path: root/drivers/ide/ide-cd_ioctl.c
2008-03-07ide-cd: mark REQ_TYPE_ATA_PC write requests with REQ_RW flagBartlomiej Zolnierkiewicz
On Thursday 06 March 2008, walt wrote: > For me, this commit causes the problem it's intended to fix: > > commit 9f10d9ee0ac6d79d7bc8b9a158bf4a29322d84d3 > Author: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> > Date: Tue Feb 26 21:50:35 2008 +0100 > > ide-cd: fix 'ireason' handling for REQ_TYPE_ATA_PC requests > > This fixes some hangs caused by not finishing the transfer before ending > the request and also makes use of 'ireason == 1' quirk for spurious IRQs. > > When I mount a CD there is a long delay, and I see this error message: > > hdc: ide_cd_check_ireason: wrong transfer direction! > cdrom: failed setting lba address space > hdc: status error: status=0x58 { DriveReady SeekComplete DataRequest } > ide: failed opcode was: unknown > hdc: drive not ready for command > <repeated many times> > > When I revert this commit everything works properly again, including > CD burning. It turned out that REQ_TYPE_ATA_PC write requests were not marked as such (the previous commit assumed them to be). Reported-by: walt <w41ter@gmail.com> Tested-by: walt <w41ter@gmail.com> Reviewed-by: Borislav Petkov <petkovbb@googlemail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-01ide-cd: move the remaining cdrom.c ioctl handling code to ide-cd_ioctl.cBorislav Petkov
There should be no functional changes from this. Signed-off-by: Borislav Petkov <bbpetkov@yahoo.de> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-01ide-cd: move code handling cdrom.c IOCTLs to ide-cd_ioctl.cBartlomiej Zolnierkiewicz
There should be no functionality changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
