path: root/drivers/ide/ide-cd.h
2009-04-19ide-cd: convert to using generic sense requestBorislav Petkov
Preallocate a sense request in the ->do_request method and reinitialize it only on demand, in case it's been consumed in the IRQ handler path. The reason for this is that we don't want to be mapping rq to bio in the IRQ path and introduce all kinds of unnecessary hacks to the block layer. tj: * Both user and kernel PC requests expect sense data to be stored in separate storage other than drive->sense_data. Copy sense data to rq->sense on completion if rq->sense is not NULL. This fixes bogus sense data on PC requests. As a result, remove cdrom_queue_request_sense. CC: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> CC: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2009-03-27ide-cd: use ide_drive_t's rq in cdrom_queue_request_senseBorislav Petkov
There should be no functionality change resulting from this patch. Suggested-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-27ide: improve debugging schemeBorislav Petkov
and more specifically, push __func__ into debug macro thus making ide_debug_log() calls shorter and more readable. Signed-off-by: Borislav Petkov <petkovbb@gmail.com>
2009-02-25ide: fix refcounting in device driversBartlomiej Zolnierkiewicz
During host driver module removal del_gendisk() results in a final put on drive->gendev and freeing the drive by drive_release_dev(). Convert device drivers from using struct kref to use struct device so device driver's object holds reference on ->gendev and prevents drive from prematurely going away. Also fix ->remove methods to not erroneously drop reference on a host driver by using only put_device() instead of ide*_put(). Reported-by: Stanislaw Gruszka <stf_xl@wp.pl> Tested-by: Stanislaw Gruszka <stf_xl@wp.pl> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-01-06ide: remove ide_driver_t typedefBartlomiej Zolnierkiewicz
While at it: - s/struct ide_driver_s/struct ide_driver/ - use to_ide_driver() macro in ide-proc.c Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-01-06ide: remove 'byte' typedefBartlomiej Zolnierkiewicz
Just use u8 instead, also s/__u8/u8/ in ide-cd.h while at it. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-01-02ide-cd: move cdrom_timer_expiry to ide-atapi.cBorislav Petkov
- cdrom_timer_expiry -> ide_cd_expiry - remove expiry-arg to ide_issue_pc as it is redundant now - ide_debug_log -> debug_log Signed-off-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-01-02ide-cd: move debug defines into headerBorislav Petkov
While at it: - disable compiling-in debug support by default Signed-off-by: Borislav Petkov <petkovbb@gmail.com> [bart: fixup patch description] Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-12-29ide-cd: remove obsolete seek optimizationBartlomiej Zolnierkiewicz
It doesn't make much sense nowadays and is problematic on some drives. Cc: Borislav Petkov <petkovbb@googlemail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-13ide-cd: move cdrom_info.dma to ide_drive_t.dmaBorislav Petkov
There should be no functionality change resulting from this patch. Signed-off-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-23ide-cd: convert to using the new atapi_flagsBorislav Petkov
There should be no functionality change resulting from this patch. [bart: IDE_FLAG_* -> IDE_AFLAG_*, dev_flags -> atapi_flags] Signed-off-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-15ide-cd: remove ide_cd_init_rqFUJITA Tomonori
ide_cd_init_rq is not used by ide-cd_ioctl any more. Only cdrom_queue_request_sense use it. This converts cdrom_queue_request_sense to use blk_rq_init directly and removes ide_cd_init_rq. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Borislav Petkov <petkovbb@gmail.com> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-15ide-cd: convert ide_cd_queue_pc to use blk_execute_rqFUJITA Tomonori
This converts ide_cd_queue_pc to use blk_execute_rq, necessitating changing the ide_cd_queue_pc prototype into a form that doesn't takes a pointer to request struct. ide_cd_queue_pc works like scsi_execute. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Borislav Petkov <petkovbb@gmail.com> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-26ide-cd: remove the internal 64k bufferBorislav Petkov
This removes the internal ide-cd buffer and falls back to read-ahead block layer capabilities. Thorough testing (cd burning, dvd read, raw read) gives with the bufferless mode marginally better performance in addition to simplified code. bufferless: dd: reading `/dev/hdc': Input/output error 6238+0 records in 6238+0 records out 204406784 bytes (204 MB) copied, 259.891 s, 787 kB/s real 4m21.598s user 0m0.014s sys 0m0.744s with the old buffer (2.6.25-rc1): dd: reading `/dev/hdc': Input/output error 6238+0 records in 6238+0 records out 204406784 bytes (204 MB) copied, 262.893 s, 778 kB/s real 4m22.938s user 0m0.009s sys 0m0.771s Signed-off-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-01ide: delete filenames/versions from commentsBartlomiej Zolnierkiewicz
Delete filenames/versions from comments. I'm leaving decisions about adding DRV_VERSION defines and MODULE_VERSION()-s to maintainers of the respective drivers. While at it: * Remove unused VERSION define from ide.c. * Remove unused/stale DRV_VERSION define from au1xxx-ide.c. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-01ide-cd: move the remaining cdrom.c ioctl handling code to ide-cd_ioctl.cBorislav Petkov
There should be no functional changes from this. Signed-off-by: Borislav Petkov <bbpetkov@yahoo.de> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-01ide-cd: move code handling cdrom.c IOCTLs to ide-cd_ioctl.cBartlomiej Zolnierkiewicz
There should be no functionality changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-01ide-cd: move VERBOSE_IDE_CD_ERRORS code to ide-cd_verbose.cBartlomiej Zolnierkiewicz
* Rename ide-cd kernel module to ide-cd_mod in preparation to moving code out from ide-cd.[c,h]. Add MODULE_ALIAS("ide-cd") to preserve compatibility. * Move VERBOSE_IDE_CD_ERRORS code from ide-cd.[c,h] to ide-cd_verbose.c. ide-cd_verbose.c is IDE subsystem independent and may be easily converted into generic library usable by other drivers (i.e. libata) if needed. * Add CONFIG_BLK_DEV_IDECD_VERBOSE_ERRORS config option to drivers/ide/Kconfig replacing VERBOSE_IDE_CD_ERRORS define. Make this config option enabled by default and visible only if CONFIG_EMBEDDED is defined. before the patch: text data bss dec hex filename 22841 360 1056 24257 5ec1 drivers/ide/ide-cd.o after the patch w/ CONFIG_BLK_DEV_IDECD_VERBOSE_ERRORS=y: text data bss dec hex filename 22857 360 1056 24273 5ed1 drivers/ide/ide-cd_mod.o after the patch w/ CONFIG_BLK_DEV_IDECD_VERBOSE_ERRORS=n: text data bss dec hex filename 15091 360 1056 16507 407b drivers/ide/ide-cd_mod.o Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-01ide-cd: coding style fixes for VERBOSE_IDE_CD_ERRORS codeBartlomiej Zolnierkiewicz
* Coding style fixes for VERBOSE_IDE_CD_ERRORS code. * Add KERN_{ERR,CONT} printk() levels where needed. This is a preparation for moving this code out of ide-cd.[c,h]. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-01ide-cd: remove duplicate sense keys definitions from ide-cd.hBartlomiej Zolnierkiewicz
ide-cd.c already uses sense keys definitions from <scsi/scsi.h>. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-01ide-cd: re-organize handling of quirky devicesBartlomiej Zolnierkiewicz
Re-organize handling of quirky devices: * Add struct cd_list_entry, ide_cd_quirks_list[] and ide_cd_flags() helper. * Set flags returned by ide_cd_flags() in ide_cdrom_setup(). * Add IDE_CD_FLAG_VERTOS_{300_SDD,600_ESD} and IDE_CD_FLAG_SANYO_3CD flags. * Move device quirks from ide_cdrom_setup() to ide_cd_quirks_list[]. * Rename IDE_CD_FLAG_NEC260 to IDE_CD_FLAG_PRE_ATAPI12 and handle quirky Stingray 8X CD-ROM using ide_cd_quirks_list[]. * Add IDE_CD_FLAG_FULL_CAPS_PAGE flag and handle quirky ACER 50X CD-ROM / WPI 32X CD-ROM using ide_cd_quirk_list[]. * Add IDE_CD_FLAG_PLAY_AUDIO_OK flag and handle quirky MATSHITA DVD-ROMs using ide_cd_quirks_list[]. * Add IDE_CD_FLAG_LE_SPEED_FIELDS flag and handle quirky ACER/AOpen 24X CD-ROM using ide_cd_quirk_list[]. * Fix some comments about quirky devices while at it. There should be no functionality changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-01ide-cd: remove STANDARD_ATAPI defineBartlomiej Zolnierkiewicz
Remove STANDARD_ATAPI define + drive-by coding style fixes. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-01ide-cd: remove NO_DOOR_LOCKING defineBartlomiej Zolnierkiewicz
2008-02-01ide-cd: remove struct ide_cd_{config,state}_flagsBartlomiej Zolnierkiewicz
* Remove unused ->{writing,reserved} fields from struct ide_cd_config_flags. * Move ->max_speed from struct ide_cd_config_flags to struct cdrom_info. * Move ->current_speed from struct ide_cd_state_flags to struct cdrom_info. * Add defines for config and state flags. * Add 'unsigned int cd_flags' to struct cdrom_info and use ->cd_flags instead of ->{config,state}_flags. * Remove no longer needed struct ide_cd_{config,state}_flags. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-01ide-cd: remove struct atapi_capabilities_page (take 2)Bartlomiej Zolnierkiewicz
* Remove struct atapi_capabilities_page. * Add ATAPI_CAPABILITIES_PAGE[_PAD]_SIZE define. v2: * The buf[] array access indexes were swapped between 'curspeed'/'maxspeed'. (Noticed by Borislav Petkov). Cc: Borislav Petkov <bbpetkov@yahoo.de> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-01ide-cd: kill CDROM_STATE_FLAGS() macroBartlomiej Zolnierkiewicz
While at it rename 'info' variable to 'cd' in cdrom_saw_media_change(). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-01ide-cd: kill CDROM_CONFIG_FLAGS() macroBartlomiej Zolnierkiewicz
While at it rename 'info' variable to 'cd' in ide_cdrom_probe_capabilities() and ide_cdrom_setup(). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-01ide-cd: remove redundant config flagsBartlomiej Zolnierkiewicz
* Use CDC_* flags directly and remove redundant flags from ->config_flags. While at it: * Add KERN_CONT to printk()-s in ide_cdrom_probe_capabilities(). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-01ide-cd: remove struct atapi_{mechstat_header,changer_info,slot}Bartlomiej Zolnierkiewicz
* Remove ->changer_info from struct cdrom_info (it is never allocated). * Remove unused struct atapi_{mechstat_header,changer_info,slot}. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-01ide-cd: remove unused and write-only struct ide_cd_config_flags fieldsBartlomiej Zolnierkiewicz
unused fields: * ->writing * ->reserved write-only fields: * ->playmsf_as_bcd * ->subchan_as_bcd * ->test_write * ->supp_disc_present Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-01ide-cd: remove unused struct atapi_cdrom_subchnlBartlomiej Zolnierkiewicz
2008-02-01ide-cd: remove unused defines from ide-cd.hBartlomiej Zolnierkiewicz
2007-12-24ide-cd: fix SAMSUNG CD-ROM SCR-3231 quirkBartlomiej Zolnierkiewicz
cdi->mask is cleared by ide_cdrom_register() which is called after the quirk. Fix it by adding new ->no_speed_select flag to struct ide_cd_config_flags and using it in ide_cdrom_register() to set CDC_SELECT_SPEED flag. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-07-09ide-cd: replace C code with call to ARRAY_SIZE() macroRobert P. J. Day
Delete the unnecessary macro ARY_LEN and use ARRAY_SIZE directly. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2005-12-15[PATCH] ide-cd: remove write-only cmd field from struct cdrom_infoBartlomiej Zolnierkiewicz
