path: root/drivers/ide/buddha.c
2009-06-15ide: move ack_intr() method into 'struct ide_port_ops' (take 2)Sergei Shtylyov
Move the ack_intr() method into 'struct ide_port_ops', also renaming it to test_irq() while at it... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-06-15ide: move IRQ clearing from ack_intr() method to clear_irq() method (take 2)Sergei Shtylyov
There are now two methods that clear the port interrupt: ack_intr() method, implemented only on M680x0 machines, that is called at the start of ide_intr(), and clear_irq() method, that is called somewhat later in this function. In order to stop this duplication, delegate the task of clearing the interrupt to clear_irq() method, only leaving to ack_intr() the task of testing for the port interrupt. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-05-17ide: remove hw_regs_t typedefBartlomiej Zolnierkiewicz
Remove hw_regs_t typedef and rename struct hw_regs_s to struct ide_hw. There should be no functional changes caused by this patch. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-05-17ide: pass number of ports to ide_host_{alloc,add}() (v2)Bartlomiej Zolnierkiewicz
Pass number of ports to ide_host_{alloc,add}() and then update all users accordingly. v2: - drop no longer needed NULL initializers in buddha.c, cmd640.c and gayle.c (noticed by Sergei) There should be no functional changes caused by this patch. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-05-17ide: remove chipset field from hw_regs_tBartlomiej Zolnierkiewicz
* Convert host drivers that still use hw_regs_t's chipset field to use the one in struct ide_port_info instead. * Move special handling of ide_pci chipset type from ide_hw_configure() to ide_init_port(). * Remove chipset field from hw_regs_t. While at it: - remove stale comment in delkin_cb.c There should be no functional changes caused by this patch. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-27ide: allow host drivers to specify IRQ flagsBartlomiej Zolnierkiewicz
* Add ->irq_flags field to struct ide_port_info and struct ide_host. * Update host drivers and IDE PCI code to use ->irq_flags field. * Convert init_irq() and ide_intr() to use host->irq_flags. This fixes handling of shared IRQs for non-PCI hosts and removes ugly ifdeffery from core IDE code. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-27ide: make m68k host drivers use IDE_HFLAG_MMIOBartlomiej Zolnierkiewicz
Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Michael Schmitz <schmitz@debian.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-27buddha: use struct ide_port_infoBartlomiej Zolnierkiewicz
This fixes hwif->channel and drive->dn assignments. Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-21ide: remove useless subdirs from drivers/ide/Bartlomiej Zolnierkiewicz
Suggested-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
