path: root/drivers/ide/cmd64x.c
2010-01-19cmd64x: fix handling of address setup timingsBartlomiej Zolnierkiewicz
Account for the requirements of the DMA mode currently used. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-19ide: change ->set_dma_mode method parametersBartlomiej Zolnierkiewicz
Change ->set_dma_mode method parameters to match ->set_dmamode method used in struct ata_port_operations. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2010-01-19ide: change ->set_pio_mode method parametersBartlomiej Zolnierkiewicz
Change ->set_pio_mode method parameters to match ->set_piomode method used in struct ata_port_operations. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-19cmd64x: remove superfluous checks from cmd64x_set_dma_mode()Bartlomiej Zolnierkiewicz
2010-01-19cmd64x: fix PIO and MWDMA timings calculationsBartlomiej Zolnierkiewicz
Just use the standard ide_timing_compute() helper to calculate PIO and MWDMA timings. This fixes some issues with the open-coded version like allowing faster MWDMA timings than the ones required by the current PIO mode or not accounting for the enhanced MWDMA cycle time specified by the device. Based on libata pata_cmd64x host driver. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-03cmd64x: remove no longer needed debugging codeBartlomiej Zolnierkiewicz
2009-10-29ide: Serialize CMD643 and CMD646 to fix a hardware bug with SSDMikulas Patocka
CMD646 corrupts data on concurrent transfers on both channels when IDE SSD is connected to one of the channels. Setup that demonstrates this hardware bug: Ultra 5, onboard CMD646, rev 3. /dev/hda is 8GB Seagate ST38410A in MWDMA2 /dev/hdd is 32GB SSD SiliconHardDisk in MWDMA2 - When reading /dev/hdd (for example with dd or fsck), reads from /dev/hda are corrupted, there are twiddled single bits 1->0 and some full 32-bit words corrupted, sometimes commands fail (which switches /dev/hda to PIO mode but the corruptions happen even in PIO). - Reads from /dev/hdd don't seem to be corrupted (i.e. fsck passes fine). - When I connected normal rotating harddisk to /dev/hdd, there was no corruption, so the corruption is something specific to SSD. - I tried the same setup on a PCI card with CMD649 and saw no corruption. This patch serializes the operation for CMD646 and 643 (I didn't test CMD643 but it may have the same hw bug too because it's earlier design). CMD649 is good. I don't know anything about CMD 648. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Tested-by: Frans Pop <elendil@planet.nl> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-21ide cmd64x: Remove serialize setting.David S. Miller
This begins to fix regressions reported by Frans Pop on his Ultra-10. There are still some funnies left that we are investigating. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-15ide: do not access ide_drive_t 'drive_data' field directlyJoao Ramos
Change ide_drive_t 'drive_data' field from 'unsigned int' type to 'void *' type, allowing a wider range of values/types to be stored in this field. Added 'ide_get_drivedata' and 'ide_set_drivedata' helpers to get and set the 'drive_data' field. Fixed all host drivers to maintain coherency with the change in the 'drive_data' field type. Signed-off-by: Joao Ramos <joao.ramos@inov.pt> [bart: fix qd65xx build, cast to 'unsigned long', minor Coding Style fixups] Acked-by: Sergei Shtylyov <sshtylyov@ru.montavista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-06-15cmd64x: implement test_irq() methodSergei Shtylyov
Convert the driver's two dma_test_irq() methods into test_irq() methods. The driver will now use the standard dma_test_irq() method implementation which allows to remove 'cmd54x_dma_ops' and 'cmd648_dma_ops' that become identical to 'sff_dma_ops'... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-06-15cmd64x: implement clear_irq() method (take 2)Sergei Shtylyov
Convert the driver's two dma_end() methods into clear_irq() methods -- the driver will now use the standard dma_end() method implementation, ide_dma_end(). Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-31ide: set/clear drive->waiting_for_dma flag in the core codeBartlomiej Zolnierkiewicz
Set/clear drive->waiting_for_dma flag in the core code instead of in ->dma_setup and ->dma_end methods. There should be no functional changes caused by this patch. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-31ide: destroy DMA mappings after ending DMA (v2)Bartlomiej Zolnierkiewicz
Move ide_destroy_dmatable() call out from ->dma_end method to {ide_pc,cdrom_newpc,ide_dma}_intr(), ide_dma_timeout_retry() and sgiioc4_resetproc(). This causes minor/safe behavior changes w.r.t.: * cmd64x.c::cmd64{8,x}_dma_end() * cs5536.c::cs5536_dma_end() * icside.c::icside_dma_end() * it821x.c::it821x_dma_end() * scc_pata.c::__scc_dma_end() * sl82c105.c::sl82c105_dma_end() * tx4939ide.c::tx4939ide_dma_end() v2: * Fix build for CONFIG_BLK_DEV_IDEDMA=n (reported by Randy Dunlap). Cc: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-31ide: add ->dma_clear method and remove ->dma_timeout oneBartlomiej Zolnierkiewicz
All custom ->dma_timeout implementations call the generic one thus it is possible to have only an optional method for resetting DMA engine instead: * Add ->dma_clear method and convert hpt366, pdc202xx_old and sl82c105 host drivers to use it. * Always use ide_dma_timeout() in ide_dma_timeout_retry() and remove ->dma_timeout method. * Make ide_dma_timeout() static. There should be no functional changes caused by this patch. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-27ide: add ->dma_timer_expiry method and remove ->dma_exec_cmd one (v2)Bartlomiej Zolnierkiewicz
* Rename dma_timer_expiry() to ide_dma_sff_timer_expiry() and export it. * Add ->dma_timer_expiry method and use it to set hwif->expiry for ATA_PROT_DMA protocol in do_rw_taskfile(). * Initialize ->dma_timer_expiry to ide_dma_sff_timer_expiry() for SFF hosts. * Move setting hwif->expiry from ide_execute_command() to its users and drop 'expiry' argument. * Use ide_execute_command() instead of ->dma_exec_cmd in do_rw_taskfile(). * Remove ->dma_exec_cmd method and its implementations. * Unexport ide_execute_command() and ide_dma_intr(). v2: * Fix CONFIG_BLK_DEV_IDEDMA=n build (noticed by Randy Dunlap). * Fix *dma_expiry naming (suggested by Sergei Shtylyov). There should be no functional changes caused by this patch. Cc: Randy Dunlap <randy.dunlap@oracle.com> Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-24ide: fix ->init_chipset method to return 'int' valueBartlomiej Zolnierkiewicz
* Return 0 instead of dev->irq in ->init_chipset implementations. * Fix ->init_chipset method to return 'int' value instead of 'unsigned int' one. This fixes ->init_chipset handling for host drivers (cs5530, hpt366 and pdc202xx_new) for which it is possible for this method to fail. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-01-06ide: move read_sff_dma_status() method to 'struct ide_dma_ops'Sergei Shtylyov
Move apparently misplaced read_sff_dma_status() method from 'struct ide_tp_ops' to 'struct ide_dma_ops', renaming it to dma_sff_read_status() and making only required for SFF-8038i compatible IDE controller drivers (greatly cutting down the number of initializers) as its only user (outside ide-dma-sff.c and such drivers) appears to be ide_pci_check_simplex() which is only called for such controllers... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-01-06cmd64x: use ide_get_pair_dev() helperBartlomiej Zolnierkiewicz
2009-01-06ide: remove HWIF() macroBartlomiej Zolnierkiewicz
2008-12-29cmd64x: set IDE_HFLAG_SERIALIZE explictly for CMD646Bartlomiej Zolnierkiewicz
* Set IDE_HFLAG_SERIALIZE explictly for CMD646. * Remove no longer needed ide_cmd646 chipset type (which has a nice side-effect of fixing handling of unexpected IRQs). Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-21ide: remove useless subdirs from drivers/ide/Bartlomiej Zolnierkiewicz
Suggested-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
