path: root/drivers/ide/icside.c
2010-03-02Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/ide-2.6
2010-01-19ide: change ->set_dma_mode method parametersBartlomiej Zolnierkiewicz
Change ->set_dma_mode method parameters to match ->set_dmamode method used in struct ata_port_operations. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2010-01-12icside: bring back ->maskproc methodBartlomiej Zolnierkiewicz
Bring back ->maskproc method since it is still needed for proper operation, as noticed by Russell King: > This change is bogus. > > writeb(0, base + ICS_ARCIN_V6_INTROFFSET_1); > readb(base + ICS_ARCIN_V6_INTROFFSET_2); > > writeb(0, base + ICS_ARCIN_V6_INTROFFSET_2); > readb(base + ICS_ARCIN_V6_INTROFFSET_1); > > This sequence of code does: > > 1. enable interrupt 1 > 2. disable interrupt 2 > 3. enable interrupt 2 > 4. disable interrupt 1 > > which results in the interrupt for the second channel being enabled - > leaving channel 1 blocked. > > Firstly, icside shares its two IDE channels with one DMA engine - so it's > a simplex interface. IDE supports those (or did when the code was written) > serializing requests between the two interfaces. libata does not. > > Secondly, the interrupt lines on icside float when there's no drive connected > or when the drive has its NIEN bit set, which means that you get spurious > screaming interrupts which can kill off all expansion card interrupts on > the machine unless you disable the channel interrupt on the card. > > Since libata can not serialize the operation of the two channels like IDE > can, the libata version of the icside driver does not contain the interrupt > stearing logic. Instead, it looks at the status after reset, and if > nothing was found on that channel, it masks the interrupt from that > channel. This patch reverts changes done in commit dff8817 (I became confused due to non-standard & undocumented ->maskproc method, anyway sorry about that). Noticed-by: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-15ide: do not access ide_drive_t 'drive_data' field directlyJoao Ramos
Change ide_drive_t 'drive_data' field from 'unsigned int' type to 'void *' type, allowing a wider range of values/types to be stored in this field. Added 'ide_get_drivedata' and 'ide_set_drivedata' helpers to get and set the 'drive_data' field. Fixed all host drivers to maintain coherency with the change in the 'drive_data' field type. Signed-off-by: Joao Ramos <joao.ramos@inov.pt> [bart: fix qd65xx build, cast to 'unsigned long', minor Coding Style fixups] Acked-by: Sergei Shtylyov <sshtylyov@ru.montavista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-06-07icside: remove superfluous ->maskproc methodBartlomiej Zolnierkiewicz
[inspired by pata_icside] Enabling/disabling of card IRQs is handled fine by IRQ and IDE subsystems so there is no need for custom ->maskproc method. Moreover icside_maskproc() would enable IRQ only if it was already enabled [because of 'if (state->enabled && !mask)' check]. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-05-17ide: remove hw_regs_t typedefBartlomiej Zolnierkiewicz
Remove hw_regs_t typedef and rename struct hw_regs_s to struct ide_hw. There should be no functional changes caused by this patch. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-05-17ide: pass number of ports to ide_host_{alloc,add}() (v2)Bartlomiej Zolnierkiewicz
Pass number of ports to ide_host_{alloc,add}() and then update all users accordingly. v2: - drop no longer needed NULL initializers in buddha.c, cmd640.c and gayle.c (noticed by Sergei) There should be no functional changes caused by this patch. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-05-17ide: remove chipset field from hw_regs_tBartlomiej Zolnierkiewicz
* Convert host drivers that still use hw_regs_t's chipset field to use the one in struct ide_port_info instead. * Move special handling of ide_pci chipset type from ide_hw_configure() to ide_init_port(). * Remove chipset field from hw_regs_t. While at it: - remove stale comment in delkin_cb.c There should be no functional changes caused by this patch. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-05-16icside: register second channel of version 6 PCBSergei Shtylyov
The second IDE channel of version 6 PCB is not being registered anymore since the commit 48c3c1072651922ed153bcf0a33ea82cf20df390 (ide: add struct ide_host (take 3)). Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-31ide: set/clear drive->waiting_for_dma flag in the core codeBartlomiej Zolnierkiewicz
Set/clear drive->waiting_for_dma flag in the core code instead of in ->dma_setup and ->dma_end methods. There should be no functional changes caused by this patch. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-31ide: destroy DMA mappings after ending DMA (v2)Bartlomiej Zolnierkiewicz
Move ide_destroy_dmatable() call out from ->dma_end method to {ide_pc,cdrom_newpc,ide_dma}_intr(), ide_dma_timeout_retry() and sgiioc4_resetproc(). This causes minor/safe behavior changes w.r.t.: * cmd64x.c::cmd64{8,x}_dma_end() * cs5536.c::cs5536_dma_end() * icside.c::icside_dma_end() * it821x.c::it821x_dma_end() * scc_pata.c::__scc_dma_end() * sl82c105.c::sl82c105_dma_end() * tx4939ide.c::tx4939ide_dma_end() v2: * Fix build for CONFIG_BLK_DEV_IDEDMA=n (reported by Randy Dunlap). Cc: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-31ide: add ->dma_clear method and remove ->dma_timeout oneBartlomiej Zolnierkiewicz
All custom ->dma_timeout implementations call the generic one thus it is possible to have only an optional method for resetting DMA engine instead: * Add ->dma_clear method and convert hpt366, pdc202xx_old and sl82c105 host drivers to use it. * Always use ide_dma_timeout() in ide_dma_timeout_retry() and remove ->dma_timeout method. * Make ide_dma_timeout() static. There should be no functional changes caused by this patch. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-27ide: add ->dma_timer_expiry method and remove ->dma_exec_cmd one (v2)Bartlomiej Zolnierkiewicz
* Rename dma_timer_expiry() to ide_dma_sff_timer_expiry() and export it. * Add ->dma_timer_expiry method and use it to set hwif->expiry for ATA_PROT_DMA protocol in do_rw_taskfile(). * Initialize ->dma_timer_expiry to ide_dma_sff_timer_expiry() for SFF hosts. * Move setting hwif->expiry from ide_execute_command() to its users and drop 'expiry' argument. * Use ide_execute_command() instead of ->dma_exec_cmd in do_rw_taskfile(). * Remove ->dma_exec_cmd method and its implementations. * Unexport ide_execute_command() and ide_dma_intr(). v2: * Fix CONFIG_BLK_DEV_IDEDMA=n build (noticed by Randy Dunlap). * Fix *dma_expiry naming (suggested by Sergei Shtylyov). There should be no functional changes caused by this patch. Cc: Randy Dunlap <randy.dunlap@oracle.com> Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-27ide: pass command to ide_map_sg()Bartlomiej Zolnierkiewicz
* Set IDE_TFLAG_WRITE flag and ->rq also for ATA_CMD_PACKET commands. * Pass command to ->dma_setup method and update all its implementations accordingly. * Pass command instead of request to ide_build_sglist(), *_build_dmatable() and ide_map_sg(). While at it: * Fix scc_dma_setup() documentation + use ATA_DMA_WR define. * Rename sgiioc4_build_dma_table() to sgiioc4_build_dmatable(), change return value type to 'int' and drop unused 'ddir' argument. * Do some minor cleanups in [tx4939]ide_dma_setup(). There should be no functional changes caused by this patch. Acked-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-27ide: move command related fields from ide_hwif_t to struct ide_cmdBartlomiej Zolnierkiewicz
* Move command related fields from ide_hwif_t to struct ide_cmd. * Make ide_init_sg_cmd() take command and sectors number as arguments. There should be no functional changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-27ide: call ide_build_sglist() prior to ->dma_setup (v2)Bartlomiej Zolnierkiewicz
* Re-map sg table if needed in ide_build_sglist(). * Move ide_build_sglist() call from ->dma_setup to its users. * Un-export ide_build_sglist(). v2: * Build fix for CONFIG_BLK_DEV_IDEDMA=n (noticed by Randy Dunlap). There should be no functional changes caused by this patch. Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-27icside: icside_dma_setup() fixesBartlomiej Zolnierkiewicz
Check for ide_build_sglist() return value and re-map sg table if necessary. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-27icside: use struct ide_port_info also for PCB version 5 (v2)Bartlomiej Zolnierkiewicz
This fixes hwif->channel and drive->dn assignments. v2: Fix v5/v6 mismatch noticed by Russell. Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-02-02icside: fix PCB version 6 support (v2)Bartlomiej Zolnierkiewicz
We need to pass struct ide_port_info also to ide_host_register(). v2: Fix v5/v6 mismatch noticed by Russell. Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-01-06ide: remove HWIF() macroBartlomiej Zolnierkiewicz
2009-01-06ide: merge ide_hwgroup_t with ide_hwif_t (v2)Bartlomiej Zolnierkiewicz
* Merge ide_hwgroup_t with ide_hwif_t. * Cleanup init_irq() accordingly, then remove no longer needed ide_remove_port_from_hwgroup() and ide_ports[]. * Remove now unused HWGROUP() macro. While at it: * ide_dump_ata_error() fixups v2: * Fix ->quirk_list check in do_ide_request() (s/hwif->cur_dev/prev_port->cur_dev). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-11-30icside section warningsAl Viro
icside_register_v[56] is called from (__devinit) icside_probe Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-26arm ide breakageAl Viro
a) semicolon before the function body is a bad idea b) it's const struct foo, not struct const foo c) incidentally, it's ecard_remove_driver(), not ecard_unregister_driver() d) compiling is occasionally useful. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-21ide: remove useless subdirs from drivers/ide/Bartlomiej Zolnierkiewicz
Suggested-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
