by removing the superfluous config option.
Reported-and-tested-by: Kamalesh Babulal <kamalesh@linux.vnet.ibm.com>
Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com>
The CLPS7500 platform has not built since 2.6.22-git7 and there
seems to be no interest in fixing it. So, remove the platform
support.
This is the driver for the Toshiba TX4938 SoC EBUS controller ATA mode.
It has custom set_pio_mode and some hacks for big endian.
Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
Cc: ralf@linux-mips.org
Cc: sshtylyov@ru.mvista.com
This is the driver for the Toshiba TX4939 SoC ATA controller.
This controller has standard ATA taskfile registers and DMA
command/status registers, but the register layout is swapped on big
endian. There are some other endian issue and some special registers
which requires many custom dma_ops/tp_ops routines and build_dmatable.
No big loss since HPT343/363 controllers are properly supported
by pata_hpt3x3 driver from Alan Cox.
* Add struct ide_disk_ops containing protocol specific methods.
* Add 'struct ide_disk_ops *' to ide_drive_t.
* Convert ide-{disk,floppy} drivers to use struct ide_disk_ops.
* Merge ide-{disk,floppy} drivers into generic ide-gd driver.
While at it:
- ide_disk_init_capacity() -> ide_disk_get_capacity()
Acked-by: Borislav Petkov <petkovbb@gmail.com>
Using "def_bool n" is pointless, simply using bool here appears more
appropriate.
Further, retaining such options that don't have a prompt and aren't
selected by anything seems also at least questionable.
Signed-off-by: Jan Beulich <jbeulich@novell.com>
Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
Because hd.c was moved to drivers/block/ this config option
is superfluous now and may be removed.
v2:
Fix drivers/ide/Makefile (noticed by Adrian Bunk).
Cc: Adrian Bunk <bunk@kernel.org>
Use multi PIO by default when available and remove no longer
needed CONFIG_IDEDISK_MULTI_MODE (it should be safe nowadays,
despite to what help entry has been saying).
The Swarm IDE driver uses a release method which is defined in the driver
itself thus potentially oopsable. The simple fix would be to just leak
the device but this patch goes the full length and moves the entire
handling of the platform device in the platform code and retains only
the platform driver code in drivers/ide/mips/swarm.c.
Cc: "Maciej W. Rozycki" <macro@linux-mips.org>
[bart: remove no longer needed BLK_DEV_IDE_SWARM from ide/Kconfig]
Enabling IDE generic may prevent ATA controllers located on legacy
ports from being attached to more proper driver or can prevent other
controllers which share the IRQ from working. Note it in the help
message.
Cc: xerces8 <xerces8@butn.net>
Cc: Jeff Garzik <jgarzik@pobox.com>
Cc: stein@hermes.si
[bart: s/will grab/may grab/ since Borislav has fixed PCI-case for .28]
Mark ide-scsi as deprecated and remove stale/bogus documentation.
The benefits of a user settable CONFIG_IDE_MAX_HWIFS have become pretty
tiny and are no longer considered worth the trouble of an own option.
Simply always #define MAX_HWIFS to 10.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Alan Cox has noticed some time ago that hpt34x is broken
(http://lkml.org/lkml/2007/7/3/257):
"No the old driver doesn't even do that. It starts up. It spuriously
adjusts some non writable PCI BAR registers, prints a message about
resources being in use already then exits."
Reported-by: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
This patch moves hd.c to drivers/block/
Cc: rmk@arm.linux.org.uk
After commit 80aa31cb460d12c1e02327b43eceb3eebc6e7090
(ide: remove CONFIG_BLK_DEV_HD_IDE config option (take 2))
the indirection through BLK_DEV_HD_ONLY is no longer required.
This driver was only used by arch/ppc code and is obsolete
now with the move to common arch/powerpc code.
[bart: port it over IDE tree, remove leftover 'choice' from Kconfig]
Acked-by: Kumar Gala <galak@kernel.crashing.org>
* Don't include ide-timing.h in cs5535 and sis5513 host drivers
(they don't need it currently).
* Convert ide-timing.h to ide-timings.c library and add CONFIG_IDE_TIMINGS
config option to be selected by host drivers using the library.
While at it:
- fix ide_timing_find_mode() placement
v2:
* Add missing EXPORT_SYMBOLs. (Stephen Rothwell <sfr@canb.auug.org.au>)
Remove the old BAST IDE driver, as we are now using the platform-pata
support.
Signed-off-by: Ben Dooks <ben-linux@fluff.org>
* Add ide-atapi.c file for generic ATAPI support together with
CONFIG_IDE_ATAPI config option.
* Add generic ide_transfer_pc() helper to ide-atapi.c and then
convert ide-{floppy,tape,scsi} device drivers to use it.
Cc: Borislav Petkov <petkovbb@gmail.com>
This reverts commit ac1623625c5818bbdf5c68973098ba386ba7a004.
It was premature to remove it now, we will do it post-2.6.26.
Thanks to Russell King for noticing the issue.
support.
