The driver expected a *virtual* address in the IDE platform device's memory
resource and didn't request the memory region for the register block. Fix this
taking into account the fact that DaVinci SoC devices are fixed-mapped to the
virtual memory early and we can get their virtual addresses using IO_ADDRESS()
macro, not having to call ioremap()...
While at it, also do some cosmetic changes...
Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
Don't fail the probe if there are no devices attached to the controller.
Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com>
* Add IDE_HFLAG_MMIO host flag and set it for hosts which use
default_hwif_mmiops().
v2:
* Fix kernel panic in pmac host driver (',' should be '|').
Thanks to Kamalesh for reporting it + testing the fix
and to Andrew for hinting me about the source of the issue.
Cc: Kamalesh Babulal <kamalesh@linux.vnet.ibm.com>
Cc: Andy Whitcroft <apw@shadowen.org>
* Add struct ide_io_ports and use it instead of `unsigned long io_ports[]`
in ide_hwif_t.
* Rename io_ports[] in hw_regs_t to io_ports_array[].
* Use un-named union for 'unsigned long io_ports_array[]' and 'struct
ide_io_ports io_ports' in hw_regs_t.
* Remove IDE_*_OFFSET defines.
v2:
* scc_pata.c build fix from Stephen Rothwell.
v3:
* Fix ctl_adrr typo in Sparc-specific part of ns87415.c.
(Noticed by Andrew Morton)
* Remove ide_unregister() call from ide_exit()
(host drivers take care of unregistering hwif-s themselves).
* Remove ide_unregister() call from probe methods of
bast-ide, palm_bk3710, ide-cs and delkin_cb host drivers
(ide_find_port() returns only free ide_hwifs[] entries).
* Export ide_dma_exec_cmd() and __ide_dma_test_irq().
* Constify struct ide_dma_ops.
* Always set hwif->dma_ops to &sff_dma_ops in ide_setup_dma()
(it is later overriden by ide_init_port() if needed) and drop
'const struct ide_port_info *d' argument.
While at it:
* Rename __ide_dma_test_irq() to ide_dma_test_irq().
Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com>
Add struct ide_dma_ops and convert core code + drivers to use it.
While at it:
* Drop "ide_" prefix from ->ide_dma_end and ->ide_dma_test_irq methods.
* Drop "ide_" "infixes" from DMA methods.
* au1xxx-ide.c:
- use auide_dma_{test_irq,end}() directly in auide_dma_timeout()
* pdc202xx_old.c:
- drop "old_" "infixes" from DMA methods
* siimage.c:
- add siimage_dma_test_irq() helper
- print SATA warning in siimage_init_one()
* Remove no longer needed ->init_hwif implementations.
v2:
* Changes based on review from Sergei:
- s/siimage_ide_dma_test_irq/siimage_dma_test_irq/
- s/drive->hwif/hwif/ in idefloppy_pc_intr().
- fix patch description w.r.t. au1xxx-ide changes
- fix au1xxx-ide build
- fix naming for cmd64*_dma_ops
- drop "ide_" and "old_" infixes
- s/hpt3xxx_dma_ops/hpt37x_dma_ops/
- s/hpt370x_dma_ops/hpt370_dma_ops/
- use correct DMA ops for HPT302/N, HPT371/N and HPT374
- s/it821x_smart_dma_ops/it821x_pass_through_dma_ops/
v3:
* Two bugs slipped in v2 (noticed by Sergei):
- use correct DMA ops for HPT374 (for real this time)
- handle HPT370/HPT370A properly
* Move DMA setup to palm_bk3710_init_dma().
* Convert the driver to use ->init_dma method.
Cc: Anton Vorontsov <avorontsov@ru.mvista.com>
* There is no need to call ide_release_dma_engine().
* Move the code up to (and including) ide_allocate_dma_engine()
call to the callers of ide_setup_dma().
There should be no functional changes caused by this patch.
* Move hooks for port/host specific methods from ide_hwif_t to
'struct ide_port_ops'.
* Add 'const struct ide_port_ops *port_ops' to 'struct ide_port_info'
and ide_hwif_t.
* Update host drivers and core code accordingly.
While at it:
* Rename ata66_*() cable detect functions to *_cable_detect() to match
the standard naming. (Suggested by Sergei Shtylyov)
v2:
* Fix build for bast-ide. (Noticed by Andrew Morton)
The kernel.h macro DIV_ROUND_UP performs the computation (((n) + (d) - 1) /
(d)) but is perhaps more readable.
An extract of the semantic patch that makes this change is as follows:
(http://www.emn.fr/x-info/coccinelle/)
// <smpl>
@haskernel@
#include <linux/kernel.h>
@depends on haskernel@
expression n,d;
- (n + d - 1) / d
+ DIV_ROUND_UP(n,d)
- (n + (d - 1)) / d
+ DIV_ROUND_UP(n,d)
expression n,d;
- DIV_ROUND_UP((n),d)
+ DIV_ROUND_UP(n,d)
expression n,d;
- DIV_ROUND_UP(n,(d))
+ DIV_ROUND_UP(n,d)
// </smpl>
Remove no longer needed matching against I/O base and 'base' argument.
Since 43cc71eed1250755986da4c0f9898f9a635cb3bf, the platform modalias
is prefixed with "platform:". Add MODULE_ALIAS() to the hotpluggable
ATA and IDE platform drivers, to re-enable auto loading.
NOTE: both ata/pata_platform.c and ide/legacy/ide_platform.c claim
to provide "the" platform_pata driver, and there's no build-time
mutual exclusion mechanism. This means that configs which enable
both drivers will make some trouble when hotplugging...
[dbrownell@users.sourceforge.net: more drivers, registration fixes]
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
Cc: Tejun Heo <htejun@gmail.com>
Acked-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
->hold is write-only now, remove it.
v2:
* v1 missed bast-ide, palm_bk3710, ide-cs and delkin_cb host drivers.
hdparm explicitely marks HDIO_[UNREGISTER,SCAN]_HWIF ioctls as DANGEROUS
and given the number of bugs we can assume that there are no real users:
* DMA has no chance of working because DMA resources are released by
ide_unregister() and they are never allocated again.
* Since ide_init_hwif_ports() is used for ->io_ports[] setup the ioctls
don't work for almost all hosts with "non-standard" (== non ISA-like)
layout of IDE taskfile registers (there is a lot of such host drivers).
* ide_port_init_devices() is not called when probing IDE devices so:
- drive->autotune is never set and IDE host/devices are not programmed
for the correct PIO/DMA transfer modes (=> possible data corruption)
- host specific I/O 32-bit and IRQ unmasking settings are not applied
- host specific ->port_init_devs method is not called (=> no luck with
ht6560b, qd65xx and opti621 host drivers)
* ->rw_disk method is not preserved (=> no HPT3xxN chipsets support).
* ->serialized flag is not preserved (=> possible data corruption when
using icside, aec62xx (ATP850UF chipset), cmd640, cs5530, hpt366
(HPT3xxN chipsets), rz1000, sc1200, dtc2278 and ht6560b host drivers).
* ->ack_intr method is not preserved (=> needed by ide-cris, buddha,
gayle and macide host drivers).
* ->sata_scr[] and sata_misc[] is cleared by ide_unregister() and it
isn't initialized again (SiI3112 support needs them).
* To issue an ioctl() there need to be at least one IDE device present
in the system.
* ->cable_detect method is not preserved + it is not called when probing
IDE devices so cable detection is broken (however since DMA support is
also broken it doesn't really matter ;-).
* Some objects which may have already been freed in ide_unregister()
are restored by ide_hwif_restore() (i.e. ->hwgroup).
* ide_register_hw() may unregister unrelated IDE ports if free ide_hwifs[]
slot cannot be found.
* When IDE host drivers are modular unregistered port may be re-used by
different host driver that owned it first causing subtle bugs.
Since we now have a proper warm-plug support remove these ioctls,
then remove no longer needed:
- ide_register_hw() and ide_hwif_restore() functions
- 'init_default' and 'restore' arguments of ide_unregister()
- zeroeing of hwif->{dma,extra}_* fields in ide_unregister()
As an added bonus IDE core code size shrinks by ~3kB (x86-32).
v2:
* fix ide_unregister() arguments in cleanup_module() (Andrew Morton).
v3:
* fix ide_unregister() arguments in palm_bk3710.c.
* Use ide_find_port() instead of ide_deprecated_find_port() in bast-ide/
palm_bk3710/ide-cs/delkin_cb host drivers and in ide_register_hw().
* Remove no longer needed ide_deprecated_find_port().
* Factor out cable detection to palm_bk3710_cable_detect().
* Add palm_bk3710_init_hwif() (->init_hwif method implementation).
* Remove needless ->quirkproc initialization.
* Add missing ->pio_mask initialization.
* Use ATA_* defines for setting ->{ultra,mwdma}_mask.
* Add 'struct ide_port_info palm_bk3710_port_info' and pass it to
ide_device_add(). Then remove open-coded 'hwif' initialization.
Cc: Anton Salnikov <asalnikov@ru.mvista.com>
Probe port _after_ it is fully initialized.
Don't set 'restore' flag for ide_unregister() when initializing new
interface.
[ identical change as done to bast-ide/ide-cs/delkin_cb host drivers
by commit 909f4369bca30f9a186316a3bf2b4a9c1e702a25 ]
* Convert palm_bk3710 host driver to use ide_device_add() instead of
ide_register_hw() (while at it drop doing "ide_unregister()" loop which
tries to unregister _all_ IDE interfaces if useable ide_hwifs[] slot
cannot be find).
by commit 9e016a719209d95338e314b46c3012cc7feaaeec ]
* Rename 'ide_ctlr_info' to 'hw' and 'index' to 'i' while at it.
This is Palmchip BK3710 IDE controller support.
The IDE controller logic supports PIO, MultiWord-DMA and Ultra-DMA modes.
Supports interface to Compact Flash (CF) configured in True-IDE mode.
Bart:
- remove dead code
- fix ide_hwif_setup_dma() build problem
Signed-off-by: Anton Salnikov <asalnikov@ru.mvista.com>
Reviewed-by: Alan Cox <alan@lxorguk.ukuu.org.uk>
Reviewed-by: Sergei Shtylyov <sshtylyov@ru.mvista.com>
